path: root/drivers/ide/sis5513.c
2010-01-19ide: change ->set_dma_mode method parametersBartlomiej Zolnierkiewicz
Change ->set_dma_mode method parameters to match ->set_dmamode method used in struct ata_port_operations. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2010-01-19ide: change ->set_pio_mode method parametersBartlomiej Zolnierkiewicz
Change ->set_pio_mode method parameters to match ->set_piomode method used in struct ata_port_operations. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03sis5513: remove stale TODOBartlomiej Zolnierkiewicz
2009-10-07sis5513: fix PIO setup for ATAPI devicesBartlomiej Zolnierkiewicz
Clear prefetch setting before potentially (re-)enabling it in config_drive_art_rwp() so the transition of the device type on the port from ATA to ATAPI (i.e. during warm-plug operation) is handled correctly. This is a really old bug (it probably goes back to very early days of the driver) but it was only affecting warm-plug operation until the recent "ide: try to use PIO Mode 0 during probe if possible" change (commit 6029336426a2b43e4bc6f4a84be8789a047d139e). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Tested-by: David Fries <david@fries.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-24ide: fix ->init_chipset method to return 'int' valueBartlomiej Zolnierkiewicz
* Return 0 instead of dev->irq in ->init_chipset implementations. * Fix ->init_chipset method to return 'int' value instead of 'unsigned int' one. This fixes ->init_chipset handling for host drivers (cs5530, hpt366 and pdc202xx_new) for which it is possible for this method to fail. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-24ide: remove no longer needed IDE_HFLAG[_FORCE]_LEGACY_IRQSBartlomiej Zolnierkiewicz
There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06ide: remove HWIF() macroBartlomiej Zolnierkiewicz
2008-10-21ide: remove useless subdirs from drivers/ide/Bartlomiej Zolnierkiewicz
Suggested-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
