commit 5ba5b437efaa7a502eec393c045d3bf90c92c4e9 upstream.
We should be allocating enough information for a tiadc_device struct
which is about 400 bytes but instead we allocate enough for a second
iio_dev struct which is over 2000 bytes.
Fixes: fea89e2dfcea ("iio: adc: ti_am335x_adc: use variable names for sizeof() operator")
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
commit f7d86ecf83cb66d3c4c6ac4edb1dd50c0919aa2b upstream.
The third argument of devm_request_threaded_irq() is the primary
handler. It is called in hardirq context and checks whether the
interrupt is relevant to the device. If the primary handler returns
IRQ_WAKE_THREAD, the secondary handler (a.k.a. handler thread) is
scheduled to run in process context.
bcm_iproc_adc.c uses the secondary handler as the primary one
and the other way around. So this patch fixes the same, along with
re-naming the secondary handler and primary handler names properly.
Tested on the BCM9583XX iProc SoC based boards.
Fixes: 4324c97ecedc ("iio: Add driver for Broadcom iproc-static-adc")
Reported-by: Pavel Roskin <plroskin@gmail.com>
Signed-off-by: Raveendra Padasalagi <raveendra.padasalagi@broadcom.com>
commit e83bb3e6f3efa21f4a9d883a25d0ecd9dfb431e1 upstream.
The tiadc_irq_h(int irq, void *private) function is handling FIFO
overruns by clearing flags, disabling and enabling the ADC to
recover.
If the ADC is running in continuous mode a FIFO overrun happens
regularly. If the disabling of the ADC happens concurrently with
a new conversion. It might happen that the enabling of the ADC
is ignored by the hardware. This stops the ADC permanently. No
more interrupts are triggered.
According to the AM335x Reference Manual (SPRUH73H October 2011 -
Revised April 2013 - Chapter 12.4 and 12.5) it is necessary to
check the ADC FSM bits in REG_ADCFSM before enabling the ADC
again. Because the disabling of the ADC is done right after the
current conversion has been finished.
To trigger this bug it is necessary to run the ADC in continuous
mode. The ADC values of all channels need to be read in an endless
loop. The bug appears within the first 6 hours (~5.4 million
handled FIFO overruns). The user space application will hang on
reading new values from the character device.
Fixes: ca9a563805f7a ("iio: ti_am335x_adc: Add continuous sampling support")
Signed-off-by: Michael Engl <michael.engl@wjw-solutions.com>
commit d1aaf20ee655888c227d5137b7a63551f8d15416 upstream.
The suspend/resume functions were using dev_to_iio_dev() to get
the iio_dev. That only works on IIO dev's. Use dev_get_drvdata()
for a platform device to get the correct iio_dev.
Signed-off-by: Alison Schofield <amsfield22@gmail.com>
Commit 08e05d1fce5c ("ti-adc081c: Initial triggered buffer support") added
triggered buffer support but that also requires CONFIG_IIO_TRIGGERED_BUFFER,
otherwise we get errors from linker such as:
drivers/built-in.o: In function `adc081c_remove':
drivers/iio/adc/ti-adc081c.c:225: undefined reference to `iio_triggered_buffer_cleanup'
Fix these by explicitly selecting both CONFIG_IIO_TRIGGERED_BUFFER and
CONFIG_IIO_BUFFER in Kconfig for the driver.
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Check for iio_info structures that are only stored in the info field of a
iio_dev structure. This field is declared const, so iio_info structures
that have this property can be declared as const also.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r disable optional_qualifier@
identifier i;
position p;
static struct iio_info i@p = { ... };
@ok@
identifier r.i;
struct iio_dev e;
position p;
e.info = &i@p;
@bad@
position p != {r.p,ok.p};
identifier r.i;
struct iio_info e;
e@i@p
@depends on !bad disable optional_qualifier@
identifier r.i;
static
+const
struct iio_info i = { ... };
// </smpl>
The result of size on this file before the change is:
1529 312 0 1841 731
drivers/iio/adc/men_z188_adc.o
and after the change it is:
1689 168 0 1857 741
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next
Jonathan writes:
Second set of iio new device support, features and cleanups for the 4.9 cycle.
