path: root/drivers/idle
2013-11-19Merge branch 'pm-cpuidle'Rafael J. Wysocki
* pm-cpuidle: intel_idle: Support Intel Atom Processor C2000 Product Family
2013-11-14Merge tag 'pm+acpi-3.13-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management updates from Rafael J Wysocki: - New power capping framework and the the Intel Running Average Power Limit (RAPL) driver using it from Srinivas Pandruvada and Jacob Pan. - Addition of the in-kernel switching feature to the arm_big_little cpufreq driver from Viresh Kumar and Nicolas Pitre. - cpufreq support for iMac G5 from Aaro Koskinen. - Baytrail processors support for intel_pstate from Dirk Brandewie. - cpufreq support for Midway/ECX-2000 from Mark Langsdorf. - ARM vexpress/TC2 cpufreq support from Sudeep KarkadaNagesha. - ACPI power management support for the I2C and SPI bus types from Mika Westerberg and Lv Zheng. - cpufreq core fixes and cleanups from Viresh Kumar, Srivatsa S Bhat, Stratos Karafotis, Xiaoguang Chen, Lan Tianyu. - cpufreq drivers updates (mostly fixes and cleanups) from Viresh Kumar, Aaro Koskinen, Jungseok Lee, Sudeep KarkadaNagesha, Lukasz Majewski, Manish Badarkhe, Hans-Christian Egtvedt, Evgeny Kapaev. - intel_pstate updates from Dirk Brandewie and Adrian Huang. - ACPICA update to version 20130927 includig fixes and cleanups and some reduction of divergences between the ACPICA code in the kernel and ACPICA upstream in order to improve the automatic ACPICA patch generation process. From Bob Moore, Lv Zheng, Tomasz Nowicki, Naresh Bhat, Bjorn Helgaas, David E Box. - ACPI IPMI driver fixes and cleanups from Lv Zheng. - ACPI hotplug fixes and cleanups from Bjorn Helgaas, Toshi Kani, Zhang Yanfei, Rafael J Wysocki. - Conversion of the ACPI AC driver to the platform bus type and multiple driver fixes and cleanups related to ACPI from Zhang Rui. - ACPI processor driver fixes and cleanups from Hanjun Guo, Jiang Liu, Bartlomiej Zolnierkiewicz, Mathieu Rhéaume, Rafael J Wysocki. - Fixes and cleanups and new blacklist entries related to the ACPI video support from Aaron Lu, Felipe Contreras, Lennart Poettering, Kirill Tkhai. - cpuidle core cleanups from Viresh Kumar and Lorenzo Pieralisi. - cpuidle drivers fixes and cleanups from Daniel Lezcano, Jingoo Han, Bartlomiej Zolnierkiewicz, Prarit Bhargava. - devfreq updates from Sachin Kamat, Dan Carpenter, Manish Badarkhe. - Operation Performance Points (OPP) core updates from Nishanth Menon. - Runtime power management core fix from Rafael J Wysocki and update from Ulf Hansson. - Hibernation fixes from Aaron Lu and Rafael J Wysocki. - Device suspend/resume lockup detection mechanism from Benoit Goby. - Removal of unused proc directories created for various ACPI drivers from Lan Tianyu. - ACPI LPSS driver fix and new device IDs for the ACPI platform scan handler from Heikki Krogerus and Jarkko Nikula. - New ACPI _OSI blacklist entry for Toshiba NB100 from Levente Kurusa. - Assorted fixes and cleanups related to ACPI from Andy Shevchenko, Al Stone, Bartlomiej Zolnierkiewicz, Colin Ian King, Dan Carpenter, Felipe Contreras, Jianguo Wu, Lan Tianyu, Yinghai Lu, Mathias Krause, Liu Chuansheng. - Assorted PM fixes and cleanups from Andy Shevchenko, Thierry Reding, Jean-Christophe Plagniol-Villard. * tag 'pm+acpi-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (386 commits) cpufreq: conservative: fix requested_freq reduction issue ACPI / hotplug: Consolidate deferred execution of ACPI hotplug routines PM / runtime: Use pm_runtime_put_sync() in __device_release_driver() ACPI / event: remove unneeded NULL pointer check Revert "ACPI / video: Ignore BIOS initial backlight value for HP 250 G1" ACPI / video: Quirk initial backlight level 0 ACPI / video: Fix initial level validity test intel_pstate: skip the driver if ACPI has power mgmt option PM / hibernate: Avoid overflow in hibernate_preallocate_memory() ACPI / hotplug: Do not execute "insert in progress" _OST ACPI / hotplug: Carry out PCI root eject directly ACPI / hotplug: Merge device hot-removal routines ACPI / hotplug: Make acpi_bus_hot_remove_device() internal ACPI / hotplug: Simplify device ejection routines ACPI / hotplug: Fix handle_root_bridge_removal() ACPI / hotplug: Refuse to hot-remove all objects with disabled hotplug ACPI / scan: Start matching drivers after trying scan handlers ACPI: Remove acpi_pci_slot_init() headers from internal.h ACPI / blacklist: fix name of ThinkPad Edge E530 PowerCap: Fix build error with option -Werror=format-security ... Conflicts: arch/arm/mach-omap2/opp.c drivers/Kconfig drivers/spi/spi.c
