commit 71b33f6f93ef9462c84560e2236ed22209d26a58 upstream.
The PS ADC Channel data is spread over 2 registers in little-endian
form. This patch adds the missing endianness conversion.
Fixes: 2690be905123 ("iio: Add Lite-On ltr501 ambient light / proximity sensor driver")
Signed-off-by: Oliver Lang <Oliver.Lang@gossenmetrawatt.com>
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
Tested-by: Nikita Travkin <nikita@trvn.ru> # ltr559
Link: https://lore.kernel.org/r/20210610134619.2101372-4-mkl@pengutronix.de
Cc: <Stable@vger.kernel.org>
Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
commit 421a26f3d7a7c3ca43f3a9dc0f3cb0f562d5bd95 upstream.
The ltr559 chip uses only the lowest bit of the ALS_CONTR register to
configure between active and stand-by mode. In the original driver
BIT(1) is used, which does a software reset instead.
This patch fixes the problem by using BIT(0) as als_mode_active for
the ltr559 chip.
Fixes: 8592a7eefa54 ("iio: ltr501: Add support for ltr559 chip")
Link: https://lore.kernel.org/r/20210610134619.2101372-3-mkl@pengutronix.de
as volatile, too
commit 2ac0b029a04b673ce83b5089368f467c5dca720c upstream.
The regmap is configured for 8 bit registers, uses a RB-Tree cache and
marks several registers as volatile (i.e. do not cache).
The ALS and PS data registers in the chip are 16 bit wide and spans
two regmap registers. In the current driver only the base register is
marked as volatile, resulting in the upper register only read once.
Further the data sheet notes:
| When the I2C read operation starts, all four ALS data registers are
| locked until the I2C read operation of register 0x8B is completed.
Which results in the registers never update after the 2nd read.
This patch fixes the problem by marking the upper 8 bits of the ALS
and PS registers as volatile, too.
Fixes: 2f2c96338afc ("iio: ltr501: Add regmap support.")
Reported-by: Oliver Lang <Oliver.Lang@gossenmetrawatt.com>
Link: https://lore.kernel.org/r/20210610134619.2101372-2-mkl@pengutronix.de
commit d68c592e02f6f49a88e705f13dfc1883432cf300 upstream
Currently, the proxy sensor scale is zero because it just return the
exponent directly. To fix this issue, this patch use
hid_sensor_format_scale to process the scale first then return the
output.
Fixes: 39a3a0138f61 ("iio: hid-sensors: Added Proximity Sensor Driver")
Signed-off-by: Ye Xiang <xiang.ye@intel.com>
Link: https://lore.kernel.org/r/20210130102530.31064-1-xiang.ye@intel.com
[sudip: adjust context]
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
commit 2684d5003490df5398aeafe2592ba9d4a4653998 upstream.
One of a class of bugs pointed out by Lars in a recent review.
iio_push_to_buffers_with_timestamp assumes the buffer used is aligned
to the size of the timestamp (8 bytes). This is not guaranteed in
this driver which uses an array of smaller elements on the stack.
Here we use a structure on the stack. The driver already did an
explicit memset so no data leak was possible.
Forced alignment of ts is not strictly necessary but probably makes
the code slightly less fragile.
Note there has been some rework in this driver of the years, so no
way this will apply cleanly all the way back.
Reported-by: Lars-Peter Clausen <lars@metafoo.de>
[ Upstream commit 18dfb5326370991c81a6d1ed6d1aeee055cb8c05 ]
The bytes returned by the i2c reading need to be swapped
unconditionally. Otherwise, on be16 platforms, an incorrect value will be
returned.
Taking the slow path via next merge window as its been around a while
and we have a patch set dependent on this which would be held up.
