path: root/drivers/idle
2010-05-28intel_idle: native hardware cpuidle driver for latest Intel processorsLen Brown
This EXPERIMENTAL driver supersedes acpi_idle on Intel Atom Processors, Intel Core i3/i5/i7 Processors and associated Intel Xeon processors. It does not support the Intel Core2 processor or earlier. For kernels configured with ACPI, CONFIG_INTEL_IDLE=y allows intel_idle to probe before the ACPI processor driver. Booting with "intel_idle.max_cstate=0" disables intel_idle and the system will fall back on ACPI's "acpi_idle". Typical Linux distributions load ACPI processor module early, making CONFIG_INTEL_IDLE=m not easily useful on ACPI platforms. intel_idle probes all processors at module_init time. Processors that are hot-added later will be limited to using C1 in idle. Signed-off-by: Len Brown <len.brown@intel.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-17cpumask: convert drivers/idle/i7300_idle.c to cpumask_var_tRusty Russell
Fairly simple transformation: 1) cpumask_t -> cpumask_var_t and alloc_cpumask_var/free_cpumask_var (which are a NOOP unless CONFIG_CPUMASK_OFFSTACK=y). 2) cpu_set -> cpumask_set_cpu 3) cpus_weight -> cpumask_weight 4) cpu_clear -> cpumask_clear_cpu Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> To: Andy Henroid <andrew.d.henroid@intel.com>
2009-09-08ioat: switch watchdog and reset handler from workqueue to timerDan Williams
In order to support dynamic resizing of the descriptor ring or polling for a descriptor in the presence of a hung channel the reset handler needs to make progress while in a non-preemptible context. The current workqueue implementation precludes polling channel reset completion under spin_lock(). This conversion also allows us to return to opportunistic cleanup in the ioat2 case as the timer implementation guarantees at least one cleanup after every descriptor is submitted. This means the worst case completion latency becomes the timer frequency (for exceptional circumstances), but with the benefit of avoiding busy waiting when the lock is contended. Signed-off-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-07-28ioat: move to drivers/dma/ioat/Dan Williams
When first created the ioat driver was the only inhabitant of drivers/dma/. Now, it is the only multi-file (more than a .c and a .h) driver in the directory. Moving it to an ioat/ subdirectory allows the naming convention to be cleaned up, and allows for future splitting of the source files by hardware version (v1, v2, and v3). Signed-off-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-05-28i7300_idle: allow testing on i5000-series hardware w/o re-compileLen Brown
Testing the i7300_idle driver on i5000-series hardware required an edit to i7300_idle.h to "#define SUPPORT_I5000 1" and a re-build of both i7300_idle and ioat_dma. Replace that build-time scheme with a load-time module parameter: "7300_idle.forceload=1" to make it easier to test the driver on hardware that while not officially validated, works fine and is much more commonly available. By default (no modparam) the driver will continue to load only on the i7300. Note that ioat_dma runs a copy of i7300_idle's probe routine to know to reserve an IOAT channel for i7300_idle. This change makes ioat_dma do that always on the i5000, just like it does on the i7300. Signed-off-by: Len Brown <len.brown@intel.com> Acked-by: Andrew Henroid <andrew.d.henroid@intel.com>
2009-04-07dma-mapping: replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64)Yang Hongyang
Replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06i7300_idle: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
CC: Andy Henroid <andrew.d.henroid@intel.com> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-28i7300_idle: Kconfig, show menu only on x86_64Venki Pallipadi
...since today it contains only a single driver which is visible to just x86_64 Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-24i7300_idle: Cleanup based review commentsVenki Pallipadi
Cleanup of i7300 idle driver based on review comments from Randy Dunlap, Andi Kleen and Len Brown. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-24i7300_idle: Disable ioat channel only on platforms where ile driver can loadVenki Pallipadi
Based on input from Andi Kleen: share the platform detection code with ioat_dma and disable the channel in dma engine only for specific platforms. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-21i7300_idle driver v1.55Andy Henroid
The Intel 7300 Memory Controller supports dynamic throttling of memory which can be used to save power when system is idle. This driver does the memory throttling when all CPUs are idle on such a system. Refer to "Intel 7300 Memory Controller Hub (MCH)" datasheet for the config space description. Signed-off-by: Andy Henroid <andrew.d.henroid@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