2013-11-12intel_idle: Support Intel Atom Processor C2000 Product FamilyLen Brown
Support the "Intel(R) Atom(TM) Processor C2000 Product Family", formerly code-named Avoton. It is based on the next generation Intel Atom processor architecture, formerly code-named Silvermont. Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-30intel_idle: use CPU_TASKS_FROZEN instead of a numeric constantPrarit Bhargava
Small fixup to use CPU_TASKS_FROZEN instead of 0xf. Signed-off-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-09-25sched, idle: Fix the idle polling state logicPeter Zijlstra
Mike reported that commit 7d1a9417 ("x86: Use generic idle loop") regressed several workloads and caused excessive reschedule interrupts. The patch in question failed to notice that the x86 code had an inverted sense of the polling state versus the new generic code (x86: default polling, generic: default !polling). Fix the two prominent x86 mwait based idle drivers and introduce a few new generic polling helpers (fixing the wrong smp_mb__after_clear_bit usage). Also switch the idle routines to using tif_need_resched() which is an immediate TIF_NEED_RESCHED test as opposed to need_resched which will end up being slightly different. Reported-by: Mike Galbraith <bitbucket@online.de> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: lenb@kernel.org Cc: tglx@linutronix.de Link: http://lkml.kernel.org/n/tip-nc03imb0etuefmzybzj7sprf@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-24intel_idle: mark some functions with __init tagBartlomiej Zolnierkiewicz
intel_idle_probe() and intel_idle_cpuidle_driver_init() can be marked with __init tag as they are only called from intel_idle_init(). Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Daniel Lezcano <daniel.lezcano@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-09-24intel_idle: mark states tables with __initdata tagBartlomiej Zolnierkiewicz
States tables are only accessed during driver initialization so they can be marked with __initdata tag. Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Daniel Lezcano <daniel.lezcano@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-09-24intel_idle: shrink states tablesBartlomiej Zolnierkiewicz
There is no reason to define CPUIDLE_STATE_MAX (currently 10) entries in states tables if the driver always stops iterating over table when it encounters first .enter == NULL entry. $ size drivers/idle/intel_idle.o.* text data bss dec hex filename 2886 5440 32 8358 20a6 drivers/idle/intel_idle.o.before 2886 3752 32 6670 1a0e drivers/idle/intel_idle.o.after Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-05-11Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux Pull idle update from Len Brown: "Add support for new Haswell-ULT CPU idle power states" * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: intel_idle: initial C8, C9, C10 support tools/power turbostat: display C8, C9, C10 residency
2013-04-28Merge branch 'pm-cpuidle'Rafael J. Wysocki
* pm-cpuidle: (51 commits) cpuidle: add maintainer entry ARM: s3c64xx: cpuidle: use init/exit common routine SH: cpuidle: use init/exit common routine cpuidle: fix comment format ARM: imx: cpuidle: use init/exit common routine ARM: davinci: cpuidle: use init/exit common routine ARM: kirkwood: cpuidle: use init/exit common routine ARM: calxeda: cpuidle: use init/exit common routine ARM: tegra: cpuidle: use init/exit common routine for tegra3 ARM: tegra: cpuidle: use init/exit common routine for tegra2 ARM: OMAP4: cpuidle: use init/exit common routine ARM: shmobile: cpuidle: use init/exit common routine ARM: tegra: cpuidle: use init/exit common routine ARM: OMAP3: cpuidle: use init/exit common routine ARM: at91: cpuidle: use init/exit common routine ARM: ux500: cpuidle: use init/exit common routine cpuidle: make a single register function for all ARM: ux500: cpuidle: replace for_each_online_cpu by for_each_possible_cpu cpuidle: remove en_core_tk_irqen flag ARM: OMAP3: remove cpuidle_wrap_enter ...
