[ Upstream commit 594e6c5d41ed2471ab0b90f3f0b66cdf618b7ac9 ]
Properly unwind QP counter rebinding in case of failure.
Trying to rebind the counter after unbiding it is not going to work
reliably, move the unbind to the end so it doesn't have to be unwound.
Fixes: b389327df905 ("RDMA/nldev: Allow counter manual mode configration through RDMA netlink")
Link: https://lore.kernel.org/r/20191002115627.16740-1-leon@kernel.org
Reviewed-by: Mark Zhang <markz@mellanox.com>
Signed-off-by: Leon Romanovsky <leonro@mellanox.com>
Reviewed-by: Jason Gunthorpe <jgg@mellanox.com>
Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
[ Upstream commit ab59ca3eb4e7059727df85eee68bda169d26c8f8 ]
According to surrounding error paths, it is likely that 'goto err_get;' is
expected here. Otherwise, a call to 'rdma_restrack_put(res);' would be
missing.
Fixes: c5dfe0ea6ffa ("RDMA/nldev: Add resource tracker doit callback")
Link: https://lore.kernel.org/r/20190818091044.8845-1-christophe.jaillet@wanadoo.fr
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
task_active_pid_ns() is wrong API to check PID namespace because it
posses some restrictions and return PID namespace where the process
was allocated. It created mismatches with current namespace, which
can be different.
Rewrite whole rdma_is_visible_in_pid_ns() logic to provide reliable
results without any relation to allocated PID namespace.
Fixes: 8be565e65fa9 ("RDMA/nldev: Factor out the PID namespace check")
Fixes: 6a6c306a09b5 ("RDMA/restrack: Make is_visible_in_pid_ns() as an API")
Link: https://lore.kernel.org/r/20190815083834.9245-4-leon@kernel.org
Signed-off-by: Doug Ledford <dledford@redhat.com>
We need to set the error codes on these paths. Currently the only
possible error code is -EMSGSIZE so that's what the patch uses.
Fixes: 83c2c1fcbd08 ("RDMA/nldev: Allow get counter mode through RDMA netlink")
Reviewed-by: Leon Romanovsky <leonro@mellanox.com>
Link: https://lore.kernel.org/r/20190809101311.GA17867@mwanda
While creating new RDMA devices based on netdevice name, consider the net
namespace of the caller skb's socket similar to rest of the doit()
callbacks and nldev_dellink() which deletes the RDMA device created using
nldev_newlink().
Fixes: 3856ec4b93c94 ("RDMA/core: Add RDMA_NLDEV_CMD_NEWLINK/DELLINK support")
Signed-off-by: Parav Pandit <parav@mellanox.com>
Added parameter in ib_device for enabling dynamic interrupt moderation so
that it can be configured in userspace using rdma tool.
In order to set adaptive-moderation for an ib device the command is:
rdma dev set [DEV] adaptive-moderation [on|off]
Please set on/off.
rdma dev show
0: mlx5_0: node_type ca fw 16.26.0055 node_guid 248a:0703:00a5:29d0
sys_image_guid 248a:0703:00a5:29d0 adaptive-moderation on
rdma resource show cq
dev mlx5_0 cqn 0 cqe 1023 users 4 poll-ctx UNBOUND_WORKQUEUE
adaptive-moderation off comm [ib_core]
Signed-off-by: Yamin Friedman <yaminf@mellanox.com>
Reviewed-by: Sagi Grimberg <sagi@grimberg.me>
This patch adds the ability to return the hwstats of per-port default
counters (which can also be queried through sysfs nodes).
Signed-off-by: Mark Zhang <markz@mellanox.com>
Provide an option to get current counter mode through RDMA netlink.
Reviewed-by: Majd Dibbiny <majd@mellanox.com>
Provide an option to allow users to manually bind a qp with a counter
through RDMA netlink. Limit it to users with ADMIN capability only.
This patch adds the ability to return all available counters together with
their properties and hwstats.
Provide an option to enable/disable per-port counter auto mode through
Remove is_visible_in_pid_ns() from nldev.c and make it as a restrack API,
so that it can be taken advantage by other parts like counter.
For all string attributes for which we don't currently accept the element
as input, we only use it as output, set the string length to
RDMA_NLDEV_ATTR_EMPTY_STRING which is defined as 1. That way we will only
accept a null string for that element. This will prevent someone from
writing a new input routine that uses the element without also updating
the policy to have a valid value.
