path: root/drivers/ide/ide-proc.c
2009-01-06ide: add port and host iteratorsBartlomiej Zolnierkiewicz
Add ide_port_for_each_dev() / ide_host_for_each_port() iterators and update IDE code to use them. While at it: - s/unit/i/ variable in ide_port_wait_ready(), ide_probe_port(), ide_port_tune_devices(), ide_port_init_devices_data(), do_reset1(), ide_acpi_set_state() and scc_dma_end() - s/d/i/ variable in ide_proc_port_register_devices() There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06ide: dynamic allocation of device structuresBartlomiej Zolnierkiewicz
Allocate device structures dynamically instead of having them embedded in ide_hwif_t: * Remove needless zeroing of port structure from ide_init_port_data(). * Add ide_hwif_t.devices[MAX_DRIVES] (table of pointers to the devices). * Add ide_port_{alloc,free}_devices() helpers and use them respectively in ide_{host,free}_alloc(). * Convert all users of ->drives[] to use ->devices[] instead. While at it: * Use drive->dn for the slave device check in scc_pata.c. As a nice side-effect this patch cuts ~1kB (x86-32) from the resulting code size: text data bss dec hex filename 53963 1244 237 55444 d894 drivers/ide/ide-core.o.before 52981 1244 237 54462 d4be drivers/ide/ide-core.o.after Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06ide: remove ide_driver_t typedefBartlomiej Zolnierkiewicz
While at it: - s/struct ide_driver_s/struct ide_driver/ - use to_ide_driver() macro in ide-proc.c Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-12-29cy82c693: remove superfluous ide_cy82c693 chipset typeBartlomiej Zolnierkiewicz
Since CY82C693 doesn't require serialization we may as well use the default ide_pci chipset type. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-12-29trm290: add IDE_HFLAG_TRM290 host flagBartlomiej Zolnierkiewicz
* Add IDE_HFLAG_TRM290 host flag and use it in ide_build_dmatable(). * Remove no longer needed ide_trm290 chipset type. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-12-29rz1000: apply chipset quirks early (v2)Bartlomiej Zolnierkiewicz
* Use pci_name(dev) instead of hwif->name in init_hwif_rz1000(). * init_hwif_rz1000() -> rz1000_init_chipset(). Update rz1000_init_one() to use rz1000_init_chipset() and add now required rz1000_remove(). * Remove superfluous ide_rz1000 chipset type. v2: * unsigned int rz1000_init_chipset() -> int rz1000_disable_readahead() per Sergei's suggestion. Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-12-29cmd64x: set IDE_HFLAG_SERIALIZE explictly for CMD646Bartlomiej Zolnierkiewicz
* Set IDE_HFLAG_SERIALIZE explictly for CMD646. * Remove no longer needed ide_cmd646 chipset type (which has a nice side-effect of fixing handling of unexpected IRQs). Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-12-29ide: IDE settings don't need an ide_lock heldBartlomiej Zolnierkiewicz
IDE settings are protected by ide_setting_mtx mutex so there is no need to hold ide_lock in ide_setting_ioctl(), ide_read_setting() and ide_proc_unregister_driver(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-11-02ide: Switch to a common addressAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-17ide: allow device drivers to specify per-device type /proc settingsBartlomiej Zolnierkiewicz
Turn ide_driver_t's 'proc' field into ->proc_entries method (and also 'settings' field into ->proc_devsets method). Then update all device drivers accordingly. There should be no functional changes caused by this patch. Acked-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: add device flagsBartlomiej Zolnierkiewicz
Add 'unsigned long dev_flags' to ide_drive_t and convert bitfields to IDE_DFLAG_* flags. While at it: - IDE_DFLAG_ADDRESSING -> IDE_DFLAG_LBA48 - fixup some comments - remove needless g->flags zeroing from ide*_probe() There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: Remove ide_spin_wait_hwgroup() and use special requests insteadElias Oltmanns
Use a special request for serialisation purposes and get rid of the awkward ide_spin_wait_hwgroup(). This also involves converting the ide_devset structure so it can be shared by the /proc and the ioctl code. Signed-off-by: Elias Oltmanns <eo@nebensachen.de> [bart: use rq->cmd[] directly] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: remove SECTOR_WORDS defineBartlomiej Zolnierkiewicz
