path: root/drivers/iio/industrialio-core.c
2012-11-20iio: Factor out fixed point number parsing into its own functionLars-Peter Clausen
Factor out the code for parsing fixed point numbers into its own function and make this function globally available. This allows us to reuse the code to parse fixed point numbers in individual IIO drivers. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-11-20iio: Add pressure channel typeLars-Peter Clausen
This patch adds support for a new IIO channel type for pressure measurements. This can for example be used for barometric pressure sensors. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-11-10staging:iio: Add support for multiple buffersJonathan Cameron
Route all buffer writes through the demux. Addition or removal of a buffer results in tear down and setup of all the buffers for a given device. Signed-off-by: Jonathan Cameron <jic23@kernel.org> Tested-by: srinivas pandruvada <srinivas.pandruvada@intel.com>
2012-11-02iio: Accept a leading '+' sign when parsing fixed point numbersLars-Peter Clausen
If we encounter a leading '+' sign just skip over it. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-11-02iio: Reject trailing garbage when parsing fixed point numbersLars-Peter Clausen
When parsing a fixed point number IIO stops parsing the string once it has reached the last requested decimal place. This means that the remainder of the string is silently accepted regardless, of whether it is part of a valid number or not. This patch modifies the code to scan the whole string and only accept valid numbers. Since fract_mult is 0 after the last decimal place any digit that may follows won't affect the result. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-11-02iio: Do not accept multiple '.' in fixed point numbersLars-Peter Clausen
Currently when parsing a fix-point number we silently skip any additional '.' found in the string. E.g. '1.2.3.4' gets parsed as '1.234'. This patch disallows this and returns an error if more than one '.' is encountered. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-10-19iio: Add a logarithmic fractional value typeLars-Peter Clausen
For ADCs or DACs the denominator for fractional types often is a power of two. In this case we can use a shift operation instead of the rather expensive 64 bit division. This patch adds a new fractional type which expects the denominator to be specified as the log2 of the actual denominator. E.g. for ADCs and DACs this will usually be the number of significant bits. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-15iio: Introduce a new fractional value typeLars-Peter Clausen
Currently IIO uses a decimal fixed point representations for real type numbers. This patch introduces a new representation for rational type numbers. The number will be expressed by specifying a numerator and denominator. For converting a raw value to a processed value multiply it by the numerator and divide it by the denominator. The reasoning for introducing this new type is that for a lot of devices the scale can be represented easily by a fractional number, but it is not possible to represent it as fixed point number without rounding. E.g. for a simple DAC the scale is often the reference voltage divided by the number of possible values (Usually 2**n_bits - 1). Each driver currently implements the conversion of this fraction to a fixed point number on its own. Also when it comes to the in-kernel interface this allows to directly use the fractional factors to convert a raw value to a processed value. This should on one hand require less instructions and on the other hand increase the precision. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-06iio: core: Add hysteresis in channel specsrinivas pandruvada
Added hysteresis to the list of channel info enumeration, shared /separate bit defines and to postfix channel info strings. Signed-off-by: srinivas pandruvada <srinivas.pandruvada@intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-03IIO: Update email address for Jonathan Cameron.Jonathan Cameron
2012-09-03iio: whitespace cleanup and removal of semicolon after functionsPeter Meerwald
Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-03iio: fix typosPeter Meerwald
2012-07-10IIO channel type and modifiers for CCT and RGBC dataJon Brenner
Add iio channel type and modifiers for Correlated Color Temperature (CCT) and RGBC (red/green/blue/clear) data. Add CCT and RGBC descriptions to documentation. Changes: Revised/condensed RGBC descriptions. Merge and trivial fix done by Jonathan Cameron. Signed-off-by: Jon Brenner <jbrenner@taosinc.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-06-30IIO: Add a modifier for x^2+y^2+z^2Jonathan Cameron
There will probably be a number of such modifiers eventually but this one is used in the adis16240 accelerometer driver. Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-06-30IIO: Add a modifier for sqrt(x^2+y^2)Jonathan Cameron
There will probably be a number of such modifiers eventually but this one is used in the adis16204 accelerometer driver. Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-06-13Merge branch 'staging-linus' into staging-nextGreg Kroah-Hartman
We need this for the pstore fixes that went into the staging-linus branch, so that things apply properly for the pstore/android code merge. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-07iio: iio_enum_available_read: Prevent possible buffer overflowLars-Peter Clausen