Also while there, make sure the existing entries that are valid have the
correct policy, if not, correct the policy. Remove unnecessary checks
for nla_strlcpy() overflow once the policy has been set correctly.
Sort the netlink policy array by netlink attribute name. This will make
it easier in the future to find the entry you are looking for when you
need to make changes, or to make sure you don't add the same entry
twice.
Fix the whitespace while we are there.
Update the struct ib_client for all modules exporting cdevs related to the
ibdevice to also implement RDMA_NLDEV_CMD_GET_CHARDEV. All cdevs are now
autoloadable and discoverable by userspace over netlink instead of relying
on sysfs.
uverbs also exposes the DRIVER_ID for drivers that are able to support
driver id binding in rdma-core.
Allow userspace to issue a netlink query against the ib_device for
something like "uverbs" and get back the char dev name, inode major/minor,
and interface ABI information for "uverbs0".
Since we are now in netlink this can also trigger a module autoload to
make the uverbs device come into existence.
Largely this will let us replace searching and reading inside sysfs to
setup devices, and provides an alternative (using driver_id) to device
name based provider binding for things like rxe.
Pull more rdma updates from Jason Gunthorpe:
"This is being sent to get a fix for the gcc 9.1 build warnings, and
I've also pulled in some bug fix patches that were posted in the last
two weeks.
- Avoid the gcc 9.1 warning about overflowing a union member
- Fix the wrong callback type for a single response netlink to doit
- Bug fixes from more usage of the mlx5 devx interface"
* tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rdma/rdma:
net/mlx5: Set completion EQs as shared resources
IB/mlx5: Verify DEVX general object type correctly
RDMA/core: Change system parameters callback from dumpit to doit
RDMA: Directly cast the sockaddr union to sockaddr
.dumpit() callback is used for returning same type of data in the loop,
e.g. loop over ports, resources, devices.
However system parameters are general and standalone for whole
subsystem. It means that getting system parameters should be doit
callback.
Fixes: cb7e0e130503 ("RDMA/core: Add interface to read device namespace sharing mode")
Pull rdma updates from Jason Gunthorpe:
"This has been a smaller cycle than normal. One new driver was
accepted, which is unusual, and at least one more driver remains in
review on the list.
Summary:
- Driver fixes for hns, hfi1, nes, rxe, i40iw, mlx5, cxgb4,
vmw_pvrdma
- Many patches from MatthewW converting radix tree and IDR users to
use xarray
- Introduction of tracepoints to the MAD layer
- Build large SGLs at the start for DMA mapping and get the driver to
split them
- Generally clean SGL handling code throughout the subsystem
- Support for restricting RDMA devices to net namespaces for
containers
- Progress to remove object allocation boilerplate code from drivers
- Change in how the mlx5 driver shows representor ports linked to VFs
- mlx5 uapi feature to access the on chip SW ICM memory
- Add a new driver for 'EFA'. This is HW that supports user space
packet processing through QPs in Amazon's cloud"
* tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rdma/rdma: (186 commits)
RDMA/ipoib: Allow user space differentiate between valid dev_port
IB/core, ipoib: Do not overreact to SM LID change event
RDMA/device: Don't fire uevent before device is fully initialized
lib/scatterlist: Remove leftover from sg_page_iter comment
RDMA/efa: Add driver to Kconfig/Makefile
RDMA/efa: Add the efa module
RDMA/efa: Add EFA verbs implementation
RDMA/efa: Add common command handlers
RDMA/efa: Implement functions that submit and complete admin commands
RDMA/efa: Add the ABI definitions
RDMA/efa: Add the com service API definitions
RDMA/efa: Add the efa_com.h file
RDMA/efa: Add the efa.h header file
RDMA/efa: Add EFA device definitions
RDMA: Add EFA related definitions
RDMA/umem: Remove hugetlb flag
RDMA/bnxt_re: Use core helpers to get aligned DMA address
RDMA/i40iw: Use core helpers to get aligned DMA address within a supported page size
RDMA/verbs: Add a DMA iterator to return aligned contiguous memory blocks
RDMA/umem: Add API to find best driver supported page size in an MR
We currently have two levels of strict validation:
1) liberal (default)
- undefined (type >= max) & NLA_UNSPEC attributes accepted
- attribute length >= expected accepted
- garbage at end of message accepted
2) strict (opt-in)
- NLA_UNSPEC attributes accepted
Split out parsing strictness into four different options:
* TRAILING - check that there's no trailing data after parsing
attributes (in message or nested)
* MAXTYPE - reject attrs > max known type
* UNSPEC - reject attributes with NLA_UNSPEC policy entries
* STRICT_ATTRS - strictly validate attribute size
The default for future things should be *everything*.
