commit f8ff6c732d35904d773043f979b844ef330c701b upstream.
Fixes: ec7d9c9ce8 ("ide: replace ->proc_fops with ->proc_show")
Reported-by: kernel test robot <lkp@intel.com>
Use DEFINE_SHOW_ATTRIBUTE macro to simplify the code.
Signed-off-by: Yangtao Li <tiny.windzz@gmail.com>
use of_node_put() to release the refcount.
Update device_add_disk() to take an 'groups' argument so that
individual drivers can register a device with additional sysfs
attributes.
This avoids race condition the driver would otherwise have if these
groups were to be created with sysfs_add_groups().
Signed-off-by: Martin Wilck <martin.wilck@suse.com>
Signed-off-by: Hannes Reinecke <hare@suse.com>
Reviewed-by: Bart Van Assche <bvanassche@acm.org>
Pull IDE updates from David Miller:
- Remove redundant variables (Colin Ian King)
- Expected switch fall-through annotations (Gustavo A. R. Silva)
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/ide:
ide: mark expected switch fall-throughs
ide-tape: remove redundant variable buffer_size
ide: remove redundant variables queue_run_ms and left
In preparation to enabling -Wimplicit-fallthrough, mark switch cases
where we are expecting to fall through.
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
Variable buffer_size is being assigned but is never used hence it is
redundant and can be removed.
Cleans up clang warning:
warning: variable 'buffer_size' set but not used [-Wunused-but-set-variable]
Variable queue_run_ms is not being used and is redundant and hence can
be removed. Removing this also means that variable left can also be
removed.
warning: variable ‘queue_run_ms’ set but not used [-Wunused-but-set-variable]
This is already able to process the sense buffer, so remove the redundant
parsing during the failure path. This also fixes any possible stale values
since the prior code did not check the sense length.
There is a lot of needless struct request_sense usage in the CDROM
code. These can all be struct scsi_sense_hdr instead, to avoid any
confusion over their respective structure sizes. This patch is a lot
of noise changing "sense" to "sshdr", but the final code is more
readable to distinguish between "sense" meaning "struct request_sense"
and "sshdr" meaning "struct scsi_sense_hdr".
This drops unused sense buffers from:
cdrom_eject()
cdrom_read_capacity()
cdrom_read_tocentry()
ide_cd_lockdoor()
ide_cd_read_toc()
The kzalloc() function has a 2-factor argument form, kcalloc(). This
patch replaces cases of:
kzalloc(a * b, gfp)
with:
kcalloc(a * b, gfp)
as well as handling cases of:
kzalloc(a * b * c, gfp)
with:
kzalloc(array3_size(a, b, c), gfp)
as it's slightly less ugly than:
kzalloc_array(array_size(a, b), c, gfp)
This does, however, attempt to ignore constant size factors like:
kzalloc(4 * 1024, gfp)
though any constants defined via macros get caught up in the conversion.
Any factors with a sizeof() of "unsigned char", "char", and "u8" were
dropped, since they're redundant.
The Coccinelle script used for this was:
// Fix redundant parens around sizeof().
type TYPE;
expression THING, E;
kzalloc(
- (sizeof(TYPE)) * E
+ sizeof(TYPE) * E
kzalloc(
- (sizeof(THING)) * E
+ sizeof(THING) * E
// Drop single-byte sizes and redundant parens.
expression COUNT;
typedef u8;
typedef __u8;
kzalloc(
- sizeof(u8) * (COUNT)
+ COUNT
kzalloc(
- sizeof(__u8) * (COUNT)
+ COUNT
kzalloc(
- sizeof(char) * (COUNT)
+ COUNT
kzalloc(
- sizeof(unsigned char) * (COUNT)
+ COUNT
kzalloc(
- sizeof(u8) * COUNT
+ COUNT
kzalloc(
- sizeof(__u8) * COUNT
+ COUNT
kzalloc(
- sizeof(char) * COUNT
+ COUNT
kzalloc(
- sizeof(unsigned char) * COUNT
+ COUNT
// 2-factor product with sizeof(type/expression) and identifier or constant.
type TYPE;
expression THING;
identifier COUNT_ID;
constant COUNT_CONST;
- kzalloc
+ kcalloc
- sizeof(TYPE) * (COUNT_ID)
+ COUNT_ID, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * COUNT_ID
- kzalloc
+ kcalloc
- sizeof(TYPE) * (COUNT_CONST)
+ COUNT_CONST, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * COUNT_CONST
- kzalloc
+ kcalloc
- sizeof(THING) * (COUNT_ID)
+ COUNT_ID, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * COUNT_ID
- kzalloc
+ kcalloc
- sizeof(THING) * (COUNT_CONST)
+ COUNT_CONST, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * COUNT_CONST
// 2-factor product, only identifiers.
identifier SIZE, COUNT;
- kzalloc
+ kcalloc
- SIZE * COUNT
+ COUNT, SIZE
// 3-factor product with 1 sizeof(type) or sizeof(expression), with
// redundant parens removed.
expression THING;
identifier STRIDE, COUNT;
type TYPE;
kzalloc(
- sizeof(TYPE) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(TYPE))
kzalloc(
- sizeof(TYPE) * (COUNT) * STRIDE
kzalloc(
- sizeof(TYPE) * COUNT * (STRIDE)
kzalloc(
- sizeof(TYPE) * COUNT * STRIDE
kzalloc(
- sizeof(THING) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(THING))
kzalloc(
- sizeof(THING) * (COUNT) * STRIDE
kzalloc(
- sizeof(THING) * COUNT * (STRIDE)
kzalloc(
- sizeof(THING) * COUNT * STRIDE
// 3-factor product with 2 sizeof(variable), with redundant parens removed.
expression THING1, THING2;
identifier COUNT;
type TYPE1, TYPE2;
kzalloc(
- sizeof(TYPE1) * sizeof(TYPE2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2))
kzalloc(
- sizeof(TYPE1) * sizeof(THING2) * (COUNT)
kzalloc(
- sizeof(THING1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(THING1), sizeof(THING2))
kzalloc(
- sizeof(THING1) * sizeof(THING2) * (COUNT)
kzalloc(
- sizeof(TYPE1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(THING2))
kzalloc(
// 3-factor product, only identifiers, with redundant parens removed.
