This is the 4.4.291 stable release
commit 4170d3dd1467e9d78cb9af374b19357dc324b328 upstream.
The ssp_print_mcu_debug() function should return negative error codes on
error. Returning "length" is meaningless. This change does not affect
runtime because the callers only care about zero/non-zero.
Reported-by: Jonathan Cameron <jic23@kernel.org>
Fixes: 50dd64d57eee ("iio: common: ssp_sensors: Add sensorhub driver")
Link: https://lore.kernel.org/r/20210914105333.GA11657@kili
Cc: <Stable@vger.kernel.org>
Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
commit 8167c9a375ccceed19048ad9d68cb2d02ed276e0 upstream.
The "idx" is validated at the start of the loop but it gets incremented
during the iteration so it needs to be checked again.
Link: https://lore.kernel.org/r/20210909091336.GA26312@kili
commit bbcf40816b547b3c37af49168950491d20d81ce1 upstream.
A successful 'regulator_enable()' call should be balanced by a
corresponding 'regulator_disable()' call in the error handling path of the
probe, as already done in the remove function.
Update the error handling path accordingly.
Fixes: 913b86468674 ("iio: adc: Add TI ADC128S052")
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Reviewed-by: Alexandru Ardelean <ardeleanalex@gmail.com>
Link: https://lore.kernel.org/r/85189f1cfcf6f5f7b42d8730966f2a074b07b5f5.1629542160.git.christophe.jaillet@wanadoo.fr
This is the 4.4.288 stable release
[ Upstream commit 97683c851f9cdbd3ea55697cbe2dcb6af4287bbd ]
The naming of the regulator is problematic. VCC is usually a supply
voltage whereas these devices have a separate VREF pin.
Secondly, the regulator core might have provided a stub regulator if
a real regulator wasn't provided. That would in turn have failed to
provide a voltage when queried. So reality was that there was no way
to use the internal reference.
In order to avoid breaking any dts out in the wild, make sure to fallback
to the original vcc naming if vref is not available.
Reported-by: kernel test robot <lkp@intel.com>
Acked-by: Nuno Sá <nuno.sa@analog.com>
Link: https://lore.kernel.org/r/20210627163244.1090296-9-jic23@kernel.org
commit 8090d67421ddab0ae932abab5a60200598bf0bbb upstream
According to the BMA253 datasheet [1] and BMA250 datasheet [2] the
bandwidth value for BMA25x should be set as 01xxx:
"Settings 00xxx result in a bandwidth of 7.81 Hz; [...]
It is recommended [...] to use the range from ´01000b´ to ´01111b´
only in order to be compatible with future products."
However, at the moment the drivers sets bandwidth values from 0 to 6,
which is not recommended and always results into 7.81 Hz bandwidth
according to the datasheet.
Fix this by introducing a bw_offset = 8 = 01000b for BMA25x,
so the additional bit is always set for BMA25x.
[1]: https://www.bosch-sensortec.com/media/boschsensortec/downloads/datasheets/bst-bma253-ds000.pdf
[2]: https://datasheet.octopart.com/BMA250-Bosch-datasheet-15540103.pdf
Cc: Peter Meerwald <pmeerw@pmeerw.net>
Fixes: 2017cff24cc0 ("iio:bma180: Add BMA250 chip support")
Signed-off-by: Stephan Gerhold <stephan@gerhold.net>
Link: https://lore.kernel.org/r/20210526094408.34298-2-stephan@gerhold.net
[sudip: adjust context]
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
commit 9436abc40139503a7cea22a96437697d048f31c0 upstream
This uses the C99 explicit .member assignment for the
variant data in struct bma180_part_info. This makes it
easier to understand and add new variants.
Cc: Oleksandr Kravchenko <o.v.kravchenko@globallogic.com>
iio_push_to_buffers_with_timestamp()
[ Upstream commit 334883894bc1e145a1e0f5de1b0d1b6a1133f0e6 ]
To make code more readable, use a structure to express the channel
layout and ensure the timestamp is 8 byte aligned.
Found during an audit of all calls of this function.