The current *_strict() is a combination of TRAILING and MAXTYPE,
and is renamed to _deprecated_strict().
The current regular parsing has none of this, and is renamed to
*_parse_deprecated().
Additionally it allows us to selectively set one of the new flags
even on old policies. Notably, the UNSPEC flag could be useful in
this case, since it can be arranged (by filling in the policy) to
not be an incompatible userspace ABI change, but would then going
forward prevent forgetting attribute entries. Similar can apply
to the POLICY flag.
We end up with the following renames:
* nla_parse -> nla_parse_deprecated
* nla_parse_strict -> nla_parse_deprecated_strict
* nlmsg_parse -> nlmsg_parse_deprecated
* nlmsg_parse_strict -> nlmsg_parse_deprecated_strict
* nla_parse_nested -> nla_parse_nested_deprecated
* nla_validate_nested -> nla_validate_nested_deprecated
Using spatch, of course:
expression TB, MAX, HEAD, LEN, POL, EXT;
-nla_parse(TB, MAX, HEAD, LEN, POL, EXT)
+nla_parse_deprecated(TB, MAX, HEAD, LEN, POL, EXT)
expression NLH, HDRLEN, TB, MAX, POL, EXT;
-nlmsg_parse(NLH, HDRLEN, TB, MAX, POL, EXT)
+nlmsg_parse_deprecated(NLH, HDRLEN, TB, MAX, POL, EXT)
-nlmsg_parse_strict(NLH, HDRLEN, TB, MAX, POL, EXT)
+nlmsg_parse_deprecated_strict(NLH, HDRLEN, TB, MAX, POL, EXT)
expression TB, MAX, NLA, POL, EXT;
-nla_parse_nested(TB, MAX, NLA, POL, EXT)
+nla_parse_nested_deprecated(TB, MAX, NLA, POL, EXT)
expression START, MAX, POL, EXT;
-nla_validate_nested(START, MAX, POL, EXT)
+nla_validate_nested_deprecated(START, MAX, POL, EXT)
expression NLH, HDRLEN, MAX, POL, EXT;
-nlmsg_validate(NLH, HDRLEN, MAX, POL, EXT)
+nlmsg_validate_deprecated(NLH, HDRLEN, MAX, POL, EXT)
For this patch, don't actually add the strict, non-renamed versions
yet so that it breaks compile if I get it wrong.
Also, while at it, make nla_validate and nla_parse go down to a
common __nla_validate_parse() function to avoid code duplication.
Ultimately, this allows us to have very strict validation for every
new caller of nla_parse()/nlmsg_parse() etc as re-introduced in the
next patch, while existing things will continue to work as is.
In effect then, this adds fully strict validation for any new command.
Even if the NLA_F_NESTED flag was introduced more than 11 years ago, most
netlink based interfaces (including recently added ones) are still not
setting it in kernel generated messages. Without the flag, message parsers
not aware of attribute semantics (e.g. wireshark dissector or libmnl's
mnl_nlmsg_fprintf()) cannot recognize nested attributes and won't display
the structure of their contents.
Unfortunately we cannot just add the flag everywhere as there may be
userspace applications which check nlattr::nla_type directly rather than
through a helper masking out the flags. Therefore the patch renames
nla_nest_start() to nla_nest_start_noflag() and introduces nla_nest_start()
as a wrapper adding NLA_F_NESTED. The calls which add NLA_F_NESTED manually
are rewritten to use nla_nest_start().
Except for changes in include/net/netlink.h, the patch was generated using
this semantic patch:
@@ expression E1, E2; @@
-nla_nest_start(E1, E2)
+nla_nest_start_noflag(E1, E2)
-nla_nest_start_noflag(E1, E2 | NLA_F_NESTED)
+nla_nest_start(E1, E2)
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
Acked-by: Jiri Pirko <jiri@mellanox.com>
Acked-by: David Ahern <dsahern@gmail.com>
Provide an option to change the net namespace of a rdma device through a
netlink command. When multiple rdma devices exists in a system, and when
containers are used, this will limit rdma device visibility to a specified
net namespace.