2013-04-23cpuidle: remove en_core_tk_irqen flagDaniel Lezcano
The en_core_tk_irqen flag is set in all the cpuidle driver which means it is not necessary to specify this flag. Remove the flag and the code related to it. Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org> Acked-by: Kevin Hilman <khilman@linaro.org> # for mach-omap2/* Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-04-22intel_idle: remove stop/start critical timingsDaniel Lezcano
The start/stop_critical_timings are called from arch/x86/kernel/process.c in the cpu_idle loop function. Remove the ones in the cpuidle driver. Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org> Acked-by: Len Brown <len.brown@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-04-17intel_idle: initial C8, C9, C10 supportLen Brown
Allow intel_idle and cpuidle to utilize C8, C9, C10 when they are present on... "Fourth Generation Intel(R) Core(TM) Processors", which are based on Intel(R) microarchitecture code name Haswell. Signed-off-by: Len Brown <len.brown@intel.com>
2013-03-15intel_idle: additional Haswell CPU-idLen Brown
There is an additional HSW CPU-id, 0x46, which has C-states exactly like CPU-id 0x45. Signed-off-by: Len Brown <len.brown@intel.com>
2013-02-22Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core locking changes from Ingo Molnar: "The biggest change is the rwsem lock-steal improvements, both to the assembly optimized and the spinlock based variants. The other notable change is the clean up of the seqlock implementation to be based on the seqcount infrastructure. The rest is assorted smaller debuggability, cleanup and continued -rt locking changes." * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: rwsem-spinlock: Implement writer lock-stealing for better scalability futex: Revert "futex: Mark get_robust_list as deprecated" generic: Use raw local irq variant for generic cmpxchg lockdep: Selftest: convert spinlock to raw spinlock seqlock: Use seqcount infrastructure seqlock: Remove unused functions ntp: Make ntp_lock raw intel_idle: Convert i7300_idle_lock to raw_spinlock locking: Various static lock initializer fixes lockdep: Print more info when MAX_LOCK_DEPTH is exceeded rwsem: Implement writer lock-stealing for better scalability lockdep: Silence warning if CONFIG_LOCKDEP isn't set watchdog: Use local_clock for get_timestamp() lockdep: Rename print_unlock_inbalance_bug() to print_unlock_imbalance_bug() locking/stat: Fix a typo
2013-02-21Merge tag 'driver-core-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg Kroah-Hartman: "Here is the big driver core merge for 3.9-rc1 There are two major series here, both of which touch lots of drivers all over the kernel, and will cause you some merge conflicts: - add a new function called devm_ioremap_resource() to properly be able to check return values. - remove CONFIG_EXPERIMENTAL Other than those patches, there's not much here, some minor fixes and updates" Fix up trivial conflicts * tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits) base: memory: fix soft/hard_offline_page permissions drivercore: Fix ordering between deferred_probe and exiting initcalls backlight: fix class_find_device() arguments TTY: mark tty_get_device call with the proper const values driver-core: constify data for class_find_device() firmware: Ignore abort check when no user-helper is used firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER firmware: Make user-mode helper optional firmware: Refactoring for splitting user-mode helper code Driver core: treat unregistered bus_types as having no devices watchdog: Convert to devm_ioremap_resource() thermal: Convert to devm_ioremap_resource() spi: Convert to devm_ioremap_resource() power: Convert to devm_ioremap_resource() mtd: Convert to devm_ioremap_resource() mmc: Convert to devm_ioremap_resource() mfd: Convert to devm_ioremap_resource() media: Convert to devm_ioremap_resource() iommu: Convert to devm_ioremap_resource() drm: Convert to devm_ioremap_resource() ...
