commit 5b810a242c28e1d8d64d718cebe75b79d86a0b2d upstream.
The real QP is destroyed in case of the ref count reaches zero, but
for XRC target QPs this call was missed and caused to QP leaks.
Let's call to destroy for all flows.
Fixes: 0e0ec7e0638e ('RDMA/core: Export ib_open_qp() to share XRC...')
Signed-off-by: Tariq Toukan <tariqt@mellanox.com>
Signed-off-by: Noa Osherovich <noaos@mellanox.com>
Signed-off-by: Leon Romanovsky <leon@kernel.org>
Signed-off-by: Doug Ledford <dledford@redhat.com>
commit d1e09f304a1d9651c5059ebfeb696dc2effc9b32 upstream.
Fixes an oops that might happen if uverbs_close races with
remove_one.
Both contexts may run ib_uverbs_cleanup_ucontext, it depends
on the flow.
Currently, there is no protection for a case that remove_one
didn't make the cleanup it runs to its end, the underlying
ib_device was freed then uverbs_close will call
ib_uverbs_cleanup_ucontext and OOPs.
Above might happen if uverbs_close deleted the file from the list
then remove_one didn't find it and runs to its end.
Fixes to protect against that case by a new cleanup lock so that
ib_uverbs_cleanup_ucontext will be called always before that
remove_one is ended.
Fixes: 35d4a0b63dc0 ("IB/uverbs: Fix race between ib_uverbs_open and remove_one")
Reported-by: Devesh Sharma <devesh.sharma@broadcom.com>
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Signed-off-by: Yishai Hadas <yishaih@mellanox.com>
commit e6bd18f57aad1a2d1ef40e646d03ed0f2515c9e3 upstream.
The drivers/infiniband stack uses write() as a replacement for
bi-directional ioctl(). This is not safe. There are ways to
trigger write calls that result in the return structure that
is normally written to user space being shunted off to user
specified kernel memory instead.
For the immediate repair, detect and deny suspicious accesses to
the write API.
For long term, update the user space libraries and the kernel API
to something that doesn't present the same security vulnerabilities
(likely a structured ioctl() interface).
The impacted uAPI interfaces are generally only available if
hardware from drivers/infiniband is installed in the system.
Reported-by: Jann Horn <jann@thejh.net>
[ Expanded check to all known write() entry points ]
ib_uverbs_ex_create_qp follows the extension verbs
mechanism. New features (for example, QP creation flags
field which is added in a downstream patch) could used
via user-space libraries without breaking the ABI.
Signed-off-by: Eran Ben Elisha <eranbe@mellanox.com>
Reviewed-by: Haggai Eran <haggaie@mellanox.com>
Enables the uverbs_remove_one to succeed despite the fact that there are
running IB applications working with the given ib device. This
functionality enables a HW device to be unbind/reset despite the fact that
there are running user space applications using it.
It exposes a new IB kernel API named 'disassociate_ucontext' which lets
a driver detaching its HW resources from a given user context without
crashing/terminating the application. In case a driver implemented the
above API and registered with ib_uverb there will be no dependency between its
device to its uverbs_device. Upon calling remove_one of ib_uverbs the call
should return after disassociating the open HW resources without waiting to
clients disconnecting. In case driver didn't implement this API there will be no
change to current behaviour and uverbs_remove_one will return only when last
client has disconnected and reference count on uverbs device became 0.
In case the lower driver device was removed any application will
continue working over some zombie HCA, further calls will ended with an
immediate error.
Signed-off-by: Shachar Raindel <raindel@mellanox.com>
Reviewed-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Done in preparation for deploying RCU for the device removal
flow. Allows isolating the RCU handling to the uverb_main layer and
keeping the uverbs_cmd code as is.
Fixes: 2a72f212263701b927559f6850446421d5906c41 ("IB/uverbs: Remove dev_table")
Before this commit there was a device look-up table that was protected
by a spin_lock used by ib_uverbs_open and by ib_uverbs_remove_one. When
it was dropped and container_of was used instead, it enabled the race
with remove_one as dev might be freed just after:
dev = container_of(inode->i_cdev, struct ib_uverbs_device, cdev) but
before the kref_get.
In addition, this buggy patch added some dead code as
container_of(x,y,z) can never be NULL and so dev can never be NULL.
