path: root/drivers/ieee1394/ohci1394.h
2007-07-10ieee1394: remove old isochronous ABIStefan Richter
Based on patch "the scheduled removal of RAW1394_REQ_ISO_{SEND,LISTEN}" from Adrian Bunk, November 20 2006. This patch also removes the underlying facilities in ohci1394 and disables them in pcilynx. That is, hpsb_host_driver.devctl() and hpsb_host_driver.transmit_packet() are no longer used for iso reception and transmission. Since video1394 and dv1394 only work with ohci1394 and raw1394's rawiso interface has never been implemented in pcilynx, pcilynx is now no longer useful for isochronous applications. raw1394 will still handle the request types but will complete the requests with errors that indicate API version conflicts. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-04-30ieee1394: move some comments from declaration to definitionStefan Richter
2006-06-12ohci1394: set address range propertiesBen Collins
This patch supplies the API extension introduced by patch "ieee1394: extend lowlevel API for address range properties" with proper addresses. Like in patch ''ohci1394, sbp2: fix "scsi_add_device failed" with PL-3507 based devices'', 1 TeraByte is chosen as physical upper bound. This leaves a window for the middle address range. This choice is only relevant for adapters which actually have a programmable pysical upper bound register. (Only ALi and Fujitsu adapters are known for this. Most adapters have a fixed bound at 4 GB.) The middle address range is suitable for posted writes. AFAIK, PCILynx does not support physical DMA nor posted writes, therefore no equivalent change in the pcilynx driver is necessary. There is also a driver for GP2Lynx, although not in mainline Linux. I assume this hardware does not support these OHCI features either. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Ben Collins <bcollins@ubuntu.com>
2005-11-18Remove amdtp, cmp drivers.Jody McIntyre
Remove the Audio and Music Data Transmission Protocol driver and the Connection Management Procedures driver. These are incomplete, have never worked, and are better implemented in userland via raw1394 (see http://freebob.sourceforge.net/ for example.) Signed-off-by: Jody McIntyre <scjody@steamballoon.com> Cc: Adrian Bunk <bunk@stusta.de>
2005-05-17[PATCH] ieee1394: fix cross_bound check for null ISO packetsJody McIntyre
Fix cross_bound to not return 1 for zero-length regions. Fixes regression when sending null ISO packets. Signed-off-by: Jody McIntyre <scjody@steamballoon.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