Fixes: 62a1efb9f868 ("iio: add vcnl4000 combined ALS and proximity sensor")
Signed-off-by: Mathieu Othacehe <m.othacehe@gmail.com>
[ Upstream commit f552fde983d378e7339f9ea74a25f918563bf0d3 ]
Separate the declaration of struct bh1750_chip_info from definition
of bh1750_chip_info_tbl[] in a single statement as it makes the code
hard to read, and with the extra newline it makes it look as if the
bh1750_chip_info_tbl[] had no explicit type.
This change also resolves the following compiler warning about the
unusual position of the static keyword that can be seen when building
with warnings enabled (W=1):
drivers/iio/light/bh1750.c:64:1: warning:
‘static’ is not at beginning of declaration [-Wold-style-declaration]
Related to commit 3a11fbb037a1 ("iio: light: add support for ROHM
BH1710/BH1715/BH1721/BH1750/BH1751 ambient light sensors").
Signed-off-by: Krzysztof Wilczynski <kw@linux.com>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
commit 82f3015635249a8c8c45bac303fd84905066f04f upstream.
When an end-of-conversion interrupt is received after performing a
single-shot reading of the light sensor, the driver was waking up the
result ready queue before checking opt->ok_to_ignore_lock to determine
if it should unlock the mutex. The problem occurred in the case where
the other thread woke up and changed the value of opt->ok_to_ignore_lock
to false prior to the interrupt thread performing its read of the
variable. In this case, the mutex would be unlocked twice.
Signed-off-by: David Frey <dpfrey@gmail.com>
Reviewed-by: Andreas Dannenberg <dannenberg@ti.com>
Fixes: 94a9b7b1809f ("iio: light: add support for TI's opt3001 light sensor")
[ Upstream commit db4e5376d058af8924fafd0520a0942d92538d0e ]
In function cm3232_reg_init(), it returns 0 even if the last call to
i2c_smbus_write_byte_data() returns a negative value (indicates error).
As a result, the return value may be inconsistent with the execution
status, and the caller of cm3232_reg_init() will not be able to detect
the error. This patch fixes the bug.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=188641
Signed-off-by: Pan Bian <bianpan2016@163.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
commit a3507e48d3f99a93a3056a34a5365f310434570f upstream.
The TSL2563 driver provides three iio channels, two of which are raw ADC
channels (channel 0 and channel 1) in the device and the remaining one
is calculated by the two. The ADC channel 0 only supports programmable
interrupt with threshold settings and this driver supports the event but
the generated event code does not contain the corresponding iio channel
type.
This is going to change userspace ABI. Hopefully fixing this to be
what it should always have been won't break any userspace code.
Cc: Jonathan Cameron <jic23@kernel.org>
commit 7cc3bff4efe6164a0c8163331c8aa55454799f42 upstream.
The register mapping for the IIO driver for the Liteon Light and Proximity
sensor LTR501 interrupt mode is interchanged (ALS/PS).
There is a register called INTERRUPT register (address 0x8F)
Bit 0 represents PS measurement trigger.
Bit 1 represents ALS measurement trigger.
This two bit fields are interchanged within the driver.
see datasheet page 24:
http://optoelectronics.liteon.com/upload/download/DS86-2012-0006/S_110_LTR-501ALS-01_PrelimDS_ver1%5B1%5D.pdf
Signed-off-by: Franziska Naepelt <franziska.naepelt@idt.com>
Fixes: 7ac702b3144b6 ("iio: ltr501: Add interrupt support")
Acked-by: Peter Meerwald-Stadler <pmeerw@pmeerw.net>
commit 590b92a30242dd3f73de3d9a51d9924f1ab33e93 upstream.
Without this, the iio:deviceX is missing in the /sys/bus/i2c/devices/0-0039
Some userspace tools use this path to identify a specific instance of the
device.
Signed-off-by: Yong Li <sdliyong@gmail.com>
Reviewed-By: Matt Ranostay <mranostay@gmail.com>
commit fa34e6dd44d7c02c8a8468ce4a52a7506f907bef upstream.
As per the ACPI specification (Revision 5.0) [1], the data coming
from the sensor represent the ambient light illuminance reading
expressed in lux. So use IIO_CHAN_INFO_PROCESSED to signify that
the data are pre-processed.