Just use SECTOR_SIZE instead. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: /proc/ide/hd*/settings reworkBartlomiej Zolnierkiewicz
* Add struct ide_devset, S_* flags, *DEVSET() & ide*_devset_*() macros. * Add 'const struct ide_devset **settings' to ide_driver_t. * Use 'const struct ide_devset **settings' in ide_drive_t instead of 'struct ide_settings_s *settings'. Then convert core code and device drivers to use struct ide_devset and co.: - device settings are no longer allocated dynamically for each device but instead there is an unique struct ide_devset instance per setting - device driver keeps the pointer to the table of pointers to its settings in ide_driver_t.settings - generic settings are kept in ide_generic_setting[] - ide_proc_[un]register_driver(), ide_find_setting_by_name(), ide_{read,write}_setting() and proc_ide_{read,write}_settings() are updated accordingly - ide*_add_settings() are removed * Remove no longer used __ide_add_setting(), ide_add_setting(), __ide_remove_setting() and auto_remove_settings(). * Remove no longer used TYPE_*, SETTING_*, ide_procset_t and ide_settings_t. * ->keep_settings, ->using_dma, ->unmask, ->noflush, ->dsc_overlap, ->nice1, ->addressing, ->wcache and ->nowerr ide_drive_t fields can now be bitfield flags. While at it: * Rename ide_find_setting_by_name() to ide_find_setting(). * Rename write_wcache() to set_wcache(). There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: preparations for /proc/ide/hd*/settings reworkBartlomiej Zolnierkiewicz
After rework settings will be no longer created dynamically for each device so we need to make some fixups first. * Use set_[ksettings,unmaskirq]() as a set function for ["keepsettings","unmaskirq"] setting. * Allow writes to ["io_32bit","unmaskirq"] settings also when drive->no_[io_32bit,unmask] is set (this is checked later inside set_[io_32bit,unmaskirq]() anywyay and keeps consistency with the corresponding HDIO_SET_[32BIT,UNMASKINTR] ioctls). * Use max possible multi sectors value (16) as an allowed max for "multcount" setting. set_multcount() set function checks against device's max possbile value anyway and it makes the proc setting consistent with the corresponding HDIO_SET_MULTCOUNT ioctl. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: include <linux/hdreg.h> only when neededBartlomiej Zolnierkiewicz
* Include <linux/ata.h> directly in <linux/ide.h> instead of through <linux/hdreg.h>. * Include <linux/hdreg.h> only when needed. Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: WIN_* -> ATA_CMD_*Bartlomiej Zolnierkiewicz
* Use ATA_CMD_* defines instead of WIN_* ones. While at it: * EXABYTE_ENABLE_NEXT -> ATA_EXABYTE_ENABLE_NEST * SETFEATURES_{EN,DIS}_WCACHE -> SETFEATURES_WC_{ON,OFF} * SETFEATURES_{EN,DIS}_AAM -> SETFEATURES_AAM_{ON,OFF} * SMART_* -> ATA_SMART_* * Remove stale comment from ide-proc.c. Partially based on earlier work by Chris Wedgwood. Acked-by: Chris Wedgwood <cw@f00f.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: make drive->id an union (take 2)Bartlomiej Zolnierkiewicz
Make drive->id an unnamed union so id can be accessed either by using 'u16 *id' or 'struct hd_driveid *driveid'. Then convert all existing drive->id users accordingly (using 'u16 *id' when possible). This is an intermediate step to make ide 'struct hd_driveid'-free. While at it: - Add missing KERN_CONTs in it821x.c. - Use ATA_ID_WORDS and ATA_ID_*_LEN defines. - Remove unnecessary checks for drive->id. - s/drive_table/table/ in ide_in_drive_list(). - Cleanup ide_config_drive_speed() a bit. - s/drive1/dev1/ & s/drive0/dev0/ in ide_undecoded_slave(). v2: Fix typo in drivers/ide/ppc/pmac.c. (From Stephen Rothwell) There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24ide: trivial sparse annotationsHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-23ide: filter out "default" transfer mode values in set_xfer_rate()Bartlomiej Zolnierkiewicz
