path: root/drivers/ide/ide-tape.c
2008-04-29ide: use blk_rq_init() to initialize the requestFUJITA Tomonori
This converts ide to use blk_rq_init to initialize the request. This is a preparation for large command support, which needs to initialize the request in a proper way (that is, just doing a memset() will not work). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-28ide: add ide_pad_transfer() helperBartlomiej Zolnierkiewicz
* Add ide_pad_transfer() helper (which uses ->{in,out}put_data methods internally so the transfer is also padded to drive+host requirements) and use it instead of ide_atapi_{write_zeros,discard_data}(). * Remove no longer needed ide_atapi_{write_zeros,discard_data}(). Cc: Borislav Petkov <petkovbb@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-28ide: add ide_execute_pkt_cmd() helperBartlomiej Zolnierkiewicz
Add ide_execute_pkt_cmd() helper for executing PACKET command, then convert ATAPI device drivers to use it. As a nice side-effect this fixes ide-{floppy,tape,scsi} w.r.t. ide_lock taking (ide-cd was OK). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-28ide-{floppy,tape,scsi}: 400ns delay is required after executing the commandBartlomiej Zolnierkiewicz
2008-04-28ide: always use ->OUTBSYNC method for executing commandsBartlomiej Zolnierkiewicz
Always use ->OUTBSYNC method for executing commands so the posting is done if needed (this affects only pmac and scc_pata host drivers at the moment). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-28ide: merge ->atapi_*put_bytes and ->ata_*put_data methodsBartlomiej Zolnierkiewicz
* Merge ->atapi_{in,out}put_bytes and ->ata_{in,out}put_data methods into new ->{in,out}put_data methods which take number of bytes to transfer as an argument and always do padding. While at it: * Use 'hwif' or 'drive->hwif' instead of 'HWIF(drive)'. There should be no functional changes caused by this patch (all users of ->ata_{in,out}put_data methods were using multiply-of-4 word counts). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide-tape: remove tape->merge_stageBorislav Petkov
Get rid of the pipeline merge stage but retain the chrdev req caching functionality by using a merge buffer tape->merge_bh which is flushed in chunks of several blocks at a time. Also, remove last references to pipelining, e.g. typedef idetape_stage_s. Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide-tape: mv tape->merge_stage_size tape->merge_bh_sizeBorislav Petkov
This is the size of the merge buffer. Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide-tape: mv idetape_empty_write_pipeline ide_tape_flush_merge_bufferBorislav Petkov
2008-04-27ide-tape: mv idetape_discard_read_pipeline ide_tape_discard_merge_bufferBorislav Petkov
Also, rename its __-low level helper too. Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide-tape: make __idetape_discard_read_pipeline() of type voidBorislav Petkov
It always returns 0 which has no effect on tape positioning calculation so simplify it by converting its type to void, bringing no functional change to the driver. Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide-tape: improve buffer pages freeing strategyBorislav Petkov
Instead of freeing pages one by one, free them 2^order-wise. Also, mv __idetape_kfree_stage() to ide_tape_kfree_buffer(). [bart: add updating bh->b_data] Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide-tape: mv tape->pages_per_stage tape->pages_per_bufferBorislav Petkov
2008-04-27ide-tape: mv tape->stage_size tape->buffer_sizeBorislav Petkov
2008-04-27ide-tape: improve buffer allocation strategyBorislav Petkov
Instead of allocating pages for the buffer one by one, take advantage of the buddy alloc system and request them 2^order at a time. This increases the chance for bigger buffer parts to be contigious and reduces loop iteration count. While at it, rename function __idetape_kmalloc_stage() to ide_tape_kmalloc_buffer(). [bart: fold with "ide-tape: fix mem leak" patch to preserve bisectability] Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide: add struct ide_io_ports (take 3)Bartlomiej Zolnierkiewicz
* Add struct ide_io_ports and use it instead of `unsigned long io_ports[]` in ide_hwif_t. * Rename io_ports[] in hw_regs_t to io_ports_array[]. * Use un-named union for 'unsigned long io_ports_array[]' and 'struct ide_io_ports io_ports' in hw_regs_t. * Remove IDE_*_OFFSET defines. v2: * scc_pata.c build fix from Stephen Rothwell. v3: * Fix ctl_adrr typo in Sparc-specific part of ns87415.c. (Noticed by Andrew Morton) Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide-tape: remove misc references to pipelined operation in the commentsBorislav Petkov