However, to keep backward ABI compatibility, the IIO_CHAN_INFO_RAW
bit is not removed.
[1] http://www.acpi.info/DOWNLOADS/ACPIspec50.pdf
This issue has also been responsible for at least one userspace bug
report hence marking what is a small semantic fix really for stable.
[2] https://github.com/hadess/iio-sensor-proxy/issues/46
Signed-off-by: Gabriele Mazzotta <gabriele.mzt@gmail.com>
commit c08ae18560aaed50fed306a2e11f36ce70130f65 upstream.
The return type "unsigned int" was used by the ltr501_match_samp_freq()
function despite of the aspect that it will eventually return a negative
error code.
Improve this implementation detail by deletion of the type modifier then.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
Add missing pm_runtime_mark_last_busy to apds9960_set_power_state
function.
Unless pm_runtime_mark_last_busy is called the
pm_runtime_put_autosuspend may put the device into suspend before the
delay time requested.
Signed-off-by: Matt Ranostay <mranostay@gmail.com>
This patch is a tidy up of warnings from the autobuilder.
>> drivers/iio/light/apds9960.c:495:32: sparse: cast to restricted __le16
drivers/iio/light/apds9960.c:635:24: sparse: cast to restricted __le16
>> drivers/iio/light/apds9960.c:672:21: sparse: incorrect type in assignment (different base types)
drivers/iio/light/apds9960.c:672:21: expected unsigned short [unsigned] [usertype] buf
drivers/iio/light/apds9960.c:672:21: got restricted __le16 [usertype] <noident>
Cc: mranostay@gmail.com
Commit 845c877009cf014b ("i2c / ACPI: Assign IRQ for devices that have
GpioInt automatically") automatically assigns the first ACPI GPIO
interrupt in client->irq, so we can remove the probing code from
drivers that use only one interrupt.
Signed-off-by: Octavian Purdila <octavian.purdila@intel.com>
Since commit dab472eb931bc291 ("i2c / ACPI: Use 0 to indicate that
device does not have interrupt assigned") 0 is not a valid i2c
client irq anymore, so change all driver's checks accordingly.
The same issue occurs when the device is instantiated via device tree
with no IRQ, or from the i2c sysfs interface, even before the patch
above.
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next
Jonathan writes:
First round of new driver, new functionality and cleanups for IIO in the 4.4 cycle
New device support
* APDS9960 ALS + proximity driver
* bmg160 SPI devices.
* HDC100x humidity sensors
* Holt HI-8435 threshold detector
* mma8453Q accelerometer added to the mma8452 driver
* mma86452FC and mma8653FC accelerometers added to the mma8452 driver
* mxc4005 accelerometer
* PulsedLight LIDAR
* SensorTech VZ89x volatile organic compound sensor
* UPISEMI uS5182d ALS and proximity sensors
New core functionality
* triggered events - use triggers to check for changes in threshold type
detectors on devices with out interrupt support. First user is the holt
comparator.
* chemical concentration and resistance channel types.
New driver functionality
* vf610
- buffer support.
- followup coccinelle warning fix.
Core rework
* buffers
- break out callback buffer to own module.
- move buffer implementations to a new subdirectory
* percolate the error code form iio_event_getfd out to userspace
rather than giving a missleading error later on.
Cleanups
* adddac drivers
- use BIT macro where appropriate.
* meter drivers
* ad7303
- add an OF match table to line up with the binding docs.
* adc128s052
* adf4350
* as3935
* berlin2-adc
- use GENMASK and BIT for masks
- prevent attempting to sample multiple channels at once by moving a
mutex scop
- coding style cleanups
* bmg150_magn
- kconfig sort order was wrong - fix it.
* bmg160
- use i2c regmap and drop all uses of i2c_client
- separate i2c and core driver
* cc10001_adc
* evgen (dummy driver helper module)
- move interrupt generation to irq_work to reduce differences between
the dummy driver and real hardware drivers.
