path: root/drivers/ide/pci
2008-10-21ide: remove useless subdirs from drivers/ide/Bartlomiej Zolnierkiewicz
Suggested-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-17scc_pata: kill unused variablesSergei Shtylyov
Fix the "unused variable" warning in init_hwif_scc() caused by the commit 48c3c1072651922ed153bcf0a33ea82cf20df390 (ide: add struct ide_host (take 3)). Moreover, remove the write-only variable 'dma_status_port' in init_setup_scc() about which gcc gives no warning and which has been there from the very start... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-17sgiioc4: kill duplicate ioremap()Sergei Shtylyov
By the time ide_dma_sgiioc4() gets called, sgiioc4_ide_setup_pci_device() will have called ioremap() on the whole BAR0 region, so calling ioremap() on the DMA registers means wasting a page. Replace this call by a mere address calculation, based on the fact that IRQ registers (pointed to by 'hwif->io_ports.irq_addr') are situated at offset 0 from BAR0. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: jeremy@sgi.com Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-17sgiioc4: kill useless address checksSergei Shtylyov
The driver performs a number of checks on the virtual/physical addresses which would always evaluate as true (except ide_dma_sgiioc4() -- always false): - for sgiioc4_init_hwif_ports(), its caller, sgiioc4_ide_setup_pci_device(), guarantees that 'ctrl_port' and 'irq_port' parameters are never 0; - in sgiioc4_read_status(), we always read the IDE status register, so there's no need to check the register's address (must be a leftover from the times when this function implemented the INB() method); - in ide_dma_sgiioc4(), 'dma_base' can never be 0 as IOC4_DMA_OFFSET is not 0. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: jeremy@sgi.com Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-17delkin_cb: add PM supportBartlomiej Zolnierkiewicz
* Factor out chipset initialization code from delkin_cb_probe() to delkin_cb_init_chipset(). * Assign ->init_chipset in struct delkin_cb_port_info. * Add delkin_cb_{suspend,resume}() (->suspend/->resume methods). Fixes kernel bugzilla bug #11735: http://bugzilla.kernel.org/show_bug.cgi?id=11735 Tested-by: bumble.bee@xs4all.nl Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-17ide: remove broken hpt34x driverBartlomiej Zolnierkiewicz
No big loss since HPT343/363 controllers are properly supported by pata_hpt3x3 driver from Alan Cox. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-17sgiioc4: remove maskproc() methodSergei Shtylyov
Since the maskproc() method calls either mirror the interrupt en/disable via the nIEN bit of the device control register done by the IDE core before issuing a command or unmask the interrupt after a command executed in polled mode (when interrupt is already not expected), it is pointless to implement this method by manipulating the nIEN bit... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: jeremy@sgi.com Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-17hpt366: cleanup maskproc() methodSergei Shtylyov
Since the maskproc() method calls either mirror the interrupt en/disable via the nIEN bit of the device control register done by the IDE core before issuing a command or unmask the interrupt after a command executed in polled mode (when interrupt is already not expected), it is pointless to manipulate the nIEN bit in this method; therefore, just do nothing for the drives not on the quirk list. Move the code to the left by using an early return and the 'else if' construct, while at it.... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> [bart: fix checkpatch.pl warning] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-17hpt366: fix compile warningBartlomiej Zolnierkiewicz