2008-04-27ide-tape: remove pipelined mode parametersBorislav Petkov
2008-04-27ide-tape: remove pipeline-specific members from struct ide_tape_objBorislav Petkov
Bart: - merge "ide-tape: remove pipeline-specific code from idetape_setup" patch - cleanup __idetape_discard_read_pipeline() - cleanup idetape_empty_write_pipeline() - fix 't' assignment in idetape_setup() - fix idetape_blkdev_ioctl() w.r.t. 'nr_stages' Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide-tape: remove pipelined mode tape control flagsBorislav Petkov
[bart: sync patch with current code and fix idetape_init_read()] Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide-tape: remove remaining pipeline functionalityBorislav Petkov
The driver is using now solely its own request queue. - tape->next_stage is always NULL so it is safe to remove all code depending on tape->next_stage != NULL - this patch removes the last place which sets IDETAPE_FLAG_PIPELINE_ACTIVE in tape->flags [bart: add above explanations] Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide-tape: unwrap idetape_queue_pc_tail()Borislav Petkov
idetape_queue_pc_tail() is a wrapper for its __idetape_queue_pc_tail() counterpart and has no other functionality. Remove it and call the "wrapped" function directly. Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide-tape: remove pipeline-specific code from idetape_end_request()Borislav Petkov
As a side effect, remove unused idetape_kfree_stage() and idetape_abort_pipeline() [bart: resurrect taking tape->lock + clearing IDETAPE_FLAG_PIPELINE_ACTIVE] Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide-tape: remove idetape_remove_stage_head()Borislav Petkov
2008-04-27ide-tape: remove idetape_pipeline_size()Borislav Petkov
The computation of the block offset of the the tape position (MTIOCPOS, MTIOCGET) is not influenced by the stages queued in the pipeline anymore but by the size of the current buffer which is going to be sent to the drive. [bart: resurrect deleted idetape_wait_for_pipeline() call] Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide-tape: remove pipeline-specific code in idetape_space_over_filemarks()Borislav Petkov
Since we don't do pipeline read-ahead anymore, we don't have to look for filemarks we have crossed. Therefore, remove the code chunk that does that and pass on the command to the tape. As a side effect, remove unused idetape_wait_first_stage(). Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide-tape: remove unused parameter from idetape_copy_stage_from_userBorislav Petkov
2008-04-27ide-tape: remove unused parameter from idetape_copy_stage_to_userBorislav Petkov
2008-04-27ide-tape: remove pipeline-specific code from idetape_add_chrdev_read_request()Borislav Petkov
In order to do away with queueing read requests on the pipeline, several things have to be done: 1. Do not allocate additional pipeline stages in idetape_init_read() until (tape->nr_stages < max_stages) and do only read operation preparations. As a collateral result, idetape_add_stage_tail() becomes unused so remove it. 2. Queue the read request's buffer directly thru idetape_queue_rw_tail(). 3. Remove now unused idetape_kmalloc_stage() and idetape_switch_buffers(). [bart: simplify the original patch] Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide-tape remove pipeline speed/control calculationsBorislav Petkov
Pipeline handling calculations in idetape_calculate_speeds() can go since they do not have any effect on other functionality besides: 1. info is only being exported through /proc as a read-only item (controlled_pipeline_head_speed, uncontrolled_pipeline_head_speed) 2. used in idetape_restart_speed_control() which, in turn, is unrelated to other code 3. used only for pipeline frames number accounting (tape->pipeline_head), also unused elsewhere. 4.some variables are: only written to: tape->buffer_head; unused: tape->tape_head, tape->last_tape_head Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide-tape: remove pipeline-specific code from idetape_add_chrdev_write_requestBorislav Petkov
Refrain from adding more write requests to the pipeline and queue them directly on the device's request queue instead. [bart: re-do for minimal behavior changes] Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide-tape: remove tape->cache_stageBorislav Petkov