New device support
* ad8801 dac
- new driver supporting ad8801 and ad8803 DACs.
* adc12138
- new driver supporting TI adc12130/adc12132 and adc12138 ADCs.
* ltc2485 adc
- new driver
* mxc6255
- add support for the mxc6225 part name and fixup the ID check so it works.
* vz89x VOC sensor
- add support for the vz89te part which drops the voc_short channel and adds
CRCs compared to other supported parts.
New features
* core
- immutable triggers. These effectively grant exclusive control over a
trigger. The typical usecase is a device representing an analog part
(perhaps a MUX) that needs to control the sampling of a downstream
ADC.
- resource managed trigger registration and triggered_buffer_init.
- iio_push_event now protected against case of the event interface
registration not having yet occured. Only matters if an interrupt
can occur during this window - might happen on shared interrupt lines.
- helper to let a driver query if the trigger it is using is provided by
itself (using the convention of both device and trigger having the same
parent).
* tools
- iio-utils. Used channel modifier scaling in preference to generic scaling
when both exist.
* at91-adc
- Add support for touchscreen switches closure time needed by some newer
parts.
* stx104
- support the ADC channels on this ADC/DAC board. As these are the primary
feature of the board also move the driver to the iio/adc directory.
* sx9500
- device tree bindings.
Cleanups / Fixes
* ad5755
- fix an off-by-one on devnr limit check (introduced earlier this cycle)
* ad7266
- drop NULL check on devm_regulator_get_optional as it can't return NULL.
* ak8974
- avoid an unused functional warning due to rework in PM core code.
- remove .owner field setting as done by i2c_core.
* ina2xx
- clear out a left over debug field from chip global data.
* hid-sensors
* maxim-thermocouple
- fix non static symbol warnings.
* ms5611
- fetch and enable regulators unconditionally when they aren't optional.
* sca3000
- whitespace cleanup.
* st_sensors
- fetch and enable regulators unconditionally rather than having them
supported as optional regulators (missunderstanding on my part amongst
others a while back)
- followup to previous patch fixes error checking on the regulators.
- mark symbols static where possible.
- use the 'is it my trigger' help function. This prevents the odd case
of another device triggering from the st-sensors trigger whilst the
st-sensors trigger is itself not using it but rather using say an hrtimer.
* ti-ads1015
- add missing of_node_put.
* vz89x
- rework to all support of new devices.
- prevent reading of a corrupted buffer.
- fixup a return value of 0/1 in a bool returning function.
Address updates
- Vlad Dogaru email address change.
On newer components compatible with the at91sam9x5, the Touchscreen
Switches Closure Time or TSSCTIM value of the Touchscreen Mode Register is
not filled at all.
On some hardware, having no time indicated for it may lead to incoherent
values and jitter.
We fix this time to 10us as it is usually difficult to retrieve impedance
values from LCD manufacturers.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
This patch is inspired by a comment of Jonathan Cameron on patch of
Linus Walleij commit aeb55fff3891834e07a3144159a7298a19696af8 ("iio:
st_sensors: fetch and enable regulators unconditionally"). Because
changes made in this patch are actually reference generators they should
be using devm_regulator_get_optional, but if they do not explicitly set
the reference to NULL they should not be using IS_ERR_OR_NULL, but
simple IS_ERR check.
Suggested-by: Lars-Peter Clausen <lars@metafoo.de>
Signed-off-by: Crt Mori <cmo@melexis.com>
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
We want the staging fixes in here as well to handle merge issues.
The Apex Embedded Systems STX104 features 16 channels of single-ended (8
channels of true differential) 16-bit analog input. Differential input
configuration may be selected via a physical jumper on the device.
Similarly, input polarity (unipolar/bipolar) is configured via a
Input gain selection is available to the user via software, thus
allowing eight possible input ranges: +-10V, +-5V, +-2.5V, +-1.25V,
0 to 10V, 0 to 5V, 0 to 2.5V, and 0 to 1.25V. Four input gain
configurations are supported: x1, x2, x4, and x8.
