path: root/drivers/infiniband/Kconfig
2008-02-04RDMA/nes: Add a driver for NetEffect RNICsGlenn Streiff
Add a standard NIC and RDMA/iWARP driver for NetEffect 1/10Gb ethernet adapters. Signed-off-by: Glenn Streiff <gstreiff@neteffect.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-07-09IB: Use menuconfig for InfiniBand menuJan Engelhardt
Change Kconfig objects from "menu, config" into "menuconfig" so that the user can disable the whole feature without having to enter the menu first. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-05-10[S390] Kconfig: menus with depends on HAS_IOMEM.Martin Schwidefsky
Add "depends on HAS_IOMEM" to a number of menus to make them disappear for s390 which does not have I/O memory. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-05-08IB/mlx4: Add a driver Mellanox ConnectX InfiniBand adaptersRoland Dreier
Add an InfiniBand driver for Mellanox ConnectX adapters. Because these adapters can also be used as ethernet NICs and Fibre Channel HBAs, the driver is split into two modules: mlx4_core: Handles low-level things like device initialization and processing firmware commands. Also controls resource allocation so that the InfiniBand, ethernet and FC functions can share a device without stepping on each other. mlx4_ib: Handles InfiniBand-specific things; plugs into the InfiniBand midlayer. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-05-08IB/uverbs: Export ib_umem_get()/ib_umem_release() to modulesRoland Dreier
Export ib_umem_get()/ib_umem_release() and put low-level drivers in control of when to call ib_umem_get() to pin and DMA map userspace, rather than always calling it in ib_uverbs_reg_mr() before calling the low-level driver's reg_user_mr method. Also move these functions to be in the ib_core module instead of ib_uverbs, so that driver modules using them do not depend on ib_uverbs. This has a number of advantages: - It is better design from the standpoint of making generic code a library that can be used or overridden by device-specific code as the details of specific devices dictate. - Drivers that do not need to pin userspace memory regions do not need to take the performance hit of calling ib_mem_get(). For example, although I have not tried to implement it in this patch, the ipath driver should be able to avoid pinning memory and just use copy_{to,from}_user() to access userspace memory regions. - Buffers that need special mapping treatment can be identified by the low-level driver. For example, it may be possible to solve some Altix-specific memory ordering issues with mthca CQs in userspace by mapping CQ buffers with extra flags. - Drivers that need to pin and DMA map userspace memory for things other than memory regions can use ib_umem_get() directly, instead of hacks using extra parameters to their reg_phys_mr method. For example, the mlx4 driver that is pending being merged needs to pin and DMA map QP and CQ buffers, but it does not need to create a memory key for these buffers. So the cleanest solution is for mlx4 to call ib_umem_get() in the create_qp and create_cq methods. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-02-12RDMA/cxgb3: Add driver for Chelsio T3 RNICSteve Wise
Add an RDMA/iWARP driver for the Chelsio T3 1GbE and 10GbE adapters. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22RDMA/amso1100: Add driver for Ammasso 1100 RNICTom Tucker
Add a driver for the Ammasso 1100 gigabit ethernet RNIC. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB: Whitespace fixesRoland Dreier
Remove some trailing whitespace that has snuck in despite the best efforts of whitespace=error-all. Also fix a few other whitespace bogosities. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB/ehca: Add driver for IBM eHCA InfiniBand adaptersHeiko J Schick
Add a driver for IBM GX bus InfiniBand adapters, which are usable with some pSeries/System p systems. Signed-off-by: Heiko J Schick <schickhj.ibm.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-06-22IB/iser: iSER Kconfig and MakefileOr Gerlitz
Kconfig and Makefile for iSER. Signed-off-by: Or Gerlitz <ogerlitz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-06-17IB: address translation to map IP toIB addresses (GIDs)Sean Hefty
Add an address translation service that maps IP addresses to InfiniBand GID addresses using IPoIB. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-03-31IB/ipath: kbuild infrastructureBryan O'Sullivan
Integrate the ipath core and OpenIB drivers into the kernel build infrastructure. Add entry to MAINTAINERS. Signed-off-by: Bryan O'Sullivan <bos@pathscale.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2005-11-02IB: Add SCSI RDMA Protocol (SRP) initiatorRoland Dreier
Add an InfiniBand SCSI RDMA Protocol (SRP) initiator. This driver is used to talk talk to InfiniBand SRP targets (storage devices). Signed-off-by: Roland Dreier <rolandd@cisco.com>
2005-09-07[PATCH] IB: clean up user access config optionsJames Lentini
Add a new config option INFINIBAND_USER_MAD to control whether we build ib_umad. Change INFINIBAND_USER_VERBS to INFINIBAND_USER_ACCESS, and have it control ib_ucm and ib_uat as well as ib_uverbs. Signed-off-by: James Lentini <jlentini@netapp.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2005-08-23[PATCH] Kconfig fix (infiniband and PCI)Al Viro
infiniband uses PCI helpers all over the place (including the core parts) and won't build without PCI. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] IB uverbs: hook up Kconfig/MakefileRoland Dreier
Hook up InfiniBand userspace verbs to Kconfig and the make system. Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