* hmc5843
- set the name dynamically rather than to a fixed value for one of the
suported parts.
- export module alias information to allow autoprobing of module.
* lpc32xx
- on failure to get resource or irq return -ENXIO as uppose to -EBUSY
* max1027
- set .of_match_table to actually allow OF style matching.
* max5821
- add MODULE_DEVICE_TABLE for OF table.
* mma8452
- refactor to separate out chip specific data.
- add freefall / motion interrupt source for devices that do their
interrupts slightly differently.
- update copywrite notice.
- leave naming of events directory in sysfs to the core
* mcp320x
- set .of_match_table so that it can be use for OF style matching.
* mlx90614
- Implement filter configuration (note the datasheet changed as a result
of the driver reviews to include the values we needed ;)
* opt3001
- drop .owner field as assigned by platform driver core.
* si7020
- replace a bitmask on the humidity values with a more correct range
check.
* stk310
- improved error handling.
- use BIT macro where appropriate and use the resulting defines
instead of magic numbers in the code.
- fix indentation
* st-sensors
- add debugfs register read hook
* tsl4531
- fix error handling in check_id
* twl6030
- fix module autoload for OF
* iio-trig-sysfs
- document add and remove attribute
* trigger in staging
- code alignment fixes.
- braces on both branches of if statement if needed for one.
* xilinx-xadc
- push interrupts into hardirq context as there isn't much in them
any more and it avoids breaking PREEMPT_RT builds due to the use
of a spinlock between the hardirq and the thread.
Tools
* event-monitor
- report unsupported events. We keep expanding what can come from drivers
so give a helpful error if one turns up in an out of date userspace
program.
* generic-buffer
- helpful message about needing to enable a channel to start the buffer.
drivers/iio/light/apds9960.c:1125:3-8: No need to set .owner here. The core will do it.
Remove .owner field if calls are used which set it automatically
Generated by: scripts/coccinelle/api/platform_no_drv_owner.cocci
CC: Matt Ranostay <mranostay@gmail.com>
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
drivers/iio/light/apds9960.c:986:1-4: WARNING: end returns can be simpified
Simplify a trivial if-return sequence. Possibly combine with a
preceding function call.
Generated by: scripts/coccinelle/misc/simple_return.cocci
Add support for UPISEMI us5182d als and proximity sensor.
Supports raw readings.
Data sheet for this device can be found here:
http://www.upi-semi.com/temp/uS5182D-DS-P0103-temp.pdf
Signed-off-by: Adriana Reus <adriana.reus@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO updates from Linus Walleij:
"This is the bulk of GPIO changes for the v4.3 kernel cycle.
There is quite a lot going on in the GPIO subsystem this merge window,
so the main matter is decribed below.
The hits in other subsystems when making the GPIO flags optional are
all ACKed by their respective subsystem maintainers.
Core changes:
- Root out the wrapper devm_gpiod_get() and gpiod_get() etc versions
of the descriptor calls that did not use the flags argument on the
end. This was around for too long and eventually Uwe Kleine-König
took the time to clean it out and the last users are removed along
with the macros in this tag. In several cases the use of flags
simplifies the code. For this reason we have (ACKed) patches
hitting in DRM, IIO, media, NFC, USB+PHY up until we hammer in the
nail with removing the macros.
- Add a fat document describing how much ready-made GPIO stuff we
have i the kernel to discourage people from reinventing a square
wheel in userspace, as so often happens.
- Create a separate lockdep class for each instance of a GPIO IRQ
chip instead of using one class for all chips, as the current code
will not work with systems with several GPIO chips doing lockdep
debugging.
- Protect against driver unloading also when a GPIO line is only used
as IRQ for the GPIOLIB_IRQCHIP helpers.
- If the GPIO chip has no designated owner, assign the parent device
driver owner as owner.