* Filter out "default" transfer mode values (0x00 - default PIO mode, 0x01 - default PIO mode w/ IORDY disabled) in write handler for obsoleted /proc/ide/hd?/settings:current_speed setting. Allowing "default" transfer mode values is a dangerous thing to do as we don't support programming controller to the "default" transfer mode and devices often use different values for the default and maximum PIO mode (i.e. PIO2 default and PIO4 maximum) so the controller will stay programmed for higher PIO mode while device will use the lower PIO mode. There is no functionality loss as by using special IOCTLs device can still be programmed to "default" transfer modes (it is only useful for debugging/testing purposes anyway). * Remove no longer needed IDE_HFLAG_ABUSE_SET_DMA_MODE host flag, it was previously used by few host drivers to program the controller to PIO0 timings for "default" transfer mode == 0x01 (although some host drivers would program invalid PIO timings instead). * Cleanup ide_set_xfer_rate() and add BUG_ON(). Suggested-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-23ide: filter out invalid transfer mode values in set_xfer_rate()Bartlomiej Zolnierkiewicz
Filter out invalid transfer mode values (0x02-0x07) in write handler for obsoleted /proc/ide/hd?/settings:current_speed setting. While at it: * Use XFER_UDMA_6 define. Suggested-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-30ide: fix /proc/ide/ide?/mate reportingBartlomiej Zolnierkiewicz
Now that we support warm-plug mate port will be registered even if there are no devices attached to it. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-10ide: remove the ide_etrax100 chipset typeAdrian Bunk
I forgot to remove the ide_etrax100 chipset type when removing the ETRAX_IDE driver. Reported-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-29drivers: use non-racy method for proc entries creation (2)Denis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Peter Osterlund <petero2@telia.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Neil Brown <neilb@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-27ide: remove now unused ide_pci_create_host_proc()Alexey Dobriyan
It creates files in proc with obsoleted ->get_info interface. Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Cc: Andrew Morton <akpm@osdl.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ [bart: fix checkpatch.pl errors in ide-lib.c and ppc/mpc8xx.c while at it] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26IDE: Coding Style fixes to drivers/ide/ide-proc.cPaolo Ciarrocchi
Lot of errors and warnings removed. Compile tested. [bart: minor fixes, md5sum checked] Signed-off-by: Paolo Ciarrocchi <paolo.ciarrocchi@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: remove obsoleted "idex=base[,ctl[,irq]]" kernel parameters (take 2)Bartlomiej Zolnierkiewicz
* Remove obsoleted "idex=base[,ctl[,irq]]" kernel parameters and update Documentation/ide/ide.txt. * Remove no longer needed ide_forced chipset type. v2: * is_chipset_set[] -> is_chipset_set in ide.c. * Documentation/ide/ide.txt fix. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: remove IDE devices from /proc/ide/ before unregistering themBartlomiej Zolnierkiewicz
IDE devices need to be removed from /proc/ide/ _before_ being unregistered: * Drop 'ide_hwif_t *hwif' argument from destroy_proc_ide_device() and use drive->hwif instead. * Rename destroy_proc_ide_device() to ide_proc_unregister_device(). * Call ide_proc_unregister_device() in drive_release_dev(). * Remove no longer needed destroy_proc_ide_drives(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-06Palmchip BK3710 IDE driverAnton Salnikov
This is Palmchip BK3710 IDE controller support. The IDE controller logic supports PIO, MultiWord-DMA and Ultra-DMA modes. Supports interface to Compact Flash (CF) configured in True-IDE mode. Bart: - remove dead code - fix ide_hwif_setup_dma() build problem Signed-off-by: Anton Salnikov <asalnikov@ru.mvista.com> Reviewed-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Reviewed-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-02ide: move create_proc_ide_drives() call to ide_device_add_all()Bartlomiej Zolnierkiewicz
* Un-static create_proc_ide_drives() and call it from ide_device_add_all(). While at it: * Rename create_proc_ide_drives() to ide_proc_port_register_devices(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-02ide: move hwif->present check out from ide_proc_register_port()Bartlomiej Zolnierkiewicz