This ADC resolution is 16-bits (1/65536 of full scale). Analog input
samples are taken on software trigger; neither FIFO sampling nor
interrupt triggering is supported by this driver.
The Apex Embedded Systems STX104 is primarily an analog-to-digital
converter device. The STX104 IIO driver was initially placed in the DAC
directory because only the DAC portion of the STX104 was supported at
the time. Now that ADC support has been added to the STX104 IIO driver,
the driver should be moved to the more appropriate ADC directory.
Signed-off-by: William Breathitt Gray <vilhelm.gray@gmail.com>
commit 1961bce76452 "iio: ina2xx: Remove trace_printk debug
statements" removed the code that used the chip->prev_ns field.
This patch cleans it up further by removing the unused field
and assignments.
Cc: Daniel Baluta <daniel.baluta@gmail.com>
This adds Texas Instruments' ADC12130/ADC12132/ADC12138 12-bit plus
sign ADC driver. I have tested with the ADC12138. The ADC12130 and
ADC12132 are not tested but these are similar to ADC12138 except that
the mode programming instruction is a bit different.
Acked-by: Rob Herring <robh@kernel.org>
Cc: Jonathan Cameron <jic23@kernel.org>
Cc: Hartmut Knaack <knaack.h@gmx.de>
Cc: Lars-Peter Clausen <lars@metafoo.de>
Cc: Peter Meerwald <pmeerw@pmeerw.net>
ads1015_get_channels_config_of()
When terminating for_each_child_of_node() iteration with
break or return, of_node_put() should be used to prevent
stale device node references from being left behind.
This is detected by Coccinelle semantic patch.
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
Adds basic support for the LTC2485 ADC - a delta-sigma analog-to-digital
converter with an I2C interface that operates in single shot conversion
mode.
The driver supports an on board 5V reference and the power-on default
configuration which rejects both 50hz & 60hz line frequencies and
operates in 1x speed mode.
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into work-testing
Jonathan writes:
First round of new features, device support and cleanups for IIO in the 4.9 cycle.
Device support
* ak8974
- New driver and bindings for this 2009 vintage magnetometer (it was very
popular back then!)
* atlas-ph-sensor
- ORP sensor support(I had to look up what one of these was)
* cio-dac
- New driver for Measurement Computing DAC boards
* dmard06
- New driver for Domintech DMARDO6 accelerometer. Also vendor prefix.
* dmard09
- New driver for Domintech DMARD09 accelerometer.
- max6675 and max31855 new driver
* mt6577 auxdac
- new driver for this Mediatek chip mt2701, mt6577 and mt8173 have this
hardware.
* ti-adc161s626
- new driver for this TI single channel differential ADC.
* vcnl4000
- support vcnl4010 and vcnl4020 which are compatible for all features
currently supported by this driver.
New features
* Core
- Allow retrieving of underlying iio_dev from a callback buffer handle.
This is needed to allow client drivers to perform operations such as
configuring the trigger used.
* hid-sensors
- asynchronous resume support to avoid really long resume times.
* kxcjk-1013
- add the mysterious KIOX000A ACPI id seen in the wild.
* Tools
- lsiio now enumerates processed as well as raw channels.
Cleanup
* ad7298
- use iio_device_claim_direct_mode and friends to simplify locking around
mode switching and drop some boilerplate.
* ad7793
* ade7854
- checkpatch fixups (alignment of parameters)
* atlas-ph-sensor
- Switch to REGCACHE_NONE as there are no useful register to cache.
* bma180
* hdc100x
- Add mention of the HDC1000 and HDC1008 to the Kconfig help text.
* isl29018
- Add driver specific prefixes to defines and function names.
- Remove excessive logging.
- Drop newlines which add nothing to readability.
- General tidying up of comments.
- Drop I2C_CLASS_HWMON as irrelevant to driver.
* isl29028
- Add driver specific prefixes to defines, enums and function names.
- Drop comma's from available attribute output as not ABI compliant.
* kxsd9
- devicetree bindings.
* mag3110
- This one wasn't locking to protect against mode switches during
raw_reads. Use the iio_claim_direct_mode function to fix this buglet.
