I added a failure check in patch "sbp2: variable status FIFO address
(fix login timeout)" --- alas for a wrong error value. This is a bug
since Linux 2.6.16. Leads to NULL pointer dereference if the call
failed, and bogus failure handling if call succeeded.
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
There is a firmware bug in several Apple iPods which prevents access to
these iPods under certain conditions. The disk size reported by the iPod
is one sector too big. Once access to the end of the disk is attempted,
the iPod becomes inaccessible. This problem has been known for USB iPods
for some time and has recently been discovered to exist with
FireWire/USB combo iPods too.
This patch is derived from the fix in Linux 2.6.17, commit
e9a1c52c7b19d10342226c12f170d7ab644427e2, to be applicable to 2.6.16.x
without prerequisite patches. It hard-wires a workaround for three known
affected model numbers (those of 4th generation iPod, iPod Photo, iPod
mini).
Note: This patch lacks Linux 2.6.17's ability to enable and disable the
workaround via a module parameter.
Re-enable posted writes for status FIFO.
Besides bringing back a very minor bandwidth tweak from Linux 2.6.15.x
and older, this also fixes an interoperability regression since 2.6.16:
http://bugzilla.kernel.org/show_bug.cgi?id=6356
(sbp2: scsi_add_device failed. IEEE1394 HD is not working anymore.)
Tested-by: Vanei Heidemann <linux@javanei.com.br>
Tested-by: Martin Putzlocher <mputzi@gmx.de> (chip type unconfirmed)
sbp2util_mark_command_completed takes a lock which was already taken by
sbp2scsi_complete_all_commands. This is a regression in Linux 2.6.15.
Reported by Kristian Harms at
https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=187394
Cc: Ben Collins <bcollins@debian.org>
Cc: Jody McIntyre <scjody@modernduck.com>
Cc: Stefan Richter <stefanr@s5r6.in-berlin.de>
Since about Linux 2.6.14, sbp2's inquiry workaround did not work anymore
due to changes in the SCSI layer. Update it to become effective again.
Testing one of the two known affected bridges has shown that skip_ms_page_8
is required as well.
Also, make force_inquiry_hack tunable via /sys/module/sbp2/parameters.
Signed-off-by: Jody McIntyre <scjody@modernduck.com>
(cherry picked from 99496037c6744fd938ffb8ccfc8fc91762322ff8 commit)
Let the ieee1394 core select a suitable 1394 address range for sbp2's
status FIFO instead of using a fixed range. Since the core only selects
addresses which are guaranteed to be out of the "physical range" as per
OHCI 1.1, this patch also fixes an old bug:
OHCI controllers which implement a writeable PhysicalUpperBound register
included sbp2's status FIFO in the physical range. That way sbp2 was
never notified of a succesful login and always failed after timeout.
Affected OHCI host adapters include ALi and Fujitsu controllers.
As another side effect of this patch, the status FIFO is no longer
located in a range for which OHCI chips perform "posted writes". Each
status write now requires a response subaction. But since large data
transfers involve only few status writes, there is no measurable
decrease of I/O throughput. What's more, the status FIFO is now safe
from potential host bus errors. Nevertheless, posted writes could be
re-enabled by extensions to the ARM features of the 1394 stack.
(cherry picked from b2d38cccad4ef80d6b672b8f89aae5fe2907b113 commit)
If there were commands enqueued but not completed before an SBP-2 unit
was unplugged (or an attempt to reconnect failed), knodemgrd or any
process which tried to remove the device would sleep uninterruptibly
in blk_execute_rq(). Therefore make sure that all commands are
completed when sbp2 retreats.
(cherry picked from 61daa34c132c5d4ed8630e2c46e9bf2f0c7b3428 commit)
sbp2.c mangles INQUIRY response in a way that only applies to standard
inquiry data (i.e. when both cmddt and evpd bits are 0). Leave other cases
alone; e.g. when asking for VPD the length of reply is in byte 3, not 4
and byte 4 is the first byte of device serial number.
The feature removal was done in 7301c8d3a05dc52d33598364da7c4eb6ab6357eb
but these files were not removed for some reason.
These days ioctl32.h is only used for communication of fs/compat.c and
fs/compat_ioctl.c and doesn't contain anything of interest to drivers.
Remove inclusion in various drivers.
We had a report from one loony user who tried out suspend to disk using a
swap partition on a firewire drive. As the firewire thread was put to
sleep it didn't work out too well.
Signed-off-by: Dave Jones <davej@redhat.com>
Cc: Pavel Machek <pavel@ucw.cz>
Trivial manual merge fixup for usb_find_interface clashes.
Leave the overloaded "hotplug" word to susbsystems which are handling
real devices. The driver core does not "plug" anything, it just exports
the state to userspace and generates events.
Signed-off-by: Kay Sievers <kay.sievers@suse.de>
Ignore all files generated from *_shipped files, plus a few others.
