We need the staging fixes in here as well.
i2c_driver does not need to set an owner because i2c_register_driver()
will set it.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
the millisecond values in tcs3414_times should be checked against
val2, not val, which is always zero.
Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net>
Reported-by: Stephan Kleisinger <stephan.kleisinger@gmail.com>
Cc: <Stable@vger.kernel.org>
Signed-off-by: Roberta Dobrescu <roberta.dobrescu@gmail.com>
Reviewed-by: Daniel Baluta <daniel.baluta@intel.com>
16-bit digital color sensor with red, green, blue and clear channel
datasheet: http://ams.com/eng/content/download/250258/975997/TCS3414_Datasheet_EN_v1.pdf