An example command to change net namespace of mlx5_1 device to the
previously created net namespace 'foo' is:
$ ip netns add foo
$ rdma dev set mlx5_1 netns foo
Add new RDMA_NLDEV_ATTR_DEV_PROTOCOL attribute to give ability for UDEV
rules create IB device stable names based on link type protocol. The
assumption that devices like mlx4 with duality in their link type under
one IB device struct won't be allowed in the future.
Reviewed-by: Parav Pandit <parav@mellanox.com>
Add netlink command that enables/disables sharing rdma device among
multiple net namespaces.
Using rdma tool,
$rdma sys set netns shared (default mode)
When rdma subsystem netns mode is set to shared mode, rdma devices
will be accessible in all net namespaces.
Using rdma tool,
$rdma sys set netns exclusive
When rdma subsystem netns mode is set to exclusive mode, devices
will be accessible in only one net namespace at any given
point of time.
If there are any net namespaces other than default init_net exists,
while executing this command, it will fail and mode cannot be changed.
To change this mode, netlink command is used instead of sysctl, because
netlink command allows to auto load a module.
Add an interface via netlink command to query whether rdma devices are
shared among multiple net namespaces or not. When using RDMAtool, it can
be queried as,
$rdma system show netns
netns shared
Extend ib_device_get_by_index() API to check device access for
net namespace for serving netlink commands.
Also enforce net ns check on dumpit commands which iterate over all
registered rdma devices and which don't call ib_device_get_by_index().
The first parameter of WARN_ONCE() is a condition, then following
parameters are the message. In this case, we left out the condition so it
will just print the ops->type string.
Fixes: 3856ec4b93c9 ("RDMA/core: Add RDMA_NLDEV_CMD_NEWLINK/DELLINK support")
Reviewed-by: Steve Wise <swise@opengridcomputing.com>
Add support for new LINK messages to allow adding and deleting rdma
interfaces. This will be used initially for soft rdma drivers which
instantiate device instances dynamically by the admin specifying a netdev
device to use. The rdma_rxe module will be the first user of these
messages.
The design is modeled after RTNL_NEWLINK/DELLINK: rdma drivers register
with the rdma core if they provide link add/delete functions. Each driver
registers with a unique "type" string, that is used to dispatch messages
coming from user space. A new RDMA_NLDEV_ATTR is defined for the "type"
string. User mode will pass 3 attributes in a NEWLINK message:
RDMA_NLDEV_ATTR_DEV_NAME for the desired rdma device name to be created,
RDMA_NLDEV_ATTR_LINK_TYPE for the "type" of link being added, and
RDMA_NLDEV_ATTR_NDEV_NAME for the net_device interface to use for this
link. The DELLINK message will contain the RDMA_NLDEV_ATTR_DEV_INDEX of
the device to delete.
Signed-off-by: Steve Wise <swise@opengridcomputing.com>
Reviewed-by: Michael J. Ruhl <michael.j.ruhl@intel.com>
The associated netdev should not actually be very dynamic, so for most
drivers there is no reason for a callback like this. Provide an API to
inform the core code about the net dev affiliation and use a core
maintained data structure instead.
This allows the core code to be more aware of the ndev relationship which
will allow some new APIs based around this.
This also uses locking that makes some kind of sense, many drivers had a
confusing RCU lock, or missing locking which isn't right.
We have many loops iterating over all of the end port numbers on a struct
ib_device, simplify them with a for_each helper.
Netlink dumpit handshake exchanges the index from which kernel should
start to return its value, in current code, this index included
not-visible in this PID items too and indirectly revealed the number of
entries.
This patch adds ability to query specific QP based on its LQPN (local
QPN), which is assigned by HW and needs special treatment while inserting
into restrack DB.
PD, MR and QP objects have parents objects: contexts and PDs. The exposed
parent IDs allow to correlate various objects and simplify debug
investigation.
Give to the user space tools unique identifier for PD, MR, CQ and CM_ID
objects, so they can be able to query on them with .doit callbacks.
QP .doit is not supported yet, till all drivers will be updated to provide
their LQPN to be equal to their restrack ID.
As a preparation to extension of rdma_restrack_root to provide software
IDs, which will be per-type too. We convert the rdma_restrack_root from
struct with arrays to array of structs.
Such conversion allows us to drop rwsem lock in favour of internal XArray
lock.
There is no need to expose internals of restrack DB to IB/core.
Implement doit callbacks and ensure that users won't provide port values
on resource entry allocated in per-device mode needed for .doit callback.