* maxim-theromcouple
- Fix missing selects for triggered buffer support in Kconfig.
* nau7802
- Use complete instead of complete_all as only one completion at a time.
* sx9500
* us5182d
- Add a missing error code asignment instead of checking the result of
an already checked statement.
* vcnl4000
- Use BIT macro where appropriate.
- Refactor return codes in read_raw callback.
- Add some missing locking for concurrent accesses to the device.
SARADC controller needs to be reset before programming it, otherwise
it will not function properly.
Signed-off-by: Caesar Wang <wxt@rock-chips.com>
Cc: Heiko Stuebner <heiko@sntech.de>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: linux-iio@vger.kernel.org
Cc: linux-rockchip@lists.infradead.org
Tested-by: Guenter Roeck <linux@roeck-us.net>
Cc: <Stable@vger.kernel.org>
Add Mediatek auxadc driver based on iio.
It will register a device in iio and support iio.
So thermal can read auxadc channel to sample data by iio device.
It is tested successfully on mt2701 platform.
Mt8173 and mt6577 platforms are not tested.
But the expectation is compatible.
Signed-off-by: Zhiyong Tao <zhiyong.tao@mediatek.com>
Now that open delay and sample delay for each channel is configurable
via DT, the default IDLE_TIMEOUT value is not enough as this is
calculated based on hardcoded macros. This results in driver returning
EBUSY sometimes. Fix this by increasing the timeout
value based on maximum value possible to open delay and sample delays
for each channel.
Fixes: 5dc11e810676e ("iio: adc: ti_am335x_adc: make sample delay, open delay, averaging DT parameters")
Signed-off-by: Vignesh R <vigneshr@ti.com>
Acked-by: Lee Jones <lee.jones@linaro.org>
It is possible that two or more ADC channels can be simultaneously
requested for raw samples, in which case there can be race in access to
FIFO data resulting in loss of samples.
If am335x_tsc_se_set_once() is called again from tiadc_read_raw(), when
ADC is still acquired to sample one of the channels, the second process
might be put into uninterruptible sleep state. Fix these issues, by
protecting FIFO access and channel configurations with a mutex. Since
tiadc_read_raw() might take anywhere between few microseconds to few
milliseconds to finish execution (depending on averaging and delay
values supplied via DT), its better to use mutex instead of spinlock.
Fixes: 7ca6740cd1cd4 ("mfd: input: iio: ti_amm335x: Rework TSC/ADC synchronization")
Add support for Texas Instruments ADC141S626, and ADC161S626 chips.
Signed-off-by: Matt Ranostay <mranostay@gmail.com>
The call to i2c_get_clientdata(client) returns a struct iio_dev*, not
the needed struct ads1015_data*. We need here an intermediate step as
in the function: void ads1015_get_channels_config(struct i2c_client *client).
Signed-off-by: Giorgio Dal Molin <giorgio.nicole@arcor.de>
Fixes: ecc24e72f437 ("iio: adc: Add TI ADS1015 ADC driver support")
There is only one waiter for the completion, therefore there
is no need to use complete_all(). Let's make that clear by
using complete() instead of complete_all().
The usage pattern of the completion is:
waiter context waker context
nau7802_read_irq()
reinit_completion()
nau7802_read_conversion()
wait_for_completion_interruptible_timeout()
nau7802_eoc_trigger()
complete()
Signed-off-by: Daniel Wagner <daniel.wagner@bmw-carit.de>
The driver always assumes that an input device has been created when
reading channel 3. This causes a kernel panic when dereferencing
st->ts_input.
The change was introduced in
commit 84882b060301 ("iio: adc: at91_adc: Add support for touchscreens
without TSMR"). Earlier versions only entered that part of the if-else
statement if only the following flags are set:
AT91_ADC_IER_XRDY | AT91_ADC_IER_YRDY | AT91_ADC_IER_PRDY
Signed-off-by: Anders Darander <anders@chargestorm.se>
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
The data buffer for captured mode for the ad799x driver is allocated in the
update_scan_mode() callback. This callback is not set in the iio_info
struct for the ad7791/ad7995/ad7999, which means that the data buffer is
not allocated when a captured transfer is started. As a result the driver
crashes when the first sample is received. To fix this properly set the
Fixes: d8dca33027c1 ("staging:iio:ad799x: Preallocate sample buffer")
Replace the code that guarantees the device stays in direct mode
with iio_device_claim_direct_mode() which does same.