As a result the comment above ib_uverbs_open saying "the open method
will either immediately run -ENXIO" is wrong as it can never happen.
The solution follows Jason Gunthorpe suggestion from below URL:
https://www.mail-archive.com/linux-rdma@vger.kernel.org/msg25692.html
cdev will hold a kref on the parent (the containing structure,
ib_uverbs_device) and only when that kref is released it is
guaranteed that open will never be called again.
In addition, fixes the active count scheme to use an atomic
not a kref to prevent WARN_ON as pointed by above comment
from Jason.
Fix the reference counting usage to be handled in the event file
creation/destruction function, instead of being done by the caller.
This is done for both async/non-async event files.
Based on Jason Gunthorpe report at https://www.mail-archive.com/
linux-rdma@vger.kernel.org/msg24680.html:
"The existing code for this is broken, in ib_uverbs_get_context all
the error paths between ib_uverbs_alloc_event_file and the
kref_get(file->ref) are wrong - this will result in fput() which will
call ib_uverbs_event_close, which will try to do kref_put and
ib_unregister_event_handler - which are no longer paired."
An ib_client callback that is called with the lists_rwsem locked only for
read is protected from changes to the IB client lists, but not from
ib_unregister_device() freeing its client data. This is because
ib_unregister_device() will remove the device from the device list with
lists_rwsem locked for write, but perform the rest of the cleanup,
including the call to remove() without that lock.
Mark client data that is undergoing de-registration with a new going_down
flag in the client data context. Lock the client data list with lists_rwsem
for write in addition to using the spinlock, so that functions calling the
callback would be able to lock only lists_rwsem for read and let callbacks
sleep.
Since ib_unregister_client() now marks the client data context, no need for
remove() to search the context again, so pass the client data directly to
remove() callbacks.
Signed-off-by: Haggai Eran <haggaie@mellanox.com>
ib_uverbs_ex_create_cq follows the extension verbs
mechanism. New features (for example, CQ creation flags
Signed-off-by: Matan Barak <matanb@mellanox.com>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
When an application using XRCs abruptly terminates, the mmaped pages
of the CQ buffers are leaked.
This comes from the fact that when resources are released in
ib_uverbs_cleanup_ucontext(), we fail to release the CQs because their
refcount is not 0.
When creating an XRC SRQ, we increment the associated CQ refcount.
This refcount is only decremented when the SRQ is released.
Therefore we need to release the SRQs prior to the CQs to make sure
that all references to the CQs are gone before trying to release these.
Signed-off-by: Sebastien Dugue <sebastien.dugue@bull.net>
Add extensible query device capabilities verb to allow adding new features.
ib_uverbs_ex_query_device is added and copy_query_dev_fields is used to copy
capability fields to be used by both ib_uverbs_query_device and
ib_uverbs_ex_query_device.
Following the discussion about this patch [1], the code now validates
the command's comp_mask is zero, returning -EINVAL for unknown values,
in order to allow extending the verb in the future.
The verb also checks the user-space provided response buffer size and
only fills in capabilities that will fit in the buffer. In attempt to
follow the spirit of presentation [2] by Tzahi Oved that was presented
during OpenFabrics Alliance International Developer Workshop 2013, the
comp_mask bits will only describe which fields are valid. Furthermore,
fields that can simply be cleared when they are not supported, do not
require a comp_mask bit at all. The verb returns a response_length
field containing the actual number of bytes written by the kernel, so
that a newer version running on an older kernel can tell which fields
were actually returned.
[1] [PATCH v1 0/5] IB/core: extended query device caps cleanup for v3.19
http://thread.gmane.org/gmane.linux.kernel.api/7889/
[2] https://www.openfabrics.org/images/docs/2013_Dev_Workshop/Tues_0423/2013_Workshop_Tues_0830_Tzahi_Oved-verbs_extensions_ofa_2013-tzahio.pdf
Signed-off-by: Eli Cohen <eli@mellanox.com>
Reviewed-by: Yann Droneaud <ydroneaud@opteya.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
Commit 5a77abf9a97a ("IB/core: Add support for extended query device caps")
added a new extended verb to query the capabilities of RDMA devices, but the
semantics of this verb are still under debate [1].
Don't expose this verb to userspace until the ABI is nailed down.
http://www.spinics.net/lists/linux-rdma/msg22904.html
* Extend the umem struct to keep the ODP related data.
