path: root/drivers/iio
2015-09-04Merge tag 'gpio-v4.3-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO updates from Linus Walleij: "This is the bulk of GPIO changes for the v4.3 kernel cycle. There is quite a lot going on in the GPIO subsystem this merge window, so the main matter is decribed below. The hits in other subsystems when making the GPIO flags optional are all ACKed by their respective subsystem maintainers. Core changes: - Root out the wrapper devm_gpiod_get() and gpiod_get() etc versions of the descriptor calls that did not use the flags argument on the end. This was around for too long and eventually Uwe Kleine-König took the time to clean it out and the last users are removed along with the macros in this tag. In several cases the use of flags simplifies the code. For this reason we have (ACKed) patches hitting in DRM, IIO, media, NFC, USB+PHY up until we hammer in the nail with removing the macros. - Add a fat document describing how much ready-made GPIO stuff we have i the kernel to discourage people from reinventing a square wheel in userspace, as so often happens. - Create a separate lockdep class for each instance of a GPIO IRQ chip instead of using one class for all chips, as the current code will not work with systems with several GPIO chips doing lockdep debugging. - Protect against driver unloading also when a GPIO line is only used as IRQ for the GPIOLIB_IRQCHIP helpers. - If the GPIO chip has no designated owner, assign the parent device driver owner as owner. - Consolidation of chained IRQ handler install/remove replacing all call sites where irq_set_handler_data() and irq_set_chained_handler() were done in succession with a combined call to irq_set_chained_handler_and_data(). This series was created by Thomas Gleixner after the problem was observed by Russell King. - Tglx also made another series of patches switching __irq_set_handler_locked() for irq_set_handler_locked() which is way cleaner. - Tglx and Jiang Liu wrote a good bunch of patches to make use of irq_desc_get_xxx() accessors and avoid looking up irq_descs from IRQ numbers. The goal is to get rid of the irq number from the handlers in the IRQ flow which is nice. - Rob Herring killed off the set_irq_flags() for all GPIO drivers. This was an ARM specific function that is replaced with the generic irq_modify_status() where special flags are actually needed. - When an OF node has a pin range for its GPIOs, return -EPROBE_DEFER if the pin controller isn't available. Pretty logical, yet needed to be fixed. - If a driver using GPIOLIB_IRQCHIP has its own irq_*_resources call back, then call these instead of the defaults provided by the GPIOLIB. - Fix an undocumented ABI hole: named GPIOs were not properly documented. Driver improvements: - Add get_direction() support to the generic GPIO driver, it's strange that we didn't have that before. - Make it possible to have input-only GPIO chips using the generic GPIO driver. - Clean out platform data support from the Emma Mobile (EM) driver - Finegrained runtime PM support for the RCAR driver. - Support r8a7795 (R-car H3) in the RCAR driver. - Support interrupts on GPIOs 16 thru 31 in the DaVinci driver. - Some consolidation and new support in the MPC8xxx driver, we now support MPC5125. - Preempt-RT-friendly patches: the OMAP, MPC8xxx, drivers uses raw spinlocks making it work better with the realime patches. - Interrupt support for the EXTRAXFS GPIO driver. - Make the ETRAXFS GPIO driver support also ARTPEC-3. - Interrupt and wakeup support for the BRCMSTB driver, also for wakeup from S5 cold boot. - Mask MXC IRQs during suspend. - Improve OMAP2 GPIO set_debounce() to work according to spec. - The VF610 driver handles IRQs properly. New drivers: - ZTE ZX GPIO driver" * tag 'gpio-v4.3-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (87 commits) Revert "gpio: extraxfs: fix returnvar.cocci warnings" gpio: tc3589x: use static container helper gpio: xlp: fix error return code gpio: vf610: handle level IRQ's properly gpio: max732x: Fix error handling in probe() gpio: omap: fix clk_prepare/unprepare usage gpio: omap: protect regs access in omap_gpio_irq_handler gpio: omap: fix omap2_set_gpio_debounce gpio: omap: switch to use platform_get_irq gpio: omap: remove wrong irq_domain_remove usage in probe gpiolib: add description for gpio irqchip fields in struct gpio_chip gpio: extraxfs: fix returnvar.cocci warnings gpiolib: irqchip: use different lockdep class for each gpio irqchip gpio/grgpio: fix deadlock in grgpio_irq_unmap() Documentation: gpio: consumer: describe active low property gpio: mxc: fix section mismatch warning gpio/mxc: mask gpio interrupts in suspend gpio: omap: Fix missing raw locks conversion gpio: brcmstb: support wakeup from S5 cold boot gpio: brcmstb: Add interrupt and wakeup source support ...
