path: root/drivers/ide/ide-generic.c
2009-05-17ide: remove hw_regs_t typedefBartlomiej Zolnierkiewicz
Remove hw_regs_t typedef and rename struct hw_regs_s to struct ide_hw. There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-05-17ide: pass number of ports to ide_host_{alloc,add}() (v2)Bartlomiej Zolnierkiewicz
Pass number of ports to ide_host_{alloc,add}() and then update all users accordingly. v2: - drop no longer needed NULL initializers in buddha.c, cmd640.c and gayle.c (noticed by Sergei) There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-05-17ide: remove chipset field from hw_regs_tBartlomiej Zolnierkiewicz
* Convert host drivers that still use hw_regs_t's chipset field to use the one in struct ide_port_info instead. * Move special handling of ide_pci chipset type from ide_hw_configure() to ide_init_port(). * Remove chipset field from hw_regs_t. While at it: - remove stale comment in delkin_cb.c There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: merge ide_arm and ide_generic host driversBartlomiej Zolnierkiewicz
There is no need for a separate ide_arm host driver nowadays so merge it into ide_generic one. While at it: - return -EBUSY from ide_generic_init() if I/O resources are busy - scale down ide_generic_check_pci_legacy_iobases() for CONFIG_PCI=n Cc: Russell King <rmk@arm.linux.org.uk> Cc: Alexander Schulz <alex@shark-linux.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide-generic: remove no longer needed sysfs interfaceBartlomiej Zolnierkiewicz
Nowadays we have "ide_generic.probe_mask=" module parameter and ide_platform host driver so sysfs interface for adding IDE interfaces is no longer needed. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-27ide-generic: use struct ide_port_infoBartlomiej Zolnierkiewicz
This fixes hwif->channel and drive->dn assignments. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide-generic: remove no longer needed ide_probe_legacy()Bartlomiej Zolnierkiewicz
There is now a generic solution [ide_generic_check_pci_legacy_iobases()] so MIPS-specific ide_probe_legacy() is no longer necessary. Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide-generic: no need to probe all ports at onceBartlomiej Zolnierkiewicz
2008-10-10ide-generic: handle probing of legacy io-ports v5Borislav Petkov
Avoid probing the io-ports in case an IDE PCI controller is present and it uses the legacy iobases. If we still want to enforce the probing, we do ide_generic.probe_mask=0x3f on the kernel command line. The iobase checking code is adapted from drivers/ata/pata_legacy.c after converting hex pci ids into their corresponding macros in <linux/pci_ids.h>. Also, check only BAR0/2 resources since those are guaranteed by the workaround in drivers/pci/probe.c:pci_setup_device(). Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> [bart: trivial printk() fixups] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24ide-generic: remove ide_default_{io_base,irq}() inlines (take 3)Bartlomiej Zolnierkiewicz
Replace ide_default_{io_base,irq}() inlines by legacy_{bases,irqs}[]. v2: Add missing zero-ing of hws[] (caught during testing by Borislav Petkov). v3: Fix zero-oing of hws[] for _real_ this time. There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24ide-generic: minor fix for mipsBartlomiej Zolnierkiewicz
Move ide_probe_legacy() call to ide_generic_init() so it fails early if necessary and returns the proper error value (nowadays ide_default_io_base() is used only by ide-generic). Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-23ide: add ide_host_free() helper (take 2)Bartlomiej Zolnierkiewicz
* Add ide_host_free() helper and convert ide_host_remove() to use it. * Fix handling of ide_host_register() failure in ide_host_add(), icside.c, ide-generic.c, falconide.c and sgiioc4.c. While at it: * Fix handling of ide_host_alloc_all() failure in ide-generic.c. * Fix handling of ide_host_alloc() failure in falconide.c (also return the correct error value if no device is found). v2: * falconide build fix. (From Stephen Rothwell) Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-23ide: add ide_host_add() helperBartlomiej Zolnierkiewicz
Add ide_host_add() helper which does ide_host_alloc()+ide_host_register(), then convert ide_setup_pci_device[s](), ide_legacy_device_add() and some host drivers to use it. While at it: * Fix ide_setup_pci_device[s](), ide_arm.c, gayle.c, ide-4drives.c, macide.c, q40ide.c, cmd640.c and cs5520.c to return correct error value. * -ENOENT -> -ENOMEM in rapide.c, ide-h8300.c, ide-generic.c, au1xxx-ide.c and pmac.c * -ENODEV -> -ENOMEM in palm_bk3710.c, ide_platform.c and delkin_cb.c * -1 -> -ENOMEM in ide-pnp.c Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-23ide: add struct ide_host (take 3)Bartlomiej Zolnierkiewicz
* Add struct ide_host which keeps pointers to host's ports. * Add ide_host_alloc[_all]() and ide_host_remove() helpers. * Pass 'struct ide_host *host' instead of 'u8 *idx' to ide_device_add[_all]() and rename it to ide_host_register[_all](). * Convert host drivers and core code to use struct ide_host. * Remove no longer needed ide_find_port(). * Make ide_find_port_slot() static. * Unexport ide_unregister(). v2: * Add missing 'struct ide_host *host' to macide.c. v3: * Fix build problem in pmac.c (s/ide_alloc_host/ide_host_alloc/) (Noticed by Stephen Rothwell). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-23ide-generic: probing fixBartlomiej Zolnierkiewicz