Prior to allocating a new pipeline stage, the code checked for the existence of a cached pipeline stage to use. Do away with and stick to normal pipeline stages only. [bart: keep idetape_kmalloc_stage() for now] Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: add struct ide_dma_ops (take 3)Bartlomiej Zolnierkiewicz
Add struct ide_dma_ops and convert core code + drivers to use it. While at it: * Drop "ide_" prefix from ->ide_dma_end and ->ide_dma_test_irq methods. * Drop "ide_" "infixes" from DMA methods. * au1xxx-ide.c: - use auide_dma_{test_irq,end}() directly in auide_dma_timeout() * pdc202xx_old.c: - drop "old_" "infixes" from DMA methods * siimage.c: - add siimage_dma_test_irq() helper - print SATA warning in siimage_init_one() * Remove no longer needed ->init_hwif implementations. v2: * Changes based on review from Sergei: - s/siimage_ide_dma_test_irq/siimage_dma_test_irq/ - s/drive->hwif/hwif/ in idefloppy_pc_intr(). - fix patch description w.r.t. au1xxx-ide changes - fix au1xxx-ide build - fix naming for cmd64*_dma_ops - drop "ide_" and "old_" infixes - s/hpt3xxx_dma_ops/hpt37x_dma_ops/ - s/hpt370x_dma_ops/hpt370_dma_ops/ - use correct DMA ops for HPT302/N, HPT371/N and HPT374 - s/it821x_smart_dma_ops/it821x_pass_through_dma_ops/ v3: * Two bugs slipped in v2 (noticed by Sergei): - use correct DMA ops for HPT374 (for real this time) - handle HPT370/HPT370A properly Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide-tape: remove idetape_pipeline_active()Borislav Petkov
This function was simply a wrapper for a test_bit() macro so remove it and use the macro instead. Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: use generic ATAPI packet command flags in ide-{floppy,tape}Borislav Petkov
2008-04-18ide-tape: convert driver to using generic ide_atapi_pcBorislav Petkov
2008-04-18ide-tape: remove atomic test/set macros for packet commandsBorislav Petkov
Removing the atomic tests for pc's is unobjectionable. Since this driver will probably go to /dev/null soon, the atomic tests for tape->flags are left in place for there are some situations where they're needed (chrdev DSC handling, low level pipeline operation and so on). While at it, rename all test/set flag bit defines explicitly to *_FLAG_* for clarity. Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide-tape: move all struct and other defs at the topBorislav Petkov
Bart: - no need to move defines for tape flags around (they are completely rewritten by the next patch) Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: remove IDE_*_REG macrosBartlomiej Zolnierkiewicz
* Add IDE_{ALTSTATUS,IREASON,BCOUNTL,BCOUNTH}_OFFSET defines. * Remove IDE_*_REG macros - this results in more readable and slightly smaller code. There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: add ide_atapi_{discard_data,write_zeros} inline helpersBartlomiej Zolnierkiewicz
Add ide_atapi_{discard_data,write_zeros} inline helpers to <linux/ide.h> and use them instead of home-brewn helpers in ide-{floppy,tape,scsi}. There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-03-22Revert "ide-tape: schedule driver for removal after 6 months"Bartlomiej Zolnierkiewicz
This reverts commit d48567dd43868b3d2e1fcc33ee76dc2d38a1ddeb. Borislav is working on ide-tape "light" version instead. Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-26ide-tape: schedule driver for removal after 6 monthsBorislav Petkov
2008-02-11ide-tape: remove never executed codeBartlomiej Zolnierkiewicz
rq->cmd[0] is never set to REQ_IDETAPE_READ_BUFFER so remove REQ_IDETAPE_READ_BUFFER handling from idetape_create_write_cmd() and the define itself. Then remove no longer used idetape_create_read_buffer_cmd() and IDETAPE_RETRIEVE_FAULTY_BLOCK define. There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-06ide-tape: bump minor driver versionBorislav Petkov
2008-02-06ide-tape: cleanup the remaining codestyle issuesBorislav Petkov
... thus decreasing checkpatch.pl errors to 0. Bart: - remove needless function prototypes while at it - remove needless parentheses while at it - add missing KERN_ level to ide_tape_probe() - other minor fixups Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-06ide-tape: fix syntax error in idetape_identify_device()Borislav Petkov
Spotted by Sergei Shtylyov. CC: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-06ide-tape: remove leftover OnStream support warningBorislav Petkov
2008-02-06ide-tape: collect module-related macro calls at the endBorislav Petkov
2008-02-06ide-tape: include proper headersBorislav Petkov
2008-02-06ide-tape: remove unused "length" arg from idetape_create_read_buffer_cmd()Borislav Petkov