identifier STRIDE, SIZE, COUNT;
kzalloc(
- (COUNT) * STRIDE * SIZE
+ array3_size(COUNT, STRIDE, SIZE)
kzalloc(
- COUNT * (STRIDE) * SIZE
kzalloc(
- COUNT * STRIDE * (SIZE)
kzalloc(
- (COUNT) * (STRIDE) * SIZE
kzalloc(
- COUNT * (STRIDE) * (SIZE)
kzalloc(
- (COUNT) * STRIDE * (SIZE)
kzalloc(
- (COUNT) * (STRIDE) * (SIZE)
kzalloc(
- COUNT * STRIDE * SIZE
// Any remaining multi-factor products, first at least 3-factor products,
// when they're not all constants...
expression E1, E2, E3;
constant C1, C2, C3;
kzalloc(C1 * C2 * C3, ...)
kzalloc(
- (E1) * E2 * E3
+ array3_size(E1, E2, E3)
kzalloc(
- (E1) * (E2) * E3
kzalloc(
- (E1) * (E2) * (E3)
kzalloc(
- E1 * E2 * E3
// And then all remaining 2 factors products when they're not all constants,
// keeping sizeof() as the second factor argument.
expression THING, E1, E2;
type TYPE;
kzalloc(sizeof(THING) * C2, ...)
kzalloc(sizeof(TYPE) * C2, ...)
kzalloc(C1 * C2, ...)
- kzalloc
+ kcalloc
- sizeof(TYPE) * (E2)
+ E2, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * E2
+ E2, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(THING) * (E2)
+ E2, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * E2
+ E2, sizeof(THING)
- kzalloc
+ kcalloc
- (E1) * E2
+ E1, E2
- kzalloc
+ kcalloc
- (E1) * (E2)
+ E1, E2
- kzalloc
+ kcalloc
- E1 * E2
+ E1, E2
The kmalloc() function has a 2-factor argument form, kmalloc_array(). This
kmalloc(a * b, gfp)
with:
kmalloc_array(a * b, gfp)
kmalloc(a * b * c, gfp)
with:
kmalloc(array3_size(a, b, c), gfp)
kmalloc_array(array_size(a, b), c, gfp)
kmalloc(4 * 1024, gfp)
The tools/ directory was manually excluded, since it has its own
implementation of kmalloc().
type TYPE;
kmalloc(
+ sizeof(TYPE) * E
kmalloc(
+ sizeof(THING) * E
expression COUNT;
typedef u8;
typedef __u8;
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
type TYPE;
expression THING;
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- SIZE * COUNT
+ COUNT, SIZE
expression THING;
type TYPE;
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
identifier COUNT;
type TYPE1, TYPE2;
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(C1 * C2 * C3, ...)
kmalloc(
- (E1) * E2 * E3
kmalloc(
- (E1) * (E2) * E3
kmalloc(
kmalloc(
- E1 * E2 * E3
type TYPE;
kmalloc(sizeof(THING) * C2, ...)
kmalloc(sizeof(TYPE) * C2, ...)
kmalloc(C1 * C2, ...)
- kmalloc
+ kmalloc_array
+ E2, sizeof(TYPE)
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * E2
+ E2, sizeof(TYPE)
- kmalloc
+ kmalloc_array
+ E2, sizeof(THING)
- kmalloc
+ kmalloc_array
+ E2, sizeof(THING)
- kmalloc
+ kmalloc_array
- (E1) * E2
+ E1, E2
- kmalloc
+ kmalloc_array
- (E1) * (E2)
+ E1, E2
- kmalloc
+ kmalloc_array
- E1 * E2
+ E1, E2
The interrupts are enabled/disabled so the interrupt handler can run
with enabled interrupts while serving the interrupt and not lose other
interrupts especially the timer tick.
If the system runs with force-threaded interrupts then there is no need
to enable the interrupts.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
ide_pio_bytes() disables interrupts around kmap_atomic(). This is a
leftover from the old kmap_atomic() implementation which relied on fixed
mapping slots, so the caller had to make sure that the same slot could not
be reused from an interrupting context.
kmap_atomic() was changed to dynamic slots long ago and commit 1ec9c5ddc17a
("include/linux/highmem.h: remove the second argument of k[un]map_atomic()")
removed the slot assignements, but the callers were not checked for now
redundant interrupt disabling.
Remove the conditional interrupt disable.
ide_timer_expiry() disables interrupt at function entry when acquiring
hwif->lock. Before disabling the device interrupt it unlocks hwif->lock,
but interrupts stay disabled. After the call to disable_irq() interrupts
are disabled again, which is a pointless exercise.
After the device irq handler has been invoked with interrupts disabled,
hwif->lock is acquired again with spin_lock_irq() because the device irq
handler might have reenabled interrupts. This is not documented and
confusing for the casual reader.
Remove the redundant local_irq_disable() and add a comment which explains
why hwif->lock has to be reacquired with spin_lock_irq().
init_chipset_ali15x3() initializes the chipset during init with disabled
interrupts. There is no need to keep the interrupts disabled during
pci_dev_put().
Move the irq-restore before pci_dev_put() is invoked.
Side note: The same init is performed in
drivers/ata/pata_ali.c::ali_init_chipset() without disabled interrupts.
It looks that the same hardware is supported in the ATA land. Would it
make sense to remove this driver since it is supported in the other
subsystem?
Pull dma-mapping updates from Christoph Hellwig:
- replace the force_dma flag with a dma_configure bus method. (Nipun
Gupta, although one patch is іncorrectly attributed to me due to a
git rebase bug)
- use GFP_DMA32 more agressively in dma-direct. (Takashi Iwai)
- remove PCI_DMA_BUS_IS_PHYS and rely on the dma-mapping API to do the
right thing for bounce buffering.
- move dma-debug initialization to common code, and apply a few
cleanups to the dma-debug code.