Fixes: db6a19b8251f ("iio: accel: Add trigger support for STK8BA50")
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Link: https://lore.kernel.org/r/20210501170121.512209-8-jic23@kernel.org
[ Upstream commit f40a71ffec808e7e51848f63f0c0d3c32d65081b ]
Fixes: 95c12bba51c3 ("iio: accel: Add buffer mode for Sensortek STK8312")
Link: https://lore.kernel.org/r/20210501170121.512209-7-jic23@kernel.org
[ Upstream commit fc36da3131a747a9367a05caf06de19be1bcc972 ]
Fixes: b9a6a237ffc9 ("iio:bma180: Drop _update_scan_mode()")
Link: https://lore.kernel.org/r/20210501170121.512209-2-jic23@kernel.org
[ Upstream commit d877539ad8e8fdde9af69887055fec6402be1a13 ]
On an IRQ handler we should not return normal error codes as 'irqreturn_t'
is expected.
Not necessarily stable material as the old check cannot fail, so it's a bug
we can not hit.
Fixes: ccd2b52f4ac69 ("staging:iio: Add common ADIS library")
Signed-off-by: Nuno Sa <nuno.sa@analog.com>
Link: https://lore.kernel.org/r/20210422101911.135630-2-nuno.sa@analog.com
commit 71b33f6f93ef9462c84560e2236ed22209d26a58 upstream.
The PS ADC Channel data is spread over 2 registers in little-endian
form. This patch adds the missing endianness conversion.
Fixes: 2690be905123 ("iio: Add Lite-On ltr501 ambient light / proximity sensor driver")
Signed-off-by: Oliver Lang <Oliver.Lang@gossenmetrawatt.com>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
Tested-by: Nikita Travkin <nikita@trvn.ru> # ltr559
Link: https://lore.kernel.org/r/20210610134619.2101372-4-mkl@pengutronix.de
commit 421a26f3d7a7c3ca43f3a9dc0f3cb0f562d5bd95 upstream.
The ltr559 chip uses only the lowest bit of the ALS_CONTR register to
configure between active and stand-by mode. In the original driver
BIT(1) is used, which does a software reset instead.
This patch fixes the problem by using BIT(0) as als_mode_active for
the ltr559 chip.
Fixes: 8592a7eefa54 ("iio: ltr501: Add support for ltr559 chip")
Link: https://lore.kernel.org/r/20210610134619.2101372-3-mkl@pengutronix.de
as volatile, too
commit 2ac0b029a04b673ce83b5089368f467c5dca720c upstream.
The regmap is configured for 8 bit registers, uses a RB-Tree cache and
marks several registers as volatile (i.e. do not cache).
The ALS and PS data registers in the chip are 16 bit wide and spans
two regmap registers. In the current driver only the base register is
marked as volatile, resulting in the upper register only read once.
Further the data sheet notes:
| When the I2C read operation starts, all four ALS data registers are
| locked until the I2C read operation of register 0x8B is completed.
Which results in the registers never update after the 2nd read.
This patch fixes the problem by marking the upper 8 bits of the ALS
and PS registers as volatile, too.
Fixes: 2f2c96338afc ("iio: ltr501: Add regmap support.")
Reported-by: Oliver Lang <Oliver.Lang@gossenmetrawatt.com>
Link: https://lore.kernel.org/r/20210610134619.2101372-2-mkl@pengutronix.de
Linux 4.4.274
commit 4ed243b1da169bcbc1ec5507867e56250c5f1ff9 upstream.
Set error code while device ID query failed.
Fixes: 88bc30548aae ("IIO: ADC: New driver for AD7792/AD7793 3 Channel SPI ADC")
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
commit d68c592e02f6f49a88e705f13dfc1883432cf300 upstream
Currently, the proxy sensor scale is zero because it just return the
exponent directly. To fix this issue, this patch use
hid_sensor_format_scale to process the scale first then return the
output.
Fixes: 39a3a0138f61 ("iio: hid-sensors: Added Proximity Sensor Driver")
Signed-off-by: Ye Xiang <xiang.ye@intel.com>
Link: https://lore.kernel.org/r/20210130102530.31064-1-xiang.ye@intel.com
commit 9c0530e898f384c5d279bfcebd8bb17af1105873 upstream.
