path: root/drivers/infiniband/core/device.c
2007-10-09IB: find_first_zero_bit() takes unsigned pointerRoland Dreier
Fix sparse warning drivers/infiniband/core/device.c:142:6: warning: incorrect type in argument 1 (different signedness) drivers/infiniband/core/device.c:142:6: expected unsigned long const *addr drivers/infiniband/core/device.c:142:6: got long *[assigned] inuse by making the local variable inuse unsigned. Does not affect generated code at all. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-08-03IB/core: Ignore membership bit in ib_find_pkey()Moni Shoua
ib_find_pkey() is used as a replacement for ib_find_cached_pkey(), and the original function ignored the membership bit when searching for a P_Key, so ib_find_pkey() should ignore the bit too. In particular, IPoIB turns on the P_Key membership bit of limited membership P_Keys when creating a child interface and looks for the full membership P_key. This broke if a port was a partial member of a partition when IPoIB switched from ib_find_cached_pkey() to ib_find_pkey(), and this change fixes things again. Signed-off-by: Moni Shoua <monis@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-05-21Merge branch 'for-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband: IB/cm: Improve local id allocation IPoIB/cm: Fix SRQ WR leak IB/ipoib: Fix typos in error messages IB/mlx4: Check if SRQ is full when posting receive IB/mlx4: Pass send queue sizes from userspace to kernel IB/mlx4: Fix check of opcode in mlx4_ib_post_send() mlx4_core: Fix array overrun in dump_dev_cap_flags() IB/mlx4: Fix RESET to RESET and RESET to ERROR transitions IB/mthca: Fix RESET to ERROR transition IB/mlx4: Set GRH:HopLimit when sending globally routed MADs IB/mthca: Set GRH:HopLimit when building MLX headers IB/mlx4: Fix check of max_qp_dest_rdma in modify QP IB/mthca: Fix use-after-free on device restart IB/ehca: Return proper error code if register_mr fails IPoIB: Handle P_Key table reordering IB/core: Use start_port() and end_port() IB/core: Add helpers for uncached GID and P_Key searches IB/ipath: Fix potential deadlock with multicast spinlocks IB/core: Free umem when mm is already gone
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-19IB/core: Use start_port() and end_port()Roland Dreier
Clean up ib_query_port() and ib_modify_port() slightly by using the just-added start_port() and end_port() helpers. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-05-19IB/core: Add helpers for uncached GID and P_Key searchesYosef Etigin
Add ib_find_gid() and ib_find_pkey() functions that use uncached device queries. The calls might block but the returns are always up-to-date. Cache P_Key and GID table lengths in core to avoid extra port info queries. Signed-off-by: Yosef Etigin <yosefe@voltaire.com> Acked-by: Michael S. Tsirkin <mst@dev.mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-05-08IB/uverbs: Export ib_umem_get()/ib_umem_release() to modulesRoland Dreier
Export ib_umem_get()/ib_umem_release() and put low-level drivers in control of when to call ib_umem_get() to pin and DMA map userspace, rather than always calling it in ib_uverbs_reg_mr() before calling the low-level driver's reg_user_mr method. Also move these functions to be in the ib_core module instead of ib_uverbs, so that driver modules using them do not depend on ib_uverbs. This has a number of advantages: - It is better design from the standpoint of making generic code a library that can be used or overridden by device-specific code as the details of specific devices dictate. - Drivers that do not need to pin userspace memory regions do not need to take the performance hit of calling ib_mem_get(). For example, although I have not tried to implement it in this patch, the ipath driver should be able to avoid pinning memory and just use copy_{to,from}_user() to access userspace memory regions. - Buffers that need special mapping treatment can be identified by the low-level driver. For example, it may be possible to solve some Altix-specific memory ordering issues with mthca CQs in userspace by mapping CQ buffers with extra flags. - Drivers that need to pin and DMA map userspace memory for things other than memory regions can use ib_umem_get() directly, instead of hacks using extra parameters to their reg_phys_mr method. For example, the mlx4 driver that is pending being merged needs to pin and DMA map QP and CQ buffers, but it does not need to create a memory key for these buffers. So the cleanest solution is for mlx4 to call ib_umem_get() in the create_qp and create_cq methods. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-02-10IB/core: Use ARRAY_SIZE macro for mandatory_tableAhmed S. Darwish
Use ARRAY_SIZE() macro already defined in kernel.h instead of open coding equivalent code. Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB: Fix typo in kerneldoc for ib_set_client_data()Krishna Kumar
Signed-off-by: Krishna Kumar <krkumar2@in.ibm.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22RDMA: iWARP Core Changes.Tom Tucker
Modifications to the existing rdma header files, core files, drivers, and ulp files to support iWARP, including: - Hook iWARP CM into the build system and use it in rdma_cm. - Convert enum ib_node_type to enum rdma_node_type, which includes the possibility of RDMA_NODE_RNIC, and update everything for this. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-01-13IB: convert from semaphores to mutexesIngo Molnar
semaphore to mutex conversion by Ingo and Arjan's script. Signed-off-by: Ingo Molnar <mingo@elte.hu> [ Sanity-checked on real IB hardware ] Signed-off-by: Roland Dreier <rolandd@cisco.com>
2005-11-02[IB] kzalloc() conversionsRoland Dreier
Replace kmalloc()+memset(,0,) with kzalloc(), for a net savings of 35 source lines and about 500 bytes of text. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2005-10-17[IB] Check port number in ib_query_port()/ib_modify_port()Roland Dreier
Check port number before passing query_port or modify_port operations on to device driver. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2005-08-26[PATCH] IB: Add copyright noticesRoland Dreier
Make some lawyers happy and add copyright notices for people who forgot to include them when they actually touched the code. Signed-off-by: Roland Dreier <rolandd@cisco.com>
