path: root/drivers/ide
2006-06-26[PATCH] ata: add some NVIDIA chipset IDsRandy Dunlap
From: Randy Dunlap <randy.dunlap@oracle.com> Add some nVidia chipset ID's support. http://www.kernel.org/git/?p=linux/kernel/git/bcollins/ubuntu-dapper.git;a=commitdiff;h=b407680553280f9999a20706d5ab2a3be65312c1;hp=ce4cb48010ab2cca537432b5ccb47d4b1fb489e5 Snagged from lkml. Cc: Jeff Garzik <jeff@garzik.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-06-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: typo fixes Clean up 'inline is not at beginning' warnings for usb storage Storage class should be first i386: Trivial typo fixes ixj: make ixj_set_tone_off() static spelling fixes fix paniced->panicked typos Spelling fixes for Documentation/atomic_ops.txt move acknowledgment for Mark Adler to CREDITS remove the bouncing email address of David Campbell
2006-06-26[PATCH] Remove code that has long been commented out from pdc20265_oldTobias Oed
Signed-off-by: Tobias Oed <tobiasoed@hotmail.com> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] pdc202xx_old depends on CONFIG_BLK_DEV_IDEDMATobias Oed
The driver pdc202xx_old requires CONFIG_BLK_DEV_IDEDMA, so it's always defined Signed-off-by: Tobias Oed <tobiasoed@hotmail.com> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] fix IDE deadlock in error reporting codeIngo Molnar
Michal Piotrowski reported the following validator assert: hdd: set_drive_speed_status: status=0x51 { DriveReady SeekComplete Error } hdd: set_drive_speed_status: error=0xb4 { AbortedCommand LastFailedSense=0x0b } ============================ [ BUG: illegal lock usage! ] ---------------------------- illegal {in-hardirq-W} -> {hardirq-on-W} usage. hdparm/1821 [HC0[0]:SC0[0]:HE1:SE1] takes: (ide_lock){++..}, at: [<c0268388>] ide_dump_opcode+0x13/0x9b [...] stack backtrace: [<c0104513>] show_trace+0x1b/0x20 [<c01045f1>] dump_stack+0x1f/0x24 [<c013976c>] print_usage_bug+0x1a5/0x1b1 [<c0139e90>] mark_lock+0x2ca/0x4f7 [<c013aa96>] __lockdep_acquire+0x47e/0xaa4 [<c013b536>] lockdep_acquire+0x67/0x7f [<c030552d>] _spin_lock+0x24/0x32 [<c0268388>] ide_dump_opcode+0x13/0x9b [<c02688b6>] ide_dump_status+0x4a6/0x4cc [<c0267ae6>] ide_config_drive_speed+0x32a/0x33a [<c0262dc5>] piix_tune_chipset+0x2ed/0x2f8 [<c0262e31>] piix_config_drive_xfer_rate+0x61/0xb5 [<c0263a82>] set_using_dma+0x2f/0x60 [<c0263bee>] ide_write_setting+0x4a/0xc3 [<c02647ca>] generic_ide_ioctl+0x8a/0x47f [<f886003a>] idecd_ioctl+0xfd/0x133 [ide_cd] [<c01f1fff>] blkdev_driver_ioctl+0x4b/0x5f [<c01f2783>] blkdev_ioctl+0x770/0x7bd [<c017dc0d>] block_ioctl+0x1f/0x21 [<c0189353>] do_ioctl+0x27/0x6e [<c0189604>] vfs_ioctl+0x26a/0x280 [<c0189667>] sys_ioctl+0x4d/0x7e [<c0305ed2>] sysenter_past_esp+0x63/0xa1 in ide_dump_opcode() takes the ide_lock in an irq-unsafe manner, i.e. this function expects to be called with irqs disabled. But ide_dump_ata[pi]_status() doesnt do that - it enables interrupts specifically. That is a no-no - what guarantees that another IDE port couldnt generate an IDE interrupt while we are dumping this error? The fix is to turn the irq-enabling in these functions into irq-disabling. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] ide: pdc202xx_old: remove the obsolete busprocSergei Shtylyov
Remove the busproc from pdc202xx_old.c because: - it handles the obsolete HDIO_TRISTATE_HWIF ioctl instead of the modern HDIO_SET_BUSSTATE, so treats its argument wrong; - I don't think that tristating both channels is good idea (probably can't be done otherwise since there seems to be only single bit controlling this). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] ide: actually honor drive's minimum PIO/DMA cycle timesSergei Shtylyov
The function ide_timing_compute() fails to *actually* take drive's specified minimum PIO/DMA cycle times into account -- when doing this, it calls ide_timing_merge() on the 'struct ide_timing' argument which contains garbage at the moment, and then ultimately destroys the read cycle time by quantizing the ide_timing[] entry, instead of copying from that entry to the argument structure, and only then doing a merge/quantize. Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] ide-io: increase timeout value to allow for slave wakeupAl Boldi
