path: root/drivers/ide
2010-05-05pata_pcmcia / ide-cs: Fix bad hashes for Transcend and kingston IDsKristoffer Ericson
This patch fixes the bad hashes for one Kingston and one Transcend card. Thanks to komuro for pointing this out. Signed-off-by: Kristoffer Ericson <kristoffer.ericson@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-04-22pata_pcmcia/ide-cs: add IDs for transcend and kingston cardsKristoffer Ericson
This patch adds idstrings for Kingston 1GB/4GB and Transcend 4GB/8GB. Signed-off-by: Kristoffer Ericson <kristoffer.ericson@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-04-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/ide-2.6: ide: Fix IDE taskfile with cfq scheduler ide: Must hold queue lock when requeueing ide: Requeue request after DMA timeout
2010-04-06ide: Fix IDE taskfile with cfq schedulerMikulas Patocka
When ide taskfile access is being used (for example with hdparm --security commands) and cfq scheduler is selected, the scheduler crashes on BUG in cfq_put_request. The reason is that the cfq scheduler is tracking counts of read and write requests separately; the ide-taskfile subsystem allocates a read request and then flips the flag to make it a write request. The counters in cfq will mismatch. This patch changes ide-taskfile to allocate the READ or WRITE request as required and don't change the flag later. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-01ide: Must hold queue lock when requeueingHerbert Xu
ide-atapi requeues requests without holding the queue lock. This patch fixes it by using ide_requeue_and_plug. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-01ide: Requeue request after DMA timeoutHerbert Xu
I noticed that my KVM virtual machines were experiencing IDE issues resulting in processes stuck on waiting for buffers to complete. The root cause is of course race conditions in the ancient qemu backend that I'm using. However, the fact that the guest isn't recovering is a bug. I've tracked it down to the change made last year to dequeue requests at the start rather than at the end in the IDE layer. commit 8f6205cd572fece673da0255d74843680f67f879 Author: Tejun Heo <tj@kernel.org> Date: Fri May 8 11:53:59 2009 +0900 ide: dequeue in-flight request The problem is that the function ide_dma_timeout_retry does not requeue the current request, causing one request to be lost for each DMA timeout. This patch fixes this by requeueing the request. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-28Revert "ide: skip probe if there are no devices on the port (v2)"David S. Miller
This reverts commit a20b2a44eca52818ef52a94959480b7e6ea2f528. As requested by David Fries. This makes CDROMs which are slave drives on a ribbon without a master disappear and causes other similar kinds of badness. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-27Revert "via82cxxx: workaround h/w bugs"David S. Miller
This reverts commit f931a5d5785d7b7c44871bd7ad2762e29dfddf29. It causes regressions for some users. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/ide-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/ide-next-2.6: (49 commits) drivers/ide: Fix continuation line formats ide: fixed section mismatch warning in cmd640.c ide: ide_timing_compute() fixup ide: make ide_get_best_pio_mode() static via82cxxx: use ->pio_mode value to determine pair device speed tx493xide: use ->pio_mode value to determine pair device speed siimage: use ->pio_mode value to determine pair device speed palm_bk3710: use ->pio_mode value to determine pair device speed it821x: use ->pio_mode value to determine pair device speed cs5536: use ->pio_mode value to determine pair device speed cs5535: use ->pio_mode value to determine pair device speed cmd64x: fix handling of address setup timings amd74xx: use ->pio_mode value to determine pair device speed alim15x3: fix handling of UDMA enable bit alim15x3: fix handling of DMA timings alim15x3: fix handling of command timings alim15x3: fix handling of address setup timings ide-timings: use ->pio_mode value to determine fastest PIO speed ide: change ->set_dma_mode method parameters ide: change ->set_pio_mode method parameters ...
