path: root/drivers/ide/ide-iops.c
2009-04-08ide: refactor tf_read() methodSergei Shtylyov
Simplify tf_read() method, making it deal only with 'struct ide_taskfile' and the validity flags that the upper layer passes, and factoring out the code that deals with the high order bytes into ide_tf_readback() to be called from the only two functions interested, ide_complete_cmd() and ide_dump_sector(). This should stop the needless code duplication in this method and so make it about twice smaller than it was; along with simplifying the setup for the method call, this should save both time and space... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-08ide: refactor tf_load() methodSergei Shtylyov
Simplify tf_load() method, making it deal only with 'struct ide_taskfile' and the validity flags that the upper layer passes, and moving the code that deals with the high order bytes into the only function interested, do_rw_taskfile(). This should stop the needless code duplication in this method and so make it about twice smaller than it was; along with simplifying the setup for the method call, this should save both time and space... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-08ide: replace IDE_TFLAG_* flags by IDE_VALID_*Sergei Shtylyov
Replace IDE_TFLAG_{IN|OUT}_* flags meaning to the taskfile register validity on input/output by the IDE_VALID_* flags and introduce 4 symmetric 8-bit register validity indicator subfields, 'valid.{input/output}.{tf|hob}', into the 'struct ide_cmd' instead of using the 'tf_flags' field for that purpose (this field can then be turned from 32-bit into 8-bit one). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: inline SELECT_DRIVE()Sergei Shtylyov
Since SELECT_DRIVE() has boiled down to a mere dev_select() method call, it now makes sense to just inline it... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: turn selectproc() method into dev_select() method (take 5)Sergei Shtylyov
Turn selectproc() method into dev_select() method by teaching it to write to the device register and moving it from 'struct ide_port_ops' to 'struct ide_tp_ops'. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: benh@kernel.crashing.org Cc: petkovbb@gmail.com [bart: add ->dev_select to at91_ide.c and tx4939.c (__BIG_ENDIAN case)] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: rename IDE_TFLAG_IN_[HOB_]FEATURESergei Shtylyov
The feature register has never been readable -- when its location is read, one gets the error register value; hence rename IDE_TFLAG_IN_[HOB_]FEATURE into IDE_TFLAG_IN_[HOB_]ERROR and introduce the 'hob_error' field into the 'struct ide_taskfile' (despite the error register not really depending on the HOB bit). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: turn set_irq() method into write_devctl() methodSergei Shtylyov
Turn set_irq() method with its software reset hack into write_devctl() method (for just writing a value into the device control register) at last... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: add support for CFA specified transfer modes (take 3)Sergei Shtylyov
Add support for the CompactFlash specific PIO modes 5/6 and MWDMA modes 3/4. Since there were no PIO5 capable hard drives produced and one would also need 66 MHz IDE clock to actually get the difference WRT the address setup timings programmed, I decided to simply replace the old non-standard PIO mode 5 timings with the CFA specified ones. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: stf_xl@wp.pl Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide-iops: only clear DMA words on setting DMA modeSergei Shtylyov
The bytes indicating current DMA mode in the identify data words 62, 63, and 88 should only change on setting a DMA mode, so stop clearing them on setting PIO mode in ide_config_drive_speed(). While at it, correct SW/MW DMA mode masks... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-27ide: remove ide_execute_pkt_cmd() (v2)Bartlomiej Zolnierkiewicz
* Pass command structure to ide_execute_command() and skip __ide_set_handler() for ATAPI protocols on non-DRQ devices. * Convert ide_issue_pc() to always use ide_execute_command() and remove no longer needed ide_execute_pkt_cmd(). v2: * Fix for non-DRQ devices (based on report from Borislav). There should be no functional changes caused by this patch. Acked-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-27ide: add ->dma_timer_expiry method and remove ->dma_exec_cmd one (v2)Bartlomiej Zolnierkiewicz