In adis_update_scan_mode_burst, if adis->buffer allocation fails release
the adis->xfer.
Signed-off-by: Navid Emamdoost <navid.emamdoost@gmail.com>
Reviewed-by: Alexandru Ardelean <alexandru.ardelean@analog.com>
[krzk: backport applied to adis16400_buffer.c instead of adis_buffer.c]
Signed-off-by: Krzysztof Kozlowski <krzysztof.kozlowski@canonical.com>
commit ab612b1daf415b62c58e130cb3d0f30b255a14d0 upstream.
In adis_update_scan_mode, if allocation for adis->buffer fails,
previously allocated adis->xfer needs to be released.
commit efd597b2839a9895e8a98fcb0b76d2f545802cd4 upstream.
The power-down mask of the ad5504 is actually a power-up mask. Meaning if
a bit is set the corresponding channel is powered up and if it is not set
the channel is powered down.
The driver currently has this the wrong way around, resulting in the
channel being powered up when requested to be powered down and vice versa.
Fixes: 3bbbf150ffde ("staging:iio:dac:ad5504: Use strtobool for boolean values")
Acked-by: Alexandru Ardelean <alexandru.ardelean@analog.com>
Link: https://lore.kernel.org/r/20201209104649.5794-1-lars@metafoo.de
commit 19ef7b70ca9487773c29b449adf0c70f540a0aab upstream
When updating the buffer demux, we will skip a scan element from the
device in the case `in_ind != out_ind` and we enter the while loop.
in_ind should only be refreshed with `find_next_bit()` in the end of the
loop.
Note, to cause problems we need a situation where we are skippig over
an element (channel not enabled) that happens to not have the same size
as the next element. Whilst this is a possible situation we haven't
actually identified any cases in mainline where it happens as most drivers
have consistent channel storage sizes with the exception of the timestamp
which is the last element and hence never skipped over.
Fixes: 5ada4ea9be16 ("staging:iio: add demux optionally to path from device to buffer")
Signed-off-by: Nuno Sá <nuno.sa@analog.com>
Link: https://lore.kernel.org/r/20201112144323.28887-1-nuno.sa@analog.com
commit 89deb1334252ea4a8491d47654811e28b0790364 upstream
One of a class of bugs pointed out by Lars in a recent review.
iio_push_to_buffers_with_timestamp() assumes the buffer used is aligned
to the size of the timestamp (8 bytes). This is not guaranteed in
this driver which uses an array of smaller elements on the stack.
As Lars also noted this anti pattern can involve a leak of data to
userspace and that indeed can happen here. We close both issues by
moving to a suitable structure in the iio_priv() data.
This data is allocated with kzalloc() so no data can leak apart from
previous readings.
The explicit alignment of ts is not necessary in this case but
does make the code slightly less fragile so I have included it.
Fixes: 39631b5f9584 ("iio: Add Freescale mag3110 magnetometer driver")
Reported-by: Lars-Peter Clausen <lars@metafoo.de>
Link: https://lore.kernel.org/r/20200920112742.170751-4-jic23@kernel.org
commit 198cf32f0503d2ad60d320b95ef6fb8243db857f upstream.
Whilst this is another case of the issue Lars reported with
an array of elements of smaller than 8 bytes being passed
to iio_push_to_buffers_with_timestamp(), the solution here is
a bit different from the other cases and relies on __aligned
working on the stack (true since 4.6?)
This one is unusual. We have to do an explicit memset() each time
as we are reading 3 bytes into a potential 4 byte channel which
may sometimes be a 2 byte channel depending on what is enabled.
As such, moving the buffer to the heap in the iio_priv structure
doesn't save us much. We can't use a nice explicit structure
on the stack either as the data channels have different storage
sizes and are all separately controlled.
Fixes: cc26ad455f57 ("iio: Add Freescale MPL3115A2 pressure / temperature sensor driver")
Link: https://lore.kernel.org/r/20200920112742.170751-7-jic23@kernel.org
rockchip_saradc_resume
commit 560c6b914c6ec7d9d9a69fddbb5bf3bf71433e8b upstream.