- Consolidation of chained IRQ handler install/remove replacing all
call sites where irq_set_handler_data() and
irq_set_chained_handler() were done in succession with a combined
call to irq_set_chained_handler_and_data().
This series was created by Thomas Gleixner after the problem was
observed by Russell King.
- Tglx also made another series of patches switching
__irq_set_handler_locked() for irq_set_handler_locked() which is
way cleaner.
- Tglx and Jiang Liu wrote a good bunch of patches to make use of
irq_desc_get_xxx() accessors and avoid looking up irq_descs from
IRQ numbers. The goal is to get rid of the irq number from the
handlers in the IRQ flow which is nice.
- Rob Herring killed off the set_irq_flags() for all GPIO drivers.
This was an ARM specific function that is replaced with the generic
irq_modify_status() where special flags are actually needed.
- When an OF node has a pin range for its GPIOs, return -EPROBE_DEFER
if the pin controller isn't available. Pretty logical, yet needed
to be fixed.
- If a driver using GPIOLIB_IRQCHIP has its own irq_*_resources call
back, then call these instead of the defaults provided by the
GPIOLIB.
- Fix an undocumented ABI hole: named GPIOs were not properly
documented.
Driver improvements:
- Add get_direction() support to the generic GPIO driver, it's
strange that we didn't have that before.
- Make it possible to have input-only GPIO chips using the generic
GPIO driver.
- Clean out platform data support from the Emma Mobile (EM) driver
- Finegrained runtime PM support for the RCAR driver.
- Support r8a7795 (R-car H3) in the RCAR driver.
- Support interrupts on GPIOs 16 thru 31 in the DaVinci driver.
- Some consolidation and new support in the MPC8xxx driver, we now
support MPC5125.
- Preempt-RT-friendly patches: the OMAP, MPC8xxx, drivers uses raw
spinlocks making it work better with the realime patches.
- Interrupt support for the EXTRAXFS GPIO driver.
- Make the ETRAXFS GPIO driver support also ARTPEC-3.
- Interrupt and wakeup support for the BRCMSTB driver, also for
wakeup from S5 cold boot.
- Mask MXC IRQs during suspend.
- Improve OMAP2 GPIO set_debounce() to work according to spec.
- The VF610 driver handles IRQs properly.
New drivers:
- ZTE ZX GPIO driver"
* tag 'gpio-v4.3-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (87 commits)
Revert "gpio: extraxfs: fix returnvar.cocci warnings"
gpio: tc3589x: use static container helper
gpio: xlp: fix error return code
gpio: vf610: handle level IRQ's properly
gpio: max732x: Fix error handling in probe()
gpio: omap: fix clk_prepare/unprepare usage
gpio: omap: protect regs access in omap_gpio_irq_handler
gpio: omap: fix omap2_set_gpio_debounce
gpio: omap: switch to use platform_get_irq
gpio: omap: remove wrong irq_domain_remove usage in probe
gpiolib: add description for gpio irqchip fields in struct gpio_chip
gpiolib: irqchip: use different lockdep class for each gpio irqchip
gpio/grgpio: fix deadlock in grgpio_irq_unmap()
Documentation: gpio: consumer: describe active low property
gpio: mxc: fix section mismatch warning
gpio/mxc: mask gpio interrupts in suspend
gpio: omap: Fix missing raw locks conversion
gpio: brcmstb: support wakeup from S5 cold boot
gpio: brcmstb: Add interrupt and wakeup source support
The tsl4531_check_id() function returned 1 on "found" and 0 on "not
found" and negative error codes on failure. This was non-standard and
bug prone. The caller treated all non-zero values including error codes
as "found".
This patch fixes it by changing the tsl4531_check_id() to return zero on
success or a negative error code, and updates the caller.
Acked-by: Peter Meerwald <pmeerw@pmeerw.net>
APDS9960 is a combination of ALS, proximity, and gesture sensors.
This patch adds support for these functions along with gain control,
integration time, and event thresholds.
drivers/iio/light/opt3001.c:796:3-8: No need to set .owner here. The core will do it.