* Allocate and initialize the ODP related information in the umem
(page_list, dma_list) and freeing as needed in the end of the run.
* Store a reference to the process PID struct in the ucontext. Used to
safely obtain the task_struct and the mm during fault handling,
without preventing the task destruction if needed.
* Add 2 helper functions: ib_umem_odp_map_dma_pages and
ib_umem_odp_unmap_dma_pages. These functions get the DMA addresses
of specific pages of the umem (and, currently, pin them).
* Support for page faults only - IB core will keep the reference on
the pages used and call put_page when freeing an ODP umem
area. Invalidations support will be added in a later patch.
Signed-off-by: Sagi Grimberg <sagig@mellanox.com>
Signed-off-by: Majd Dibbiny <majd@mellanox.com>
copy capability fields to be used by both ib_uverbs_query_device and
In ib_uverbs_open_qp, the sharable xrc target qp is created as a
"pseudo" qp and added to a list of qp's sharing the same physical
QP. This is done before the "pseudo" qp is assigned a uobject.
There is a race condition here if an async event arrives at the
physical qp. If the event is handled after the pseudo qp is added to
the list, but before it is assigned a uobject, the kernel crashes in
ib_uverbs_qp_event_handler, due to trying to dereference a NULL
uobject pointer.
Note that simply checking for non-NULL is not enough, due to error
flows in ib_uverbs_open_qp. If the failure is after assigning the
uobject, but before the qp has fully been created, we still have a
problem.
Thus, in ib_uverbs_qp_event_handler, we test that the uobject is
present, and also that it is live.
Reported-by: Matthew Finlay <matt@mellanox.com>
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Clear the reserved field of struct ib_uverbs_async_event_desc which is
copied to user space.
Memory re-registration is a feature that enables changing the
attributes of a memory region registered by user-space, including PD,
translation (address and length) and access flags.
Add the required support in uverbs and the kernel verbs API.
This patch adds a check on the output buffer with access_ok(VERIFY_WRITE, ...)
to ensure the whole buffer is in userspace memory before using the
pointer in uverbs functions. If the buffer or a subset of it is not
valid, returns -EFAULT to the caller.
This will also catch invalid buffer before the final call to
copy_to_user() which happen late in most uverb functions.
Just like the check in read(2) syscall, it's a sanity check to detect
invalid parameters provided by userspace. This particular check was added
in vfs_read() by Linus Torvalds for v2.6.12 with following commit message:
https://git.kernel.org/cgit/linux/kernel/git/tglx/history.git/commit/?id=fd770e66c9a65b14ce114e171266cf6f393df502
Make read/write always do the full "access_ok()" tests.
The actual user copy will do them too, but only for the
range that ends up being actually copied. That hides
bugs when the range has been clamped by file size or other
issues.
Note: there's no need to check input buffer since vfs_write() already does
access_ok(VERIFY_READ, ...) as part of write() syscall.
Link: http://marc.info/?i=cover.1387273677.git.ydroneaud@opteya.com
Signed-off-by: Yann Droneaud <ydroneaud@opteya.com>
As noted by Daniel Vetter in its article "Botching up ioctls"[1]
"Check *all* unused fields and flags and all the padding for whether
it's 0, and reject the ioctl if that's not the case. Otherwise
your nice plan for future extensions is going right down the
gutters since someone *will* submit an ioctl struct with random
stack garbage in the yet unused parts. Which then bakes in the ABI
that those fields can never be used for anything else but garbage."
It's important to ensure that reserved fields are set to known value,
so that it will be possible to use them latter to extend the ABI.
The same reasonning apply to comp_mask field present in newer uverbs
command: per commit 22878dbc9173 ("IB/core: Better checking of
userspace values for receive flow steering"), unsupported values in
comp_mask are rejected.
[1] http://blog.ffwll.ch/2013/11/botching-up-ioctls.html
Link: http://marc.info/?i=cover.1386798254.git.ydroneaud@opteya.com>
Trying to have a ternary operator to choose between NULL (or 0) and the
real pointer value in invocations leads to an impossible choice between
a sparse error about a literal 0 used as a NULL pointer, and a gcc
warning about "pointer/integer type mismatch in conditional expression."
Rather than clutter the source with more casts, move the ternary
operator into a new INIT_UDATA_BUF_OR_NULL() macro, which makes it
easier to use and simplifies its callers.