During an STR resume cycle, the ide master disk times-out when there is also a slave present (especially CD). Increasing the timeout in ide-io from 10,000 to 100,000 fixes this problem. Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] Fix IDE locking errorAlan Cox
This bit us a few kernels ago, and for some reason never made it's way upstream. https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=144743 Kernel panic - not syncing: drivers/ide/pci/piix.c:231: spin_lock(drivers/ide/ide.c:c03cef28) already locked by driver/ide/ide-iops.c/1153. Signed-off-by: Dave Jones <davej@redhat.com> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Dave Jones <davej@redhat.com> Cc: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] ide: pdc202xx_old.c: remove unneeded tuneproc() callTobias Oed
Remove a call to hwif->tuneproc() on the error path of config_chipset_for_dma(), as its single caller (pdc202xx_config_drive_xfer_rate()) will do the call in that case. Signed-off-by: Tobias Oed <tobiasoed@hotmail.com> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26spelling fixesAndreas Mohr
acquired (aquired) contiguous (contigious) successful (succesful, succesfull) surprise (suprise) whether (weather) some other misspellings Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-25[PATCH] ide-floppy: fix debug-only syntax errorRandy Dunlap
Fix debug-only printk syntax error. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] IDE CD end-of media error fixAlan Cox
This is a patch from Alan that fixes a real ide-cd.c regression causing bogus "Media Check" failures for perfectly valid Fedora install ISOs, on certain CD-ROM drives. This is a forward port to 2.6.16 (from RHEL) of the minimal changes for the end of media problem. It may not be sufficient for some controllers (promise notably) and it does not touch the locking so the error path locking is as horked as in mainstream. From: Ingo Molnar <mingo@elte.hu> I have ported the patch to 2.6.17-rc4 and tested it by provoking end-of-media IO errors with an unaligned ISO image. Unlike the vanilla kernel, the patched kernel interpreted the error condition correctly with 512 byte granularity: hdc: command error: status=0x51 { DriveReady SeekComplete Error } hdc: command error: error=0x54 { AbortedCommand LastFailedSense=0x05 } ide: failed opcode was: unknown ATAPI device hdc: Error: Illegal request -- (Sense key=0x05) Illegal mode for this track or incompatible medium -- (asc=0x64, ascq=0x00) The failed "Read 10" packet command was: "28 00 00 04 fb 78 00 00 06 00 00 00 00 00 00 00 " end_request: I/O error, dev hdc, sector 1306080 Buffer I/O error on device hdc, logical block 163260 Buffer I/O error on device hdc, logical block 163261 Buffer I/O error on device hdc, logical block 163262 the unpatched kernel produces an incorrect error dump: hdc: command error: status=0x51 { DriveReady SeekComplete Error } hdc: command error: error=0x54 { AbortedCommand LastFailedSense=0x05 } ide: failed opcode was: unknown end_request: I/O error, dev hdc, sector 1306080 Buffer I/O error on device hdc, logical block 163260 hdc: command error: status=0x51 { DriveReady SeekComplete Error } hdc: command error: error=0x54 { AbortedCommand LastFailedSense=0x05 } ide: failed opcode was: unknown end_request: I/O error, dev hdc, sector 1306088 Buffer I/O error on device hdc, logical block 163261 hdc: command error: status=0x51 { DriveReady SeekComplete Error } hdc: command error: error=0x54 { AbortedCommand LastFailedSense=0x05 } ide: failed opcode was: unknown end_request: I/O error, dev hdc, sector 1306096 Buffer I/O error on device hdc, logical block 163262 I do not have the right type of CD-ROM drive to reproduce the end-of-media data corruption bug myself, but this same patch in RHEL solved it. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Jens Axboe <axboe@suse.de> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] idetape gcc 4.1 warning fixDaniel Walker
