path: root/drivers/ide/pci/piix.c
2008-10-21ide: remove useless subdirs from drivers/ide/Bartlomiej Zolnierkiewicz
Suggested-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13piix: add Hercules EC-900 mini-notebook to ich_laptop short cable listHerton Ronaldo Krzesinski
Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: ->ide_dma_clear_irq() -> ->clear_irq()Bartlomiej Zolnierkiewicz
* Rename ->ide_dma_clear_irq method to ->clear_irq and move it from ide_hwif_t to struct ide_port_ops. * Move ->waiting_for_dma check inside ->clear_irq method. * Move ->dma_base check inside ->clear_irq method. piix.c: * Add ich_port_ops and remove init_hwif_ich() wrapper. There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: use unique names for struct pci_driver instancesBartlomiej Zolnierkiewicz
Noticed-by: Russell King <rmk+lkml@arm.linux.org.uk> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: add proper PCI PM support (v2)Bartlomiej Zolnierkiewicz
* Keep pointer to ->init_chipset method also in struct ide_host and set it in ide_host_alloc_all(). * Add ide_pci_suspend() and ide_pci_resume() helpers (default ->suspend and ->resume implementations). * ->init_chipset can no longer be marked __devinit. * Add proper PCI PM support to IDE PCI host drivers (rz1000.c and tc86c001.c are skipped for now since they need to be converted from using ->init_hwif to use ->init_chipset instead). v2: * Cleanup CONFIG_PM #ifdef-s per akpm's suggestion. Cc: Andrew Morton <akpm@linux-foundation.org> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: include <linux/hdreg.h> only when neededBartlomiej Zolnierkiewicz
* Include <linux/ata.h> directly in <linux/ide.h> instead of through <linux/hdreg.h>. * Include <linux/hdreg.h> only when needed. Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-08-05ide: ->cable_detect method cannot be marked __devinitBartlomiej Zolnierkiewicz
Now that we have warm-plug support ->cable_detect method no longer can be be marked __devinit. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24ide: drop 'name' parameter from ->init_chipset methodBartlomiej Zolnierkiewicz
There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24ide: prefix messages from IDE PCI host drivers by driver nameBartlomiej Zolnierkiewicz
Prefix messages from IDE PCI host drivers by driver name instead of marketed chipset name (it is still possible to exactly identify the particular chipset basing on driver messages). As a bonus this provides nice code savings for some drivers: text data bss dec hex filename 3826 112 8 3946 f6a drivers/ide/pci/amd74xx.o.before 2786 112 8 2906 b5a drivers/ide/pci/amd74xx.o.after 764 108 0 872 368 drivers/ide/pci/cs5520.o.before 680 108 0 788 314 drivers/ide/pci/cs5520.o.after 1680 112 4 1796 704 drivers/ide/pci/generic.o.before 1155 112 4 1271 4f7 drivers/ide/pci/generic.o.after 7128 792 0 7920 1ef0 drivers/ide/pci/hpt366.o.before 6984 792 0 7776 1e60 drivers/ide/pci/hpt366.o.after 2800 148 0 2948 b84 drivers/ide/pci/pdc202xx_new.o.before 2523 148 0 2671 a6f drivers/ide/pci/pdc202xx_new.o.after 2831 148 0 2979 ba3 drivers/ide/pci/pdc202xx_old.o.before 2683 148 0 2831 b0f drivers/ide/pci/pdc202xx_old.o.after 3776 112 4 3892 f34 drivers/ide/pci/piix.o.before 2804 112 4 2920 b68 drivers/ide/pci/piix.o.after 4693 116 0 4809 12c9 drivers/ide/pci/siimage.o.before 4600 116 0 4716 126c drivers/ide/pci/siimage.o.after Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24piix: add ->remove method and module_exit()Bartlomiej Zolnierkiewicz
2008-07-24ide: add ->dev and ->host_priv fields to struct ide_hostBartlomiej Zolnierkiewicz