Fixup for commit 1785192b5310ee25165768f5bb80f13146788e3e ("hpt366: add hpt3xx_disable_fast_irq() helper"):    CC      drivers/ide/pci/hpt366.o drivers/ide/pci/hpt366.c: In function `init_hwif_hpt366': drivers/ide/pci/hpt366.c:1290: warning: unused variable `dev' Reported-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13piix: add Hercules EC-900 mini-notebook to ich_laptop short cable listHerton Ronaldo Krzesinski
Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: switch to DMA-mapping API part #2Bartlomiej Zolnierkiewicz
Follow-up to commit 5c05ff68b9a9b40a9be949497e0aa980185565cf ("ide: switch to DMA-mapping API"): * pci_{alloc,free}_consistent() -> dma_{alloc,free}_coherent() in ide_{allocate,release}_dma_engine(). * Add ->prd_max_nents and ->prd_ent_size fields to ide_hwif_t (+ set default values in ide_allocate_dma_engine()). * Make ide_{allocate,release}_dma_engine() available also for CONFIG_BLK_DEV_IDEDMA_SFF=n. Then convert au1xxx-ide.c, scc_pata.c and sgiioc4.c to use them. * Add missing ->init_dma method to scc_pata. This patch also fixes: - ->dmatable_cpu leak for au1xxx-ide - too early realease of ->dmatable_cpu for scc_pata - wrong amount of ->dmatable_cpu memory being freed for sgiioc4 While at it: - remove superfluous ->dma_base check from ide_unregister() - return -ENOMEM on error in ide_release_dma_engine() - beautify error message in ide_release_dma_engine() Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: __ide_dma_end() -> ide_dma_end()Bartlomiej Zolnierkiewicz
While at it: - use EXPORT_SYMBOL_GPL() to match the rest of SFF DMA functions Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: ->ide_dma_clear_irq() -> ->clear_irq()Bartlomiej Zolnierkiewicz
* Rename ->ide_dma_clear_irq method to ->clear_irq and move it from ide_hwif_t to struct ide_port_ops. * Move ->waiting_for_dma check inside ->clear_irq method. * Move ->dma_base check inside ->clear_irq method. piix.c: * Add ich_port_ops and remove init_hwif_ich() wrapper. There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: use unique names for struct pci_driver instancesBartlomiej Zolnierkiewicz
Noticed-by: Russell King <rmk+lkml@arm.linux.org.uk> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: remove [ata_]select_tBartlomiej Zolnierkiewicz
* Use 'drive->dn & 1' in ide_init_disk(). * remove [ata_]select_t. While at it: * Use ATA_DEVICE_OBS define in ide_port_init_devices_data(). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: use 'drive->dn & 1' instead of drive->select.b.unitBartlomiej Zolnierkiewicz
* Call ide_port_init_devices() in ide_host_register() also if 'struct ide_port_info *d' is not available. * Init drive->dn in ide_port_init_devices() instead of ide_probe_port() so it is valid also in ->init_dev. * Pass device number to ide_dev_apply_params(). * Use 'drive->dn & 1' instead of drive->select.b.unit. There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13cy82c693: remove no longer needed CY82C693_DEBUG_LOGS codeBartlomiej Zolnierkiewicz
Having CY82C693_DEBUG_INFO is enough nowadays. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13cy82c693: remove dead CY82C693_SETDMA_CLOCK codeBartlomiej Zolnierkiewicz
Remove dead CY82C693_SETDMA_CLOCK code and now not needed init_chipset_cy82c693(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: remove superfluous ->waiting_for_dma checksBartlomiej Zolnierkiewicz
2008-10-13ide: remove superfluous ->dma field from ide_hwif_tBartlomiej Zolnierkiewicz
2008-10-13ide: add device flagsBartlomiej Zolnierkiewicz
Add 'unsigned long dev_flags' to ide_drive_t and convert bitfields to IDE_DFLAG_* flags. While at it: - IDE_DFLAG_ADDRESSING -> IDE_DFLAG_LBA48 - fixup some comments - remove needless g->flags zeroing from ide*_probe() There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13sgiioc4: fix messagesSergei Shtylylov