Fix the missing clk_disable_unprepare() of info->pclk
before return from rockchip_saradc_resume in the error
handling case when fails to prepare and enable info->clk.
Suggested-by: Robin Murphy <robin.murphy@arm.com>
Fixes: 44d6f2ef94f9 ("iio: adc: add driver for Rockchip saradc")
Signed-off-by: Qinglang Miao <miaoqinglang@huawei.com>
Link: https://lore.kernel.org/r/20201103120743.110662-1-miaoqinglang@huawei.com
commit 10ab7cfd5522f0041028556dac864a003e158556 upstream.
iio_push_to_buffers_with_timestamp assumes the buffer used is aligned
this driver which uses a 16 byte array of smaller elements on the stack.
This is fixed by using an explicit c structure. As there are no
holes in the structure, there is no possiblity of data leakage
in this case.
The explicit alignment of ts is not strictly necessary but potentially
makes the code slightly less fragile. It also removes the possibility
of this being cut and paste into another driver where the alignment
isn't already true.
Fixes: 36e0371e7764 ("iio:itg3200: Use iio_push_to_buffers_with_timestamp()")
Link: https://lore.kernel.org/r/20200722155103.979802-6-jic23@kernel.org
This is the 4.4.237 stable release
commit 89226a296d816727405d3fea684ef69e7d388bd8 upstream.
this driver which uses a 16 byte u8 array on the stack. As Lars also noted
this anti pattern can involve a leak of data to userspace and that
indeed can happen here. We close both issues by moving to
a suitable structure in the iio_priv() data with alignment
ensured by use of an explicit c structure. This data is allocated
with kzalloc so no data can leak appart from previous readings.
The additional forcing of the 8 byte alignment of the timestamp
is not strictly necessary but makes the code less fragile by
making this explicit.
Fixes: c7eeea93ac60 ("iio: Add Freescale MMA8452Q 3-axis accelerometer driver")
commit a6f86f724394de3629da63fe5e1b7a4ab3396efe upstream.
userspace and that indeed can happen here. We close both issues by moving
to a suitable structure in the iio_priv() data with alignment
Fixes tag is beyond some major refactoring so likely manual backporting
would be needed to get that far back.
Whilst the force alignment of the ts is not strictly necessary, it
does make the code less fragile.
Fixes: 3bbec9773389 ("iio: bmc150_accel: add support for hardware fifo")
Acked-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
commit 2684d5003490df5398aeafe2592ba9d4a4653998 upstream.
Here we use a structure on the stack. The driver already did an
explicit memset so no data leak was possible.
Forced alignment of ts is not strictly necessary but probably makes
Note there has been some rework in this driver of the years, so no
way this will apply cleanly all the way back.
[ Upstream commit a139ffa40f0c24b753838b8ef3dcf6ad10eb7854 ]
Reading from the chip should be unlocked on error path else the lock
could never being released.
Fixes: 07914c84ba30 ("iio: adc: Add driver for Microchip MCP3422/3/4 high resolution ADC")
Fixes: 3f1093d83d71 ("iio: adc: mcp3422: fix locking scope")
Acked-by: Jonathan Cameron <jonathan.cameron@huawei.com>
Signed-off-by: Angelo Compagnucci <angelo.compagnucci@gmail.com>
Link: https://lore.kernel.org/r/20200901093218.1500845-1-angelo.compagnucci@gmail.com
commit 3f1093d83d7164e4705e4232ccf76da54adfda85 upstream.
Locking should be held for the entire reading sequence involving setting
the channel, waiting for the channel switch and reading from the
channel.
If not, reading from a channel can result mixing with the reading from
another channel.
Link: https://lore.kernel.org/r/20200819075525.1395248-1-angelo.compagnucci@gmail.com
[ Upstream commit 18dfb5326370991c81a6d1ed6d1aeee055cb8c05 ]
The bytes returned by the i2c reading need to be swapped
unconditionally. Otherwise, on be16 platforms, an incorrect value will be
returned.
Taking the slow path via next merge window as its been around a while
and we have a patch set dependent on this which would be held up.