Jonathan writes:
Third set of IIO new device support, features and cleanups for the 4.8 cycle.
New core features
- Selection of the clock source for IIO timestamps. This is done per device
as it makes little sense to have events in one timebase and data timestamped
on another. Biggest reason for this is that we currently use a clock
source which is non monotonic which can result in 'interesting' data sets.
(Includes export for get_monotonic_corse64 which Thomas Gleixner didn't mind
in an earlier version.)
- MAINTAINERS add the git tree to the list for IIO.
New device support + a kind of indirect staging graduation.
* Broadcom iproc-static-adc
- new driver
* mcp4531
- support for MCP454x, MCP456x, MCP464x and MCP466x potentiometers
* mpu6050
- support the IC20608 6 axis motion tracking device
* st-sensors
- support the lis3l02dq + drop the lis3l02dq driver from staging.
The general purpose driver is missing event support, but good to get
rid of this driver which was rather long in the tooth.
New driver features
* ak8975
- Add vid regulator support and refactor handling in general.
- Allow a delay after enabling regulators.
- Runtime and system PM.
* bmg160
- filter frequency control support.
* bmp280
- SPI device support.
- EOC interrupt support for the BMP085
- power management support.
- supply regulator support.
- reset gpio support
- dt bindings for reset gpio and regulators.
- of table to support device tree registration
* max1363
- Device tree bindings.
* mcp4531
* st-pressure
- temperature channels as part of triggered buffer (previously not due
probably to alignment issues - see below).
- lps22hb open drain interrupt support.
- lps22hb temperature channel support
Cleanups and reworkings.
* numerous ADC drivers
- ensure the iio_dev->dev.of_node is set to the parent dev.of_node so
as to allow client bindings to find the device.
* ak8975
- Fix incorrect handling of missing regulator
- make sure power is down and remove.
* bmp280
- read the calibration data only once as it doesn't change.
* isl29125
- Use a few macros to make code a touch more readable.
* mma8452
- fix a memory leak on error.
- drop an unecessary bit of return value handling.
* potentiometer kconfig
- typo fix.
* st-pressure
- drop some uninformative default assignments of elements of the channel
array structure (aids readability).
* st-sensors
- Harden interrupt handling considerably. These are actually all using
level interrupts, but at least two known boards have them wired to
edge only interrupt chips. Hence a slightly interesting bit of handling
is needed in which we first allow for the easy option (level triggered) and
secondly check the status registers before reenabling edge interrupts and
fall back to a tight loop in the thread until we successfully clear the
interrupt. No harm is done if we never succeed in doing so. It's an odd
patch that has been through a lot of revisions to reach a consensus on how
to handle what is basically broken hardware (which the previous defaults
allowed to kind of work).
- Fix alignment to defined storagebytes boundaries.
- Ensure alignment of power of 2 byte boundaries. This has always in theory
been part of the ABI of IIO, but we missed a few that snuck in that need
fixing. The effect was minor as they were only followed by timestamp
channels which were correctly aligned,
- Add some docs to explain the gain calculations.
We want the staging fixes in here as well.
Adding missing indio_dev->dev.of_node references to allow iio consumers
to access the device channels.
Add the pointer to the device tree node of the ADC so that iio
consumers can reference the respective channels.
Acked-by: Daniel Baluta <daniel.baluta@intel.com>
This patch adds the necessary device tree binding to allow DT probing of
currently supported parts.
Signed-off-by: Florian Vaussard <florian.vaussard@heig-vd.ch>
This patch adds basic driver implementation for Broadcom's
static adc controller used in iProc SoC's family.
Reviewed-by: Ray Jui <ray.jui@broadcom.com>
Reviewed-by: Scott Branden <scott.branden@broadcom.com>
Adds a new per-device sysfs attribute "current_timestamp_clock" to allow
userspace to select a particular POSIX clock for buffered samples and
events timestamping.