Signed-off-by: Brian Gerst <bgerst@didntduck.org>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Use sbp2_remove_device() to free FIFO and ORB DMAs in a failure case.
sbp2_create_command_orb() code cleanup:
- add two helper functions to reduce nesting depth
- omit the return value which was always ignored
- remove unnecessary declaration from sb2.h
Print the number of IR and IT contexts which a hardware implements
as an informational log message when ohci1394 initializes.
recognition)
Some old 1394-1995 SBP-2 bridges would hang if they received a broadcast write
request to BROADCAST_CHANNEL before the config ROM was read. Affected devices
include Datafab MD2-FW2 2.5" HDD and SmartDisk VST FWCDRW-V8 portable CD writer.
The write request is now directed to specific nodes instead of being broadcast
to all nodes at once, and it is only performed if a previous read request at
this register succeeded.
Fixes an old interoperability problem which was perceived as a 2.6.14-specific
regression: http://marc.theaimsgroup.com/?t=113190586800003
(cherry picked from 61c7f775ca25ccfc0e51486103a724fb1a3a08f2 commit)
After initializing an IEEE 1394 host, broadcast a resume packet. This makes
remote nodes visible which suspended their ports while the host was down.
Such nodes had to be unplugged and replugged in order to be recognized.
Motorola DCT6200 cable reciever was affected, probably other devices too.
http://marc.theaimsgroup.com/?t=113202715800001
(cherry picked from 14c0fa243b358c24040ff5f44b60c47aaf6430c3 commit)
If scsi_add_device() at the end of sbp2_start_device() fails, e.g. due to
transport errors during SCSI inquiry, sbp2 needs to log out of the device
and release all associated resources.
DMA_BIDIRECTIONAL data direction may be handled properly by Linux in the
future. For now, reject it instead to convert it to another direction.
After a bus reset, let nodemgr call high-level update hooks first for nodes
which do not need to be probed. The main benefit is for a bus with more
than one SBP-2 device: SBP-2 reconnects will be performed before SBP-2
logins, thus have a much higher chance to succeed, and their SCSI devices
will not be blocked much longer than necessary. This was demonstrated for
Linux 2.4 by Dave Cinege a while ago.
A better approach would be to perform time-consuming probes in parallel by a
subthread. I actually plan to implement this for sbp2 but it may take a
while to get that done and tested. Until then, this tweak is a huge
improvement for users with multiple SBP-2 devices.
recognition)
Eliminate some code in hpsb_send_phy_config() which is provided
by hpsb_make_phypacket().
Introduce new macros related to phy packets and use them in ieee1394_core and
nodemgr.
This patch contains fixes by LIndent.
Signed-off-by: Jens-Michael Hoffmann <jensmh@gmx.de>
Don't read the keyval if there's already a valid one in place. May not be
necessary but shouldn't hurt.
Signed-off-by: Jody McIntyre <scjdy@steamballoon.com>
csr1212_parse_csr() did not properly check return values when reading
keyvals. Fix this by using _csr1212_read_keyval() instead of
csr1212_get_keyval() and checking the return code.
Signed-off-by: Jody McIntyre <scjody@steamballoon.com>
raw1394: use correct deallocation macro for CSR cache
The coverity checker spotted that this was a NULL pointer dereference in
the "if (copy_from_user(...))" case since the next step is to
kfree(cache->filled_head).
There's no need to free cache at this point, and it's getting free'd
later.
- sbp2scsi_reset does not need to take host_lock
- sbp2scsi_reset, as our device reset handler, does not need to stand in as
bus reset or host reset handler
- let scsi_mod use scsi_host_template.name instead of .info
(sbp2 is not an emulation anway)
This patch fixes the incoherent timestamps generated by video1394 since
the single-buffer patch was applied in 2.6.11. Credits have also been
removed from the header and a "//" comment was changed to "/* */".
Signed-off-by: Damien Douxchamps <ddouxchamps@users.sf.net>
it's global functions.
Fixes an oops in sbp2util_find_command_for_SCpnt after sbp2scsi_abort:
https://bugzilla.novell.com/show_bug.cgi?id=113734
(cherry picked from 7945619794314414a5c44df11fca4d3f2a3389cf commit)
Remove the Audio and Music Data Transmission Protocol driver and the
Connection Management Procedures driver. These are incomplete, have never
worked, and are better implemented in userland via raw1394 (see
http://freebob.sourceforge.net/ for example.)
Cc: Adrian Bunk <bunk@stusta.de>
Use schedule_timeout_interruptible() instead of
set_current_state()/schedule_timeout() to reduce kernel size.
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com>
dv1394 and video1394.
dv1394, eth1394, ieee1394, ohci1394, pcilynx, raw1394, sbp2c, video1394:
- use kzalloc
- provide safer size arguments to kmalloc and kzalloc
- omit some casts
Their version information is not trustworthy.
sbp2: various code formatting cleanups
ohci1394: remove form feed characters
