path: root/drivers/iio/temperature
2013-09-25Merge 3.12-rc2 into staging-next.Greg Kroah-Hartman
This resolves the merge problem with two iio drivers that Stephen Rothwell pointed out. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-21iio: Fix tmp006 dev-to-indio_dev conversion in suspend/resumePeter Meerwald
dev_to_iio_dev() is a false friend Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-09-15iio:temperature:tmp006 put sampling_frequency in info_mask_shared_by_allJonathan Cameron
Doing this makes it possible to access this control from within the kernel. Signed-off-by: Jonathan Cameron <jic23@kernel.org> Acked-by: Peter Meerwald <pmeerw@pmeerw.net> Reviewed-by: Lars-Peter Clausen <lars@metafoo.de>
2013-08-17iio: Add tmp006 IR temperature sensorPeter Meerwald
the TI TMP006 is a non-contact temperature sensor with I2C interface; it measures the surface temperature of a distance object using a thermopile to absorb IR energy emitted from the object the sensor has two channels: IR sensor voltage (16-bit) and reference temperature of the chip (14-bit); datasheet is here: http://www.ti.com/lit/ds/symlink/tmp006.pdf v2 (thanks to Grygorii Strashko, Lars-Peter Clausen, Jonathan Cameron for review comments): * power down device on driver remove * use sign_extend32() * style cleanup * add comments what channel raw LSBs mean * spelling of thermopile Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net> Cc: Grygorii Strashko <grygorii.strashko@ti.com> Cc: Lars-Peter Clausen <lars@metafoo.de> Cc: Jonathan Cameron <jic23@kernel.org> Cc: LM Sensors <lm-sensors@lm-sensors.org> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