Fixes: 62a1efb9f868 ("iio: add vcnl4000 combined ALS and proximity sensor")
Signed-off-by: Mathieu Othacehe <m.othacehe@gmail.com>
[ Upstream commit 28535877ac5b2b84f0d394fd67a5ec71c0c48b10 ]
It should use ad7797_attribute_group in ad7797_info,
according to commit ("iio:ad7793: Add support for the ad7796 and ad7797").
Scale is fixed for the ad7796 and not programmable, hence
should not have the scale_available attribute.
Fixes: fd1a8b912841 ("iio:ad7793: Add support for the ad7796 and ad7797")
Reviewed-by: Lars-Peter Clausen <lars@metafoo.de>
simultaneous mode
commit 8bef455c8b1694547ee59e8b1939205ed9d901a6 upstream.
The XADC has two internal ADCs. Depending on the mode it is operating in
either one or both of them are used. The device manual calls this
continuous (one ADC) and simultaneous (both ADCs) mode.
The meaning of the sequencing register for the aux channels changes
depending on the mode.
In continuous mode each bit corresponds to one of the 16 aux channels. And
the single ADC will convert them one by one in order.
In simultaneous mode the aux channels are split into two groups the first 8
channels are assigned to the first ADC and the other 8 channels to the
second ADC. The upper 8 bits of the sequencing register are unused and the
lower 8 bits control both ADCs. This means a bit needs to be set if either
the corresponding channel from the first group or the second group (or
both) are set.
Currently the driver does not have the special handling required for
simultaneous mode. Add it.
Fixes: bdc8cda1d010 ("iio:adc: Add Xilinx XADC driver")
commit f954b098fbac4d183219ce5b42d76d6df2aed50a upstream.
When enabling the trigger and unmasking the end-of-sequence (EOS) interrupt
the EOS interrupt should be cleared from the status register. Otherwise it
is possible that it was still set from a previous capture. If that is the
case the interrupt would fire immediately even though no conversion has
been done yet and stale data is being read from the device.
The old code only clears the interrupt if the interrupt was previously
unmasked. Which does not make much sense since the interrupt is always
masked at this point and in addition masking the interrupt does not clear
the interrupt from the status register. So the clearing needs to be done
unconditionally.
commit e44ec7794d88f918805d700240211a9ec05ed89d upstream.
The check for shutting down the second ADC is inverted. This causes it to
be powered down when it should be enabled. As a result channels that are
supposed to be handled by the second ADC return invalid conversion results.
This is the 4.4.214 stable release
commit 883f616530692d81cb70f8a32d85c0d2afc05f69 upstream.
Previous versions of `iio_compute_scan_bytes` only aligned each element
to its own length (i.e. its own natural alignment). Because multiple
consecutive sets of scan elements are buffered this does not work in
case the computed scan bytes do not align with the natural alignment of
the first scan element in the set.
This commit fixes this by aligning the scan bytes to the natural
alignment of the largest scan element in the set.
Fixes: 959d2952d124 ("staging:iio: make iio_sw_buffer_preenable much more general.")
Signed-off-by: Lars Möllendorf <lars.moellendorf@plating.de>
[ Upstream commit b1e18768ef1214c0a8048327918a182cabe09f9d ]
Currently the pointer val is being incorrectly incremented
instead of the value pointed to by val. Fix this by adding
in the missing * indirection operator.
Addresses-Coverity: ("Unused value")
Fixes: c03f2c536818 ("staging:iio:dac: Add AD5380 driver")
commit 9b742763d9d4195e823ae6ece760c9ed0500c1dc upstream.
This was found only after the whole thing with the inline functions, but
the compiler actually found something. The value of the `bias` (in
adis16480_get_calibbias()) should only be set if the read operation was
successful.
No actual known problem occurs as users of this function all
ultimately check the return value. Hence probably not stable material.