* Add 'struct device *dev[2]' and 'void *host_priv' fields to struct ide_host. * Set ->dev[] in ide_host_alloc_all()/ide_setup_pci_device[s](). * Pass 'void *priv' argument to ide_setup_pci_device[s]() and use it to set ->host_priv. * Set PCI dev's ->driver_data to point to the struct ide_host instance if PCI host driver wants to use ->host_priv. * Rename ide_setup_pci_device[s]() to ide_pci_init_{one,two}(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-23ide: remove ->dma_{status,command} fields from ide_hwif_tBartlomiej Zolnierkiewicz
* Use ->dma_base + offset instead of ->dma_{status,command} and remove no longer needed ->dma_{status,command}. While at it: * Use ATA_DMA_* defines. There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-28piix: add Asus Eee 701 controller to short cable listBartlomiej Zolnierkiewicz
Based on ata_piix patch by Dan McGee. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: add struct ide_port_ops (take 2)Bartlomiej Zolnierkiewicz
* Move hooks for port/host specific methods from ide_hwif_t to 'struct ide_port_ops'. * Add 'const struct ide_port_ops *port_ops' to 'struct ide_port_info' and ide_hwif_t. * Update host drivers and core code accordingly. While at it: * Rename ata66_*() cable detect functions to *_cable_detect() to match the standard naming. (Suggested by Sergei Shtylyov) v2: * Fix build for bast-ide. (Noticed by Andrew Morton) Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: IDE_HFLAG_BOOTABLE -> IDE_HFLAG_NON_BOOTABLEBartlomiej Zolnierkiewicz
"bootable" should be the default behavior so replace IDE_HFLAG_BOOTABLE host flag with IDE_HFLAG_NON_BOOTABLE. There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-02ide: remove needless includes from PCI host driversBartlomiej Zolnierkiewicz
2008-02-02ide: add ->cable_detect method to ide_hwif_tBartlomiej Zolnierkiewicz
* Add ->cable_detect method to ide_hwif_t. * Call the new method in ide_init_port() if: - the host supports UDMA modes > UDMA2 ('hwif->ultra_mask & 78') - DMA initialization was successful (if hwif->dma_base is not set ide_init_port() sets hwif->ultra_mask to zero) - "idex=ata66" is not used ('hwif->cbl != ATA_CBL_PATA40_SHORT') * Convert PCI host drivers to use ->cable_detect method. While at it: * Factor out cable detection to separate functions (if not already done). * hpt366.c/it8213.c/slc90e66.c: - don't check cable type if "idex=ata66" is used * pdc202xx_new.c: - add __devinit tag to pdcnew_cable_detect() * pdc202xx_old.c: - rename pdc202xx_old_cable_detect() to pdc2026x_old_cable_detect() - add __devinit tag to pdc2026x_old_cable_detect() Reviewed-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide: delete filenames/versions from commentsBartlomiej Zolnierkiewicz
Delete filenames/versions from comments. I'm leaving decisions about adding DRV_VERSION defines and MODULE_VERSION()-s to maintainers of the respective drivers. While at it: * Remove unused VERSION define from ide.c. * Remove unused/stale DRV_VERSION define from au1xxx-ide.c. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide: keep pointer to struct device instead of struct pci_dev in ide_hwif_tBartlomiej Zolnierkiewicz
Keep pointer to struct device instead of struct pci_dev in ide_hwif_t. While on it: * Use *dev->dma_mask instead of pci_dev->dma_mask in ide_toggle_bounce(). There should be no functionality changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01piix: remove stale commentsBartlomiej Zolnierkiewicz
2008-01-25ide: add IDE_HFLAG_ABUSE_SET_DMA_MODE host flagBartlomiej Zolnierkiewicz