CC: Andreas Dannenberg <dannenberg@ti.com>
Linux 4.2-rc4
Adjust some indentation issues as spotted by checkpatch.pl --strict
Signed-off-by: Hartmut Knaack <knaack.h@gmx.de>
Reviewed-by: Tiberiu Breana <tiberiu.a.breana@intel.com>
Indicate the bit number of predefined states, make use of these names and
change the state type in _resume to u8 to avoid type casting.
Check for the following error cases:
* lower boundary for val in _write_event
* return value of regmap_(field_)read
* possible values for chan->type
* return value of stk3310_gpio_probe
Also add an error path in _probe to put the sensor back into stand-by mode
in case of serious errors.
Jonathan writes:
Second set of new device support, features and cleanup for the 4.3 cycle.
Take 2 also includes a fix set that was too late for the 4.2 cycle.
As we had a lot of tools and docs work in this set, I have broken those
out into their own categories in this description.
Fixes from the pull request '4th set of IIO fixes for the 4.2 cycle'.
* Poll functions for both event chardev and the buffer one were returning
negative error codes (via a positive value).
* A recent change to lsiio adding some error handling that was wrong and
stopped the tool working.
* bmg160 was missing some dependencies in Kconfig
* berlin2-adc had a misshandled register (wrote a value rather than a bitmap)
New device support
* TI opt3001 light sensor
* TXC PA12 ALS and proximity sensor.
* mcp3301 ADC support (in mcp320x driver)
* ST lsm303agr accelerometer and magnetometer drivers (plus some st-sensors
common support to allow different WHOAMI register addresses, devices with
fixed scale and allow interrupt equiped magnetometers).
* ADIS16305, ADIS16367, ADIS16445IMUs (in the adis16400 driver)
* ADIS16266 gyro (in the adis16260 driver)
* ADIS16137 gyro (in the adis16136 driver)
New functionality
* mmc35240 DT bindings.
* Inverse unit conversion macros to aid handing of values written to sysfs
attributes.
Core cleanup
* Forward declaration of struct iio_trigger to avoid a compile warning.
Driver cleanup / fixes
* mxs-lradc
- Clarify which parts are supported.
- Fix spelling erorrs.
- Missing/extra includes
- reorder includes
- add datasheet name listings for all usable channels (to allow them
to be bound by name from consumer drivers)
* acpi-als - add some function prefixes as per general iio style.
* bmc150_magn - replace a magic value with the existing define.
* vf610 - determine possible sample frequencies taking into account the
electrical characteristics (defining a minimum sample time)
* dht11
- whitespace
- additional docs
- avoid mulitple assignments in one line
- Use the new funciton ktime_get_resolution_ns to cleanup a nasty trick
previously used for timing.
* Fix all drivers that consider 0 a valid IRQ for historical reasons.
* Export I2C module alias info where previously missing (to allow autoprobing)
* Export OF module alias info where previously missing.
* mmc35240 - switch some variables into arrays to improve readability.
* mlx90614 - define some magic numbers for readability.
* bmc150_magn
- expand area locked by a mutex to cover all the use of the
data->buffer.
- use descriptive naming for a mask instead of a magic value.
* berin2-adc
- pass up an error code rather that a generic error
- constify the iio_chan_spec
- some other little tidy ups.
* stk8312
- fix a dependency on triggered buffers in kconfig
- add a check for invalid attribute values
- improve error handling by returning error codes where possible and
return immediately where relevant
- rework macro defs to use GENMASK etc
- change some variable types to reduce unnecessary casting
- clean up code style
- drop a local buffer copy for bulk reads and use the one in data->buffer
instead.
* adis16400 - the adis16448 gyroscope scale was wrong.
* adis16480 - some more wrong scales for various parts.
* adis16300 - has an undocumented product id and serial number registers so
use them.
* iio_simple_dummy - fix some wrong code indentation.