- cleanup the Kconfig mess around swiotlb selection
- swiotlb comment fixup (Yisheng Xie)
- a trivial swiotlb fix. (Dan Carpenter)
- support swiotlb on RISC-V. (based on a patch from Palmer Dabbelt)
- add a new generic dma-noncoherent dma_map_ops implementation and use
it for arc, c6x and nds32.
- improve scatterlist validity checking in dma-debug. (Robin Murphy)
- add a struct device quirk to limit the dma-mask to 32-bit due to
bridge/system issues, and switch x86 to use it instead of a local
hack for VIA bridges.
- handle devices without a dma_mask more gracefully in the dma-direct
code.
* tag 'dma-mapping-4.18' of git://git.infradead.org/users/hch/dma-mapping: (48 commits)
dma-direct: don't crash on device without dma_mask
nds32: use generic dma_noncoherent_ops
nds32: implement the unmap_sg DMA operation
nds32: consolidate DMA cache maintainance routines
x86/pci-dma: switch the VIA 32-bit DMA quirk to use the struct device flag
x86/pci-dma: remove the explicit nodac and allowdac option
x86/pci-dma: remove the experimental forcesac boot option
Documentation/x86: remove a stray reference to pci-nommu.c
core, dma-direct: add a flag 32-bit dma limits
dma-mapping: remove unused gfp_t parameter to arch_dma_alloc_attrs
dma-debug: check scatterlist segments
c6x: use generic dma_noncoherent_ops
arc: use generic dma_noncoherent_ops
arc: fix arc_dma_{map,unmap}_page
arc: fix arc_dma_sync_sg_for_{cpu,device}
arc: simplify arc_dma_sync_single_for_{cpu,device}
dma-mapping: provide a generic dma-noncoherent implementation
dma-mapping: simplify Kconfig dependencies
riscv: add swiotlb support
riscv: only enable ZONE_DMA32 for 64-bit
Pull procfs updates from Al Viro:
"Christoph's proc_create_... cleanups series"
* 'hch.procfs' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (44 commits)
xfs, proc: hide unused xfs procfs helpers
isdn/gigaset: add back gigaset_procinfo assignment
proc: update SIZEOF_PDE_INLINE_NAME for the new pde fields
tty: replace ->proc_fops with ->proc_show
ide: remove ide_driver_proc_write
isdn: replace ->proc_fops with ->proc_show
atm: switch to proc_create_seq_private
atm: simplify procfs code
bluetooth: switch to proc_create_seq_data
netfilter/x_tables: switch to proc_create_seq_private
netfilter/xt_hashlimit: switch to proc_create_{seq,single}_data
neigh: switch to proc_create_seq_data
hostap: switch to proc_create_{seq,single}_data
bonding: switch to proc_create_seq_data
rtc/proc: switch to proc_create_single_data
drbd: switch to proc_create_single
resource: switch to proc_create_seq_data
staging/rtl8192u: simplify procfs code
jfs: simplify procfs code
Just set up the show callback in the tty_operations, and use
proc_create_single_data to create the file without additional
boilerplace code.
The driver proc file hasn't been writeable for a long time, so this is
just dead code.
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
Same numerical value (for now at least), but a much better documentation
of intent.
Reviewed-by: Hannes Reinecke <hare@suse.com>
Switch everyone to blk_get_request_flags, and then rename
blk_get_request_flags to blk_get_request.
We now have ways to deal with drainage in the block layer, and libata has
been using it for ages. We also want to get rid of PCI_DMA_BUS_IS_PHYS
now, so just reduce the PCI transfer size for ide - anyone who cares for
performance on PCI controllers should have switched to libata long ago.
Reviewed-by: Jens Axboe <axboe@kernel.dk>
ide_toggle_bounce did select various strange block bounce limits, including
not bouncing at all as soon as an iommu is present in the system. Given
that the dma_map routines now handle any required bounce buffering except
for ISA DMA, and the ide code already must handle either ISA DMA or highmem
at least for iommu equipped systems we can get rid of the block layer
bounce limit setting entirely.
Pull block layer updates from Jens Axboe:
"It's a pretty quiet round this time, which is nice. This contains:
- series from Bart, cleaning up the way we set/test/clear atomic
queue flags.
- series from Bart, fixing races between gendisk and queue
registration and removal.
- set of bcache fixes and improvements from various folks, by way of
Michael Lyle.
- set of lightnvm updates from Matias, most of it being the 1.2 to
2.0 transition.
- removal of unused DIO flags from Nikolay.
- blk-mq/sbitmap memory ordering fixes from Omar.
- divide-by-zero fix for BFQ from Paolo.
- minor documentation patches from Randy.
- timeout fix from Tejun.
- Alpha "can't write a char atomically" fix from Mikulas.
- set of NVMe fixes by way of Keith.
- bsg and bsg-lib improvements from Christoph.
- a few sed-opal fixes from Jonas.
- cdrom check-disk-change deadlock fix from Maurizio.