* Rename dma_timer_expiry() to ide_dma_sff_timer_expiry() and export it. * Add ->dma_timer_expiry method and use it to set hwif->expiry for ATA_PROT_DMA protocol in do_rw_taskfile(). * Initialize ->dma_timer_expiry to ide_dma_sff_timer_expiry() for SFF hosts. * Move setting hwif->expiry from ide_execute_command() to its users and drop 'expiry' argument. * Use ide_execute_command() instead of ->dma_exec_cmd in do_rw_taskfile(). * Remove ->dma_exec_cmd method and its implementations. * Unexport ide_execute_command() and ide_dma_intr(). v2: * Fix CONFIG_BLK_DEV_IDEDMA=n build (noticed by Randy Dunlap). * Fix *dma_expiry naming (suggested by Sergei Shtylyov). There should be no functional changes caused by this patch. Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-27ide: set hwif->expiry prior to calling [__]ide_set_handler()Bartlomiej Zolnierkiewicz
* Set hwif->expiry prior to calling [__]ide_set_handler() and drop 'expiry' argument. * Set hwif->expiry to NULL in ide_{timer_expiry,intr}() and remove 'hwif->expiry = NULL' assignments. There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-27ide: remove ide_task_t typedefBartlomiej Zolnierkiewicz
While at it: - rename struct ide_task_s to struct ide_cmd - remove stale comments from idedisk_{read_native,set}_max_address() - drop unused 'cmd' argument from ide_{cmd,task}_ioctl() - drop unused 'task' argument from tx4939ide_tf_load_fixup() - rename ide_complete_task() to ide_complete_cmd() - use consistent naming for struct ide_cmd variables There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-24ide: use try_to_identify() in ide_driveid_update()Bartlomiej Zolnierkiewicz
* Pass pointer to buffer for IDENTIFY data to do_identify() and try_to_identify(). * Un-static try_to_identify() and use it in ide_driveid_update(). * Rename try_to_identify() to ide_dev_read_id(). There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-24ide: clear drive IRQ after re-enabling local IRQs in ide_driveid_update()Bartlomiej Zolnierkiewicz
Clear drive IRQ after re-enabling local IRQs in ide_driveid_update() to match try_to_identify(). Also remove superfluous local_irq_enable() call while at it. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-24ide: sanitize SELECT_MASK() usage in ide_driveid_update()Bartlomiej Zolnierkiewicz
Call SELECT_MASK() after ide_fix_driveid(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-24ide: shorten timeout value in ide_driveid_update()Bartlomiej Zolnierkiewicz
Shorten timeout value in ide_driveid_update() (30s -> 15s) to match try_to_identify(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-24ide: propagate AltStatus workarounds to ide_driveid_update()Bartlomiej Zolnierkiewicz
Propagate AltStatus workarounds from try_to_identify() to ide_driveid_update(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-24ide: fix kmalloc() failure handling in ide_driveid_update()Bartlomiej Zolnierkiewicz
* Doing kmalloc() in the middle of command execution is not only ugly but leaves drive waiting to send data on kmalloc() failure. Fix it. While at it: * Unify error code paths. * Fixup error message to be more useful and add missing KERN_ERR level. * Rename 'stat' variable to 's'. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-24ide: move error handling code to ide-eh.c (v2)Bartlomiej Zolnierkiewicz
Do some CodingStyle fixups in <linux/ide.h> while at it. v2: Add missing <linux/delay.h> include (reported by Stephen Rothwell). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-24ide: checkpatch.pl fixes for ide-iops.cBartlomiej Zolnierkiewicz
Fix following checkpatch.pl warnings/errors: - WARNING: space prohibited between function name and open parenthesis '(' - WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable - WARNING: line over 80 characters - ERROR: trailing whitespace - ERROR: space required before the open parenthesis '(' Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-24ide: fix comments in ide_config_drive_speed()Bartlomiej Zolnierkiewicz
2009-03-24ide: fix printk() levels in [atapi_]reset_pollfunc()Bartlomiej Zolnierkiewicz
2009-03-24ide: move standard I/O code to ide-io-std.cBartlomiej Zolnierkiewicz
2009-03-24ide: move ide_read_bcount_and_ireason() to ide-atapi.cBartlomiej Zolnierkiewicz
2009-03-24ide: move drive_is_ready() to ide-io.cBartlomiej Zolnierkiewicz
Move drive_is_ready() to ide-io.c, then make it static. Also make some minor CodingStyle fixups while at it. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-24ide: remove stale comments from drive_is_ready()Bartlomiej Zolnierkiewicz
2009-03-24ide: add ide_for_each_present_dev() iteratorBartlomiej Zolnierkiewicz
* Add ide_for_each_present_dev() iterator and convert IDE code to use it. * Do some drive-by CodingStyle fixups in ide-acpi.c while at it. There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-05ide-iops: fix odd-length ATAPI PIO transfersSergei Shtylyov
Commit 9567b349f7e7dd7e2483db99ee8e4a6fe0caca38 (ide: merge ->atapi_*put_bytes and ->ata_*put_data methods) introduced a regression WRT the odd-length ATAPI PIO transfers -- the final word didn't get written (causing command timeouts). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-14ide: fix accidental LOCKDEP breakage caused by local_irq_set() removalBartlomiej Zolnierkiewicz
