[ Upstream commit df1d80aee963480c5c2938c64ec0ac3e4a0df2e0 ]
For devices from the SigmaDelta family we need to keep CS low when doing a
conversion, since the device will use the MISO line as a interrupt to
indicate that the conversion is complete.
This is why the driver locks the SPI bus and when the SPI bus is locked
keeps as long as a conversion is going on. The current implementation gets
one small detail wrong though. CS is only de-asserted after the SPI bus is
unlocked. This means it is possible for a different SPI device on the same
bus to send a message which would be wrongfully be addressed to the
SigmaDelta device as well. Make sure that the last SPI transfer that is
done while holding the SPI bus lock de-asserts the CS signal.
Signed-off-by: Alexandru Ardelean <Alexandru.Ardelean@analog.com>
Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
commit fccfb9ce70ed4ea7a145f77b86de62e38178517f upstream.
The desired channel has to be selected in order to correctly fill the
buffer with the corresponding data.
The `ad_sd_write_reg()` already does this, but for the
`ad_sd_read_reg_raw()` this was omitted.
Fixes: af3008485ea03 ("iio:adc: Add common code for ADI Sigma Delta devices")
Signed-off-by: Dragos Bogdan <dragos.bogdan@analog.com>
Signed-off-by: Alexandru Ardelean <alexandru.ardelean@analog.com>
Cc: <Stable@vger.kernel.org>
commit 7fc10de8d49a748c476532c9d8e8fe19e548dd67 upstream.
Since most of the SD ADCs have the option of reseting the serial
interface by sending a number of SCLKs with CS = 0 and DIN = 1,
a dedicated function that can do this is usefull.
Needed for the patch: iio: ad7793: Fix the serial interface reset
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
This can result in wrong reference count for trigger device, call
iio_trigger_get to increment reference.
Refer to http://www.spinics.net/lists/linux-iio/msg13669.html for discussion
with Jonathan.
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
Cc: Stable@vger.kernel.org
iio_trigger_poll_chained()
argument has been ignored; adjust drivers accordingly
Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net>
Use this new function to make code more comprehensible, since we are
reinitialzing the completion, not initializing.
[akpm@linux-foundation.org: linux-next resyncs]
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Acked-by: Linus Walleij <linus.walleij@linaro.org> (personally at LCE13)
The equivalent of iio_sw_buffer_preenable() is now done in the IIO buffer core,
so there is no need to do this from the driver anymore.
Makes the code a bit shorter and less ugly.
Now that iio_push_to_buffers() takes a void pointer for the data parameter we
can remove those casts to u8*.
Introduce iio_tigger_{set,get}_drvdata which allows to attach driver specific
data to a trigger. The functions wrap access to the triggers private_data field
and all current users are updated to use iio_tigger_{set,get}_drvdata instead of
directly accessing the private_data field. This is the first step towards
removing the private_data field from the iio_trigger struct.
The following coccinelle script has been used to update the drivers:
<smpl>
struct iio_trigger *trigger;
expression priv;
-trigger->private_data = priv
+iio_trigger_set_drv_data(trigger, priv)
+iio_trigger_get_drv_data(trigger)
</smpl>
Route all buffer writes through the demux.
Addition or removal of a buffer results in tear down and
setup of all the buffers for a given device.
Tested-by: srinivas pandruvada <srinivas.pandruvada@intel.com>
Drop timestamp parameter from buffer store_to callback and subsequently from
iio_push_to_buffer. The timestamp parameter is unused and it seems likely that
it will stay unused in the future, so it should be safe to remove it.
Most devices from the Analog Devices Sigma Delta family use a similar scheme for
communication with the device. This includes register access, as well as trigger
handling. But each device sub-family has different features and different
register layouts (some even have no registers at all) and thus it is impractical
to try to support all of the devices by the same driver. This patch adds a
common base library for Sigma Delta converter devices. It will be used by
individual drivers.
This code is mostly based on the three existing Sigma Delta drivers the AD7192,
AD7780 and AD7793, but has been improved for more robustness and flexibility.