- various little fixes, comment fixes, etc from various folks"
* tag 'for-4.17/block-20180402' of git://git.kernel.dk/linux-block: (139 commits)
blk-mq: Directly schedule q->timeout_work when aborting a request
blktrace: fix comment in blktrace_api.h
lightnvm: remove function name in strings
lightnvm: pblk: remove some unnecessary NULL checks
lightnvm: pblk: don't recover unwritten lines
lightnvm: pblk: implement 2.0 support
lightnvm: pblk: implement get log report chunk
lightnvm: pblk: rename ppaf* to addrf*
lightnvm: pblk: check for supported version
lightnvm: implement get log report chunk helpers
lightnvm: make address conversions depend on generic device
lightnvm: add support for 2.0 address format
lightnvm: normalize geometry nomenclature
lightnvm: complete geo structure with maxoc*
lightnvm: add shorten OCSSD version in geo
lightnvm: add minor version to generic geometry
lightnvm: simplify geometry structure
lightnvm: pblk: refactor init/exit sequences
lightnvm: Avoid validation of default op value
lightnvm: centralize permission check for lightnvm ioctl
git://git.kernel.org/pub/scm/linux/kernel/git/j.anaszewski/linux-leds
Pull LED updates from Jacek Anaszewski:
"New LED class driver:
- add driver for Mellanox regmap LEDs
Improvement to ledtrig-disk:
- extend disk trigger for reads and writes
Improvements and fixes to existing LED class drivers:
- add more product/board names for PC Engines APU2
- fix wrong dmi_match on PC Engines APU LEDs
- clarify chips supported by LM355x driver
- fix Kconfig text for MLXCPLD, SYSCON, MC13783, NETXBIG
- allow leds-mlxcpld compilation for 32 bit arch"
* tag 'leds_for_4.17-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/j.anaszewski/linux-leds:
leds: Fix wrong dmi_match on PC Engines APU LEDs
leds: Extends disk trigger for reads and writes
leds: Add more product/board names for PC Engines APU2
leds: add driver for support Mellanox regmap LEDs for BMC and x86 platform
leds: fix Kconfig text for MLXCPLD, SYSCON, MC13783, NETXBIG
leds: Clarify supported chips by LM355x driver
leds: leds-mlxcpld: Allow compilation for 32 bit arch
A lot of Kconfig symbols have architecture specific dependencies.
In those cases that depend on architectures we have already removed,
they can be omitted.
Acked-by: Kalle Valo <kvalo@codeaurora.org>
Acked-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
It happens often while I'm preparing a patch for a block driver that
I'm wondering: is a definition of SECTOR_SIZE and/or SECTOR_SHIFT
available for this driver? Do I have to introduce definitions of these
constants before I can use these constants? To avoid this confusion,
move the existing definitions of SECTOR_SIZE and SECTOR_SHIFT into the
<linux/blkdev.h> header file such that these become available for all
block drivers. Make the SECTOR_SIZE definition in the uapi msdos_fs.h
header file conditional to avoid that including that header file after
<linux/blkdev.h> causes the compiler to complain about a SECTOR_SIZE
redefinition.
Note: the SECTOR_SIZE / SECTOR_SHIFT / SECTOR_BITS definitions have
not been removed from uapi header files nor from NAND drivers in
which these constants are used for another purpose than converting
block layer offsets and sizes into a number of sectors.
Cc: Mike Snitzer <snitzer@redhat.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Nitin Gupta <ngupta@vflare.org>
Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com>
This adds two new disk triggers for triggering on reads
and writes respectively, named "disk-read" and "disk-write".
The use case comes from working on the D-Link DNS-313 NAS
box. This features an RGB LED for disk activity. with
these two triggers I can couple the green LED to read
activity and the red LED to write activity, which gives
the appropriate user feedback about what is happening
on the disk. When tested it gave exactly the feedback
desired.
The in-kernel interface is simply changed to pass a bool
indicating if the activity is write activity and update
each trigger (and the composite "disk-activity" trigger)
depending on what is passed in.
Reviewed-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Acked-by: Pavel Machek <pavel@ucw.cz>
Acked-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Jacek Anaszewski <jacek.anaszewski@gmail.com>
when mounting an ISO filesystem sometimes (very rarely)
the system hangs because of a race condition between two tasks.
PID: 6766 TASK: ffff88007b2a6dd0 CPU: 0 COMMAND: "mount"
#0 [ffff880078447ae0] __schedule at ffffffff8168d605
#1 [ffff880078447b48] schedule_preempt_disabled at ffffffff8168ed49
#2 [ffff880078447b58] __mutex_lock_slowpath at ffffffff8168c995
#3 [ffff880078447bb8] mutex_lock at ffffffff8168bdef
#4 [ffff880078447bd0] sr_block_ioctl at ffffffffa00b6818 [sr_mod]
#5 [ffff880078447c10] blkdev_ioctl at ffffffff812fea50
#6 [ffff880078447c70] ioctl_by_bdev at ffffffff8123a8b3
#7 [ffff880078447c90] isofs_fill_super at ffffffffa04fb1e1 [isofs]
#8 [ffff880078447da8] mount_bdev at ffffffff81202570
#9 [ffff880078447e18] isofs_mount at ffffffffa04f9828 [isofs]
#10 [ffff880078447e28] mount_fs at ffffffff81202d09
#11 [ffff880078447e70] vfs_kern_mount at ffffffff8121ea8f
#12 [ffff880078447ea8] do_mount at ffffffff81220fee
#13 [ffff880078447f28] sys_mount at ffffffff812218d6
#14 [ffff880078447f80] system_call_fastpath at ffffffff81698c49
RIP: 00007fd9ea914e9a RSP: 00007ffd5d9bf648 RFLAGS: 00010246
RAX: 00000000000000a5 RBX: ffffffff81698c49 RCX: 0000000000000010
RDX: 00007fd9ec2bc210 RSI: 00007fd9ec2bc290 RDI: 00007fd9ec2bcf30
RBP: 0000000000000000 R8: 0000000000000000 R9: 0000000000000010
R10: 00000000c0ed0001 R11: 0000000000000206 R12: 00007fd9ec2bc040
R13: 00007fd9eb6b2380 R14: 00007fd9ec2bc210 R15: 00007fd9ec2bcf30
ORIG_RAX: 00000000000000a5 CS: 0033 SS: 002b
This task was trying to mount the cdrom. It allocated and configured a
super_block struct and owned the write-lock for the super_block->s_umount
rwsem. While exclusively owning the s_umount lock, it called
sr_block_ioctl and waited to acquire the global sr_mutex lock.