Fix several issues with the log messages printed by ide_dma_sgiioc4() and sgiioc4_ide_setup_pci_device(): - IOC4 registers are memory-mapped but the "BM-DMA at" format corresponds to I/O mapped registers; - "%p" format specifiers and type casts used to print non-pointer values; - using KERN_INFO log level for the error message; - 'hwif->name' printed as drive's name. While at it, also: - return more fitting -EBUSY if request_mem_region() fails; - make the error message style consistent; - fix indentation, put the printk() facility and message on the same line; - use comparisions with NULL instead of ! operator.. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: jeremy@sgi.com Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13sgiioc4: sgiioc4_read_status drive busy check fixSergei Shtylylov
Fix the drive non-busy criterion used by sgiioc4_read_status(): neither of the bits it expects to be set guarantees that the drive is not busy (and might be interrupting), only the BSY bit itself being zero gurantees that. While at it, use ATA_BUSY instead of hardcoded value everywhere... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: jeremy@sgi.com Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: add proper PCI PM support (v2)Bartlomiej Zolnierkiewicz
* Keep pointer to ->init_chipset method also in struct ide_host and set it in ide_host_alloc_all(). * Add ide_pci_suspend() and ide_pci_resume() helpers (default ->suspend and ->resume implementations). * ->init_chipset can no longer be marked __devinit. * Add proper PCI PM support to IDE PCI host drivers (rz1000.c and tc86c001.c are skipped for now since they need to be converted from using ->init_hwif to use ->init_chipset instead). v2: * Cleanup CONFIG_PM #ifdef-s per akpm's suggestion. Cc: Andrew Morton <akpm@linux-foundation.org> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10hpt366: add hpt3xx_disable_fast_irq() helperBartlomiej Zolnierkiewicz
* Factor out disabling of "fast interrupt" prediction from init_hwif_hpt366() to hpt3xx_disable_fast_irq() helper. * Use hpt3xx_disable_fast_irq() in ->init_chipset instead of ->init_hwif method. This is a preparation for adding proper PCI PM support. While at it: * Cache chip type in chip_type variable in hpt3xx_disable_fast_irq(). There should be no functional changes caused by this patch. Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: ide_dev_is_sata() -> ata_id_is_sata()Bartlomiej Zolnierkiewicz
* Use optimized ATA version check from Sergei in ata_id_is_sata(). * ide_dev_is_sata() -> ata_id_is_sata() Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: ide_dev_has_iordy() -> ata_id_has_iordy()Bartlomiej Zolnierkiewicz
* Remove (id[ATA_ID_FIELD_VALID] & 2) check from ide_dev_has_iordy() (it is for validity of words 64-70, IORDY is in word 49). * ide_dev_has_iordy() -> ata_id_has_iordy() Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10cmd640: add __set_prefetch_mode()Bartlomiej Zolnierkiewicz
Factor out the common code from check_prefetch() and set_prefetch_mode() to __set_prefetch_mode(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: include <linux/hdreg.h> only when neededBartlomiej Zolnierkiewicz
* Include <linux/ata.h> directly in <linux/ide.h> instead of through <linux/hdreg.h>. * Include <linux/hdreg.h> only when needed. Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: check drive->present in ide_get_paired_drive()Bartlomiej Zolnierkiewicz
* Change ide_get_paired_drive() to return NULL if peer device is not present and update all users accordingly. While at it: * ide_get_paired_drive() -> ide_get_pair_dev() * Use ide_get_pair_dev() in cs5530.c, sc1200.c and via82cxxx.c. There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: use ATA_* defines instead of *_STAT and *_ERR onesBartlomiej Zolnierkiewicz