* bmc150-accel - use the chip ID to detect the chip present rather than
verifying the expected part was there. This was in response to a wrong
ACPI entry on the WinBook TW100.
* mma8452
- fix _get_hp_filter_index
- drop a double include
- pass up an error code rather than rewriting it
- range check input values to attribute writes
- register defs tidy up using GENMASK and reordering them to be easier to
follow.
- various coding style cleanups
- put the Kconfig entry in the write place (alphabetically).
Tools related
* Tools cleanup - drop an explicity NULL comparison, some unnecessary braces,
use the ARRAY_SIZE macro, send error messages to stderr instead of dropping
them in the middle of normal output.
* Fix tools to allow that scale and offset attributes are optional.
* More tools fixes including allowing true 32bit data (previously an overflow
prevented more than 31bits)
* Drop a stray header guard that ended up in a c file.
* Make calc_digits static as it isn't exported or in the header.
* Set ci_array pointer to NULL after free as a protection against non safe
usage of the tools core code. Also convert a double pointer to a single
one as the extra level of indirection was unnecessary.
Docs
* DocBook introduction by Daniel Baluta. Glad we are beginning to
draw together some more introductory docs to suplement the various
tools / examples.
* Drop bytes_per_datum sysfs attribute docs as it no longer exists.
* A whole load of missing / fixing of kernel-doc for the core of IIO.
* Document the trigger name sysfs attribute in the ABI docs.
* Minor typos in the ABI docs related to power down modes.
The I2C core always reports the MODALIAS uevent as "i2c:<client name"
regardless if the driver was matched using the I2C id_table or the
of_match_table. So technically there's no need for a driver to export
the OF table since currently it's not used.
In fact, the I2C device ID table is mandatory for I2C drivers since
a i2c_device_id is passed to the driver's probe function even if the
I2C core used the OF table to match the driver.
And since the I2C core uses different tables, OF-only drivers needs to
have duplicated data that has to be kept in sync and also the dev node
compatible manufacturer prefix is stripped when reporting the MODALIAS.
To avoid the above, the I2C core behavior may be changed in the future
to not require an I2C device table for OF-only drivers and report the
OF module alias. So, it's better to also export the OF table to prevent
breaking module autoloading if that happens.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
of_match_table. So the driver needs to export the I2C table and this
be built into the module or udev won't have the necessary information
to auto load the correct module when the device is added.
We want the iio and other fixes in this branch as well.
We need the staging fixes in here as well.
Add support for TXC PA12203001 als and proximity sensor.
Support for raw illuminance and proximity readings.
TI's opt3001 light sensor is a simple and yet powerful
little device. The device provides 99% IR rejection,
automatic full-scale, very low power consumption and
measurements from 0.01 to 83k lux.
This patch adds support for that device using the IIO
framework.
See http://www.ti.com/product/opt3001 for more information.
Signed-off-by: Felipe Balbi <balbi@ti.com>
Signed-off-by: Andreas Dannenberg <dannenberg@ti.com>
Data is stored in the device in be16 format. Make use of be16_to_cpu and
cpu_to_be16 to have correct endianness on any host architecture.
iio_device_register should be the last operation during probe. Therefor
move up interrupt setup code and while at it, change the check for invalid
values of client->irq to be smaller than zero.
Fixes: 3dd477acbdd1 ("iio: light: Add threshold interrupt support for STK3310")
As the device_register makes the userspace interfaces of the device available
it is possible for requests to come in before the probe sequence has finished.
This can lead to unhandled interrupts and similar.
The use of regmap in commit 2f2c96338afc requires REGMAP_I2C to be selected, in
order to meet all dependencies.
Acked-by: Daniel Baluta <daniel.baluta@intel.com>
When filling data->als_contr, the register content read into status needs
to be used, instead of the return status value of regmap_read.
Fixes: 8592a7eefa540 ("iio: ltr501: Add support for ltr559 chip")
The stk3310 driver makes use of regmap_i2c, so this dependency needs to be
reflected in Kconfig.