2013-02-19intel_idle: Convert i7300_idle_lock to raw_spinlockMike Galbraith
24 core Intel box's first exposure to 3.0.12-rt30-rc3 didn't go well. [ 27.104159] i7300_idle: loaded v1.55 [ 27.104192] BUG: scheduling while atomic: swapper/2/0/0x00000002 [ 27.104309] Pid: 0, comm: swapper/2 Tainted: G N 3.0.12-rt30-rc3-rt #1 [ 27.104317] Call Trace: [ 27.104338] [<ffffffff810046a5>] dump_trace+0x85/0x2e0 [ 27.104372] [<ffffffff8144eb00>] thread_return+0x12b/0x30b [ 27.104381] [<ffffffff8144f1b9>] schedule+0x29/0xb0 [ 27.104389] [<ffffffff814506e5>] rt_spin_lock_slowlock+0xc5/0x240 [ 27.104401] [<ffffffffa01f818f>] i7300_idle_notifier+0x3f/0x360 [i7300_idle] [ 27.104415] [<ffffffff814546c7>] notifier_call_chain+0x37/0x70 [ 27.104426] [<ffffffff81454748>] __atomic_notifier_call_chain+0x48/0x70 [ 27.104439] [<ffffffff81001a39>] cpu_idle+0x89/0xb0 [ 27.104449] bad: scheduling from the idle thread! This lock is taken from interrupt disabled context in the guts of idle. Convert it to a raw_spinlock. Signed-off-by: Mike Galbraith <efault@gmx.de> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Andy Henroid <andrew.d.henroid@intel.com> Link: http://lkml.kernel.org/r/1323258522.5057.73.camel@marge.simson.net Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-02-13intel_idle: export both C1 and C1ELen Brown
Here we disable HW promotion of C1 to C1E and export both C1 and C1E and distinct C-states. This allows a cpuidle governor to choose a lower latency C-state than C1E when necessary to satisfy performance and QOS constraints -- and still save power versus polling. This also corrects the erroneous latency previously reported for C1E -- it is 10usec, not 1usec. Note that if you use "intel_idle.max_cstate=N", then you must increment N by 1 to get the same behavior after this change. Signed-off-by: Len Brown <len.brown@intel.com>
2013-02-08intel_idle: remove assumption of one C-state per MWAIT flagLen Brown
Remove the assumption that cstate_tables are indexed by MWAIT flag values. Each entry identifies itself via its own flags value. This change is needed to support multiple states that share the same MWAIT flags. Note that this can have an effect on what state is described by 'N' on cmdline intel_idle.max_cstate=N on some systems. intel_idle.max_cstate=0 still disables the driver intel_idle.max_cstate=1 still results in just C1(E) However, "place holders" in the sparse C-state name-space (eg. Atom) have been removed. Signed-off-by: Len Brown <len.brown@intel.com>
2013-02-08intel_idle: remove use and definition of MWAIT_MAX_NUM_CSTATESLen Brown
Cosmetic only. Replace use of MWAIT_MAX_NUM_CSTATES with CPUIDLE_STATE_MAX. They are both 8, so this patch has no functional change. The reason to change is that intel_idle will soon be able to export more than the 8 "major" states supported by MWAIT. When we hit that limit, it is important to know where the limit comes from. Signed-off-by: Len Brown <len.brown@intel.com>
2013-02-08intel_idle: support HaswellLen Brown
This patch enables intel_idle to run on the next-generation Intel(R) Microarchitecture code named "Haswell". Signed-off-by: Len Brown <len.brown@intel.com>
2013-02-01intel_idle: stop using driver_data for static flagsLen Brown
The commit, 4202735e8ab6ecfb0381631a0d0b58fefe0bd4e2 (cpuidle: Split cpuidle_state structure and move per-cpu statistics fields) observed that the MWAIT flags for Cn on every processor to date were the same, and created get_driver_data() to supply them. Unfortunately, that assumption is false, going forward. So here we restore the MWAIT flags to the cpuidle_state table. However, instead restoring the old "driver_data" field, we put the flags into the existing "flags" field, where they probalby should have lived all along. This patch does not change any operation. This patch removes 1 of the 3 users of cpuidle_state_usage.driver_data. Perhaps some day we'll get rid of the other 2. Signed-off-by: Len Brown <len.brown@intel.com>
2013-01-25Merge 3.8-rc5 into driver-core-nextGreg Kroah-Hartman
