path: root/drivers/infiniband/Makefile
2011-12-16ib_srpt: Initial SRP Target merge for v3.3-rc1Bart Van Assche
This patch adds the kernel module ib_srpt SCSI RDMA Protocol (SRP) target implementation conforming to the SRP r16a specification for the mainline drivers/target infrastructure. This driver was originally developed by Vu Pham and has been optimized by Bart Van Assche and merged into upstream LIO based on his srpt-lio-4.1 branch here: https://github.com/bvanassche/srpt-lio/commits/srpt-lio-4.1/ This updated patch also contains the following two changes from lio-core-2.6.git/master. One is to fix a bug with 1 >= task->task_sg[] chained mappings in ib_srpt, and the other to convert the configfs control plane to reference IB Port GUID and struct srpt_port directly following mainline v4.x target_core_fabric_configfs.c convertion for ib_srpt to work with rtslib/rtsadmin v2 code. These seperate patches can be found here: ib_srpt: Fix bug with chainged SGLs in srpt_map_sg_to_ib_sge http://www.risingtidesystems.com/git/?p=lio-core-2.6.git;a=commitdiff;h=ea485147563b6555a97dbf811825fbb586519252 ib_srpt: Convert se_wwn endpoint reference to struct srpt_port->port_wwn http://www.risingtidesystems.com/git/?p=lio-core-2.6.git;a=commitdiff;h=4e544a210acb227df1bb4ca5086e65bdf4e648ea This also includes the following recent v1 -> v2 review changes: ib_srpt: Fix potential out-of-bounds array access ib_srpt: Avoid failed multipart RDMA transfers ib_srpt: Fix srpt_alloc_fabric_acl failure case return value ib_srpt: Update comments to reference $driver/$port layout ib_srpt: Fix sport->port_guid formatting code ib_srpt: Remove legacy use_port_guid_in_session_name module parameter ib_srpt: Convert srp_max_rdma_size into per port configfs attribute ib_srpt: Convert srp_max_rsp_size into per port configfs attribute ib_srpt: Convert srpt_sq_size into per port configfs attribute and v2 -> v3 review changes: ib_srpt: Fix possible race with srp_sq_size in srpt_create_ch_ib ib_srpt: Fix possible race with srp_max_rsp_size in srpt_release_channel_work ib_srpt: Fix up MAX_SRPT_RDMA_SIZE define ib_srpt: Make srpt_map_sg_to_ib_sge() failure case return -EAGAIN ib_srpt: Convert port_guid to use subnet_prefix + interface_id formatting ib_srpt: Make srpt_check_stop_free return kref_put status ib_srpt: Make compilation with BUG=n proceed` ib_srpt: Use new target_core_fabric.h include ib_srpt: Check hex2bin() return code to silence build warning Cc: Bart Van Assche <bvanassche@acm.org> Cc: Roland Dreier <roland@purestorage.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Vu Pham <vu@mellanox.com> Cc: David Dillow <dillowda@ornl.gov> Signed-off-by: Nicholas A. Bellinger <nab@risingtidesystems.com>
2010-05-23IB/qib: Add new qib driver for QLogic PCIe InfiniBand adaptersRalph Campbell
Add a low-level IB driver for QLogic PCIe adapters. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-04-21RDMA/cxgb4: Add driver for Chelsio T4 RNICSteve Wise
Add an RDMA/iWARP driver for Chelsio T4 Ethernet adapters. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-04RDMA/nes: Add a driver for NetEffect RNICsGlenn Streiff
Add a standard NIC and RDMA/iWARP driver for NetEffect 1/10Gb ethernet adapters. Signed-off-by: Glenn Streiff <gstreiff@neteffect.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-05-08IB/mlx4: Add a driver Mellanox ConnectX InfiniBand adaptersRoland Dreier
Add an InfiniBand driver for Mellanox ConnectX adapters. Because these adapters can also be used as ethernet NICs and Fibre Channel HBAs, the driver is split into two modules: mlx4_core: Handles low-level things like device initialization and processing firmware commands. Also controls resource allocation so that the InfiniBand, ethernet and FC functions can share a device without stepping on each other. mlx4_ib: Handles InfiniBand-specific things; plugs into the InfiniBand midlayer. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-02-12RDMA/cxgb3: Add driver for Chelsio T3 RNICSteve Wise
Add an RDMA/iWARP driver for the Chelsio T3 1GbE and 10GbE adapters. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22RDMA/amso1100: Add driver for Ammasso 1100 RNICTom Tucker
Add a driver for the Ammasso 1100 gigabit ethernet RNIC. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB/ipath: merge ipath_core and ib_ipath driversBryan O'Sullivan
There is little point in keeping the two drivers separate, so we are merging them. Signed-off-by: Bryan O'Sullivan <bryan.osullivan@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB/ehca: Add driver for IBM eHCA InfiniBand adaptersHeiko J Schick
Add a driver for IBM GX bus InfiniBand adapters, which are usable with some pSeries/System p systems. Signed-off-by: Heiko J Schick <schickhj.ibm.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-06-22IB/iser: iSER Kconfig and MakefileOr Gerlitz
Kconfig and Makefile for iSER. Signed-off-by: Or Gerlitz <ogerlitz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-03-31IB/ipath: kbuild infrastructureBryan O'Sullivan
Integrate the ipath core and OpenIB drivers into the kernel build infrastructure. Add entry to MAINTAINERS. Signed-off-by: Bryan O'Sullivan <bos@pathscale.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2005-11-02IB: Add SCSI RDMA Protocol (SRP) initiatorRoland Dreier
Add an InfiniBand SCSI RDMA Protocol (SRP) initiator. This driver is used to talk talk to InfiniBand SRP targets (storage devices). Signed-off-by: Roland Dreier <rolandd@cisco.com>