2010-03-02Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/ide-2.6
2010-03-01Merge branch 'acpica' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'acpica' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: ACPI: replace acpi_integer by u64 ACPICA: Update version to 20100121. ACPICA: Remove unused uint32_struct type ACPICA: Disassembler: Remove obsolete "Integer64" field in parse object ACPICA: Remove obsolete ACPI_INTEGER (acpi_integer) type ACPICA: Predefined name repair: fix NULL package elements ACPICA: AcpiGetDevices: Eliminate unnecessary _STA calls ACPICA: Update all ACPICA copyrights and signons to 2010 ACPICA: Update for new gcc-4 warning options
2010-03-01Merge branch 'for-2.6.34' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.34' of git://git.kernel.dk/linux-2.6-block: (38 commits) block: don't access jiffies when initialising io_context cfq: remove 8 bytes of padding from cfq_rb_root on 64 bit builds block: fix for "Consolidate phys_segment and hw_segment limits" cfq-iosched: quantum check tweak blktrace: perform cleanup after setup error blkdev: fix merge_bvec_fn return value checks cfq-iosched: requests "in flight" vs "in driver" clarification cciss: Fix problem with scatter gather elements in the scsi half of the driver cciss: eliminate unnecessary pointer use in cciss scsi code cciss: do not use void pointer for scsi hba data cciss: factor out scatter gather chain block mapping code cciss: fix scatter gather chain block dma direction kludge cciss: simplify scatter gather code cciss: factor out scatter gather chain block allocation and freeing cciss: detect bad alignment of scsi commands at build time cciss: clarify command list padding calculation cfq-iosched: rethink seeky detection for SSDs cfq-iosched: rework seeky detection block: remove padding from io_context on 64bit builds block: Consolidate phys_segment and hw_segment limits ...
2010-02-27MIPS: Alchemy: change dbdma to accept physical memory addressesManuel Lauss
DMA can only be done from physical addresses; move the "virt_to_phys" source/destination buffer address translation from the dbdma queueing functions (since the hardware can only DMA to/from physical addresses) to their respective users. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-02-27MIPS: Alchemy: remove dbdma compat macrosManuel Lauss
Remove dbdma compat macros, move remaining users over to default queueing functions and -flags. (Queueing function signature has changed in order to give a build failure instead of silent functional changes due to the no longer implicitly specified DDMA_FLAGS_IE flag) Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-02-26block: Consolidate phys_segment and hw_segment limitsMartin K. Petersen
Except for SCSI no device drivers distinguish between physical and hardware segment limits. Consolidate the two into a single segment limit. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-02-26block: Rename blk_queue_max_sectors to blk_queue_max_hw_sectorsMartin K. Petersen
The block layer calling convention is blk_queue_<limit name>. blk_queue_max_sectors predates this practice, leading to some confusion. Rename the function to appropriately reflect that its intended use is to set max_hw_sectors. Also introduce a temporary wrapper for backwards compability. This can be removed after the merge window is closed. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-02-03drivers/ide: Fix continuation line formatsJoe Perches
String constants that are continued on subsequent lines with \ are not good. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-28ide: fixed section mismatch warning in cmd640.cChris Frey
Signed-off-by: Chris Frey <cdfrey@foursquare.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-28ACPI: replace acpi_integer by u64Lin Ming
acpi_integer is now obsolete and removed from the ACPICA code base, replaced by u64. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-01-19ide: ide_timing_compute() fixupBartlomiej Zolnierkiewicz
XFER_SW_DMA_0 mode should be excluded from the extended cycle timing computations. [ This is just a documentation fix -- code inside the affected 'if' block already makes sure to accept only PIO modes. ] Noticed-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19ide: make ide_get_best_pio_mode() staticBartlomiej Zolnierkiewicz
2010-01-19via82cxxx: use ->pio_mode value to determine pair device speedBartlomiej Zolnierkiewicz
Use the current PIO mode value instead of the current transfer speed of the pair device on the port to determine PIO commmand timings used for both devices on the port. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19tx493xide: use ->pio_mode value to determine pair device speedBartlomiej Zolnierkiewicz