This resolves a gpio driver merge issue pointed out in linux-next. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-21drivers/idle: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. Cc: Len Brown <len.brown@intel.com> Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-18intel_idle: Don't register CPU notifier if we are not running.Konrad Rzeszutek Wilk
The 'intel_idle_probe' probes the CPU and sets the CPU notifier. But if later on during the module initialization we fail (say in cpuidle_register_driver), we stop loading, but we neglect to unregister the CPU notifier. This means that during CPU hotplug events the system will fail: calling intel_idle_init+0x0/0x326 @ 1 intel_idle: MWAIT substates: 0x1120 intel_idle: v0.4 model 0x2A intel_idle: lapic_timer_reliable_states 0xffffffff intel_idle: intel_idle yielding to none initcall intel_idle_init+0x0/0x326 returned -19 after 14 usecs ... some time later, offlining and onlining a CPU: cpu 3 spinlock event irq 62 BUG: unable to ] __cpuidle_register_device+0x1c/0x120 PGD 99b8b067 PUD 99b95067 PMD 0 Oops: 0000 [#1] SMP Modules linked in: xen_evtchn nouveau mxm_wmi wmi radeon ttm i915 fbcon tileblit font atl1c bitblit softcursor drm_kms_helper video xen_blkfront xen_netfront fb_sys_fops sysimgblt sysfillrect syscopyarea xenfs xen_privcmd mperf CPU 0 Pid: 2302, comm: udevd Not tainted 3.8.0-rc3upstream-00249-g09ad159 #1 MSI MS-7680/H61M-P23 (MS-7680) RIP: e030:[<ffffffff814d956c>] [<ffffffff814d956c>] __cpuidle_register_device+0x1c/0x120 RSP: e02b:ffff88009dacfcb8 EFLAGS: 00010286 RAX: 0000000000000000 RBX: ffff880105380000 RCX: 000000000000001c RDX: 0000000000000000 RSI: 0000000000000055 RDI: ffff880105380000 RBP: ffff88009dacfce8 R08: ffffffff81a4f048 R09: 0000000000000008 R10: 0000000000000008 R11: 0000000000000000 R12: ffff880105380000 R13: 00000000ffffffdd R14: 0000000000000000 R15: ffffffff81a523d0 FS: 00007f37bd83b7a0(0000) GS:ffff880105200000(0000) knlGS:0000000000000000 CS: e033 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000008 CR3: 00000000a09ea000 CR4: 0000000000042660 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process udevd (pid: 2302, threadinfo ffff88009dace000, task ffff88009afb47f0) Stack: ffffffff8107f2d0 ffffffff810c2fb7 ffff88009dacfce8 00000000ffffffea ffff880105380000 00000000ffffffdd ffff88009dacfd08 ffffffff814d9882 0000000000000003 ffff880105380000 ffff88009dacfd28 ffffffff81340afd Call Trace: [<ffffffff8107f2d0>] ? collect_cpu_info_local+0x30/0x30 [<ffffffff810c2fb7>] ? __might_sleep+0xe7/0x100 [<ffffffff814d9882>] cpuidle_register_device+0x32/0x70 [<ffffffff81340afd>] intel_idle_cpu_init+0xad/0x110 [<ffffffff81340bc8>] cpu_hotplug_notify+0x68/0x80 [<ffffffff8166023d>] notifier_call_chain+0x4d/0x70 [<ffffffff810bc369>] __raw_notifier_call_chain+0x9/0x10 [<ffffffff81094a4b>] __cpu_notify+0x1b/0x30 [<ffffffff81652cf7>] _cpu_up+0x103/0x14b [<ffffffff81652e18>] cpu_up+0xd9/0xec [<ffffffff8164a254>] store_online+0x94/0xd0 [<ffffffff814122fb>] dev_attr_store+0x1b/0x20 [<ffffffff81216404>] sysfs_write_file+0xf4/0x170 [<ffffffff811a1024>] vfs_write+0xb4/0x130 [<ffffffff811a17ea>] sys_write+0x5a/0xa0 [<ffffffff816643a9>] system_call_fastpath+0x16/0x1b Code: 03 18 00 c9 c3 66 2e 0f 1f 84 00 00 00 00 00 55 48 89 e5 48 83 ec 30 48 89 5d e8 4c 89 65 f0 48 89 fb 4c 89 6d f8 e8 84 08 00 00 <48> 8b 78 08 49 89 c4 e8 f8 7f c1 ff 89 c2 b8 ea ff ff ff 84 d2 RIP [<ffffffff814d956c>] __cpuidle_register_device+0x1c/0x120 RSP <ffff88009dacfcb8> This patch fixes that by moving the CPU notifier registration as the last item to be done by the module. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Reviewed-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: 3.6+ <stable@vger.kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-03intel_idle: pr_debug information need separatedYouquan Song
When debug kernel, the the below information is found: intel_idle: unaware of model 0x1a MWAIT 4 please contact lenb@kernel.orgACPI: Device input0 -> No ACPI support so this patch separates it. Signed-off-by: Youquan Song <youquan.song@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-27cpuidle: Measure idle state durations with monotonic clockJulius Werner