Move hwif->present check out from ide_proc_register_port() to ide_device_add_all(). There should be no functionality changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide: delete filenames/versions from commentsBartlomiej Zolnierkiewicz
Delete filenames/versions from comments. I'm leaving decisions about adding DRV_VERSION defines and MODULE_VERSION()-s to maintainers of the respective drivers. While at it: * Remove unused VERSION define from ide.c. * Remove unused/stale DRV_VERSION define from au1xxx-ide.c. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-26ide: switch set_xfer_rate() to use REQ_TYPE_ATA_TASKFILE requestsBartlomiej Zolnierkiewicz
Based on the earlier work by Tejun Heo. Switch set_xfer_rate() to use REQ_TYPE_ATA_TASKFILE requests and make ide_wait_cmd() static. There should be no functionality changes caused by this patch. Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-20ide: add ide_device_add()Bartlomiej Zolnierkiewicz
* Add ide_device_add() helper and convert host drivers to use it instead of open-coded variants. * Make ide_pci_setup_ports() and do_ide_setup_pci_device() take 'u8 *idx' argument instead of 'ata_index_t *index'. * Remove no longer needed ata_index_t. * Unexport probe_hwif_init() and make it static. * Unexport ide_proc_register_port(). There should be no functionality changes caused by this patch (sgiioc4.c: ide_proc_register_port() requires hwif->present to be set and it won't be set if probe_hwif_init() fails). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-09ide: use mutex instead of ide_setting_sem semaphore in IDE driverMatthias Kaehlcke
The IDE driver uses a semaphore as mutex. Use the mutex API instead of the (binary) semaphore. Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> --
2007-05-24Add two missing chipsets to drivers/ide/ide-proc.cMika Kukkonen
Compiling with '-Wswitch-enum' I noticed following: CC drivers/ide/ide-proc.o drivers/ide/ide-proc.c: In function ‘proc_ide_read_imodel’: drivers/ide/ide-proc.c:54: warning: enumeration value ‘ide_etrax100’ not handled in switch drivers/ide/ide-proc.c:54: warning: enumeration value ‘ide_acorn’ not handled in switch How about the following patch? Signed-off-by: Mika Kukkonen <mikukkon@iki.fi> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-05-10ide: add ide_proc_register_port()Bartlomiej Zolnierkiewicz
* create_proc_ide_interfaces() tries to add /proc entries for every probed and initialized IDE port, replace it by ide_proc_register_port() which does it only for the given port (also rename destroy_proc_ide_interface() to ide_proc_unregister_port() for consistency) * convert {create,destroy}_proc_ide_interface[s]() users to use new functions * pmac driver depended on proc_ide_create() to add /proc port entries, fix it * au1xxx-ide, swarm and cs5520 drivers depended indirectly on ide-generic driver (CONFIG_IDE_GENERIC=y) to add port /proc entries, fix them * there is now no need to add /proc entries for IDE ports in proc_ide_create() so don't do it * proc_ide_create() needs now to be called before drivers are probed - fix it, while at it make proc_ide_create() create /proc "ide" directory Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-05-10ide: move IDE settings handling to ide-proc.cBartlomiej Zolnierkiewicz
* move __ide_add_setting() ide_add_setting() __ide_remove_setting() auto_remove_settings() ide_find_setting_by_name() ide_read_setting() ide_write_setting() set_xfer_rate() ide_add_generic_settings() ide_register_subdriver() ide_unregister_subdriver() from ide.c to ide-proc.c * set_{io_32bit,pio_mode,using_dma}() cannot be marked static now, fix it * rename ide_[un]register_subdriver() to ide_proc_[un]register_driver(), update device drivers to use new names * add CONFIG_IDE_PROC_FS=n versions of ide_proc_[un]register_driver() and ide_add_generic_settings() * make ide_find_setting_by_name(), ide_{read,write}_setting() and ide_{add,remove}_proc_entries() static * cover IDE settings code in device drivers with CONFIG_IDE_PROC_FS #ifdef, also while at it cover with CONFIG_IDE_PROC_FS #ifdef ide_driver_t.proc * remove bogus comment from ide.h * cover with CONFIG_IDE_PROC_FS #ifdef .proc and .settings in ide_drive_t Besides saner code this patch results in the IDE core smaller by ~2 kB (on x86-32) and IDE disk driver by ~1 kB (ditto) when CONFIG_IDE_PROC_FS=n. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-04-27IDE: remove rwsem use from ide-proc coreGreg Kroah-Hartman