* Add IDE_HFLAG_ABUSE_SET_DMA_MODE host flag and use it to decide what to do with transfer modes < XFER_PIO_0 in ide_set_xfer_rate(). * Set IDE_HFLAG_ABUSE_SET_DMA_MODE in host drivers that need it (aec62xx, amd74xx, cs5520, cs5535, hpt34x, hpt366, pdc202xx_old, serverworks, tc86c001 and via82cxxx) and cleanup ->set_dma_mode methods in host drivers that don't (IDE core code guarantees that ->set_dma_mode will be called only for modes which are present in SWDMA/MWDMA/UDMA masks). While at it: * Add IDE_HFLAGS_HPT34X/HPT3XX/PDC202XX/SVWKS define in hpt34x/hpt366/pdc202xx_old/serverworks host driver. There should be no functionality changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-11-27piix: add HP compaq laptop to short cable listBartlomiej Zolnierkiewicz
Port of Jeff's libata commit 54174db300ee1bac632d62e4ac37fe02e47d1f18 ("[libata] ata_piix: add HP compaq laptop to short cable list"). Cc: Jeff Garzik <jeff@garzik.org> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-11-05piix: add support for ICH7 on Acer 5602aWLMisebdeg@ngi.it
In piix.c (and in ata_piix.c) are already included some patches to skip the cable check on some laptops and to enable UDMA > 33 modes, but I've noticed than theese doesn't work on my Acer Aspire 5602WLMi (maybe exist more versions of this laptop). With this simple patch I can set transfer mode to UDMA100. From: "sebdeg@ngi.it" <sebdeg@ngi.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-20ide: constify struct ide_port_infoBartlomiej Zolnierkiewicz
2007-10-20ide: replace ide_pci_device_t by struct ide_port_infoBartlomiej Zolnierkiewicz
* Rename struct ide_pci_device_s to struct ide_port_info. * Remove ide_pci_device_t typedef. While at it: * Fix __ide_pci_register_driver() comment. * Fix aec62xx_init_one() comment. * Remove unused 'cds' field from ide_hwgroup_t. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19ide: set drive->autotune in ide_pci_setup_ports()Bartlomiej Zolnierkiewicz
Majority of host drivers using IDE PCI layer set drive->autotune, the only exceptions are: generic.c ns87415.c rz1000.c trm290.c * no ->set_pio_mode method it821x.c: * if memory allocation fails drive->autotune won't be set (but there also won't be ->set_pio_mode method in such case) piix.c: * MPIIX controller (no ->init_hwif method so also no ->set_pio_mode method) However if there is no ->set_pio_mode method there are no changes in behavior w.r.t. PIO tuning so always set drive->autotune in ide_pci_setup_ports(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19ide: add IDE_HFLAG_LEGACY_IRQS host flagBartlomiej Zolnierkiewicz
Add IDE_HFLAG_LEGACY_IRQS host flag to tell ide_pci_setup_ports() to set hwif->irq to legacy IRQ 14/15 (iff hwif->irq is not already set) and convert atiixp, piix, serverworks, sis5513 and slc90e66 host drivers to use it. While at it: * In piix.c add IDE_HFLAGS_PIIX define and don't use ->init_hwif for MPIIX. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19piix: add DECLARE_ICH_DEV() macroBartlomiej Zolnierkiewicz
Add DECLARE_ICH_DEV() macro. While at it: * Add init_hwif_ich() (->init_hwif method) for ICH controllers. * Rename init_chipset_piix() to init_chipset_ich() and use it only for ICH controllers. * Remove no longer needed piix_is_ichx() helper. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19ide: use I/O ops directly part #2 (take 2)Bartlomiej Zolnierkiewicz
v2: - bump host driver versions (as suggested by Sergei) - use I/O ops directly in drivers/ide/setup-pci.c Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19ide: add ->mwdma_mask and ->swdma_mask to ide_pci_device_t (take 2)Bartlomiej Zolnierkiewicz