PID: 6785 TASK: ffff880078720fb0 CPU: 0 COMMAND: "systemd-udevd"
#0 [ffff880078417898] __schedule at ffffffff8168d605
#1 [ffff880078417900] schedule at ffffffff8168dc59
#2 [ffff880078417910] rwsem_down_read_failed at ffffffff8168f605
#3 [ffff880078417980] call_rwsem_down_read_failed at ffffffff81328838
#4 [ffff8800784179d0] down_read at ffffffff8168cde0
#5 [ffff8800784179e8] get_super at ffffffff81201cc7
#6 [ffff880078417a10] __invalidate_device at ffffffff8123a8de
#7 [ffff880078417a40] flush_disk at ffffffff8123a94b
#8 [ffff880078417a88] check_disk_change at ffffffff8123ab50
#9 [ffff880078417ab0] cdrom_open at ffffffffa00a29e1 [cdrom]
#10 [ffff880078417b68] sr_block_open at ffffffffa00b6f9b [sr_mod]
#11 [ffff880078417b98] __blkdev_get at ffffffff8123ba86
#12 [ffff880078417bf0] blkdev_get at ffffffff8123bd65
#13 [ffff880078417c78] blkdev_open at ffffffff8123bf9b
#14 [ffff880078417c90] do_dentry_open at ffffffff811fc7f7
#15 [ffff880078417cd8] vfs_open at ffffffff811fc9cf
#16 [ffff880078417d00] do_last at ffffffff8120d53d
#17 [ffff880078417db0] path_openat at ffffffff8120e6b2
#18 [ffff880078417e48] do_filp_open at ffffffff8121082b
#19 [ffff880078417f18] do_sys_open at ffffffff811fdd33
#20 [ffff880078417f70] sys_open at ffffffff811fde4e
#21 [ffff880078417f80] system_call_fastpath at ffffffff81698c49
RIP: 00007f29438b0c20 RSP: 00007ffc76624b78 RFLAGS: 00010246
RAX: 0000000000000002 RBX: ffffffff81698c49 RCX: 0000000000000000
RDX: 00007f2944a5fa70 RSI: 00000000000a0800 RDI: 00007f2944a5fa70
RBP: 00007f2944a5f540 R8: 0000000000000000 R9: 0000000000000020
R10: 00007f2943614c40 R11: 0000000000000246 R12: ffffffff811fde4e
R13: ffff880078417f78 R14: 000000000000000c R15: 00007f2944a4b010
ORIG_RAX: 0000000000000002 CS: 0033 SS: 002b
This task tried to open the cdrom device, the sr_block_open function
acquired the global sr_mutex lock. The call to check_disk_change()
then saw an event flag indicating a possible media change and tried
to flush any cached data for the device.
As part of the flush, it tried to acquire the super_block->s_umount
lock associated with the cdrom device.
This was the same super_block as created and locked by the previous task.
The first task acquires the s_umount lock and then the sr_mutex_lock;
the second task acquires the sr_mutex_lock and then the s_umount lock.
This patch fixes the issue by moving check_disk_change() out of
cdrom_open() and let the caller take care of it.
Signed-off-by: Maurizio Lombardi <mlombard@redhat.com>
This patch has been generated as follows:
for verb in set_unlocked clear_unlocked set clear; do
replace-in-files queue_flag_${verb} blk_queue_flag_${verb%_unlocked} \
$(git grep -lw queue_flag_${verb} drivers block/bsg*)
done
Except for protecting all queue flag changes with the queue lock
this patch does not change any functionality.
Cc: Shaohua Li <shli@fb.com>
Cc: Hannes Reinecke <hare@suse.de>
Cc: Ming Lei <ming.lei@redhat.com>
Acked-by: Martin K. Petersen <martin.petersen@oracle.com>
This patch does not change any functionality.
Reviewed-by: Joseph Qi <joseph.qi@linux.alibaba.com>
Cc: Philipp Reisner <philipp.reisner@linbit.com>
Cc: Ulf Hansson <ulf.hansson@linaro.org>
Rename get_disk() to get_disk_and_module() to make sure what the
function does. It's not a great name but at least it is now clear that
put_disk() is not it's counterpart.
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
- skip AER driver error recovery callbacks for correctable errors
reported via ACPI APEI, as we already do for errors reported via the
native path (Tyler Baicar)
- fix DPC shared interrupt handling (Alex Williamson)
- print full DPC interrupt number (Keith Busch)
- enable DPC only if AER is available (Keith Busch)
- simplify DPC code (Bjorn Helgaas)
- calculate ASPM L1 substate parameter instead of hardcoding it (Bjorn
Helgaas)
- enable Latency Tolerance Reporting for ASPM L1 substates (Bjorn
Helgaas)
- move ASPM internal interfaces out of public header (Bjorn Helgaas)
- allow hot-removal of VGA devices (Mika Westerberg)
- speed up unplug and shutdown by assuming Thunderbolt controllers
don't support Command Completed events (Lukas Wunner)
- add AtomicOps support for GPU and Infiniband drivers (Felix Kuehling,
Jay Cornwall)
- expose "ari_enabled" in sysfs to help NIC naming (Stuart Hayes)
- clean up PCI DMA interface usage (Christoph Hellwig)
- remove PCI pool API (replaced with DMA pool) (Romain Perier)
- deprecate pci_get_bus_and_slot(), which assumed PCI domain 0 (Sinan
Kaya)
- move DT PCI code from drivers/of/ to drivers/pci/ (Rob Herring)
- add PCI-specific wrappers for dev_info(), etc (Frederick Lawler)
- remove warnings on sysfs mmap failure (Bjorn Helgaas)
- quiet ROM validation messages (Alex Deucher)
- remove redundant memory alloc failure messages (Markus Elfring)
- fill in types for compile-time VGA and other I/O port resources
(Bjorn Helgaas)
- make "pci=pcie_scan_all" work for Root Ports as well as Downstream
Ports to help AmigaOne X1000 (Bjorn Helgaas)
- add SPDX tags to all PCI files (Bjorn Helgaas)
- quirk Marvell 9128 DMA aliases (Alex Williamson)
- quirk broken INTx disable on Ceton InfiniTV4 (Bjorn Helgaas)
- fix CONFIG_PCI=n build by adding dummy pci_irqd_intx_xlate() (Niklas
Cassel)
- use DMA API to get MSI address for DesignWare IP (Niklas Cassel)
- fix endpoint-mode DMA mask configuration (Kishon Vijay Abraham I)
- fix ARTPEC-6 incorrect IS_ERR() usage (Wei Yongjun)
- add support for ARTPEC-7 SoC (Niklas Cassel)
- add endpoint-mode support for ARTPEC (Niklas Cassel)