In accordance with the recent proximity ABI changes,
STK3310's proximity readings should be un-inversed
in order to return low values for far-away objects
and high values for close ones.
As consequences of this change, iio event directions
have been switched and maximum proximity sensor
reference values have also been adjusted in accordance
with the real readings.
Signed-off-by: Tiberiu Breana <tiberiu.a.breana@intel.com>
Acked-by: Hartmut Knaack <knaack.h@gmx.de>
the millisecond values in tcs3414_times should be checked against
val2, not val, which is always zero.
Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net>
Reported-by: Stephan Kleisinger <stephan.kleisinger@gmail.com>
When setting the bits for integration time, the appropriate bitmask needs
to be cleared first.
Some macros and a function were missing the acpi_als_ prefix, so add it.
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-linus
Jonathan writes:
Second set of IIO fixes for the 4.2 cycle. Note these depend (mostly) on
material in the recent merge window, hence their separation from set (a)
as the fixes-togreg branch predated the merge window. I am running rather
later with these than I would have liked hence the large set.
* stk3310 fixes from Hartmut's review that came in post merge
- fix direction of proximity inline with recent documentation
clarification.
- fix missing REGMAP_I2C dependency
- rework the error handling for raw readings to fix an failure to power
down in the event of a raw reading failing.
- fix a bug in the compensation code which was toggling an extra bit in the
register.
* mmc35240 - reported samplign frequencies were wrong.
* ltr501 fixes
- fix a case of returning the return value of a regmap_read instead of
the value read.
- fix missing regmap dependency
* sx9500 - fix missing default values for ret in a couple of places to handle
the case of no enabled channels.
* tmp006 - check that writes to info_mask elements are actually to writable
ones. Otherwise, writing to any of them will change the sampling frequency.
Jonathan writes:
First set of IIO fixes for the 4.2 cycle.
* Fix a regression in hid sensors suspend time as a result of adding runtime
pm. The normal flow of waking up devices in order to go into suspend
(given the devices are normally suspended when not reading) to a regression
in suspend time on some laptops (reports of an additional 8 seconds).
Fix this by checking to see if a user action resulting in the wake up, and
make it a null operation if it didn't. Note that for hid sensors, there is
nothing useful to be done when moving into a full suspend from a runtime
suspend so they might as well be left alone.
* rochip_saradc: fix some missing MODULE_* data including the licence so that
the driver does not taint the kernel incorrectly and can build as a module.
* twl4030 - mark irq as oneshot as it always should have been.
* inv-mpu - write formats for attributes not specified, leading to miss
interpretation of the gyro scale channel when written.
* Proximity ABI clarification. This had snuck through as a mess. Some
drivers thought proximity went in one direction, some the other. We went
with the most common option, documented it and fixed up the drivers going
the other way. Fix for sx9500 included in this set.
* ad624r - fix a wrong shift in the output data.
* at91_adc - remove a false limit on the value of the STARTUP register
applied by too small a type for the device tree parameter.
* cm3323 - clear the bits when setting the integration time (otherwise
we can only ever set more bits in the relevant field).
* bmc150-accel - multiple triggers are registered, but on error were not being
unwound in the opposite order leading to removal of triggers that had not
yet successfully been registered (count down instead of up when unwinding).
* tcs3414 - ensure right part of val / val2 pair read so that the integration
time is not always 0.
* cc10001_adc - bug in kconfig dependency. Use of OR when AND was intended.
i2c_driver does not need to set an owner because i2c_register_driver()
will set it.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Since 39b2bbe3d715 (gpio: add flags argument to gpiod_get*() functions)
which appeared in v3.17-rc1, the gpiod_get* functions take an additional
parameter that allows to specify direction and initial value for output.
Simplify driver accordingly. Furthermore this is one caller less that
stops us making the flags argument to gpiod_get*() mandatory.
Acked-by: Jonathan Cameron <jic23@kernel.org>
