path: root/drivers/ide/mips/swarm.c
2008-10-05IDE: Fix platform device registration in Swarm IDE driver (v2)Ralf Baechle
The Swarm IDE driver uses a release method which is defined in the driver itself thus potentially oopsable. The simple fix would be to just leak the device but this patch goes the full length and moves the entire handling of the platform device in the platform code and retains only the platform driver code in drivers/ide/mips/swarm.c. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: "Maciej W. Rozycki" <macro@linux-mips.org> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> [bart: remove no longer needed BLK_DEV_IDE_SWARM from ide/Kconfig] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-09-27Swarm: Fix crash due to missing initializationRalf Baechle
If things are just right this will result in the hws[0]->parent being passed to ide_host_add() being non-zero and an ooops a little later. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-23ide: add ide_host_add() helperBartlomiej Zolnierkiewicz
Add ide_host_add() helper which does ide_host_alloc()+ide_host_register(), then convert ide_setup_pci_device[s](), ide_legacy_device_add() and some host drivers to use it. While at it: * Fix ide_setup_pci_device[s](), ide_arm.c, gayle.c, ide-4drives.c, macide.c, q40ide.c, cmd640.c and cs5520.c to return correct error value. * -ENOENT -> -ENOMEM in rapide.c, ide-h8300.c, ide-generic.c, au1xxx-ide.c and pmac.c * -ENODEV -> -ENOMEM in palm_bk3710.c, ide_platform.c and delkin_cb.c * -1 -> -ENOMEM in ide-pnp.c Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-23ide: add struct ide_host (take 3)Bartlomiej Zolnierkiewicz
* Add struct ide_host which keeps pointers to host's ports. * Add ide_host_alloc[_all]() and ide_host_remove() helpers. * Pass 'struct ide_host *host' instead of 'u8 *idx' to ide_device_add[_all]() and rename it to ide_host_register[_all](). * Convert host drivers and core code to use struct ide_host. * Remove no longer needed ide_find_port(). * Make ide_find_port_slot() static. * Unexport ide_unregister(). v2: * Add missing 'struct ide_host *host' to macide.c. v3: * Fix build problem in pmac.c (s/ide_alloc_host/ide_host_alloc/) (Noticed by Stephen Rothwell). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-23ide: remove ->INB, ->OUTB and ->OUTBSYNC methodsBartlomiej Zolnierkiewicz
* Remove no longer needed ->INB, ->OUTB and ->OUTBSYNC methods. Then: * Remove no longer used default_hwif_[mm]iops() and ide_[mm_]outbsync(). * Cleanup SuperIO handling in ns87415.c. There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-23ide: pass hw_regs_t-s to ide_device_add[_all]() (take 3)Bartlomiej Zolnierkiewicz
* Add 'hw_regs_t **hws' argument to ide_device_add[_all]() and convert host drivers + ide_legacy_init_one() + ide_setup_pci_device[s]() to use it instead of calling ide_init_port_hw() directly. [ However if host has > 1 port we must still set hwif->chipset to hint consecutive ide_find_port() call that the previous slot is occupied. ] * Unexport ide_init_port_hw(). v2: * Use defines instead of hard-coded values in buddha.c, gayle.c and q40ide.c. (Suggested by Geert Uytterhoeven) * Better patch description. v3: * Fix build problem in ide-cs.c. (Noticed by Stephen Rothwell) There should be no functional changes caused by this patch. Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-16swarm: call ide_find_port_slot() laterBartlomiej Zolnierkiewicz
Move ide_find_port_slot() call closer to ide_device_add(). This is basically a preparation for the future changes. Cc: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-16ide: print message on error in ide_find_port_slot()Bartlomiej Zolnierkiewicz
* Add DRV_NAME define to ide-h8300.c. * Fix ide-h8300.c, swarm.c and sgiioc4.c to set .name field in struct ide_port_info to DRV_NAME, then convert these host drivers to use ide_find_port_slot() instead of ide_find_port(). * Print message on error in ide_find_port_slot(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-16swarm: use struct ide_port_infoBartlomiej Zolnierkiewicz
Convert the driver to use struct ide_port_info. There should be no functional changes caused by this patch. Acked-by: Maciej W. Rozycki <macro@linux-mips.org> Tested-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-05-14SWARM IDE: Fix up following changes to ide_hwif_tMaciej W. Rozycki
Following recent changes to ide_hwif_t update the SWARM IDE driver to use hw_regs_t to initialize port mapping. Plus minor layout adjustments along the lines of other drivers. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-28ide: add IDE_HFLAG_MMIO host flag (take 2)Bartlomiej Zolnierkiewicz
* Add IDE_HFLAG_MMIO host flag and set it for hosts which use default_hwif_mmiops(). v2: * Fix kernel panic in pmac host driver (',' should be '|'). Thanks to Kamalesh for reporting it + testing the fix and to Andrew for hinting me about the source of the issue. Cc: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide: add struct ide_io_ports (take 3)Bartlomiej Zolnierkiewicz