commit 54cc1428cfa619e16d75baae8cb041a2eff015f0 ("ide: remove local_irq_set() macro") accidentally replaced local_save_flags() by local_irq_set() in ide_probe_port() and __ide_wait_stat() which resulted in LOCKDEP breakage. Reported-by: Larry Finger <Larry.Finger@lwfinger.net> Tested-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06ide: move read_sff_dma_status() method to 'struct ide_dma_ops'Sergei Shtylyov
Move apparently misplaced read_sff_dma_status() method from 'struct ide_tp_ops' to 'struct ide_dma_ops', renaming it to dma_sff_read_status() and making only required for SFF-8038i compatible IDE controller drivers (greatly cutting down the number of initializers) as its only user (outside ide-dma-sff.c and such drivers) appears to be ide_pci_check_simplex() which is only called for such controllers... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06ide: add port and host iteratorsBartlomiej Zolnierkiewicz
Add ide_port_for_each_dev() / ide_host_for_each_port() iterators and update IDE code to use them. While at it: - s/unit/i/ variable in ide_port_wait_ready(), ide_probe_port(), ide_port_tune_devices(), ide_port_init_devices_data(), do_reset1(), ide_acpi_set_state() and scc_dma_end() - s/d/i/ variable in ide_proc_port_register_devices() There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06ide: dynamic allocation of device structuresBartlomiej Zolnierkiewicz
Allocate device structures dynamically instead of having them embedded in ide_hwif_t: * Remove needless zeroing of port structure from ide_init_port_data(). * Add ide_hwif_t.devices[MAX_DRIVES] (table of pointers to the devices). * Add ide_port_{alloc,free}_devices() helpers and use them respectively in ide_{host,free}_alloc(). * Convert all users of ->drives[] to use ->devices[] instead. While at it: * Use drive->dn for the slave device check in scc_pata.c. As a nice side-effect this patch cuts ~1kB (x86-32) from the resulting code size: text data bss dec hex filename 53963 1244 237 55444 d894 drivers/ide/ide-core.o.before 52981 1244 237 54462 d4be drivers/ide/ide-core.o.after Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06ide: unexport ide_wait_not_busy()Bartlomiej Zolnierkiewicz
2009-01-06ide: remove local_irq_set() macroBartlomiej Zolnierkiewicz
2009-01-06ide: remove HWIF() macroBartlomiej Zolnierkiewicz
2009-01-06ide: merge ide_hwgroup_t with ide_hwif_t (v2)Bartlomiej Zolnierkiewicz
* Merge ide_hwgroup_t with ide_hwif_t. * Cleanup init_irq() accordingly, then remove no longer needed ide_remove_port_from_hwgroup() and ide_ports[]. * Remove now unused HWGROUP() macro. While at it: * ide_dump_ata_error() fixups v2: * Fix ->quirk_list check in do_ide_request() (s/hwif->cur_dev/prev_port->cur_dev). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-12-29ide: replace the global ide_lock spinlock by per-hwgroup spinlocks (v2)Bartlomiej Zolnierkiewicz
Now that (almost) all host drivers have been fixed not to abuse ide_lock and core code usage of ide_lock has been sanitized we may safely replace ide_lock by per-hwgroup locks. This patch is partially based on earlier patch from Ravikiran G Thirumalai. While at it: - don't use deprecated HWIF() and HWGROUP() macros - update locking documentation in ide.h v2: Add missing spin_lock_init(&hwgroup->lock). (Noticed by Elias Oltmanns) Cc: Vaibhav V. Nivargi <vaibhav.nivargi@gmail.com> Cc: Alok N. Kataria <alokk@calsoftinc.com> Cc: Shai Fultheim <shai@scalex86.org> Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org> Cc: Elias Oltmanns <eo@nebensachen.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-12-02ide: remove dead code from drive_is_ready()Bartlomiej Zolnierkiewicz
We guarantee 400ns delay at the time of issuing the command. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-12-02ide: add SAMSUNG SP0822N with firmware WA100-10 to ivb_list[]Bartlomiej Zolnierkiewicz
Should fix kernel.org bug #10225: http://bugzilla.kernel.org/show_bug.cgi?id=10225 Reported-by: Matthias B. <haferfrost@web.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Sergei Shtyltov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-12-02amd74xx: workaround unreliable AltStatus register for nVidia controllersBartlomiej Zolnierkiewicz
