commit 71b33f6f93ef9462c84560e2236ed22209d26a58 upstream.
The PS ADC Channel data is spread over 2 registers in little-endian
form. This patch adds the missing endianness conversion.
Fixes: 2690be905123 ("iio: Add Lite-On ltr501 ambient light / proximity sensor driver")
Signed-off-by: Oliver Lang <Oliver.Lang@gossenmetrawatt.com>
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
Tested-by: Nikita Travkin <nikita@trvn.ru> # ltr559
Link: https://lore.kernel.org/r/20210610134619.2101372-4-mkl@pengutronix.de
Cc: <Stable@vger.kernel.org>
Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
commit 421a26f3d7a7c3ca43f3a9dc0f3cb0f562d5bd95 upstream.
The ltr559 chip uses only the lowest bit of the ALS_CONTR register to
configure between active and stand-by mode. In the original driver
BIT(1) is used, which does a software reset instead.
This patch fixes the problem by using BIT(0) as als_mode_active for
the ltr559 chip.
Fixes: 8592a7eefa54 ("iio: ltr501: Add support for ltr559 chip")
Link: https://lore.kernel.org/r/20210610134619.2101372-3-mkl@pengutronix.de
as volatile, too
commit 2ac0b029a04b673ce83b5089368f467c5dca720c upstream.
The regmap is configured for 8 bit registers, uses a RB-Tree cache and
marks several registers as volatile (i.e. do not cache).
The ALS and PS data registers in the chip are 16 bit wide and spans
two regmap registers. In the current driver only the base register is
marked as volatile, resulting in the upper register only read once.
Further the data sheet notes:
| When the I2C read operation starts, all four ALS data registers are
| locked until the I2C read operation of register 0x8B is completed.
Which results in the registers never update after the 2nd read.
This patch fixes the problem by marking the upper 8 bits of the ALS
and PS registers as volatile, too.
Fixes: 2f2c96338afc ("iio: ltr501: Add regmap support.")
Reported-by: Oliver Lang <Oliver.Lang@gossenmetrawatt.com>
Link: https://lore.kernel.org/r/20210610134619.2101372-2-mkl@pengutronix.de
commit 2684d5003490df5398aeafe2592ba9d4a4653998 upstream.
One of a class of bugs pointed out by Lars in a recent review.
iio_push_to_buffers_with_timestamp assumes the buffer used is aligned
to the size of the timestamp (8 bytes). This is not guaranteed in
this driver which uses an array of smaller elements on the stack.
Here we use a structure on the stack. The driver already did an
explicit memset so no data leak was possible.
Forced alignment of ts is not strictly necessary but probably makes
the code slightly less fragile.
Note there has been some rework in this driver of the years, so no
way this will apply cleanly all the way back.
Reported-by: Lars-Peter Clausen <lars@metafoo.de>
commit 7cc3bff4efe6164a0c8163331c8aa55454799f42 upstream.
The register mapping for the IIO driver for the Liteon Light and Proximity
sensor LTR501 interrupt mode is interchanged (ALS/PS).
There is a register called INTERRUPT register (address 0x8F)
Bit 0 represents PS measurement trigger.
Bit 1 represents ALS measurement trigger.
This two bit fields are interchanged within the driver.
see datasheet page 24:
http://optoelectronics.liteon.com/upload/download/DS86-2012-0006/S_110_LTR-501ALS-01_PrelimDS_ver1%5B1%5D.pdf
Signed-off-by: Franziska Naepelt <franziska.naepelt@idt.com>
Fixes: 7ac702b3144b6 ("iio: ltr501: Add interrupt support")
Acked-by: Peter Meerwald-Stadler <pmeerw@pmeerw.net>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
commit c08ae18560aaed50fed306a2e11f36ce70130f65 upstream.
The return type "unsigned int" was used by the ltr501_match_samp_freq()
function despite of the aspect that it will eventually return a negative
error code.
Improve this implementation detail by deletion of the type modifier then.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
We need the staging fixes in here as well.
i2c_driver does not need to set an owner because i2c_register_driver()
will set it.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
When filling data->als_contr, the register content read into status needs
to be used, instead of the return status value of regmap_read.