Following clocks, as listed in clock_gettime(2), are supported:
CLOCK_REALTIME, CLOCK_MONOTONIC, CLOCK_MONOTONIC_RAW,
CLOCK_REALTIME_COARSE, CLOCK_MONOTONIC_COARSE, CLOCK_BOOTTIME and
CLOCK_TAI.
Signed-off-by: Gregor Boirie <gregor.boirie@parrot.com>
Acked-by: Sanchayan Maity <maitysanchayan@gmail.com>
Jonathan writes:
Second round of new iio device support, features and cleanups in the 4.8 cycle
Firstly some contact detail updates:
* NXP took over freescale. Update the mma8452 header to reflect this.
* Martin Kepplinger email address change in mma8452 header.
* Adriana Reus has changed email address. Update .mailmap.
* Matt Ranostay has changed email address. Update .mailmap.
New Device Support
* max1363
- add the missing i2c_device_ids for a couple of parts so they can actually
be used.
* ms5867
- add device ids for ms5805 and ms5837 parts.
New Features
* ad5755
- DT support. This one was a bit controversial and under review for a long
time. Still no one could come up with a better solution.
* stx104
- add gpio support
* ti-adc081c
- Add ACPI device ID matching.
Core changes
* Refuse to register triggers with duplicate names. There is no way to
distinguish between them so this makes no sense. A few drivers do not
generate unique names for each instance of the device present. We can't
fix this without changing ABI so leave them and wait for someone to
actually take the rare step of two identical accelerometers on the same
board.
* buffer-dma
- use ARRAY_SIZE in a few appropriate locations.
Tools
* Fix the fact that the --trigger-num option in generic_buffer didn't allow
0 which is perfectly valid in the ABI.
Cleanups
* as3935
- improve error reporting.
- remove redundant zeroing of a field in iio_priv.
* gp2ap020a00f
- use the iio_device_claim_*_mode helpers rather than open coding locking
around mode changes.
* isl29125
- use the iio_device_claim_*_mode helpers rather than open coding locking.
* lidar
* mma8452
- more detail in devices supported description in comments (addresses and
similar)
* sca3000
- add a missing error check.
* tcs3414
* tcs3472
The driver supports MAX11644, MAX11645, MAX11646 and MAX11647 parts. But
the corresponding i2c_device_id are missing. Add them!
Add ACPI device ID matching for TI ADC081C/ADC101C/ADC121C ADCs.
Signed-off-by: Dan O'Donovan <dan@emutex.com>
Currently the ad7266 driver treats any failure to get vref as though the
regulator were not present but this means that if probe deferral is
triggered the driver will act as though the regulator were not present.
Instead only use the internal reference if we explicitly got -ENODEV which
is what is returned for absent regulators.
Signed-off-by: Mark Brown <broonie@kernel.org>
The ad7266 driver attempts to support deciding between the use of internal
and external power supplies by checking to see if an error is returned when
requesting the regulator. This doesn't work with the current code since the
driver uses a normal regulator_get() which is for non-optional supplies
and so assumes that if a regulator is not provided by the platform then
this is a bug in the platform integration and so substitutes a dummy
regulator. Use regulator_get_optional() instead which indicates to the
framework that the regulator may be absent and provides a dummy regulator
instead.
All regulator_get() variants return either a pointer to a regulator or an
ERR_PTR() so testing for NULL makes no sense and may lead to bugs if we
use NULL as a valid regulator. Fix this by using IS_ERR() as expected.
Jonathan writes:
First round of IIO new device support, features and cleanups for the 4.8 cycle.
New device support
* ads1015
- add ads1115 support
* bma220 accelerometer
- new driver
- triggered buffer support.
* bmc150
- add bmm150 support.
* bmp280
- bme280 support with addition of humidity channel.
* max5487 potentiometer
- new driver
* MMA7660FC accelerometer.
- New driver
* st-pressure
- support for the lps22hb
* loop trigger.