The additions of .doit callbacks posses new access pattern to the resource
entries by some user visible index. Back then, the legacy DB was
implemented as hash because per-index access wasn't needed and XArray
wasn't accepted yet.
Acceptance of XArray together with per-index access requires the refresh
of DB implementation.
Linux 5.0-rc5
Needed to merge the include/uapi changes so we have an up to date
single-tree for these files. Patches already posted are also expected to
need this for dependencies.
As preparation to hide rdma_restrack_root, refactor the code to use the
ops structure instead of a special callback which is hidden in
rdma_restrack_root.
In the current implementation, we have one restrack root per-device and
all users are simply providing it directly. Let's simplify the interface
and have callers provide the ib_device and internally access the
restrack_root.
The .doit callbacks don't have a netlink_callback to check capabilities so
in order to use the same fill_res_func for both .dump and .doit, we need
to do the capability check outside of those functions.
For .doit callbacks, it is possible to check CAP_NET_ADMIN directly on the
received sk_buff.
The PID namespace is going to be used in the .doit callback, so generalize
its implementation.
There is no need to manually write same callbacks, automatically generate
them using C-macro language.
This macro is going to be extended to generate doit callbacks too, so use
general name for this macro.
Reviewed-by: Yuval Shaia <yuval.shaia@oracle.com>
Unsafe global rkey is considered dangerous because it exposes memory
registered for all memory in the system. Only users with a QP on the same
PD can use the rkey, and generally those QPs will already know the
value. However, out of caution, do not expose the value to unprivleged
users on the local system. Require CAP_NET_ADMIN instead.
Cc: <stable@vger.kernel.org> # 4.16
Fixes: 29cf1351d450 ("RDMA/nldev: provide detailed PD information")
port_cap_flags2 represents IBTA PortInfo:CapabilityMask2.
The field safely extends the RDMA_NLDEV_ATTR_CAP_FLAGS operand as it was
exported as 64 bit to allow this kind of extension.
Signed-off-by: Michael Guralnik <michaelgur@mellanox.com>
Make all the required change to start use the ib_device_ops structure.
Signed-off-by: Kamal Heib <kamalheib1@gmail.com>
[leonro@server ~]$ rdma res show
1: mlx5_0: pd 3 cq 5 qp 4 cm_id 0 mr 0 ctx 0
When the rdma device is getting removed, get resource info can race with
device removal, as below:
CPU-0 CPU-1
rdma_nl_rcv_msg()
nldev_res_get_cq_dumpit()
mutex_lock(device_lock);
get device reference
mutex_unlock(device_lock); [..]
ib_unregister_device()
/* Valid reference to
* device->dev exists.
ib_dealloc_device()
provider->fill_res_entry();
Even though device object is not freed, fill_res_entry() can get called on
device which doesn't have a driver anymore. Kernel core device reference
count is not sufficient, as this only keeps the structure valid, and
doesn't guarantee the driver is still loaded.
Similar race can occur with device renaming and device removal, where
device_rename() tries to rename a unregistered device. While this is fine
for devices of a class which are not net namespace aware, but it is
incorrect for net namespace aware class coming in subsequent series. If a
class is net namespace aware, then the below [1] call trace is observed in
above situation.
Therefore, to avoid the race, keep a reference count and let device
unregistration wait until all netlink users drop the reference.
[1] Call trace:
kernfs: ns required in 'infiniband' for 'mlx5_0'
WARNING: CPU: 18 PID: 44270 at fs/kernfs/dir.c:842 kernfs_find_ns+0x104/0x120
libahci i2c_core mlxfw libata dca [last unloaded: devlink]
RIP: 0010:kernfs_find_ns+0x104/0x120
Call Trace:
kernfs_find_and_get_ns+0x2e/0x50
sysfs_rename_link_ns+0x40/0xb0
device_rename+0xb2/0xf0
ib_device_rename+0xb3/0x100 [ib_core]
nldev_set_doit+0x165/0x190 [ib_core]
rdma_nl_rcv_msg+0x249/0x250 [ib_core]
? netlink_deliver_tap+0x8f/0x3e0
rdma_nl_rcv+0xd6/0x120 [ib_core]
netlink_unicast+0x17c/0x230
netlink_sendmsg+0x2f0/0x3e0
sock_sendmsg+0x30/0x40
__sys_sendto+0xdc/0x160
Fixes: da5c85078215 ("RDMA/nldev: add driver-specific resource tracking")
Provide an option to rename IB device name through RDMA netlink and
limit it to users with ADMIN capability only.