2015-08-13Merge tag 'v4.2-rc4' into develLinus Walleij
Linux 4.2-rc4
2015-08-12Merge tag 'iio-for-4.3b-2' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next Jonathan writes: Second set of new device support, features and cleanup for the 4.3 cycle. Take 2 also includes a fix set that was too late for the 4.2 cycle. As we had a lot of tools and docs work in this set, I have broken those out into their own categories in this description. Fixes from the pull request '4th set of IIO fixes for the 4.2 cycle'. * Poll functions for both event chardev and the buffer one were returning negative error codes (via a positive value). * A recent change to lsiio adding some error handling that was wrong and stopped the tool working. * bmg160 was missing some dependencies in Kconfig * berlin2-adc had a misshandled register (wrote a value rather than a bitmap) New device support * TI opt3001 light sensor * TXC PA12 ALS and proximity sensor. * mcp3301 ADC support (in mcp320x driver) * ST lsm303agr accelerometer and magnetometer drivers (plus some st-sensors common support to allow different WHOAMI register addresses, devices with fixed scale and allow interrupt equiped magnetometers). * ADIS16305, ADIS16367, ADIS16445IMUs (in the adis16400 driver) * ADIS16266 gyro (in the adis16260 driver) * ADIS16137 gyro (in the adis16136 driver) New functionality * mmc35240 DT bindings. * Inverse unit conversion macros to aid handing of values written to sysfs attributes. Core cleanup * Forward declaration of struct iio_trigger to avoid a compile warning. Driver cleanup / fixes * mxs-lradc - Clarify which parts are supported. - Fix spelling erorrs. - Missing/extra includes - reorder includes - add datasheet name listings for all usable channels (to allow them to be bound by name from consumer drivers) * acpi-als - add some function prefixes as per general iio style. * bmc150_magn - replace a magic value with the existing define. * vf610 - determine possible sample frequencies taking into account the electrical characteristics (defining a minimum sample time) * dht11 - whitespace - additional docs - avoid mulitple assignments in one line - Use the new funciton ktime_get_resolution_ns to cleanup a nasty trick previously used for timing. * Fix all drivers that consider 0 a valid IRQ for historical reasons. * Export I2C module alias info where previously missing (to allow autoprobing) * Export OF module alias info where previously missing. * mmc35240 - switch some variables into arrays to improve readability. * mlx90614 - define some magic numbers for readability. * bmc150_magn - expand area locked by a mutex to cover all the use of the data->buffer. - use descriptive naming for a mask instead of a magic value. * berin2-adc - pass up an error code rather that a generic error - constify the iio_chan_spec - some other little tidy ups. * stk8312 - fix a dependency on triggered buffers in kconfig - add a check for invalid attribute values - improve error handling by returning error codes where possible and return immediately where relevant - rework macro defs to use GENMASK etc - change some variable types to reduce unnecessary casting - clean up code style - drop a local buffer copy for bulk reads and use the one in data->buffer instead. * adis16400 - the adis16448 gyroscope scale was wrong. * adis16480 - some more wrong scales for various parts. * adis16300 - has an undocumented product id and serial number registers so use them. * iio_simple_dummy - fix some wrong code indentation. * bmc150-accel - use the chip ID to detect the chip present rather than verifying the expected part was there. This was in response to a wrong ACPI entry on the WinBook TW100. * mma8452 - fix _get_hp_filter_index - drop a double include - pass up an error code rather than rewriting it - range check input values to attribute writes - register defs tidy up using GENMASK and reordering them to be easier to follow. - various coding style cleanups - put the Kconfig entry in the write place (alphabetically). Tools related * Tools cleanup - drop an explicity NULL comparison, some unnecessary braces, use the ARRAY_SIZE macro, send error messages to stderr instead of dropping them in the middle