path: root/drivers/iio/light/vcnl4000.c
2013-03-17iio:light:vcnl4000 move to info_mask_(shared_by_type/separate)Jonathan Cameron
The original info_mask is going away in favour of the broken out versions. Signed-off-by: Jonathan Cameron <jic23@kernel.org> cc: Peter Meerwald <pmeerw@pmeerw.net>
2013-01-03Drivers: iio: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-20iio: add vcnl4000 combined ALS and proximity sensorPeter Meerwald
minimal driver, no IR current control and proximity/event handling yet v5: * checkpatch warnings * increase msleep() to 20 ms when waiting for data ready as measurement/conversion can take up to 100 ms, 1 ms is too short v4 (address comments by Jonathan Cameron) * remove SENSORS_ prefix in Kconfig * change from IIO_INTENSITY to IIO_LIGHT * move from staging v3 (address comments by Shubhrajyoti Datta) * cleanup Kconfig entry * call I2C read/write functions directly v2 (address comments by Lars-Peter Clausen and Jonathan Cameron) * unify code for reading PS and AL data into parameterized _measure() function * limit wait for data to become ready within 20 tries * drop IIO_LIGHT channel, add SCALE to IIO_INTENSITY * drop extra string arguments used for logging purpose only Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net> Acked-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