In both the read and write cases it will return an error if copy_{from/to}_user faults. However, I let the driver try to read/write as much as it can just as it normally would , then finally it returns an error if there was one. This was the most straight forward way to handle the error , since there isn't a clear way to clean up the buffers on error . I moved retval in idetape_chrdev_write() down into the actual code blocks since it's really once used there, and it conflicted with my ret variable. Fixes the following warning, drivers/ide/ide-tape.c: In function ‘idetape_copy_stage_from_user’: drivers/ide/ide-tape.c:2662: warning: ignoring return value of ‘copy_from_user’, declared with attribute warn_unused_result drivers/ide/ide-tape.c: In function ‘idetape_copy_stage_to_user’: drivers/ide/ide-tape.c:2689: warning: ignoring return value of ‘copy_to_user’, declared with attribute warn_unused_result Signed-off-by: Daniel Walker <dwalker@mvista.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev: (258 commits) [libata] conversion to new debug scheme, part 1 of $N [PATCH] libata: Add ata_scsi_dev_disabled [libata] Add host lock to struct ata_port [PATCH] libata: implement per-dev EH action mask eh_info->dev_action[] [PATCH] libata-dev: move the CDB-intr DMA blacklisting [PATCH] ahci: disable NCQ support on vt8251 [libata] ahci: add JMicron PCI IDs [libata] sata_nv: add PCI IDs [libata] ahci: Add NVIDIA PCI IDs. [PATCH] libata: convert several bmdma-style controllers to new EH, take #3 [PATCH] sata_via: convert to new EH, take #3 [libata] sata_nv: s/spin_lock_irqsave/spin_lock/ in irq handler [PATCH] sata_nv: add hotplug support [PATCH] sata_nv: convert to new EH [PATCH] sata_nv: better irq handlers [PATCH] sata_nv: simplify constants [PATCH] sata_nv: kill struct nv_host_desc and nv_host [PATCH] sata_nv: kill not-working hotplug code [libata] Update docs to reflect current driver API [PATCH] libata: add host_set->next for legacy two host_sets case, take #3 ...
2006-06-23[PATCH] Get rid of struct request request_pm_state memberJens Axboe
The IDE power management can just use the ->end_io_data member to store it's data. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-06-23[PATCH] More BUG_ON conversionEric Sesterhenn
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: James Bottomley <James.Bottomley@steeleye.com> Acked-by: "Salyzyn, Mark" <mark_salyzyn@adaptec.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] SGI IOC4: Detect IO card variantBrent Casavant
There are three different IO cards which an SGI IOC4 controller may find itself on. One of these variants does not bring out the IDE and serial signals, so we need to disable attaching the corresponding IOC4 subdrivers to such cards. Cleans up message clutter emitted during device probing. Signed-off-by: Brent Casavant <bcasavan@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] m68k: completely initialize hw_regs_t in ide_setup_portsRoman Zippel
ide_setup_ports does not completely initialize the hw_regs_t structure which can cause random failures, as the structure is often on the stack. None of the callers expect a partially initialized structure, i.e. none of them do any setup of their own before calling ide_setup_ports(). Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] Fix cdrom being confused on using kdumpRachita Kothiyal
I have seen the cdrom drive appearing confused on using kdump on certain x86_64 systems. During the booting up of the second kernel, the following message would keep flooding the console, and the booting would not proceed any further. hda: cdrom_pc_intr: The drive appears confused (ireason = 0x01) In this patch, whenever we are hitting a confused state in the interrupt handler with the DRQ set, we end the request and return ide_stopped. Using this I dont see the status error. Signed-off-by: Rachita Kothiyal <rachita@in.ibm.com> Acked-by: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-22Merge branch 'master' into upstreamJeff Garzik
Conflicts: drivers/scsi/libata-core.c drivers/scsi/libata-scsi.c include/linux/pci_ids.h
2006-06-20[SPARC]: Kill __irq_itoa().David S. Miller