- This one is *nasty* but we have real applications (parrot drones) where
it is useful. The trigger basically spins as hard as it can firing off
a new trigger each time all triggered devices come back to say they are
done. It doesn't hang a machine even when doing it on a dummy driver.
A lot nicer than having this implemented within lots of device drivers
anyway.
Core stuff
* Add support to create IIO devices via configfs (similar to we did for
triggers a while back) + docs.
* New channel types
- IIO_ELECTRICAL_CONDUCTIVITY
* Couple of MAINTAINERS patches to list the device tree bindings.
* Make trigger ops structure non optional (comment fix). It hasn't been for
an awful long time, but that's not what the description said.
New features
* ak8975
- support adapters that are limited to byte data only by allowing the
emulated block read i2c function that was recently introduced.
* atlas-ph
- support atlas-ec (electrical conductivity sensor)
* bmi160
- add available frequency and scale attributes to make the driver
more user friendly (and avoid having to read the datasheet to know
what will work).
* dummy
- move creation to configfs interface. It's not real hardware so we
are not that worried about the ABI breakage ;)
* mma8452
- oversampling ration support
* nau7802
- expose available gains to make life easier for userspace.
* st-sensors
- allow use of emulation for SMBus block reads as all the st parts support
it.
* ti-ads1015
- list datasheet names to allow their use by inkernel consumers.
* Various module alias additions to help auto probing. Drop one redundant one
as well.
Cleanups
* ad7266, ad7476, ad7887, ad7923, ad799x
- use direct mode claim function rather than open coding it during sensor
read (prevents switching on buffers mid read).
* ad7793, ad7791
- use direct mode claim to prevent frequency changes when buffers running.
* afe440x - These are ABI breaking but the driver requires custom userspace
code to do anything useful anyway and that is still being written and under
control of TI. Ultimately we may have other libraries to do pulse
oximetry with these devices but we aren't aware of any yet.
- kernel-doc format fixes
- drop ifdef fun around of_match_ptr - it's not worth the mess to save
a tiny amount of space.
- drop some unnecessary register initializations.
- drop the weird locked gain modes as they gain us nothing (can just set
all gains separately).
- remove handling of offset attributes seeing as no channels actually have
them (oops)
- Drop the LED3 input channel as it's an alias for ALED2.
- *big one* remove channel names - an experiment that turned out to not
make sense - see patch for details.
- use regmap fields to clean up code.
- tie the tia gain stages to appropriate channels in the ABI as that is
what they really effect. Same with the LED currents.
- cleanout some unused defines and fix a missnamed one.
* atlas-ph
- reorganise to allow support of other similar parts.
* bmc150
- document supported chips in kconfig help.
* jsa1212
- drop an unneeded i2c functionality check for functionality the driver
doesn't use.
* mxs-lradc
- simply touch screen registration code.
- remove the touch screen unregister as all devm based now.
- disable only those channels that are masked in hardware stop (others
are already dealt with elsewhere)
* st-sensors
- unexport st_sensors_get_buffer_element as nothing outside the st-sensors
core driver uses it.
- fix handling of failure to start up regulators.
* tpl0102
- drop an i2c functionality test for features that aren't needed.
* ti-am335x
- use variable name rather than type in sizeof for clarity.
- use SIMPLE_DEV_PM_OPS helper macro to tidy up a bit.
Tools
* Add install / uninstall to makefile. Someone cares, so presumably
some people will find it useful!
* generic_buffer
- rename to iio_generic_buffer to line up with other tools.
- handle cleanup when receiving signals
- Add a --device-num option and a --trigger-num option rather than
relying on naming which doesn't work if you have two of the same part.
Replace ifdefs with SIMPLE_DEV_PM_OPS helper macro.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Fix the code formatting to use the kernel preferred style
of using the actual variables to determize the size using
the sizeof() operator.
Driver was checking for direct mode and trying to lock it, but
left a gap where mode could change before the desired operation.
Use iio_device_claim_direct_mode() to guarantee device stays in
direct mode.
Refactor function to clarify look-up followed by lock sequence.
direct mode.
Acked-by: Daniel Baluta <daniel.baluta@gmail.com>
Driver was checking for direct mode but not locking it down.
in direct mode.