- add Cadence PCIe host and endpoint controller driver (Cyrille
Pitchen)
- handle multiple INTx status bits being set in dra7xx (Vignesh R)
- translate dra7xx hwirq range to fix INTD handling (Vignesh R)
- remove deprecated Exynos PHY initialization code (Jaehoon Chung)
- fix MSI erratum workaround for HiSilicon Hip06/Hip07 (Dongdong Liu)
- fix NULL pointer dereference in iProc BCMA driver (Ray Jui)
- fix Keystone interrupt-controller-node lookup (Johan Hovold)
- constify qcom driver structures (Julia Lawall)
- rework Tegra config space mapping to increase space available for
endpoints (Vidya Sagar)
- simplify Tegra driver by using bus->sysdata (Manikanta Maddireddy)
- remove PCI_REASSIGN_ALL_BUS usage on Tegra (Manikanta Maddireddy)
- add support for Global Fabric Manager Server (GFMS) event to
Microsemi Switchtec switch driver (Logan Gunthorpe)
- add IDs for Switchtec PSX 24xG3 and PSX 48xG3 (Kelvin Cao)
* tag 'pci-v4.16-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (140 commits)
PCI: cadence: Add EndPoint Controller driver for Cadence PCIe controller
dt-bindings: PCI: cadence: Add DT bindings for Cadence PCIe endpoint controller
PCI: endpoint: Fix EPF device name to support multi-function devices
PCI: endpoint: Add the function number as argument to EPC ops
PCI: cadence: Add host driver for Cadence PCIe controller
dt-bindings: PCI: cadence: Add DT bindings for Cadence PCIe host controller
PCI: Add vendor ID for Cadence
PCI: Add generic function to probe PCI host controllers
PCI: generic: fix missing call of pci_free_resource_list()
PCI: OF: Add generic function to parse and allocate PCI resources
PCI: Regroup all PCI related entries into drivers/pci/Makefile
PCI/DPC: Reformat DPC register definitions
PCI/DPC: Add and use DPC Status register field definitions
PCI/DPC: Squash dpc_rp_pio_get_info() into dpc_process_rp_pio_error()
PCI/DPC: Remove unnecessary RP PIO register structs
PCI/DPC: Push dpc->rp_pio_status assignment into dpc_rp_pio_get_info()
PCI/DPC: Squash dpc_rp_pio_print_error() into dpc_rp_pio_get_info()
PCI/DPC: Make RP PIO log size check more generic
PCI/DPC: Rename local "status" to "dpc_status"
PCI/DPC: Squash dpc_rp_pio_print_tlp_header() into dpc_rp_pio_print_error()
Pointer cursg is initialized to cmd->cursg and again re-assigned the
same value a few lines later, hence the second assignment is redundant
and can be removed.
drivers/ide/ide-taskfile.c:229:22: warning: Value stored to 'cursg'
during its initialization is never read
pci_get_bus_and_slot() is restrictive such that it assumes domain=0 as
where a PCI device is present. This restricts the device drivers to be
reused for other domain numbers.
Getting ready to remove pci_get_bus_and_slot() function in favor of
pci_get_domain_bus_and_slot().
Replace pci_get_bus_and_slot() with pci_get_domain_bus_and_slot()
and extract the domain number from struct pci_dev.
Signed-off-by: Sinan Kaya <okaya@codeaurora.org>
Signed-off-by: Bjorn Helgaas <helgaas@kernel.org>
Pull small IDE cleanup from David Miller.
PNP: ide: constify pnp_device_id
Pull more block layer updates from Jens Axboe:
"A followup pull request, with some parts that either needed a bit more
testing before going in, merge sync, or just later arriving fixes.
This contains:
- Timer related updates from Kees. These were purposefully delayed
since I didn't want to pull in a later v4.14-rc tag to my block
tree.
- ide-cd prep sense buffer fix from Bart. Also delayed, as not to
clash with the late fix we put into 4.14-rc.
- Small BFQ updates series from Luca and Paolo.
- Single nvmet fix from James, fixing a non-functional case there.
- Bio fast clone fix from Michael, which made bcache return the wrong
data for some cases.
- Legacy IO path regression hang fix from Ming"
* 'for-linus' of git://git.kernel.dk/linux-block:
bio: ensure __bio_clone_fast copies bi_partno
nvmet_fc: fix better length checking
block: wake up all tasks blocked in get_request()
block, bfq: move debug blkio stats behind CONFIG_DEBUG_BLK_CGROUP
block, bfq: update blkio stats outside the scheduler lock
block, bfq: add missing invocations of bfqg_stats_update_io_add/remove
doc, block, bfq: update max IOPS sustainable with BFQ
ide: Make ide_cdrom_prep_fs() initialize the sense buffer pointer
md: Convert timers to use timer_setup()
block: swim3: Convert timers to use timer_setup()
block/aoe: Convert timers to use timer_setup()
amifloppy: Convert timers to use timer_setup()
block/floppy: Convert callback to pass timer_list
git://git.kernel.org/pub/scm/linux/kernel/git/jeyu/linux
Pull module updates from Jessica Yu:
"Summary of modules changes for the 4.15 merge window:
- treewide module_param_call() cleanup, fix up set/get function
prototype mismatches, from Kees Cook
- minor code cleanups"
* tag 'modules-for-v4.15' of git://git.kernel.org/pub/scm/linux/kernel/git/jeyu/linux:
module: Do not paper over type mismatches in module_param_call()
treewide: Fix function prototypes for module_param_call()
module: Prepare to convert all module_param_call() prototypes
kernel/module: Delete an error message for a failed memory allocation in add_module_usage()
The changes introduced through commit 82ed4db499b8 assume that the
sense buffer pointer in struct scsi_request is initialized for all
requests - passthrough and filesystem requests. Hence make sure
that that pointer is initialized for filesystem requests. Remove
the memset() call that clears .cmd because the scsi_req_init()
call in ide_initialize_rq() already initializes the .cmd.