* ERR_STAT -> ATA_ERR * INDEX_STAT -> ATA_IDX * ECC_STAT -> ATA_CORR * DRQ_STAT -> ATA_DRQ * SEEK_STAT -> ATA_DSC * WRERR_STAT -> ATA_DF * READY_STAT -> ATA_DRDY * BUSY_STAT -> ATA_BUSY * MARK_ERR -> ATA_AMNF * TRK0_ERR -> ATA_TRK0NF * ABRT_ERR -> ATA_ABORTED * MCR_ERR -> ATA_MCR * ID_ERR -> ATA_IDNF * MC_ERR -> ATA_MC * ECC_ERR -> ATA_UNC * ICRC_ERR -> ATA_ICRC * BBD_ERR -> ATA_BBK Also: * ILI_ERR -> ATAPI_ILI * EOM_ERR -> ATAPI_EOM * LFS_ERR -> ATAPI_LFS * CD -> ATAPI_COD * IO -> ATAPI_IO Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: remove drive->driveidBartlomiej Zolnierkiewicz
* Factor out HDIO_[OBSOLETE,GET]_IDENTITY ioctls handling to ide_get_identity_ioctl(). * Use temporary buffer in ide_get_identity_ioctl() instead of accessing drive->id directly. * Add ide_id_to_hd_driveid() inline to convert raw id into struct hd_driveid format (needed on big-endian). * Use ide_id_to_hd_driveid() in ide_get_identity_ioctl(), cleanup ide_fix_driveid() and switch ide to use use raw id. * Remove no longer needed drive->driveid. This leaves us with 3 users of struct hd_driveid in tree: - arch/um/drivers/ubd_kern.c - drivers/block/xsysace.c - drivers/usb/storage/isd200.c While at it: * Use ata_id_u{32,64}() and ata_id_has_{dma,lba,iordy}() macros. There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: make drive->id an union (take 2)Bartlomiej Zolnierkiewicz
Make drive->id an unnamed union so id can be accessed either by using 'u16 *id' or 'struct hd_driveid *driveid'. Then convert all existing drive->id users accordingly (using 'u16 *id' when possible). This is an intermediate step to make ide 'struct hd_driveid'-free. While at it: - Add missing KERN_CONTs in it821x.c. - Use ATA_ID_WORDS and ATA_ID_*_LEN defines. - Remove unnecessary checks for drive->id. - s/drive_table/table/ in ide_in_drive_list(). - Cleanup ide_config_drive_speed() a bit. - s/drive1/dev1/ & s/drive0/dev0/ in ide_undecoded_slave(). v2: Fix typo in drivers/ide/ppc/pmac.c. (From Stephen Rothwell) There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-09-10ide: Fix pointer arithmetic in hpt3xx driver code (3rd try)Masoud Sharbiani
git commit 74811f355f4f69a187fa74892dcf2a684b84ce99 causes crash at module load (or boot) time on my machine with a hpt374 controller. The reason for this is that for initializing second controller which sets (hwif->dev == host->dev[1]) to true (1), adds 1 to a void ptr, which advances it by one byte instead of advancing it by sizeof(hpt_info) bytes. Because of this, all initialization functions get corrupted data in info variable which causes a crash at boot time. This patch fixes that and makes my machine boot again. The card itself is a HPT374 raid conroller: Here is the lspci -v output: 03:06.0 RAID bus controller: HighPoint Technologies, Inc. HPT374 (rev 07) Subsystem: HighPoint Technologies, Inc. Unknown device 0001 Flags: bus master, 66MHz, medium devsel, latency 120, IRQ 28 I/O ports at 8000 [size=8] I/O ports at 7800 [size=4] I/O ports at 7400 [size=8] I/O ports at 7000 [size=4] I/O ports at 6800 [size=256] Expansion ROM at fe8e0000 [disabled] [size=128K] Capabilities: [60] Power Management version 2 03:06.1 RAID bus controller: HighPoint Technologies, Inc. HPT374 (rev 07) Subsystem: HighPoint Technologies, Inc. Unknown device 0001 Flags: bus master, 66MHz, medium devsel, latency 120, IRQ 28 I/O ports at 9800 [size=8] I/O ports at 9400 [size=4] I/O ports at 9000 [size=8] I/O ports at 8800 [size=4] I/O ports at 8400 [size=256] Capabilities: [60] Power Management version 2 Signed-off-by: Masoud Sharbiani <masouds@google.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Andrew Morton <akpm@linux-foundation.org> [bart: use dev_get_drvdata() per Sergei's suggestion] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-08-18sgiioc4: fixup message on resource allocation failureBartlomiej Zolnierkiewicz
There can be more than one sgiioc4 card in the system so print also PCI device name on resource allocation failure (so we know which one is the problematic one). Reported-by: Jeremy Higdon <jeremy@sgi.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-08-18drivers/ide/pci/: use __devexit_p()Adrian Bunk