of normal output. * Fix tools to allow that scale and offset attributes are optional. * More tools fixes including allowing true 32bit data (previously an overflow prevented more than 31bits) * Drop a stray header guard that ended up in a c file. * Make calc_digits static as it isn't exported or in the header. * Set ci_array pointer to NULL after free as a protection against non safe usage of the tools core code. Also convert a double pointer to a single one as the extra level of indirection was unnecessary. Docs * DocBook introduction by Daniel Baluta. Glad we are beginning to draw together some more introductory docs to suplement the various tools / examples. * Drop bytes_per_datum sysfs attribute docs as it no longer exists. * A whole load of missing / fixing of kernel-doc for the core of IIO. * Document the trigger name sysfs attribute in the ABI docs. * Minor typos in the ABI docs related to power down modes.
2015-08-12iio: event: Remove negative error code from iio_event_pollCristina Opriceana
Negative return values are not supported by iio_event_poll since its return type is unsigned int. Fixes: f18e7a068a0a3 ("iio: Return -ENODEV for file operations if the device has been unregistered") Signed-off-by: Cristina Opriceana <cristina.opriceana@gmail.com> Cc: <Stable@vger.kernel.org> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-12iio: industrialio-buffer: Fix iio_buffer_poll return valueCristina Opriceana
Change return value to 0 if no device is bound since unsigned int cannot support negative error codes. Fixes: f18e7a068 ("iio: Return -ENODEV for file operations if the device has been unregistered") Signed-off-by: Cristina Opriceana <cristina.opriceana@gmail.com> Cc: <Stable@vger.kernel.org> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-12iio: bmg160: IIO_BUFFER and IIO_TRIGGERED_BUFFER are requiredMarkus Pargmann
This patch adds selects for IIO_BUFFER and IIO_TRIGGERED_BUFFER. Without IIO_BUFFER, the driver does not compile. Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Reviewed-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Cc: <Stable@vger.kernel.org> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-12iio:adc:berlin2-adc: Fix register definitionHartmut Knaack
Active channel number is stored in BERLIN2_SM_CTRL as value, instead of a bit map. The masks for channel interrupts and data ready are a 16 bits wide bit map each, instead of just 4 bits. Also correct the data mask for the temperature sensor, which was Reported-by: Antoine Tenart <antoine.tenart@free-electrons.com> Signed-off-by: Hartmut Knaack <knaack.h@gmx.de> Acked-by: Antoine Tenart <antoine.tenart@free-electrons.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-08iio:accel:mma8452: reorder Kconfig entryHartmut Knaack
Move the entry in Kconfig to its alphabetically correct position. Signed-off-by: Hartmut Knaack <knaack.h@gmx.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-08iio:accel:mma8452: coding style cleanupHartmut Knaack
Some coding style cleanups, mainly indicated by checkpatch.pl, which includes indentation changes, drop spaces after casts and befor tabs. Also insert empty lines after logical blocks and before unconditional returns. Signed-off-by: Hartmut Knaack <knaack.h@gmx.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-08iio:accel:mma8452: rework register definitionsHartmut Knaack
Rework register definitions to be sorted by register and bit number, with bit definitions cascaded under the appropriate register, use GENMASK for consecutive bitmasks and realign properly. Signed-off-by: Hartmut Knaack <knaack.h@gmx.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-08iio:accel:mma8452: check values to be writtenHartmut Knaack
Check values to be written to the device for valid lower and upper bounds. Signed-off-by: Hartmut Knaack <knaack.h@gmx.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-08iio:accel:mma8452: pass up real error codeHartmut Knaack
Pass up the error code provided by functions. Signed-off-by: Hartmut Knaack <knaack.h@gmx.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-08iio:accel:mma8452: drop double includeHartmut Knaack