Reported-by: Yann Droneaud <ydroneaud@opteya.com>
This commit reverts commit 7afbddfae993 ("IB/core: Temporarily disable
create_flow/destroy_flow uverbs"). Since the uverbs extensions
functionality was experimental for v3.12, this patch re-enables the
support for them and flow-steering for v3.13.
Commit 400dbc96583f ("IB/core: Infrastructure for extensible uverbs
commands") added an infrastructure for extensible uverbs commands
while later commit 436f2ad05a0b ("IB/core: Export ib_create/destroy_flow
through uverbs") exported ib_create_flow()/ib_destroy_flow() functions
using this new infrastructure.
According to the commit 400dbc96583f, the purpose of this
infrastructure is to support passing around provider (eg. hardware)
specific buffers when userspace issue commands to the kernel, so that
it would be possible to extend uverbs (eg. core) buffers independently
from the provider buffers.
But the new kernel command function prototypes were not modified to
take advantage of this extension. This issue was exposed by Roland
Dreier in a previous review[1].
So the following patch is an attempt to a revised extensible command
infrastructure.
This improved extensible command infrastructure distinguish between
core (eg. legacy)'s command/response buffers from provider
(eg. hardware)'s command/response buffers: each extended command
implementing function is given a struct ib_udata to hold core
(eg. uverbs) input and output buffers, and another struct ib_udata to
hold the hw (eg. provider) input and output buffers.
Having those buffers identified separately make it easier to increase
one buffer to support extension without having to add some code to
guess the exact size of each command/response parts: This should make
the extended functions more reliable.
Additionally, instead of relying on command identifier being greater
than IB_USER_VERBS_CMD_THRESHOLD, the proposed infrastructure rely on
unused bits in command field: on the 32 bits provided by command
field, only 6 bits are really needed to encode the identifier of
commands currently supported by the kernel. (Even using only 6 bits
leaves room for about 23 new commands).
So this patch makes use of some high order bits in command field to
store flags, leaving enough room for more command identifiers than one
will ever need (eg. 256).
The new flags are used to specify if the command should be processed
as an extended one or a legacy one. While designing the new command
format, care was taken to make usage of flags itself extensible.
Using high order bits of the commands field ensure that newer
libibverbs on older kernel will properly fail when trying to call
extended commands. On the other hand, older libibverbs on newer kernel
will never be able to issue calls to extended commands.
The extended command header includes the optional response pointer so
that output buffer length and output buffer pointer are located
together in the command, allowing proper parameters checking. This
should make implementing functions easier and safer.
Additionally the extended header ensure 64bits alignment, while making
all sizes multiple of 8 bytes, extending the maximum buffer size:
legacy extended
Maximum command buffer: 256KBytes 1024KBytes (512KBytes + 512KBytes)
Maximum response buffer: 256KBytes 1024KBytes (512KBytes + 512KBytes)
For the purpose of doing proper buffer size accounting, the headers
size are no more taken in account in "in_words".
One of the odds of the current extensible infrastructure, reading
twice the "legacy" command header, is fixed by removing the "legacy"
command header from the extended command header: they are processed as
two different parts of the command: memory is read once and
information are not duplicated: it's making clear that's an extended
command scheme and not a different command scheme.
The proposed scheme will format input (command) and output (response)
buffers this way:
- command:
legacy header +
extended header +
command data (core + hw):
| flags | 00 00 | command |
| in_words | out_words |
| response |
| response |
| provider_in_words | provider_out_words |
| padding |
. <uverbs input> .
. (in_words * 8) .
. <provider input> .
. (provider_in_words * 8) .
- response, if present:
. <uverbs output space> .
. (out_words * 8) .
. <provider output space> .
. (provider_out_words * 8) .
The overall design is to ensure that the extensible infrastructure is
itself extensible while begin more reliable with more input and bound
checking.
Note:
The unused field in the extended header would be perfect candidate to
hold the command "comp_mask" (eg. bit field used to handle
compatibility). This was suggested by Roland Dreier in a previous
review[2]. But "comp_mask" field is likely to be present in the uverb
input and/or provider input, likewise for the response, as noted by
Matan Barak[3], so it doesn't make sense to put "comp_mask" in the
header.