* Add ->mwdma_mask and ->swdma_mask to ide_pci_device_t. * Set ide_hwif_t DMA masks using DMA masks from ide_pci_device_t in setup-pci.c::ide_pci_setup_ports() (iff DMA base is valid and ->init_hwif method may still override them). * Convert IDE PCI host drivers to use ide_pci_device_t DMA masks. While at it: * Use ATA_{UDMA,MWDMA,SWDMA}* defines. * hpt34x.c: add separate ide_pci_device_t instances for HPT343 and HPT345. * serverworks.c: fix DMA masks being set before checking DMA base. v2: * Add missing masks to DECLARE_GENERIC_PCI_DEV() macro. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19ide: add IDE_HFLAG_NO_{DMA,AUTODMA} host flagsBartlomiej Zolnierkiewicz
Add IDE_HFLAG_NO_{DMA,AUTODMA} host flags. Convert all host drivers using ide_pci_device_t to use these flags instead of d->autodma and then remove no longer needed d->autodma. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19ide: add IDE_HFLAG_BOOTABLE host flagBartlomiej Zolnierkiewicz
Add IDE_HFLAG_BOOTABLE host flag and IDE_HFLAG_OFF_BOARD define. Convert all host drivers using ide_pci_device_t to use IDE_HFLAG_{BOOTABLE,OFF_BOARD} instead of d->bootable and then remove no longer needed d->bootable. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19ide: add IDE_HFLAG_NO_ATAPI_DMA host flagBartlomiej Zolnierkiewicz
Add IDE_HFLAG_NO_ATAPI_DMA host flag and set it in host drivers which don't support ATAPI DMA. Then remove no longer needed hwif->atapi_dma. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-16ide: remove hwif->autodma and drive->autodmaBartlomiej Zolnierkiewicz
* hpt34x.c: disable DMA masks for HPT345 (hwif->autodma is zero so DMA won't be enabled anyway). * trm290.c: disable IDE_HFLAG_TRUST_BIOS_FOR_DMA flag (hwif->autodma is zero so DMA won't be enabled anyway). * Check noautodma global variable instead of drive->autodma in ide_tune_dma(). This fixes handling of "ide=nodma" kernel parameter for icside, ide-cris, au1xxx-ide, pmac, it821x, jmicron, sgiioc4 and siimage host drivers. * Remove hwif->autodma (it was not checked by IDE core code anyway) and drive->autodma (was set by all host drivers - except HPT345/TRM290 special cases - unless "ide=nodma" was used). While at it: - remove needless printk() from icside.c - remove stale FIXME/comment from ide-probe.c - don't force DMA off if PCI bus-mastering had to be enabled in setup-pci.c (this setting was always later over-ridden by host drivers anyway) Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-16ide: use PCI_VDEVICE() macroBartlomiej Zolnierkiewicz
While at it: - make struct pci_device_id tables const - use PCI_DEVICE_ID_ITE_8213 define in it8213.c - fix comment in generic.c Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-16it8213/piix/slc90e66: "de-couple" PIO and UDMA modesBartlomiej Zolnierkiewicz
Don't force PIO4 when programming UDMA mode (suggested by Sergei). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-16ide: remove ->ide_dma_check (take 2)Bartlomiej Zolnierkiewicz
* Add IDE_HFLAG_TRUST_BIOS_FOR_DMA host flag for host drivers that depend on BIOS for programming device/controller for DMA. Set it in cy82c693, generic, ns87415, opti621 and trm290 host drivers. * Add IDE_HFLAG_VDMA host flag for host drivers using VDMA. Set it in cs5520 host driver. * Teach ide_tune_dma() about IDE_HFLAG_TRUST_BIOS_FOR_DMA flag. * Add generic ide_dma_check() helper and remove all open coded ->ide_dma_check implementations. Fix all places checking for presence of ->ide_dma_check hook to check for ->ide_dma_on instead. * Remove no longer needed code from config_drive_for_dma(). * Make ide_tune_dma() static. v2: * Fix config_drive_for_dma() return values. * Fix ide-dma.c build for CONFIG_BLK_DEV_IDEDMA_PCI=n by adding dummy config_drive_for_dma() inline. * Fix IDE_HFLAG_TRUST_BIOS_FOR_DMA handling in ide_dma_check(). * Fix init_hwif_it8213() comment. There should be no functionality changes caused by this patch. Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-16ide: remove ide_use_fast_pio()Bartlomiej Zolnierkiewicz