Fixes: commit 82ed4db499b8 ("block: split scsi_request out of struct request")
Cc: Hongxu Jia <hongxu.jia@windriver.com>
Pull core block layer updates from Jens Axboe:
"This is the main pull request for block storage for 4.15-rc1.
Nothing out of the ordinary in here, and no API changes or anything
like that. Just various new features for drivers, core changes, etc.
In particular, this pull request contains:
- A patch series from Bart, closing the whole on blk/scsi-mq queue
quescing.
- A series from Christoph, building towards hidden gendisks (for
multipath) and ability to move bio chains around.
- NVMe
- Support for native multipath for NVMe (Christoph).
- Userspace notifications for AENs (Keith).
- Command side-effects support (Keith).
- SGL support (Chaitanya Kulkarni)
- FC fixes and improvements (James Smart)
- Lots of fixes and tweaks (Various)
- bcache
- New maintainer (Michael Lyle)
- Writeback control improvements (Michael)
- Various fixes (Coly, Elena, Eric, Liang, et al)
- lightnvm updates, mostly centered around the pblk interface
(Javier, Hans, and Rakesh).
- Removal of unused bio/bvec kmap atomic interfaces (me, Christoph)
- Writeback series that fix the much discussed hundreds of millions
of sync-all units. This goes all the way, as discussed previously
(me).
- Fix for missing wakeup on writeback timer adjustments (Yafang
Shao).
- Fix laptop mode on blk-mq (me).
- {mq,name} tupple lookup for IO schedulers, allowing us to have
alias names. This means you can use 'deadline' on both !mq and on
mq (where it's called mq-deadline). (me).
- blktrace race fix, oopsing on sg load (me).
- blk-mq optimizations (me).
- Obscure waitqueue race fix for kyber (Omar).
- NBD fixes (Josef).
- Disable writeback throttling by default on bfq, like we do on cfq
(Luca Miccio).
- Series from Ming that enable us to treat flush requests on blk-mq
like any other request. This is a really nice cleanup.
- Series from Ming that improves merging on blk-mq with schedulers,
getting us closer to flipping the switch on scsi-mq again.
- BFQ updates (Paolo).
- blk-mq atomic flags memory ordering fixes (Peter Z).
- Loop cgroup support (Shaohua).
- Lots of minor fixes from lots of different folks, both for core and
driver code"
* 'for-4.15/block' of git://git.kernel.dk/linux-block: (294 commits)
nvme: fix visibility of "uuid" ns attribute
blk-mq: fixup some comment typos and lengths
ide: ide-atapi: fix compile error with defining macro DEBUG
blk-mq: improve tag waiting setup for non-shared tags
brd: remove unused brd_mutex
blk-mq: only run the hardware queue if IO is pending
block: avoid null pointer dereference on null disk
fs: guard_bio_eod() needs to consider partitions
xtensa/simdisk: fix compile error
nvme: expose subsys attribute to sysfs
nvme: create 'slaves' and 'holders' entries for hidden controllers
block: create 'slaves' and 'holders' entries for hidden gendisks
nvme: also expose the namespace identification sysfs files for mpath nodes
nvme: implement multipath access to nvme subsystems
nvme: track shared namespaces
nvme: introduce a nvme_ns_ids structure
nvme: track subsystems
block, nvme: Introduce blk_mq_req_flags_t
block, scsi: Make SCSI quiesce and resume work reliably
block: Add the QUEUE_FLAG_PREEMPT_ONLY request queue flag
Pull timer updates from Thomas Gleixner:
"Yet another big pile of changes:
- More year 2038 work from Arnd slowly reaching the point where we
need to think about the syscalls themself.
- A new timer function which allows to conditionally (re)arm a timer
only when it's either not running or the new expiry time is sooner
than the armed expiry time. This allows to use a single timer for
multiple timeout requirements w/o caring about the first expiry
time at the call site.
- A new NMI safe accessor to clock real time for the printk timestamp
work. Can be used by tracing, perf as well if required.
- A large number of timer setup conversions from Kees which got
collected here because either maintainers requested so or they
simply got ignored. As Kees pointed out already there are a few
trivial merge conflicts and some redundant commits which was
unavoidable due to the size of this conversion effort.
- Avoid a redundant iteration in the timer wheel softirq processing.
- Provide a mechanism to treat RTC implementations depending on their
hardware properties, i.e. don't inflict the write at the 0.5
seconds boundary which originates from the PC CMOS RTC to all RTCs.
No functional change as drivers need to be updated separately.
- The usual small updates to core code clocksource drivers. Nothing
really exciting"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (111 commits)
timers: Add a function to start/reduce a timer
pstore: Use ktime_get_real_fast_ns() instead of __getnstimeofday()
timer: Prepare to change all DEFINE_TIMER() callbacks
netfilter: ipvs: Convert timers to use timer_setup()
scsi: qla2xxx: Convert timers to use timer_setup()
block/aoe: discover_timer: Convert timers to use timer_setup()
ide: Convert timers to use timer_setup()
drbd: Convert timers to use timer_setup()
mailbox: Convert timers to use timer_setup()
crypto: Convert timers to use timer_setup()
drivers/pcmcia: omap1: Fix error in automated timer conversion
ARM: footbridge: Fix typo in timer conversion
drivers/sgi-xp: Convert timers to use timer_setup()
drivers/pcmcia: Convert timers to use timer_setup()
drivers/memstick: Convert timers to use timer_setup()
drivers/macintosh: Convert timers to use timer_setup()
hwrng/xgene-rng: Convert timers to use timer_setup()
auxdisplay: Convert timers to use timer_setup()
sparc/led: Convert timers to use timer_setup()
mips: ip22/32: Convert timers to use timer_setup()
Compile ide-atapi failed with defining macro "DEBUG"
|drivers/ide/ide-atapi.c:285:52: error: 'struct request' has
no member named 'cmd'; did you mean 'csd'?
| debug_log("%s: rq->cmd[0]: 0x%x\n", __func__, rq->cmd[0]);
Since we split the scsi_request out of struct request, it missed
do the same thing on debug_log
Fixes: 82ed4db499b8 ("block: split scsi_request out of struct request")
Signed-off-by: Hongxu Jia <hongxu.jia@windriver.com>
requests
Convert blk_get_request(q, op, __GFP_RECLAIM) into
blk_get_request_flags(q, op, BLK_MQ_PREEMPT). This patch does not
Tested-by: Martin Steigerwald <martin@lichtvoll.de>
Acked-by: David S. Miller <davem@davemloft.net> [ for IDE ]
Tested-by: Oleksandr Natalenko <oleksandr@natalenko.name>
Cc: Johannes Thumshirn <jthumshirn@suse.de>
The 0day bot reports the below failure which happens occasionally, with
their randconfig testing (once every ~100 boots). The Code points at
the private pointer ->driver_data being NULL, which hints at a race of
sorts where the private driver_data descriptor has disappeared by the
time we get to run the workqueue.