One inclusion of linux/iio/trigger_consumer.h is sufficient. Fixes: ae6d9ce05691b ("iio: mma8452: Add support for interrupt driven triggers.") Signed-off-by: Hartmut Knaack <knaack.h@gmx.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-08iio:accel:mma8452: fix _get_hp_filter_indexHartmut Knaack
To iterate through the available frequencies of mma8452_hp_filter_cutoff[], the array size of a row of that table needs to be provided to _get_int_plus_micros_index(). Fixes: 1e79841a00e46 ("iio: mma8452: Add highpass filter configuration.") Signed-off-by: Hartmut Knaack <knaack.h@gmx.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-08iio:accel:bmc150-accel: Use the chip ID to detect sensor variantBastien Nocera
Instead of using the I2C or ACPI ID to determine which variant of the chipset to use, determine that from the chip ID. Under Windows, the same driver is used for those variants and, despite incorrect ACPI data, it is able to load and operate the accelerometer. Fixes the accelerometer failing with: bmc150_accel i2c-BMA250E:00: Invalid chip f8 on the WinBook TW100 Signed-off-by: Bastien Nocera <hadess@hadess.net> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-08iio:accel:bmc150-accel: Move bmc150_accel_chip_init()Bastien Nocera
Move bmc150_accel_chip_init() so that we can use bmc150_accel_chip_info_tbl[] in it. Signed-off-by: Bastien Nocera <hadess@hadess.net> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-08iio: adis16136: Add ADIS16137 supportLars-Peter Clausen
The ADIS16137 is register map compatible to the ADIS16136, but has a different scale factor for the gyroscope output. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-08iio: adis16400: Add ADIS16445 supportLars-Peter Clausen
The ADIS16445 is similar to the ADIS16448, but without the magnetometer and pressure channels as well as different scale factors for the gyroscope and accelerometer outputs. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-08iio: adis16400: Add ADIS16367 supportLars-Peter Clausen
The ADIS16367 is mostly register compatible to the ADIS16360. The only difference is the scale factor for the gyroscope output. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-08iio: adis16260: Add ADIS16266 supportLars-Peter Clausen
The ADIS16266 is mostly register compatible to the ADIS16260. The difference is a different gyroscope scale factor as well not having the relative angular displacement channel. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-08iio: adis16400: Add ADIS16305 supportLars-Peter Clausen
The ADIS16305 is fully register map compatible to the ADIS16300. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-08iio: adis16400: adis16300 has product ID and serial numberLars-Peter Clausen
The ADIS16300 has the product ID and serial number registers, they are just not documented. Set the appropriate flags so the driver makes use of them. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-08iio: adis16480: Fix scale factorsLars-Peter Clausen
The different devices support by the adis16480 driver have slightly different scales for the gyroscope and accelerometer channels. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Cc: <Stable@vger.kernel.org> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-08iio: adis16400: Fix adis16448 gyroscope scaleLars-Peter Clausen
Use the correct scale for the adis16448 gyroscope output. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Cc: <Stable@vger.kernel.org> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-08iio: trigger: Add missing fields in kernel docsCristina Opriceana
Fix kernel docs warnings by adding the missing description for each of the existing function parameters. Signed-off-by: Cristina Opriceana <cristina.opriceana@gmail.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-08iio:accel:stk8312: drop local bufferHartmut Knaack
Drop the local buffer in stk8312_trigger_handler() and use data->buffer instead for bulk reads. Signed-off-by: Hartmut Knaack <knaack.h@gmx.de> Reviewed-by: Tiberiu Breana <tiberiu.a.breana@intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-08iio:accel:stk8312: code style cleanupHartmut Knaack