This ugly hack was long overdue to die. It was a way to print out Sparc interrupts in a more freindly format, since IRQ numbers were arbitrary opaque 32-bit integers which vectored into PIL levels. These 32-bit integers were not necessarily in the 0-->NR_IRQS range, but the PILs they vectored to were. The idea now is that we will increase NR_IRQS a little bit and use a virtual<-->real IRQ number mapping scheme similar to PowerPC. That makes this IRQ printing hack irrelevant, and furthermore only a handful of drivers actually used __irq_itoa() making it even less useful. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-11Merge branch 'upstream-fixes' into upstreamJeff Garzik
Conflicts: drivers/scsi/sata_sil24.c
2006-05-31[PATCH] sgiioc4: use mmio ops instead of port ioJeremy Higdon
From: Jeremy Higdon <jeremy@sgi.com> This patch fixes a bug in sgiioc4 where it was using the default IDE port I/O operations instead of MMIO. The IDE part of the IOC4 chip uses MMIO to map the chip registers. Unfortunately, the sgiioc4 driver uses the default port IO operations, which happens to have worked for the past few years. That's about to change, however, thus this change from inX/outX to readX/writeX. Signed-off-by: Jeremy Higdon <jeremy@sgi.com> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-24[PATCH] sata_nv: Add MCP61 supportAndrew Chew
Added MCP61 SATA support to sata_nv. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-05-21[PATCH] powerpc: Fix ide-pmac sysfs entryBenjamin Herrenschmidt
It looks like the generic ide code now wants ide_init_hwif_ports() to set the parent struct device into the ide_hw structure (new field ?). Without this, the mac ide code can cause the ide probing code to explode in flames in sysfs registration due to what looks like a stale pointer in there (happens when removing/re-inserting one of the hotswap media bays on some laptops). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-15[PATCH] ide_cs: Add IBM microdrive to known IDsThomas Kleffel
Add the IBM microdrive to the known PCMCIA IDs for ide_cs. Signed-off-by: Thomas Kleffel <tk@maintech.de> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-19[PATCH] alim15x3: ULI M-1573 south Bridge supportKAI.HSU
From http://bugzilla.kernel.org/show_bug.cgi?id=6358 The alim15x3.c havn't been update for 3 years. Recently when we use this "ULI M1573" south bridge chip found that can't mount CDROM(VCD) smoothly, must waiting for a long time. After I check the "ULI M1573" south bridge datasheet, I found the reason. The reason is the "ULI M1573" version in the Linux is "0xC7" not "0xC4" anymore So I was modified the source than it was successed. Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-19[PATCH] remove the obsolete IDEPCI_FLAG_FORCE_PDCAdrian Bunk
Noted by Sergei Shtylylov <sshtylyov@ru.mvista.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-19[PATCH] ide: ATI SB600 IDE supportAnatoli Antonovitch
Add support for the IDE device on ATI SB600 Signed-off-by: Felix Kuehling <fkuehlin@ati.com> Acked-by: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-02Merge master.kernel.org:/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: (33 commits) [PATCH] pcmcia: declare pccard_iodyn_ops (fix m8xx_pcmcia.c compilation error) [PATCH] pcmcia: fix pcmcia_device_remove oops [PATCH] pcmcia: Add support for Possio GCC AKA PCMCIA Siemens MC45 [PATCH] pcmcia: pseudo device handling update [PATCH] pcmcia: convert DEV_OK to pcmcia_dev_present [PATCH] pcmcia: use bitfield instead of p_state and state [PATCH] pcmcia: remove unused p_dev->state flags [PATCH] pcmcia: make pcmcia_release_{io,irq} static [PATCH] pcmcia: add return value to _config() functions [PATCH] pcmcia: remove dev_link_t and client_handle_t indirection [PATCH] pcmcia: embed dev_link_t into struct pcmcia_device [PATCH] pcmcia: rename pcmcia_device.state [PATCH] pcmcia: remove unneeded Vcc pseudo setting [PATCH] pcmcia: remove export of pcmcia_release_configuration [PATCH] pcmcia: default suspend and resume handling [PATCH] pcmcia: convert remaining users of pcmcia_release_io and _irq [PATCH] pcmcia: add pcmcia_disable_device [PATCH] serial_cs: add Merlin U630 IDs [PATCH] pcmcia: AT91RM9200 Compact Flash driver [PATCH] pcmcia: socket.functions starts with 1 ...