Many cpuidle drivers measure their time spent in an idle state by reading the wallclock time before and after idling and calculating the difference. This leads to erroneous results when the wallclock time gets updated by another processor in the meantime, adding that clock adjustment to the idle state's time counter. If the clock adjustment was negative, the result is even worse due to an erroneous cast from int to unsigned long long of the last_residency variable. The negative 32 bit integer will zero-extend and result in a forward time jump of roughly four billion milliseconds or 1.3 hours on the idle state residency counter. This patch changes all affected cpuidle drivers to either use the monotonic clock for their measurements or make use of the generic time measurement wrapper in cpuidle.c, which was already working correctly. Some superfluous CLIs/STIs in the ACPI code are removed (interrupts should always already be disabled before entering the idle function, and not get reenabled until the generic wrapper has performed its second measurement). It also removes the erroneous cast, making sure that negative residency values are applied correctly even though they should not appear anymore. Signed-off-by: Julius Werner <jwerner@chromium.org> Reviewed-by: Preeti U Murthy <preeti@linux.vnet.ibm.com> Tested-by: Daniel Lezcano <daniel.lezcano@linaro.org> Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org> Acked-by: Len Brown <len.brown@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-09-26intel_idle: enable IVB Xeon supportLen Brown
IVB Xeon currently shares the same parameters IVB client. Signed-off-by: Len Brown <len.brown@intel.com>
2012-08-17intel_idle: Check cpu_idle_get_driver() for NULL before dereferencing it.Konrad Rzeszutek Wilk
If the machine is booted without any cpu_idle driver set (b/c disable_cpuidle() has been called) we should follow other users of cpu_idle API and check the return value for NULL before using it. Reported-and-tested-by: Mark van Dijk <mark@internecto.net> Suggested-by: Jan Beulich <JBeulich@suse.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-07-26Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux Pull ACPI & power management update from Len Brown: "Re-write of the turbostat tool. lower overhead was necessary for measuring very large system when they are very idle. IVB support in intel_idle It's what I run on my IVB, others should be able to also:-) ACPICA core update We have found some bugs due to divergence between Linux and the upstream ACPICA base. Most of these patches are to reduce that divergence to reduce the risk of future bugs. Some cpuidle updates, mostly for non-Intel More will be coming, as they depend on this part. Some thermal management changes needed by non-ACPI systems. Some _OST (OS Status Indication) updates for hot ACPI hot-plug." * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: (51 commits) Thermal: Documentation update Thermal: Add Hysteresis attributes Thermal: Make Thermal trip points writeable ACPI/AC: prevent OOPS on some boxes due to missing check power_supply_register() return value check tools/power: turbostat: fix large c1% issue tools/power: turbostat v2 - re-write for efficiency ACPICA: Update to version 20120711 ACPICA: AcpiSrc: Fix some translation issues for Linux conversion ACPICA: Update header files copyrights to 2012 ACPICA: Add new ACPI table load/unload external interfaces ACPICA: Split file: tbxface.c -> tbxfload.c ACPICA: Add PCC address space to space ID decode function ACPICA: Fix some comment fields ACPICA: Table manager: deploy new firmware error/warning interfaces ACPICA: Add new interfaces for BIOS(firmware) errors and warnings ACPICA: Split exception code utilities to a new file, utexcep.c ACPI: acpi_pad: tune round_robin_time ACPICA: Update to version 20120620 ACPICA: Add support for implicit notify on multiple devices ACPICA: Update comments; no functional change ...