* Don't skip probing IDE port if the corresponding ide_hwifs[] slot is already occupied. * Remove duplicate idx[i] assignment. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-23ide: pass hw_regs_t-s to ide_device_add[_all]() (take 3)Bartlomiej Zolnierkiewicz
* Add 'hw_regs_t **hws' argument to ide_device_add[_all]() and convert host drivers + ide_legacy_init_one() + ide_setup_pci_device[s]() to use it instead of calling ide_init_port_hw() directly. [ However if host has > 1 port we must still set hwif->chipset to hint consecutive ide_find_port() call that the previous slot is occupied. ] * Unexport ide_init_port_hw(). v2: * Use defines instead of hard-coded values in buddha.c, gayle.c and q40ide.c. (Suggested by Geert Uytterhoeven) * Better patch description. v3: * Fix build problem in ide-cs.c. (Noticed by Stephen Rothwell) There should be no functional changes caused by this patch. Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-15ide-generic: don't probe all legacy ISA IDE ports by defaultBartlomiej Zolnierkiewicz
We can't probe all legacy ISA IDE ports by default as the resources may be occupied by other ISA devices. Add "probe_mask" module parameter and probe only first two ISA IDE ports by default leaving the decision about probing the rest to the user (systems with ISA ide2-6 should be very, very rare). This fixes a regression caused by: commit 343a3451e20314d5959b59b992e33fbaadfe52bf Author: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Date: Tue Jun 10 20:56:36 2008 +0200 ide-generic: add missing hwif->chipset setup ... Reported-by: Mikael Pettersson <mikpe@it.uu.se> Bisected-by: Mikael Pettersson <mikpe@it.uu.se> Tested-by: Mikael Pettersson <mikpe@it.uu.se> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-10ide-generic: add missing hwif->chipset setupBartlomiej Zolnierkiewicz
hwif->chipset need to be set properly or ide-generic driver will break once we make a final step in fixing host drivers' dependence on ide_hwifs[]. Problem was catched early thanks to IDE tree exposure in -mm / -next trees and reported by people listed people (thank you guys!). Reported-by: "John Keller" <jpk@sgi.com> Reported-by: Dmitri Vorobiev <dmitri.vorobiev@gmail.com> Reported-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: cleanup setting hwif->mmio flagBartlomiej Zolnierkiewicz
It is no longer needed to set hwif->mmio flag to tell IDE layer to not manage resources so cleanup host drivers that used hwif->mmio flag only for this purpose. Ditto for ide_legacy_init_one(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide-generic: manage I/O resources in driverBartlomiej Zolnierkiewicz
* Tell IDE layer to not manage resources by setting hwif->mmio flag. * Use {request,release}_region() for resources management. * Use driver name for resources management. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide-generic: use ide_find_port() (take 3)Bartlomiej Zolnierkiewicz
There should be no functional changes caused by this patch. v2: * Fix comment (noticed by Sergei Shtylyov). v3: * Fix no initalization of idx in some case. (Johann Felix Soden) Cc: Johann Felix Soden <johfel@users.sourceforge.net> Cc: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: cleanup ide_find_port()Bartlomiej Zolnierkiewicz
Remove no longer needed matching against I/O base and 'base' argument. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: remove ide_init_default_irq() macroBartlomiej Zolnierkiewicz
* Use ide_default_irq() instead of ide_init_default_irq() in ide_generic host driver (so the correct IRQ is always set regardless of CONFIG_PCI / CONFIG_BLK_DEV_IDEPCI). * Remove no longer needed ide_init_default_irq() macro. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: move default IDE ports setup to ide_generic host driverBartlomiej Zolnierkiewicz
* Make CONFIG_IDE_GENERIC depended on CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS. * Move default IDE ports setup from init_ide_data() to ide_generic. * Use ide_init_port_hw() in ide_generic. * Remove no longer needed CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: remove obsoleted "idex=base[,ctl[,irq]]" kernel parameters (take 2)Bartlomiej Zolnierkiewicz
* Remove obsoleted "idex=base[,ctl[,irq]]" kernel parameters and update Documentation/ide/ide.txt. * Remove no longer needed ide_forced chipset type. v2: * is_chipset_set[] -> is_chipset_set in ide.c. * Documentation/ide/ide.txt fix. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide-generic: add ide_generic class and attribute for adding new interfacesBartlomiej Zolnierkiewicz
* Add ide_generic_sysfs_init() helper registering 'ide_generic' class (together with ide_generic_class_release() ->class_release method) and use it in ide_generic_init(). * Add "add" class attribute to 'ide_generic' class for adding new interfaces (it is intended to be a replacement for obsoleted "idex=base[,ctl[,irq]]" kernel parameters). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide-generic: set hwif->chipsetBartlomiej Zolnierkiewicz