This patch adds missing __devexit_p's. Reported-by: Russell King <rmk+lkml@arm.linux.org.uk> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-08-05ide: ->cable_detect method cannot be marked __devinitBartlomiej Zolnierkiewicz
Now that we have warm-plug support ->cable_detect method no longer can be be marked __devinit. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-08-05ide: ->quirkproc method cannot be marked __devinitBartlomiej Zolnierkiewicz
Now that we have warm-plug support ->quirkproc method no longer can be be marked __devinit. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-08-05cs5520: add enablebits checkingBartlomiej Zolnierkiewicz
Based on sparse comments in OpenFirmware code (no Cx5510/Cx5520 datasheet here). This fixes 2.6.26 regression reported by TAKADA and caused by addition of warm-plug support. Tested-by: TAKADA Yoshihito <takada@mbf.nifty.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24ide: drop 'name' parameter from ->init_chipset methodBartlomiej Zolnierkiewicz
2008-07-24ide: prefix messages from IDE PCI host drivers by driver nameBartlomiej Zolnierkiewicz
Prefix messages from IDE PCI host drivers by driver name instead of marketed chipset name (it is still possible to exactly identify the particular chipset basing on driver messages). As a bonus this provides nice code savings for some drivers: text data bss dec hex filename 3826 112 8 3946 f6a drivers/ide/pci/amd74xx.o.before 2786 112 8 2906 b5a drivers/ide/pci/amd74xx.o.after 764 108 0 872 368 drivers/ide/pci/cs5520.o.before 680 108 0 788 314 drivers/ide/pci/cs5520.o.after 1680 112 4 1796 704 drivers/ide/pci/generic.o.before 1155 112 4 1271 4f7 drivers/ide/pci/generic.o.after 7128 792 0 7920 1ef0 drivers/ide/pci/hpt366.o.before 6984 792 0 7776 1e60 drivers/ide/pci/hpt366.o.after 2800 148 0 2948 b84 drivers/ide/pci/pdc202xx_new.o.before 2523 148 0 2671 a6f drivers/ide/pci/pdc202xx_new.o.after 2831 148 0 2979 ba3 drivers/ide/pci/pdc202xx_old.o.before 2683 148 0 2831 b0f drivers/ide/pci/pdc202xx_old.o.after 3776 112 4 3892 f34 drivers/ide/pci/piix.o.before 2804 112 4 2920 b68 drivers/ide/pci/piix.o.after 4693 116 0 4809 12c9 drivers/ide/pci/siimage.o.before 4600 116 0 4716 126c drivers/ide/pci/siimage.o.after Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24it821x: remove DECLARE_ITE_DEV() macroBartlomiej Zolnierkiewicz
While at it: * it821x_chipsets[] -> it821x_chipset. * Fix it821x_chipset's name field (as it is used for IT8211/8212). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24it8213: remove DECLARE_ITE_DEV() macroBartlomiej Zolnierkiewicz
While at it: * it8213_chipsets[] -> it8213_chipset. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24ide: include PCI device name in messages from IDE PCI host driversBartlomiej Zolnierkiewicz
While at it: * Apply small fixes to messages (s/dma/DMA/, remove trailing '.', etc). * Fix printk() call in ide_setup_pci_baseregs() to use KERN_INFO. * Move printk() call from ide_pci_clear_simplex() to the caller. * Cleanup do_ide_setup_pci_device() a bit. * amd74xx.c: remove superfluous PCI device revision information. * hpt366.c: fix two printk() calls in ->init_chipset to use KERN_INFO. * pdc202xx_new.c: fix printk() call in ->init_chipset to use KERN_INFO. * pdc202xx_old.c: fix driver message in pdc202xx_init_one(). * via82cxxx.c: fix driver warning message in via_init_one(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24via82cxxx: add ->remove method and module_exit()Bartlomiej Zolnierkiewicz
2008-07-24trm290: add ->remove method and module_exit()Bartlomiej Zolnierkiewicz
2008-07-24triflex: add ->remove method and module_exit()Bartlomiej Zolnierkiewicz
2008-07-24tc86c001: add ->remove method and module_exit()Bartlomiej Zolnierkiewicz
2008-07-24slc90e66: add ->remove method and module_exit()Bartlomiej Zolnierkiewicz
2008-07-24sl82c105: add ->remove method and module_exit()Bartlomiej Zolnierkiewicz