So let's check that pointer before we continue with issuing the command
to the drive.
This fix is of the brown paper bag nature but considering that IDE is
long deprecated, let's do that so that random testing which happens to
enable CONFIG_IDE during randconfig builds, doesn't fail because of
this.
Besides, failing the TEST_UNIT_READY command because the drive private
data is gone is something which we could simply do anyway, to denote
that there was a problem communicating with the device.
BUG: unable to handle kernel NULL pointer dereference at 000001c0
IP: cdrom_check_status
*pde = 00000000
Oops: 0000 [#1] SMP
CPU: 1 PID: 155 Comm: kworker/1:2 Not tainted 4.14.0-rc8 #127
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1 04/01/2014
Workqueue: events_freezable_power_ disk_events_workfn
task: 4fe90980 task.stack: 507ac000
EIP: cdrom_check_status+0x2c/0x90
EFLAGS: 00210246 CPU: 1
EAX: 00000000 EBX: 4fefec00 ECX: 00000000 EDX: 00000000
ESI: 00000003 EDI: ffffffff EBP: 467a9340 ESP: 507aded0
DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
CR0: 80050033 CR2: 000001c0 CR3: 06e0f000 CR4: 00000690
Call Trace:
? ide_cdrom_check_events_real
? cdrom_check_events
? disk_check_events
? process_one_work
? process_one_work
? worker_thread
? kthread
? process_one_work
? __kthread_create_on_node
? ret_from_fork
Code: 53 83 ec 14 89 c3 89 d1 be 03 00 00 00 65 a1 14 00 00 00 89 44 24 10 31 c0 8b 43 18 c7 44 24 04 00 00 00 00 c7 04 24 00 00 00 00 <8a> 80 c0 01 00 00 c7 44 24 08 00 00 00 00 83 e0 03 c7 44 24 0c
EIP: cdrom_check_status+0x2c/0x90 SS:ESP: 0068:507aded0
CR2: 00000000000001c0
---[ end trace 2410e586dd8f88b2 ]---
Reported-and-tested-by: Fengguang Wu <fengguang.wu@intel.com>
Cc: Bart Van Assche <bart.vanassche@sandisk.com>
In preparation for unconditionally passing the struct timer_list pointer to
all timer callbacks, switch to using the new timer_setup() and from_timer()
to pass the timer pointer explicitly.
Cc: linux-ide@vger.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull initial SPDX identifiers from Greg KH:
"License cleanup: add SPDX license identifiers to some files
Update the files which contain no license information with the
'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally
binding shorthand, which can be used instead of the full boiler plate
text.
This patch is based on work done by Thomas Gleixner and Kate Stewart
and Philippe Ombredanne.
How this work was done:
Patches were generated and checked against linux-4.14-rc6 for a subset
of the use cases:
where non-standard license headers were used, and references to
license had to be inferred by heuristics based on keywords.
The analysis to determine which SPDX License Identifier to be applied
to a file was done in a spreadsheet of side by side results from of
the output of two independent scanners (ScanCode & Windriver)
producing SPDX tag:value files created by Philippe Ombredanne.
Philippe prepared the base worksheet, and did an initial spot review
of a few 1000 files.
The 4.13 kernel was the starting point of the analysis with 60,537
files assessed. Kate Stewart did a file by file comparison of the
scanner results in the spreadsheet to determine which SPDX license
identifier(s) to be applied to the file. She confirmed any
determination that was not immediately clear with lawyers working with
the Linux Foundation.
- Make and config files were included as candidates if they contained
>5 lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
Linux-syscall-note" otherwise it was "GPL-2.0". Results of that
was:
- when the two scanners agreed on the detected license(s), that
became the concluded license(s).
- when there was disagreement between the two scanners (one detected
a license but the other didn't, or they both detected different
resulted in a clear resolution of the license that should apply
(and which scanner probably needed to revisit its heuristics).
in time.
source files by Kate, Philippe, Thomas and, in some cases,
confirmation by lawyers working with the Linux Foundation.
disagreed against that SPDX file, to see if there was new insights.
The Windriver scanner is based on an older version of FOSSology in
part, so they are related.
files he inspected. For the non-uapi files Thomas did random spot
checks in about 15000 files.
copy/paste license identifier errors, and have been fixed to reflect
the correct identifier.
inspection and review of the 12,461 patched files from the initial
patch version early this week with:
license ids and scores
- reviewing anything where there was no detection but the patch
license was not GPL-2.0 WITH Linux-syscall-note to ensure that the
generate the patches.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
* tag 'spdx_identifiers-4.14-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
License cleanup: add SPDX license identifier to uapi header files with a license
License cleanup: add SPDX license identifier to uapi header files with no license
License cleanup: add SPDX GPL-2.0 license identifier to files with no license
After the cdrom cleanup, I get randconfig warnings for some configurations:
warning: (BLK_DEV_IDECD && BLK_DEV_SR) selects CDROM which has unmet direct dependencies (BLK_DEV)
This adds an explicit BLK_DEV dependency for both drivers. The other
drivers that select 'CDROM' already have this and don't need a change.
Fixes: 2a750166a5be ("block: Rework drivers/cdrom/Makefile")
the use cases:
lines of source
lines).
GPL-2.0 11139
in time.
they are related.
correct identifier.