Use scnprint instead of snprintf, because snprintf returns the number of bytes that would have been written to the buffer if there was enough space, and as a result writing to buf[len-1] might cause a access beyond the buffers limits. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-05iio: Add helper functions for enum style channel attributesLars-Peter Clausen
We often have the case were we do have a enum style channel attribute. These attributes have in common that they are a list of string values which usually map in a 1-to-1 fashion to integer values. This patch implements some common helper code for implementing enum style channel attributes using extended channel attributes. The helper functions take care of converting between the string and integer values, as well providing a function for "_available" attributes which list all available enum items. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-04iio: Fix potential use after freeLars-Peter Clausen
There is no guarantee that the last reference to the iio device has already been dropped when iio_device_free is called. This means that we can up calling iio_dev_release after iio_device_free which will lead to a use after free. As the general rule the struct containing the device should always be freed in the release callback. This is what this patch does, it moves freeing the iio device struct as well as releasing the idr reference to the release callback. To ensure that the device is not freed before calling iio_device_free the device_unregister call in iio_device_unregister is broken apart. iio_device_unregister will now only call device_del to remove the device from the system and iio_device_free will call put_device to drop the reference we obtained in iio_devce_alloc. We also have to take care that calling iio_device_free without having called iio_device_register still works (i.e. this can happen if something failed during device initialization). For this to work properly two minor changes were necessary: channel_attr_list needs to be initialized in iio_device_alloc and we have to check whether the chrdev has been registered before releasing it in iio_device_release. This change also brings iio_device_unregister and iio_device_free more in sync with iio_device_register and iio_device_alloc which call device_add and device_initialize respectively. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-14iio: Use dev_to_iio_dev()Lars-Peter Clausen
Replace open-coded instances of getting a iio_dev struct from a device struct with dev_to_iio_dev(). Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-14iio: core: introduce IIO_CHAN_INFO_HARDWAREGAINMichael Hennerich
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Acked-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-14iio: core: introduce dB scle: IIO_VAL_INT_PLUS_MICRO_DBMichael Hennerich
2012-05-08IIO: industrialio-core: Checking NULL instead of IS_ERR for debugfs_create_dir()Axel Lin
If defined CONFIG_DEBUG_FS, debugfs_create_dir returns NULL on failure. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-08IIO: industrialio-core: Use simple_openAxel Lin
Use simple_open to replace iio_debugfs_open. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Michael Hennerich <michael.hennerich@analog.com> Acked-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-29iio: core: iio_chan_spec_ext_info: Add private handleMichael Hennerich
There is currently no user, but we might need it in future. So better add it now, before we have to convert drivers afterwards. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Acked-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-29iio: core: Introduce IIO_ALTVOLTAGE and appropriate channel info elementsMichael Hennerich
2012-04-29staging:iio: Streamline API function namingLars-Peter Clausen
Currently we use two different naming schemes in the IIO API, iio_verb_object and iio_object_verb. E.g iio_device_register and iio_allocate_device. This patches renames instances of the later to the former. The patch also renames allocate to alloc as this seems to be the preferred form throughout the kernel. In particular the following renames are performed by the patch: iio_put_device -> iio_device_put iio_allocate_device -> iio_device_alloc iio_free_device -> iio_device_free iio_get_trigger -> iio_trigger_get iio_put_trigger -> iio_trigger_put iio_allocate_trigger -> iio_trigger_alloc iio_free_trigger -> iio_trigger_free The conversion was done with the following coccinelle patch with manual fixes to comments and documentation. <smpl> @@ @@ -iio_put_device +iio_device_put @@ @@ -iio_allocate_device +iio_device_alloc @@ @@ -iio_free_device +iio_device_free @@ @@ -iio_get_trigger +iio_trigger_get @@ @@ -iio_put_trigger +iio_trigger_put @@ @@ -iio_allocate_trigger +iio_trigger_alloc @@ @@ -iio_free_trigger +iio_trigger_free </smpl> Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-25IIO: Move the core files to drivers/iioJonathan Cameron
Take the core support + the kfifo buffer implentation out of staging. Whilst we are far from done in improving this subsystem it is now at a stage where the userspae interfaces (provided by the core) can be considered stable. Drivers will follow over a longer time scale. Signed-off-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