Fixes: 8592a7eefa540 ("iio: ltr501: Add support for ltr559 chip")
Signed-off-by: Hartmut Knaack <knaack.h@gmx.de>
Acked-by: Daniel Baluta <daniel.baluta@intel.com>
Added support to calculate lux value from visible
and IR spectrum adc count values. Also added IIO_LIGHT
channel to enable user read the lux value directly
from device using illuminance input ABI.
Signed-off-by: Kuppuswamy Sathyanarayanan <sathyanarayanan.kuppuswamy@linux.intel.com>
Currently, proximity sensor boundary check is done
inside the switch block but outside the case
statement.Since this code will never get executed,
moved the check outside the switch case statement.
867 case IIO_PROXIMITY:
868 switch (dir) {
// Following line has been moved outside the switch block.
869 if (val > LTR501_PS_THRESH_MASK)
870 return -EINVAL;
871 case IIO_EV_DIR_RISING:
Clearly the intent was to error if the value was not 0 or 1.
As implemented we have (A != 0 || A != 1) which is always true
as A is never both 0 and 1 at the same time.
As the autobuilder suggested, && makes more sense for this error
check.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Acked-by: Kuppuswamy Sathyanarayanan <sathyanarayanan.kuppuswamy@linux.intel.com>
Cc: Daniel Baluta <daniel.baluta@intel.com>
Added support for Liteon 301 Ambient light sensor. Since
LTR-301 and LTR-501 are register compatible(and even have same
part id), LTR-501 driver has been extended to support both
devices. LTR-501 is similar to LTR-301 in ALS sensing, But the
only difference is, LTR-501 also supports proximity sensing.
LTR-501 - ALS + Proximity combo
LTR-301 - ALS sensor.
Signed-off-by: Daniel Baluta <daniel.baluta@intel.com>
This device is register compatible with LTR501, with a minor difference for
ALS control register as showed below:
ALS Control register for LTR501:
7 6 5 4 3 2 1 0
| Reserved | Gain | SW | ALS Mode |
| | | Reset| |
ALS Control register for LTR559:
7 6 5 4 3 2 1 0
| Reserved | Gain | SW | ALS |
| | | Reset| Mode |
We handle this difference by introducing ltr501_chip_info.
Datasheet for LTR559 is at:
http://optoelectronics.liteon.com/upload/download/DS86-2013-0003/S_110_LTR-559ALS-01_DS_V1.pdf
Added ACPI enumeration support for LTR501 chip.
Added rate control support for ALS and proximity
threshold interrupts.Also, Added support to modify
and read ALS & proximity sensor sampling frequency.
LTR-501 supports interrupt rate control using persistence
register settings. Writing <n> to persistence register
would generate interrupt only if there are <n> consecutive
data values outside the threshold range.
Since we don't have any existing ABI's to directly
control the persistence register count, we have implemented
the rate control using IIO_EV_INFO_PERIOD. _period event
attribute represents the amount of time in seconds an
event should be true for the device to generate the
interrupt. So using _period value and device frequency,
persistence count is calculated in driver using following
logic.
count = period / measurement_rate
If the given period is not a multiple of measurement rate then
we round up the value to next multiple.
This patch also handles change to persistence count whenever
there is change in frequency.
This patch adds interrupt support for Liteon 501 chip.
Interrupt will be generated whenever ALS or proximity
data exceeds values given in upper and lower threshold
register settings.
Added support to modify and read ALS integration time.
Added regmap support. It will be useful to handle
bitwise updates to als & ps control registers.
This makes ltr501 code consistent with the coding style adopted
for the new drivers added to IIO.
We prepare the path for adding support for LTR559 chip.
Reported by checkpatch.pl
Power down device when an error occurs in order to avoid wasting
power. Move powerdown function up to be seen by the new call and
align parameters for the ltr501_write_contr() call.
Signed-off-by: Cristina Opriceana <cristina.opriceana@gmail.com>
combined ambient light (two channels) and proximity sensor with I2C
interface; the ALS channels are visible+IR and IR
datasheet is here
http://optoelectronics.liteon.com/upload/download/DS86-2012-0006/P_100_LTR-501ALS-01_PrelimDS_ver1.1.pdf
v3:
* fix use of sizeof in _read_als()
v2: (thanks to Lars-Peter Clausen)
* cannot use devm_iio_device_register() due to cleanup order in _remove()
* mutex around data wait/read
* turn info message in _probe() into check for part number
* change copyright year to 2014
Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net>
Reviewed-by: Lars-Peter Clausen <lars@metafoo.de>