It seems that on some nVidia controllers using AltStatus register can be unreliable so default to Status register if the PCI device is in Compatibility Mode. In order to achieve this: * Add ide_pci_is_in_compatibility_mode() inline helper to <linux/ide.h>. * Add IDE_HFLAG_BROKEN_ALTSTATUS host flag and set it in amd74xx host driver for nVidia controllers in Compatibility Mode. * Teach actual_try_to_identify() and drive_is_ready() about the new flag. This fixes the regression caused by removal of CONFIG_IDEPCI_SHARE_IRQ config option in 2.6.25 and using AltStatus register unconditionally when available (kernel.org bugs #11659 and #10216). [ Moreover for CONFIG_IDEPCI_SHARE_IRQ=y (which is what most people and distributions use) it never worked correctly. ] Thanks to Remy LABENE and Lars Winterfeld for help with debugging the problem. More info at: http://bugzilla.kernel.org/show_bug.cgi?id=11659 http://bugzilla.kernel.org/show_bug.cgi?id=10216 Reported-by: Remy LABENE <remy.labene@free.fr> Tested-by: Remy LABENE <remy.labene@free.fr> Tested-by: Lars Winterfeld <lars.winterfeld@tu-ilmenau.de> Acked-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-11-02ide: Switch to a common addressAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-17ide: mask interrupt in ide_config_drive_speed()Sergei Shtylyov
Apparently, there is no sense in unmasking IRQ on the controller when you call disable_irq_nosync() before doing this, set the nIEN bit afterwards, and then unmask IRQ again after the command completion, hence 0 passed to SELECT_MASK() before issuing the command in ide_config_drive_speed() is probably just a typo. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: Implement disk shock protection support (v4)Elias Oltmanns
On user request (through sysfs), the IDLE IMMEDIATE command with UNLOAD FEATURE as specified in ATA-7 is issued to the device and processing of the request queue is stopped thereafter until the specified timeout expires or user space asks to resume normal operation. This is supposed to prevent the heads of a hard drive from accidentally crashing onto the platter when a heavy shock is anticipated (like a falling laptop expected to hit the floor). Port resets are deferred whenever a device on that port is in the parked state. v3: Elias Oltmanns <eo@nebensachen.de> wrote: [...] > >> 1. Make sure that no negative value is being passed to > >> jiffies_to_msecs() in ide_park_show(). > >> 2. Drop the superfluous variable hwif in ide_special_rq(). > >> 3. Skip initialisation of task and tf in ide_special_rq() if we are not > >> handling a (un)park request. > > > > Well, #3 should have been done differently because we donn't want to > > check for REQ_(UN)?PARK_HEADS more often than is necessary. > > While preparing the backport to 2.6.27, it has just occurred to me that > we need to clear the IDE_DFLAG_PARKED flag in ide_disk_pre_reset() > because this flag must not be set after *any* sort of access to the > device. v4: Fix a memory leak due to a missing blk_put_request() in issue_park_cmd(). Additionally, we should plug the queue when enqueueing the unpark request because there is no guarantee that the park timeout has not expired by then. Even though the chance for that to happen is very slim, the request might end up hanging in the queue until the next I/O operation is queued up. While at it, clean up the code a little: - make issue_park_cmd() a function of type void since nobody cares for the return value anyway; - use blk_start_queueing() instead of __blk_run_queue() since we don't have to worry about recursion; - remove a superfluous pointer deference in task_no_data_intr(). Signed-off-by: Elias Oltmanns <eo@nebensachen.de> Cc: Jeff Garzik <jeff@garzik.org>, Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: factor out reset error reporting from reset_pollfunc()Bartlomiej Zolnierkiewicz
Factor out reset error reporting from reset_pollfunc() to ide_reset_report_error() helper. While at it: - fix KERN_* printk() levels - remove 'switch ()' Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: remove [ata_]select_tBartlomiej Zolnierkiewicz
* Use 'drive->dn & 1' in ide_init_disk(). * remove [ata_]select_t. While at it: * Use ATA_DEVICE_OBS define in ide_port_init_devices_data(). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: add device flagsBartlomiej Zolnierkiewicz
Add 'unsigned long dev_flags' to ide_drive_t and convert bitfields to IDE_DFLAG_* flags. While at it: - IDE_DFLAG_ADDRESSING -> IDE_DFLAG_LBA48 - fixup some comments - remove needless g->flags zeroing from ide*_probe() There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: ide_dev_is_sata() -> ata_id_is_sata()Bartlomiej Zolnierkiewicz
* Use optimized ATA version check from Sergei in ata_id_is_sata(). * ide_dev_is_sata() -> ata_id_is_sata() Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: remove SECTOR_WORDS defineBartlomiej Zolnierkiewicz
Just use SECTOR_SIZE instead. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: include <linux/hdreg.h> only when neededBartlomiej Zolnierkiewicz
* Include <linux/ata.h> directly in <linux/ide.h> instead of through <linux/hdreg.h>. * Include <linux/hdreg.h> only when needed. Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