Remove ide_use_fast_pio() and just re-tune PIO unconditionally if DMA tuning has failed in ->ide_dma_check. All host drivers using ide_use_fast_pio() set drive->autotune so PIO is always tuned anyway and in some cases we _really_ need to re-tune PIO because PIO and DMA timings are shared. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-16ide: remove drive->init_speed zeroingBartlomiej Zolnierkiewicz
Several host drivers used to reset drive->init_speed in their ->ide_dma_check implementations which resulted in incorrect init speed being reported to the user, fix it. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-16it8213/piix/slc90e66: remove {it8213,piix,slc90e66}_dma_2_pio()Bartlomiej Zolnierkiewicz
2007-10-13ide: move ide_config_drive_speed() calls to upper layers (take 2)Bartlomiej Zolnierkiewicz
* Convert {ide_hwif_t,ide_pci_device_t}->host_flag to be u16. * Add IDE_HFLAG_POST_SET_MODE host flag to indicate the need to program the host for the transfer mode after programming the device. Set it in au1xxx-ide, amd74xx, cs5530, cs5535, pdc202xx_new, sc1200, pmac and via82cxxx host drivers. * Add IDE_HFLAG_NO_SET_MODE host flag to indicate the need to completely skip programming of host/device for the transfer mode ("smart" hosts). Set it in it821x host driver and check it in ide_tune_dma(). * Add ide_set_pio_mode()/ide_set_dma_mode() helpers and convert all direct ->set_pio_mode/->speedproc users to use these helpers. * Move ide_config_drive_speed() calls from ->set_pio_mode/->speedproc methods to callers. * Rename ->speedproc method to ->set_dma_mode, make it void and update all implementations accordingly. * Update ide_set_xfer_rate() comments. * Unexport ide_config_drive_speed(). v2: * Fix issues noticed by Sergei: - export ide_set_dma_mode() instead of moving ->set_pio_mode abuse wrt to setting DMA modes from sc1200_set_pio_mode() to do_special() - check IDE_HFLAG_NO_SET_MODE in ide_tune_dma() - check for (hwif->set_pio_mode) == NULL in ide_set_pio_mode() - check for (hwif->set_dma_mode) == NULL in ide_set_dma_mode() - return -1 from ide_set_{pio,dma}_mode() if ->set_{pio,dma}_mode == NULL - don't set ->set_{pio,dma}_mode on it821x in "smart" mode - fix build problem in pmac.c - minor fixes in au1xxx-ide.c/cs5530.c/siimage.c - improve patch description Changes in behavior caused by this patch: - HDIO_SET_PIO_MODE ioctl would now return -ENOSYS for attempts to change PIO mode if it821x controller is in "smart" mode - removal of two debugging printk-s (from cs5530.c and sc1200.c) - transfer modes 0x00-0x07 passed from user space may be programmed twice on the device (not really an issue since 0x00 is not supported correctly by any host driver ATM, 0x01 is not supported at all and 0x02-0x07 are invalid) Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-11ide: use only ->set_pio_mode method for programming PIO modes (take 2)Bartlomiej Zolnierkiewicz
Use ->set_pio_mode method to program PIO modes in ide_set_xfer_rate() (the only place which used ->speedproc to program PIO modes) and remove handling of PIO modes from all ->speedproc implementations. v2: * Fix pmac_ide_tune_chipset() comment. There should be no functionality changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-11it8213/piix/slc90e66: don't change DMA settings when programming PIOBartlomiej Zolnierkiewicz
2007-10-11ide: add ide_set{_max}_pio() (take 4)Bartlomiej Zolnierkiewicz