2012-07-05ACPI: intel_idle : break dependency between modulesDaniel Lezcano
When the system is booted with some cpus offline, the idle driver is not initialized. When a cpu is set online, the acpi code call the intel idle init function. Unfortunately this code introduce a dependency between intel_idle and acpi. This patch is intended to remove this dependency by using the notifier of intel_idle. This patch has the benefit of encapsulating the intel_idle driver and remove some exported functions. Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org> Acked-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-06-05intel_idle: initial IVB supportLen Brown
From an OS point of view, IVB looks like SNB, but quicker. Signed-off-by: Len Brown <len.brown@intel.com>
2012-04-05simple_open: automatically convert to simple_open()Stephen Boyd
Many users of debugfs copy the implementation of default_open() when they want to support a custom read/write function op. This leads to a proliferation of the default_open() implementation across the entire tree. Now that the common implementation has been consolidated into libfs we can replace all the users of this function with simple_open(). This replacement was done with the following semantic patch: <smpl> @ open @ identifier open_f != simple_open; identifier i, f; @@ -int open_f(struct inode *i, struct file *f) -{ ( -if (i->i_private) -f->private_data = i->i_private; | -f->private_data = i->i_private; ) -return 0; -} @ has_open depends on open @ identifier fops; identifier open.open_f; @@ struct file_operations fops = { ... -.open = open_f, +.open = simple_open, ... }; </smpl> [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21drivers/idle/intel_idle.c: fix confusing code identationMarcos Paulo de Souza
Fix a code indentation in the function intel_idle_cpu_init that looks confusing.o Suggested-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Reviewed-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Marcos Paulo de Souza <marcos.mage@gmail.com> Cc: "Brown, Len" <len.brown@intel.com> Cc: Len Brown <lenb@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-15intel_idle: Revert change of auto_demotion_disable_flags for NehalemBen Hutchings
Commit b66b8b9a4a79087dde1b358a016e5c8739ccf186 ('intel-idle: convert to x86_cpu_id auto probing') added a distinction between Nehalem and Westemere processors and changed auto_demotion_disable_flags for the former to 0. This was not explained in the commit message, so change it back. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: Thomas Renninger <trenn@suse.de> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-13intel_idle: Fix ID for Nehalem-EX Xeon in device ID tableBen Hutchings
Commit b66b8b9a4a79087dde1b358a016e5c8739ccf186 ('intel-idle: convert to x86_cpu_id auto probing') put two entries for model 0x2f (Westmere-EX Xeon) in the device ID table and left out model 0x2e (Nehalem-EX Xeon). Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: Thomas Renninger <trenn@suse.de> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-02Merge 3.3-rc2 into the driver-core-next branch.Greg Kroah-Hartman
This was done to resolve a merge and build problem with the drivers/acpi/processor_driver.c file. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-26intel-idle: convert to x86_cpu_id auto probingAndi Kleen
With this it should be automatically loaded on suitable systems by udev. The old switch () is replaced with a table based approach, this also cleans up the code. Cc: Len Brown <lenb@kernel.org> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Thomas Renninger <trenn@suse.de> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-19ACPI processor hotplug: Delay acpi_processor_start() call for hotplugged coresThomas Renninger
Delay the setting up of features (cpuidle, throttling by calling acpi_processor_start()) to the time when the hotplugged core got onlined the first time and got fully initialized. Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-18Merge branches 'einj', 'intel_idle', 'misc', 'srat' and 'turbostat-ivb' into ↵Len Brown
release
2012-01-17intel_idle: Split up and provide per CPU initialization funcThomas Renninger
Function split up, should have no functional change. Provides entry point for physically hotplugged CPUs to initialize and activate cpuidle. Signed-off-by: Thomas Renninger <trenn@suse.de> CC: Deepthi Dharwar <deepthi@linux.vnet.ibm.com> CC: Shaohua Li <shaohua.li@intel.com> CC: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17intel idle: Make idle driver more robustThomas Renninger
kvm -cpu host passes the original cpuid info to the guest. Latest kvm version seem to return true for mwait_leaf cpuid function on recent Intel CPUs. But it does not return mwait C-states (mwait_substates), instead zero is returned. While real CPUs seem to always return non-zero values, the intel idle driver should not get active in kvm (mwait_substates == 0) case and bail out. Otherwise a Null pointer exception will happen later when the cpuidle subsystem tries to get active: [0.984807] BUG: unable to handle kernel NULL pointer dereference at (null) [0.984807] IP: [<(null)>] (null) ... [0.984807][<ffffffff8143cf34>] ? cpuidle_idle_call+0xb4/0x340 [0.984807][<ffffffff8159e7bc>] ? __atomic_notifier_call_chain+0x4c/0x70 [0.984807][<ffffffff81001198>] ? cpu_idle+0x78/0xd0 Reference: https://bugzilla.novell.com/show_bug.cgi?id=726296 Cc: stable@vger.kernel.org Signed-off-by: Thomas Renninger <trenn@suse.de> CC: Bruno Friedmann <bruno@ioda-net.ch> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17intel_idle: Fix a cast to pointer from integer of different size warning in ↵David Howells