Adjust some indentation issues to make checkpatch.pl happy in strict mode. Signed-off-by: Hartmut Knaack <knaack.h@gmx.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-08iio:accel:stk8312: use appropriate variable typesHartmut Knaack
Adapt some variable types to reduce unnecessary casting. Signed-off-by: Hartmut Knaack <knaack.h@gmx.de> Reviewed-by: Tiberiu Breana <tiberiu.a.breana@intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-08iio:accel:stk8312: rework macro definitionsHartmut Knaack
Make use of BIT to describe register bits, GENMASK for consecutive bitmasks, rename and sort existing definitions, replace magic value with an expressive definition, drop an unused definition. Signed-off-by: Hartmut Knaack <knaack.h@gmx.de> Reviewed-by: Tiberiu Breana <tiberiu.a.breana@intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-08iio:accel:stk8312: improve error handlingHartmut Knaack
Improve error handling in the following ways: - set return value on error condition to an appropriate error code - return error code immediately in case of an error (slightly changes code structure) - pass up real error code - add missing error handling - return 0 when error have been caught already - put device back in active mode after error occurs Signed-off-by: Hartmut Knaack <knaack.h@gmx.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-02iio:accel:stk8312: check for invalid valueHartmut Knaack
Revision 1.2 of the datasheet recommends on page 22 to only write non-zero values read from OTP register 0x70 into AFECTRL register. Signed-off-by: Hartmut Knaack <knaack.h@gmx.de> Reviewed-by: Tiberiu Breana <tiberiu.a.breana@intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-02iio:accel:stk8312: add triggered buffer dependencyHartmut Knaack
Add the still missing dependencies for triggered buffer support. Fixes: 95c12bba51c37 ("iio: accel: Add buffer mode for Sensortek STK8312") Signed-off-by: Hartmut Knaack <knaack.h@gmx.de> Reviewed-by: Tiberiu Breana <tiberiu.a.breana@intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-02iio:adc:berlin2-adc: use channel-array size directlyHartmut Knaack
Drop the otherwise unused definition of the channel-array size and use it directly in _probe - makes it a bit more obvious. Signed-off-by: Hartmut Knaack <knaack.h@gmx.de> Acked-by: Antoine Tenart <antoine.tenart@free-electrons.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-02iio:adc:berlin2-adc: use short operator formatHartmut Knaack
Use augmented assignment to subtract the offset for negative temperature values. Specify the amount of private data to be allocated through devm_iio_device_alloc() with sizeof(*priv), as it is shorter and common practice in IIO. Signed-off-by: Hartmut Knaack <knaack.h@gmx.de> Acked-by: Antoine Tenart <antoine.tenart@free-electrons.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-02iio:adc:berlin2-adc: constify iio_chan_specHartmut Knaack
Mark berlin2_adc_channels array as constant. Signed-off-by: Hartmut Knaack <knaack.h@gmx.de> Acked-by: Antoine Tenart <antoine.tenart@free-electrons.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-02iio:adc:berlin2-adc: pass up real error codeHartmut Knaack
Pass up the real error code returned by platform_get_irq_byname(). Signed-off-by: Hartmut Knaack <knaack.h@gmx.de> Acked-by: Antoine Tenart <antoine.tenart@free-electrons.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-02iio: event: Add missing fields in kernel docsCristina Opriceana
Fix kernel docs warnings by adding the missing fields, each with its associated description. Signed-off-by: Cristina Opriceana <cristina.opriceana@gmail.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-02iio: buffer: Fix kernel docs warningsCristina Opriceana
Fix kernel docs for structures and functions in order to remove some warnings when the documentation gets generated. Signed-off-by: Cristina Opriceana <cristina.opriceana@gmail.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-02iio: core: Add function params for kernel docsCristina Opriceana
This patch adds the missing fields in kernel docs to remove some warnings that appear when the IIO Documentation DocBook is generated. Signed-off-by: Cristina Opriceana <cristina.opriceana@gmail.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-02iio: magn: bmc150_magn: do not set power state twice when setting trigger stateIrina Tirdea