* Add IDE_HFLAG_ABUSE_{PREFETCH,FAST_DEVSEL,DMA_MODES} flags and set them in ht6560, cmd640, cmd64x and sc1200 host drivers. * Add set_pio_mode_abuse() for checking if host driver has a non-standard ->tuneproc() implementation and use it in do_special(). * Add ide_set_pio() for setting PIO mode (it uses hwif->pio_mask to find the maximum PIO mode supported by the host), also add ide_set_max_pio() wrapper for ide_set_pio() to use for auto-tuning. Convert users of ->tuneproc to use ide_set{_max}_pio() where possible. This leaves only do_special(), set_using_pio(), ide_hwif_restore() and ide_set_pio() as a direct users of ->tuneproc. * Remove no longer needed ide_get_best_pio_mode() calls and printk-s reporting PIO mode selected from ->tuneproc implementations. * Rename ->tuneproc hook to ->set_pio_mode and make 'pio' argument const. * Remove stale comment from ide_config_drive_speed(). v2: * Fix "ata_" prefix (Noticed by Jeff). v3: * Minor cleanups/fixups per Sergei's suggestions. v4: * Fix compile problem in drivers/ide/pci/cmd640.c (Noticed by Andrew Morton). * Improve some ->set_pio_mode comments. Reviewed-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-11ide: move ide_rate_filter() calls to the upper layer (take 2)Bartlomiej Zolnierkiewicz
* Move ide_rate_filter() calls from host drivers to IDE core. * Make ide_rate_filter() static. * Make 'speed' argument of ->speedproc const. v2: * Fix it8213_tune_chipset() comment. There should be no functionality changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-08-01piix/slc90e66: fix PIO1 handling in ->speedproc method (take 2)Bartlomiej Zolnierkiewicz
* Don't call {piix,slc90e66}_dma_2_pio() for PIO modes in {piix,slc90e66}_tune_chipset(). * Add PIO1 handling to {piix,slc90e66}_tune_chipset(). * Bump driver version. v2: * Remove PIO modes from {piix,slc90e66}_dma_2_pio(), they are no longer needed there (Noticed by Sergei) Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-20ide: add PIO masksBartlomiej Zolnierkiewicz
* Add ATA_PIO[0-6] defines to <linux/ata.h>. * Add ->pio_mask field to ide_pci_device_t and ide_hwif_t. * Add PIO masks to host drivers. <linux/ata.h> change ACK-ed by Jeff Garzik <jeff@garzik.org>. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-20ide: drop "PIO data" argument from ide_get_best_pio_mode()Bartlomiej Zolnierkiewicz
* Drop no longer needed "PIO data" argument from ide_get_best_pio_mode() and convert all users accordingly. * Remove no longer needed ide_pio_data_t. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-20ide: add ide_pci_device_t.host_flags (take 2)Bartlomiej Zolnierkiewicz
* Rename ide_pci_device_t.flags to ide_pci_device_t.host_flags and IDEPCI_FLAG_ISA_PORTS flag to IDE_HFLAG_ISA_PORTS. * Add IDE_HFLAG_SINGLE flag for single channel devices. * Convert core code and all IDE PCI drivers to use IDE_HFLAG_SINGLE and remove no longer needed ide_pci_device_t.channels field. v2: * Fix issues noticed by Sergei: - correct code alignment in scc_pata.c - s/IDE_HFLAG_SINGLE/~IDE_HFLAG_SINGLE/ in serverworks.c Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-11PCI: Change all drivers to use pci_device->revisionAuke Kok
Instead of all drivers reading pci config space to get the revision ID, they can now use the pci_device->revision member. This exposes some issues where drivers where reading a word or a dword for the revision number, and adding useless error-handling around the read. Some drivers even just read it for no purpose of all. In devices where the revision ID is being copied over and used in what appears to be the equivalent of hotpath, I have left the copy code and the cached copy as not to influence the driver's performance. Compile tested with make all{yes,mod}config on x86_64 and i386. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