* Add struct ide_io_ports and use it instead of `unsigned long io_ports[]` in ide_hwif_t. * Rename io_ports[] in hw_regs_t to io_ports_array[]. * Use un-named union for 'unsigned long io_ports_array[]' and 'struct ide_io_ports io_ports' in hw_regs_t. * Remove IDE_*_OFFSET defines. v2: * scc_pata.c build fix from Stephen Rothwell. v3: * Fix ctl_adrr typo in Sparc-specific part of ns87415.c. (Noticed by Andrew Morton) Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: cleanup setting hwif->mmio flagBartlomiej Zolnierkiewicz
It is no longer needed to set hwif->mmio flag to tell IDE layer to not manage resources so cleanup host drivers that used hwif->mmio flag only for this purpose. Ditto for ide_legacy_init_one(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: remove ->noprobe field from ide_hwif_tBartlomiej Zolnierkiewicz
Update IDE PMAC host driver to use drive->noprobe instead of hwif->noprobe and remove hwif->noprobe completely (it is always set to zero now). There should be no functional changes caused by this patch. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26swarm: use ide_find_port()Bartlomiej Zolnierkiewicz
2008-02-02ide: add struct ide_port_info instances to legacy host driversBartlomiej Zolnierkiewicz
* Remove 'struct pci_dev *dev' argument from ide_hwif_setup_dma(). * Un-static ide_hwif_setup_dma() and add CONFIG_BLK_DEV_IDEDMA_PCI=n version. * Add 'const struct ide_port_info *d' argument to ide_device_add[_all](). * Factor out generic ports init from ide_pci_setup_ports() to ide_init_port(), move it to ide-probe.c and call it in in ide_device_add_all() instead of ide_pci_setup_ports(). * Move ->mate setup to ide_device_add_all() from ide_port_init(). * Add IDE_HFLAG_NO_AUTOTUNE host flag for host drivers that don't enable ->autotune currently. * Setup hwif->chipset in ide_init_port() but iff pi->chipset is set (to not override setup done by ide_hwif_configure()). * Add ETRAX host handling to ide_device_add_all(). * cmd640.c: set IDE_HFLAG_ABUSE_* also for CONFIG_BLK_DEV_CMD640_ENHANCED=n. * pmac.c: make pmac_ide_setup_dma() return an error value and move DMA masks setup to pmac_ide_setup_device(). * Add 'struct ide_port_info' instances to legacy host drivers, pass them to ide_device_add() calls and then remove open-coded ports initialization. Reviewed-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-26swarm: set hwif->chipsetBartlomiej Zolnierkiewicz
hwif->chipset should be set if the hwif is claimed by host driver. Cc: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-20ide: remove write-only hwif->hwBartlomiej Zolnierkiewicz
2007-10-20ide: add ide_device_add()Bartlomiej Zolnierkiewicz
* Add ide_device_add() helper and convert host drivers to use it instead of open-coded variants. * Make ide_pci_setup_ports() and do_ide_setup_pci_device() take 'u8 *idx' argument instead of 'ata_index_t *index'. * Remove no longer needed ata_index_t. * Unexport probe_hwif_init() and make it static. * Unexport ide_proc_register_port(). There should be no functionality changes caused by this patch (sgiioc4.c: ide_proc_register_port() requires hwif->present to be set and it won't be set if probe_hwif_init() fails). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10ide: add ide_proc_register_port()Bartlomiej Zolnierkiewicz
* create_proc_ide_interfaces() tries to add /proc entries for every probed and initialized IDE port, replace it by ide_proc_register_port() which does it only for the given port (also rename destroy_proc_ide_interface() to ide_proc_unregister_port() for consistency) * convert {create,destroy}_proc_ide_interface[s]() users to use new functions * pmac driver depended on proc_ide_create() to add /proc port entries, fix it * au1xxx-ide, swarm and cs5520 drivers depended indirectly on ide-generic driver (CONFIG_IDE_GENERIC=y) to add port /proc entries, fix them * there is now no need to add /proc entries for IDE ports in proc_ide_create() so don't do it * proc_ide_create() needs now to be called before drivers are probed - fix it, while at it make proc_ide_create() create /proc "ide" directory Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-02-17ide: convert ide_hwif_t.mmio into flag (v2)Bartlomiej Zolnierkiewicz
All users of ->mmio == 1 are gone so convert ->mmio into flag. Noticed by Alan Cox. v2: * updated for scc_pata Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2006-10-06[PATCH] swarm: Actually initialize the IDE driverMaciej W. Rozycki
This is required for the SWARM GenBus IDE interface to be recognized. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-17[IDE] Add driver for Sibyte Swarm evaluation boardRalf Baechle
This driver supports the IDE port on the Sibyte Swarm evaluation boards and it's relatives for the BCM1250 family of systems on a chip. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