This hwif->chipset fixup is already present in ide_device_add_all() but for warm-plug support we also need to reserve not currently present interfaces. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-19falconide: locking bugfixBartlomiej Zolnierkiewicz
commit 8ac4ce742c66100931b6f2d7a36b0df08bc721fe ("ide: fix host drivers depending on ide_generic to probe for interfaces (take 2)") moved probing to falconide but forgot to take care of Atari specific locking - fix it. Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michael Schmitz <schmitz@debian.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-06ide-generic: probing bugfixBartlomiej Zolnierkiewicz
On Tuesday 05 February 2008, Linus Torvalds wrote: > > On Sat, 2 Feb 2008, Bartlomiej Zolnierkiewicz wrote: > > > > * next part of IDE probing code re-organization saga > >   (that would be me) > > This seems to cause very irritating and bogus messages for me: > >       Probing IDE interface ide0... >       Probing IDE interface ide1... >       ide2: I/O resource 0x0-0x7 not free. >       ide2: ports already in use, skipping probe >       ide3: I/O resource 0x0-0x7 not free. >       ide3: ports already in use, skipping probe >       ide4: I/O resource 0x0-0x7 not free. >       ide4: ports already in use, skipping probe >       ide5: I/O resource 0x0-0x7 not free. >       ide5: ports already in use, skipping probe >       ide6: I/O resource 0x0-0x7 not free. >       ide6: ports already in use, skipping probe >       ide7: I/O resource 0x0-0x7 not free. >       ide7: ports already in use, skipping probe >       ide8: I/O resource 0x0-0x7 not free. >       ide8: ports already in use, skipping probe >       ide9: I/O resource 0x0-0x7 not free. >       ide9: ports already in use, skipping probe > > and that's just totally bogus. It shouldn't even request that region, > since it's not been allocated! The commit 139ddfcab50e5eabcc88341c8743a990ac1be6a2 ("ide: move handling of I/O resources out of ide_probe_port()") changed the ordering of hwif->noprobe check vs ide_hwif_request_regions() call (so that we now reserve I/O regions before checking for hwif->noprobe). However ide-generic host driver depended on hwif->noprobe to be set for skipping probing of empty ide_hwifs[] slots. Fix it by passing only indexes of non-empty slots to ide_device_add_all() from ide_generic_init(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-02ide: add struct ide_port_info instances to legacy host driversBartlomiej Zolnierkiewicz
* Remove 'struct pci_dev *dev' argument from ide_hwif_setup_dma(). * Un-static ide_hwif_setup_dma() and add CONFIG_BLK_DEV_IDEDMA_PCI=n version. * Add 'const struct ide_port_info *d' argument to ide_device_add[_all](). * Factor out generic ports init from ide_pci_setup_ports() to ide_init_port(), move it to ide-probe.c and call it in in ide_device_add_all() instead of ide_pci_setup_ports(). * Move ->mate setup to ide_device_add_all() from ide_port_init(). * Add IDE_HFLAG_NO_AUTOTUNE host flag for host drivers that don't enable ->autotune currently. * Setup hwif->chipset in ide_init_port() but iff pi->chipset is set (to not override setup done by ide_hwif_configure()). * Add ETRAX host handling to ide_device_add_all(). * cmd640.c: set IDE_HFLAG_ABUSE_* also for CONFIG_BLK_DEV_CMD640_ENHANCED=n. * pmac.c: make pmac_ide_setup_dma() return an error value and move DMA masks setup to pmac_ide_setup_device(). * Add 'struct ide_port_info' instances to legacy host drivers, pass them to ide_device_add() calls and then remove open-coded ports initialization. Reviewed-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-26ide: remove ideprobe_init()Bartlomiej Zolnierkiewicz
* Rename ide_device_add() to ide_device_add_all() and make it accept 'u8 idx[MAX_HWIFS]' instead of 'u8 idx[4]' as an argument. * Add ide_device_add() wrapper for ide_device_add_all(). * Convert ide_generic_init() to use ide_device_add_all(). * Remove no longer needed ideprobe_init(). There should be no functionality changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-05-10ide: add ide_proc_register_port()Bartlomiej Zolnierkiewicz
* create_proc_ide_interfaces() tries to add /proc entries for every probed and initialized IDE port, replace it by ide_proc_register_port() which does it only for the given port (also rename destroy_proc_ide_interface() to ide_proc_unregister_port() for consistency) * convert {create,destroy}_proc_ide_interface[s]() users to use new functions * pmac driver depended on proc_ide_create() to add /proc port entries, fix it * au1xxx-ide, swarm and cs5520 drivers depended indirectly on ide-generic driver (CONFIG_IDE_GENERIC=y) to add port /proc entries, fix them * there is now no need to add /proc entries for IDE ports in proc_ide_create() so don't do it * proc_ide_create() needs now to be called before drivers are probed - fix it, while at it make proc_ide_create() create /proc "ide" directory Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