When setting the trigger state, the device power state is set through buffer preenable and postdisable hooks. There is no need to also set it in the trigger set state call. Remove duplicate set power state from the trigger set state call. Signed-off-by: Irina Tirdea <irina.tirdea@intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-02iio: magn: bmc150_magn: add locking comment for runtime resumeIrina Tirdea
Runtime resume function is called with the data->mutex lock held. Add a comment to indicate this. Signed-off-by: Irina Tirdea <irina.tirdea@intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-02iio:magnetometer:bmc150_magn: use descriptive name for maskHartmut Knaack
Define and use a descriptive name for the repetition registers data mask, instead of a 'magic' value. Signed-off-by: Hartmut Knaack <knaack.h@gmx.de> Acked-by: Irina Tirdea <irina.tirdea@intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-02iio:magnetometer:bmc150_magn: expand mutex in trigger_handlerHartmut Knaack
Keep the mutex locked, until the content of data->buffer has been pushed out. Signed-off-by: Hartmut Knaack <knaack.h@gmx.de> Acked-by: Irina Tirdea <irina.tirdea@intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-02iio: mlx90614: Define magic numbersCrt Mori
Translates the magic constant numbers to named macros and add some additional comments about their meaning. The diff is made towards togreg branch as that branch seems to have the most recent updates of mlx90614 driver (many are yet to be merged). Signed-off-by: Crt Mori <cmo@melexis.com> Acked-by: Peter Meerwald <pmeerw@pmeerw.net> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-02iio: mmc35240: minor change to improve code readibilityTeodora Baluta
This patch changes two variables to arrays to improve code readibility. Signed-off-by: Teodora Baluta <teodora.baluta@intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-02iio: Export OF module alias information in missing driversJavier Martinez Canillas
The I2C core always reports the MODALIAS uevent as "i2c:<client name" regardless if the driver was matched using the I2C id_table or the of_match_table. So technically there's no need for a driver to export the OF table since currently it's not used. In fact, the I2C device ID table is mandatory for I2C drivers since a i2c_device_id is passed to the driver's probe function even if the I2C core used the OF table to match the driver. And since the I2C core uses different tables, OF-only drivers needs to have duplicated data that has to be kept in sync and also the dev node compatible manufacturer prefix is stripped when reporting the MODALIAS. To avoid the above, the I2C core behavior may be changed in the future to not require an I2C device table for OF-only drivers and report the OF module alias. So, it's better to also export the OF table to prevent breaking module autoloading if that happens. Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-02iio: Export I2C module alias information in missing driversJavier Martinez Canillas
The I2C core always reports the MODALIAS uevent as "i2c:<client name" regardless if the driver was matched using the I2C id_table or the of_match_table. So the driver needs to export the I2C table and this be built into the module or udev won't have the necessary information to auto load the correct module when the device is added. Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-07-27Merge 4.2-rc4 into staging-nextGreg Kroah-Hartman
We want the iio and other fixes in this branch as well. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-07-23iio: st-magn: add support for lsm303agr magnetometerGiuseppe Barba
This adds support for the lsm303agr magnetometer. Signed-off-by: Giuseppe Barba <giuseppe.barba@st.com> Acked-by: Denis Ciocca <denis.ciocca@st.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-07-23iio: st-accel: add support for lsm303agr accelerometerGiuseppe Barba
This adds support for the lsm303agr accelerometer. Signed-off-by: Giuseppe Barba <giuseppe.barba@st.com> Acked-by: Denis Ciocca <denis.ciocca@st.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
