[ Upstream commit ce1f31b4c0b9551dd51874dd5364654ed4ca13ae ]
The "drive->dn" variable is a u8 controlled by root.
Add SPDX license identifiers to all files which:
- Have no license information of any form
- Have MODULE_LICENCE("GPL*") inside which was used in the initial
scan/conversion to ignore the file
These files fall under the project license, GPL v2 only. The resulting SPDX
license identifier is:
GPL-2.0-only
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
__devinitconst, and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Change ->set_dma_mode method parameters to match ->set_dmamode method
used in struct ata_port_operations.
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Change ->set_pio_mode method parameters to match ->set_piomode method
* remove dead OSB4 UDMA support
* remove unreachable code
* make isa_dev local to ->init_chipset
* Return 0 instead of dev->irq in ->init_chipset implementations.
* Fix ->init_chipset method to return 'int' value instead of
'unsigned int' one.
This fixes ->init_chipset handling for host drivers (cs5530, hpt366
and pdc202xx_new) for which it is possible for this method to fail.
There should be no functional changes caused by this patch.
Suggested-by: Ralf Baechle <ralf@linux-mips.org>