Fixes: 2f3abe6cbb6c9 ("iio:imu: Add support for the ADIS16480 and similar IMUs")
Signed-off-by: Alexandru Ardelean <alexandru.ardelean@analog.com>
[ Upstream commit db033831b4f5589f9fcbadb837614a7c4eac0308 ]
All the registers are configured by the driver, let's reset the chip
at probe time, avoiding any conflict with a possible earlier
configuration.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
[ Upstream commit f552fde983d378e7339f9ea74a25f918563bf0d3 ]
Separate the declaration of struct bh1750_chip_info from definition
of bh1750_chip_info_tbl[] in a single statement as it makes the code
hard to read, and with the extra newline it makes it look as if the
bh1750_chip_info_tbl[] had no explicit type.
This change also resolves the following compiler warning about the
unusual position of the static keyword that can be seen when building
with warnings enabled (W=1):
drivers/iio/light/bh1750.c:64:1: warning:
‘static’ is not at beginning of declaration [-Wold-style-declaration]
Related to commit 3a11fbb037a1 ("iio: light: add support for ROHM
BH1710/BH1715/BH1721/BH1750/BH1751 ambient light sensors").
Signed-off-by: Krzysztof Wilczynski <kw@linux.com>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
[ Upstream commit 4c35b7a51e2f291471f7221d112c6a45c63e83bc ]
The driver is defining debugfs entries by calling
`adis16480_debugfs_init()`. However, those entries are attached to the
iio_dev debugfs entry which won't exist if no debugfs_reg_access
callback is provided.
Fixes: 2f3abe6cbb6c ("iio:imu: Add support for the ADIS16480 and similar IMUs")
commit 342a6928bd5017edbdae376042d8ad6af3d3b943 upstream.
The IIO_HUMIDITYRELATIVE channel was being incorrectly reported back
as percent when it should have been milli percent. This is via an
incorrect scale value being returned to userspace.
Signed-off-by: Chris Lesiak <chris.lesiak@licor.com>
Acked-by: Matt Ranostay <matt.ranostay@konsulko.com>
[ Upstream commit 0833627fc3f757a0dca11e2a9c46c96335a900ee ]
Do not try to write negative values and make sure that the write goes well.
Signed-off-by: Marcus Folkesson <marcus.folkesson@gmail.com>
commit 24e1eb5c0d78cfb9750b690bbe997d4d59170258 upstream.
It could happen that either `val` or `val2` [provided from userspace] is
negative. In that case the computed frequency could get a weird value.
Fix this by checking that neither of the 2 variables is negative, and check
that the computed result is not-zero.
Fixes: e4f959390178 ("iio: imu: adis16480 switch sampling frequency attr to core support")
[ Upstream commit 6c59a962e081df6d8fe43325bbfabec57e0d4751 ]
The center temperature of the supported devices stored in the constant
BMC150_ACCEL_TEMP_CENTER_VAL is not 24 degrees but 23 degrees.
It seems that some datasheets were inconsistent on this value leading
to the error. For most usecases will only make minor difference so
not queued for stable.
Signed-off-by: Pascal Bouwmann <bouwmann@tau-tec.de>
commit 82f3015635249a8c8c45bac303fd84905066f04f upstream.
When an end-of-conversion interrupt is received after performing a
single-shot reading of the light sensor, the driver was waking up the
result ready queue before checking opt->ok_to_ignore_lock to determine
if it should unlock the mutex. The problem occurred in the case where
the other thread woke up and changed the value of opt->ok_to_ignore_lock
to false prior to the interrupt thread performing its read of the
variable. In this case, the mutex would be unlocked twice.
Signed-off-by: David Frey <dpfrey@gmail.com>
Reviewed-by: Andreas Dannenberg <dannenberg@ti.com>
Fixes: 94a9b7b1809f ("iio: light: add support for TI's opt3001 light sensor")
commit c62dd44901cfff12acc5792bf3d2dec20bcaf392 upstream.
Since commit 0f7ddcc1bff1 ("iio:adc:ad799x: Write default config on probe
and reset alert status on probe") the error path is wrong since it
leaves the vref regulator on. Fix this by disabling both regulators.
Fixes: 0f7ddcc1bff1 ("iio:adc:ad799x: Write default config on probe and reset alert status on probe")
Signed-off-by: Marco Felsch <m.felsch@pengutronix.de>