The subsystem rwsem is not used by the driver core at all, so the use of it in the ide-proc code of it doesn't make any sense. Perhaps a local lock might be needed, but I do not really think so. Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: linux ide <linux-ide@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-12[PATCH] mark struct file_operations const 3Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] proc: remove useless (and buggy) ->nlink settingsAlexey Dobriyan
Bug: pnx8550 code creates directory but resets ->nlink to 1. create_proc_entry() et al will correctly set ->nlink for you. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Corey Minyard <minyard@acm.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Greg KH <greg@kroah.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03[PATCH] IDE core: driver layer error checkingRandy Dunlap
Check driver layer return values in IDE core. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-08[PATCH] optical /proc/ide/*/mediaAlexey Dobriyan
Sergey Vlasov reported that his "FUJITSU MCC3064AP, ATAPI OPTICAL drive" pops up as UNKNOWN in /proc/ide/*/media . Closes #4145. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29Cleaned up AMD Au1200 IDE driver:Pete Popov
- converted to platform bus - removed pci dependencies - removed virt_to_phys/phys_to_virt calls System now can root off of a disk. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> diff --git a/Documentation/mips/AU1xxx_IDE.README b/Documentation/mips/AU1xxx_IDE.README new file mode 100644
2005-05-26[PATCH] convert IDE device drivers to driver-modelBartlomiej Zolnierkiewicz
* add ide_bus_match() and export ide_bus_type * split ide_remove_driver_from_hwgroup() out of ide_unregister() * move device cleanup from ide_unregister() to drive_release_dev() * convert ide_driver_t->name to driver->name * convert ide_driver_t->{attach,cleanup} to driver->{probe,remove} * remove ide_driver_t->busy as ide_bus_type->subsys.rwsem protects against concurrent ->{probe,remove} calls * make ide_{un}register_driver() void as it cannot fail now * use driver_{un}register() directly, remove ide_{un}register_driver() * use device_register() instead of ata_attach(), remove ata_attach() * add proc_print_driver() and ide_drivers_show(), remove ide_drivers_op * fix ide_replace_subdriver() and move it to ide-proc.c * remove ide_driver_t->drives, ide_drives and drives_lock * remove ide_driver_t->drivers, drivers and drivers_lock * remove ide_drive_t->driver and DRIVER() macro Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@elka.pw.edu.pl>
2005-05-17[PATCH] ide proc destroy errorZhang, Yanmin
Kernel 2.6 has an ide proc destroy error. Run #modprobe ide-core and #rmmod ide-core, then kernel will dump stack information like below. **********Log****************** Badness in remove_proc_entry at fs/proc/generic.c:693 Call Trace: [<a0000001000117e0>] show_stack+0x80/0xa0 sp=3De0000003e05dfbe0 = bsp=3De0000003e05d0ea8 [<a0000001000120b0>] dump_stack+0x30/0x60 sp=3De0000003e05dfdb0 = bsp=3De0000003e05d0e90 [<a000000100183090>] remove_proc_entry+0x530/0x540 sp=3De0000003e05dfdb0 = bsp=3De0000003e05d0e20 [<a000000221cbd280>] proc_ide_destroy+0x120/0x140 [ide_core] sp=3De0000003e05dfdc0 = bsp=3De0000003e05d0df0 [<a000000221ca65f0>] cleanup_module+0x50/0xa0 [ide_core] sp=3De0000003e05dfdc0 = bsp=3De0000003e05d0dd0 [<a0000001000a9e10>] sys_delete_module+0x390/0x580 sp=3De0000003e05dfdc0 = bsp=3De0000003e05d0d50 [<a00000010000af40>] ia64_ret_from_syscall+0x0/0x20 sp=3De0000003e05dfe30 = bsp=3De0000003e05d0d50 [<a000000000010640>] _stext+0xffffffff00010640/0x400 sp=3De0000003e05e0000 = bsp=3De0000003e05d0d50 Signed-off-by: Zhang Yanmin <yanmin.zhang@intel.com> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