intel_idle Fix the following warning: drivers/idle/intel_idle.c: In function 'intel_idle_cpuidle_devices_init': drivers/idle/intel_idle.c:518:5: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] By making get_driver_data() return a long instead of an int. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17intel_idle: remove redundant local_irq_disable() callYanmin Zhang
irq disabling happens earlier in process_32.c:cpu_idle. Basically, cpuidle_state->enter is called, cpu irq is disabled. cpuidle_state->enter would turn on irq when exiting. intel_idle doesn't follow this assumption. Although it doesn't cause real issue, it misleads developers. Remove the call to local_irq_disable() at entry. [akpm@linux-foundation.org: add comment] Signed-off-by: Mingming Zhang <mingmingx.zhang@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17intel_idle: fix API misuseShaohua Li
smp_call_function() only lets all other CPUs execute a specific function, while we expect all CPUs do in intel_idle. Without the fix, we could have one cpu which has auto_demotion enabled or has no broadcast timer setup. Usually we don't see impact because auto demotion just harms power and the intel_idle init is called in CPU 0, where boradcast timer delivers interrupt, but this still could be a problem. Cc: stable@vger.kernel.org Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2011-11-07Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: cpuidle: Single/Global registration of idle states cpuidle: Split cpuidle_state structure and move per-cpu statistics fields cpuidle: Remove CPUIDLE_FLAG_IGNORE and dev->prepare() cpuidle: Move dev->last_residency update to driver enter routine; remove dev->last_state ACPI: Fix CONFIG_ACPI_DOCK=n compiler warning ACPI: Export FADT pm_profile integer value to userspace thermal: Prevent polling from happening during system suspend ACPI: Drop ACPI_NO_HARDWARE_INIT ACPI atomicio: Convert width in bits to bytes in __acpi_ioremap_fast() PNPACPI: Simplify disabled resource registration ACPI: Fix possible recursive locking in hwregs.c ACPI: use kstrdup() mrst pmu: update comment tools/power turbostat: less verbose debugging
2011-11-06cpuidle: Single/Global registration of idle statesDeepthi Dharwar
This patch makes the cpuidle_states structure global (single copy) instead of per-cpu. The statistics needed on per-cpu basis by the governor are kept per-cpu. This simplifies the cpuidle subsystem as state registration is done by single cpu only. Having single copy of cpuidle_states saves memory. Rare case of asymmetric C-states can be handled within the cpuidle driver and architectures such as POWER do not have asymmetric C-states. Having single/global registration of all the idle states, dynamic C-state transitions on x86 are handled by the boot cpu. Here, the boot cpu would disable all the devices, re-populate the states and later enable all the devices, irrespective of the cpu that would receive the notification first. Reference: https://lkml.org/lkml/2011/4/25/83 Signed-off-by: Deepthi Dharwar <deepthi@linux.vnet.ibm.com> Signed-off-by: Trinabh Gupta <g.trinabh@gmail.com> Tested-by: Jean Pihet <j-pihet@ti.com> Reviewed-by: Kevin Hilman <khilman@ti.com> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-11-06cpuidle: Split cpuidle_state structure and move per-cpu statistics fieldsDeepthi Dharwar
This is the first step towards global registration of cpuidle states. The statistics used primarily by the governor are per-cpu and have to be split from rest of the fields inside cpuidle_state, which would be made global i.e. single copy. The driver_data field is also per-cpu and moved. Signed-off-by: Deepthi Dharwar <deepthi@linux.vnet.ibm.com> Signed-off-by: Trinabh Gupta <g.trinabh@gmail.com> Tested-by: Jean Pihet <j-pihet@ti.com> Reviewed-by: Kevin Hilman <khilman@ti.com> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-11-06cpuidle: Move dev->last_residency update to driver enter routine; remove ↵Deepthi Dharwar
dev->last_state Cpuidle governor only suggests the state to enter using the governor->select() interface, but allows the low level driver to override the recommended state. The actual entered state may be different because of software or hardware demotion. Software demotion is done by the back-end cpuidle driver and can be accounted correctly. Current cpuidle code uses last_state field to capture the actual state entered and based on that updates the statistics for the state entered. Ideally the driver enter routine should update the counters, and it should return the state actually entered rather than the time spent there. The generic cpuidle code should simply handle where the counters live in the sysfs namespace, not updating the counters. Reference: https://lkml.org/lkml/2011/3/25/52 Signed-off-by: Deepthi Dharwar <deepthi@linux.vnet.ibm.com> Signed-off-by: Trinabh Gupta <g.trinabh@gmail.com> Tested-by: Jean Pihet <j-pihet@ti.com> Reviewed-by: Kevin Hilman <khilman@ti.com> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-10-31x86: fix up files really needing to include module.hPaul Gortmaker
These files aren't just exporting symbols -- they are also defining a MODULE_LICENSE etc. so give them the full module.h file. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