2006-03-31[PATCH] LED: Add IDE disk activity LED triggerRichard Purdie
Add an LED trigger for IDE disk activity to the ide-disk driver. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Acked-by: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] Ensure ide-taskfile calls any driver specific end_request functionRichard Purdie
Ensure ide-taskfile.c calls any driver specific end_request function if present. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] pcmcia: use bitfield instead of p_state and stateDominik Brodowski
Instead of the two status values struct pcmcia_device->p_state and state, use descriptive bitfields. Most value-checking in drivers was invalid, as the core now only calls the ->remove() (a.k.a. detach) function in case the attachement _and_ configuration was successful. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: add return value to _config() functionsDominik Brodowski
Most of the driver initialization isn't done in the .probe function, but in the internal _config() functions. Make them return a value, so that .probe can properly report whether the probing of the device succeeded or not. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: remove dev_link_t and client_handle_t indirectionDominik Brodowski
dev_link_t * and client_handle_t both mean struct pcmcai_device * by now. Therefore, remove all such indirections. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: embed dev_link_t into struct pcmcia_deviceDominik Brodowski
Embed dev_link_t into struct pcmcia_device(), as they basically address the same entity. The actual contents of dev_link_t will be cleaned up step by step. This patch includes a bugfix from and signed-off-by Andrew Morton. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: remove unneeded Vcc pseudo settingDominik Brodowski
As we do not allow setting Vcc in the pcmcia core, and Vpp1 and Vpp2 can only be set to the same value, a lot of code can be streamlined. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: default suspend and resume handlingDominik Brodowski
In all but one case, the suspend and resume functions of PCMCIA drivers contain mostly of calls to pcmcia_release_configuration() and pcmcia_request_configuration(). Therefore, move this code out of the drivers and into the core. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: add pcmcia_disable_deviceDominik Brodowski
pcmcia_disable_device(struct pcmcia_device *p_dev) performs the necessary cleanups upon device or driver removal: it calls the appropriate pcmcia_release_* functions, and can replace (most) of the current drivers' _release() functions. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-29Merge ../linux-2.6Paul Mackerras
2006-03-28[PATCH] ide-tape: use time_after(), time_after_eq()Marcelo Feitoza Parisi
They deal with wrapping correctly and are nicer to read. Signed-off-by: Marcelo Feitoza Parisi <marcelo@feitoza.com.br> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] ide_generic_all_on() warning fixAndrew Morton
drivers/ide/pci/generic.c:45: warning: `ide_generic_all_on' defined but not used Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Small fixes backported to old IDE SiS driverAlan Cox
Some quick backport bits from the libata PATA work to fix things found in the sis driver. The piix driver needs some fixes too but those are way to large and need someone working on old IDE with time to do them. This patch fixes the case where random bits get loaded into SIS timing registers according to the description of the correct behaviour from Vojtech Pavlik. It also adds the SiS5517 ATA16 chipset which is not currently supported by the driver. Thanks to Conrad Harriss for loaning me the machine with the 5517 chipset. Signed-off-by: Alan Cox <alan@redhat.com> Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] ide: AMD756 no host side cable detectionRene Herman
>From http://marc.theaimsgroup.com/?l=linux-kernel&m=110304128900342&w=2 AMD756 doesn't support host side cable detection. Do disk side only and don't advice obsolete options. Acked-by: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] powerpc: Kill _machine and hard-coded platform numbersBenjamin Herrenschmidt
This removes statically assigned platform numbers and reworks the powerpc platform probe code to use a better mechanism. With this, board support files can simply declare a new machine type with a macro, and implement a probe() function that uses the flattened device-tree to detect if they apply for a given machine. We now have a machine_is() macro that replaces the comparisons of _machine with the various PLATFORM_* constants. This commit also changes various drivers to use the new macro instead of looking at _machine. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-27[PATCH] ide-cd: quiet down GPCMD_READ_CDVD_CAPACITY failureJens Axboe
Some drives like to throw a: ATAPI device hdc: Error: Not ready -- (Sense key=0x02) Incompatible medium installed -- (asc=0x30, ascq=0x00) The failed "Read Cd/Dvd Capacity" packet command was: "25 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 " warning on incompatible media, so quiet down this error. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-03-25[PATCH] ide: fix section mismatch warningSam Ravnborg
In latest -mm ide-code.o gave a number of warnings like the following: WARNING: drivers/ide/ide-core.o - Section mismatch: reference to \ .init.text: from .text between 'init_module' (at offset 0x1f97) and \ 'cleanup_module' The warning was caused by init_module() calling parse_option() and ide_init() both declared __init. Declaring init_module() __init fixes the warnings. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] ide: Allow IDE interface to specify its not capable of 32-bit operationsKumar Gala
In some embedded systems the IDE hardware interface may only support 16-bit or smaller accesses. Allow the interface to specify if this is the case and don't allow the drive or user to override the setting. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] s/;;/;/gAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