Use the current PIO mode value instead of the physical maximum one of the pair device on the port to determine PIO commmand timings used for both devices on the port. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19siimage: use ->pio_mode value to determine pair device speedBartlomiej Zolnierkiewicz
2010-01-19palm_bk3710: use ->pio_mode value to determine pair device speedBartlomiej Zolnierkiewicz
2010-01-19it821x: use ->pio_mode value to determine pair device speedBartlomiej Zolnierkiewicz
2010-01-19cs5536: use ->pio_mode value to determine pair device speedBartlomiej Zolnierkiewicz
2010-01-19cs5535: use ->pio_mode value to determine pair device speedBartlomiej Zolnierkiewicz
2010-01-19cmd64x: fix handling of address setup timingsBartlomiej Zolnierkiewicz
Account for the requirements of the DMA mode currently used. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19amd74xx: use ->pio_mode value to determine pair device speedBartlomiej Zolnierkiewicz
2010-01-19alim15x3: fix handling of UDMA enable bitBartlomiej Zolnierkiewicz
Clear UDMA enable bit also for PIO modes. Based on libata pata_ali host driver. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19alim15x3: fix handling of DMA timingsBartlomiej Zolnierkiewicz
Stop depending on the BIOS setup. Based on libata pata_ali host driver. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19alim15x3: fix handling of command timingsBartlomiej Zolnierkiewicz
2010-01-19alim15x3: fix handling of address setup timingsBartlomiej Zolnierkiewicz
Account for the requirements of the other device on the port. Based on libata pata_ali host driver. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19ide-timings: use ->pio_mode value to determine fastest PIO speedBartlomiej Zolnierkiewicz
Use the current PIO mode value instead of the physical maximum one to determine the fastest allowed PIO for shared PIO/DMA timings. Affected host drivers: amd74xx and via82cxxx. [ Update comment to match -DaveM ] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19ide: change ->set_dma_mode method parametersBartlomiej Zolnierkiewicz
Change ->set_dma_mode method parameters to match ->set_dmamode method used in struct ata_port_operations. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2010-01-19ide: change ->set_pio_mode method parametersBartlomiej Zolnierkiewicz
Change ->set_pio_mode method parameters to match ->set_piomode method used in struct ata_port_operations. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19ide: add drive->dma_mode fieldBartlomiej Zolnierkiewicz
Add dma_mode field to ide_drive_t matching dma_mode field used in struct ata_device. The validity of the field is restricted to ->dma_pio_mode method only currently in IDE subsystem. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19ide: add drive->pio_mode fieldBartlomiej Zolnierkiewicz
Add pio_mode field to ide_drive_t matching pio_mode field used in struct ata_device. The validity of the field is restricted to ->set_pio_mode method only currently in IDE subsystem. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19via82cxxx: fix UDMA settings programmingBartlomiej Zolnierkiewicz
* preserve 80-wire cable detection bit * don't clear UDMA settings when programming PIO/MWDMA modes Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19via82cxxx: add support for VT6415 PCIE PATA IDE Host ControllerBartlomiej Zolnierkiewicz
Based on commits 5955c7a and 7d948b1 for pata_via host driver. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19via82cxxx: add support for vt8261 and future chipsBartlomiej Zolnierkiewicz
Based on commit e4d866c for pata_via host driver. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19via82cxxx: workaround h/w bugsBartlomiej Zolnierkiewicz
Add custom struct ide_tp_ops instance to fix the internal bug of some VIA chipsets which will reset the device register after changing the nIEN bit in the device control register. Based on commit bfce5e0 for pata_via host driver. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19via82cxxx: fix SATA cable detectionBartlomiej Zolnierkiewicz
Add VIA_SATA_PATA flag for cx700, vx800 and vx855 chipsets (the first port is SATA). Based on commits 7585eb1, bfce5e0 and e4d866c for pata_via host driver. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19ide: add SATA cable detection supportBartlomiej Zolnierkiewicz
2010-01-19via82cxxx: vx855 is a single channel controllerBartlomiej Zolnierkiewicz
Based on commit e4d866c for pata_via host driver (PCI ID was later changed by commit 5993856). Update my credits while at it. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19serverworks: add missing pci_dev_put() callBartlomiej Zolnierkiewicz
2010-01-19serverworks: cleanup svwks_udma_filter()Bartlomiej Zolnierkiewicz
* remove dead OSB4 UDMA support * remove unreachable code * make isa_dev local to ->init_chipset Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19pdc202xx_old: add ->init_hwif methodBartlomiej Zolnierkiewicz