[1]:
http://marc.info/?i=CAL1RGDWxmM17W2o_era24A-TTDeKyoL6u3NRu_=t_dhV_ZA9MA@mail.gmail.com
[2]:
http://marc.info/?i=CAL1RGDXJtrc849M6_XNZT5xO1+ybKtLWGq6yg6LhoSsKpsmkYA@mail.gmail.com
[3]:
http://marc.info/?i=525C1149.6000701@mellanox.com
Link: http://marc.info/?i=cover.1383773832.git.ydroneaud@opteya.com
[ Convert "ret ? ret : 0" to the equivalent "ret". - Roland ]
The create_flow/destroy_flow uverbs and the associated extensions to
the user-kernel verbs ABI are under review and are too experimental to
freeze at this point.
So userspace is not exposed to experimental features and an uinstable
ABI, temporarily disable this for v3.12 (with a Kconfig option behind
staging to reenable it if desired).
The feature will be enabled after proper cleanup for v3.13.
Link: http://marc.info/?i=cover.1381351016.git.ydroneaud@opteya.com
Link: http://marc.info/?i=cover.1381177342.git.ydroneaud@opteya.com
[ Add a Kconfig option to reenable these verbs. - Roland ]
Implement ib_uverbs_create_flow() and ib_uverbs_destroy_flow() to
support flow steering for user space applications.
Signed-off-by: Hadar Hen Zion <hadarh@mellanox.com>
Add infrastructure to support extended uverbs capabilities in a
forward/backward manner. Uverbs command opcodes which are based on
the verbs extensions approach should be greater or equal to
IB_USER_VERBS_CMD_THRESHOLD. They have new header format and
processed a bit differently.
Whenever a specific IB_USER_VERBS_CMD_XXX is extended, which practically means
it needs to have additional arguments, we will be able to add them without creating
a completely new IB_USER_VERBS_CMD_YYY command or bumping the uverbs ABI version.
This patch for itself doesn't provide the whole scheme which is also dependent
on adding a comp_mask field to each extended uverbs command struct.
The new header framework allows for future extension of the CMD arguments
(ib_uverbs_cmd_hdr.in_words, ib_uverbs_cmd_hdr.out_words) for an existing
new command (that is a command that supports the new uverbs command header format
suggested in this patch) w/o bumping ABI version and with maintaining backward
and formward compatibility to new and old libibverbs versions.
In the uverbs command we are passing both uverbs arguments and the provider arguments.
We split the ib_uverbs_cmd_hdr.in_words to ib_uverbs_cmd_hdr.in_words which will now carry only
uverbs input argument struct size and ib_uverbs_cmd_hdr.provider_in_words that will carry
the provider input argument size. Same goes for the response (the uverbs CMD output argument).
For example take the create_cq call and the mlx4_ib provider:
The uverbs layer gets libibverb's struct ibv_create_cq (named struct ib_uverbs_create_cq
in the kernel), mlx4_ib gets libmlx4's struct mlx4_create_cq (which includes struct
ibv_create_cq and is named struct mlx4_ib_create_cq in the kernel) and
in_words = sizeof(mlx4_create_cq)/4 .
Thus ib_uverbs_cmd_hdr.in_words carry both uverbs plus mlx4_ib input argument sizes,
where uverbs assumes it knows the size of its input argument - struct ibv_create_cq.
Now, if we wish to add a variable to struct ibv_create_cq, we can add a comp_mask field
to the struct which is basically bit field indicating which fields exists in the struct
(as done for the libibverbs API extension), but we need a way to tell what is the total
size of the struct and not assume the struct size is predefined (since we may get different
struct sizes from different user libibverbs versions). So we know at which point the
provider input argument (struct mlx4_create_cq) begins. Same goes for extending the
provider struct mlx4_create_cq. Thus we split the ib_uverbs_cmd_hdr.in_words to
ib_uverbs_cmd_hdr.in_words which will now carry only uverbs input argument struct size and
ib_uverbs_cmd_hdr.provider_in_words that will carry the provider (mlx4_ib) input argument size.
Signed-off-by: Igor Ivanov <Igor.Ivanov@itseez.com>
The existing user/kernel uverbs API has IB_USER_VERBS_CMD_ALLOC/DEALLOC_MW.
Implement these calls, along with destroying user memory windows during
process cleanup.
Signed-off-by: Shani Michaeli <shanim@mellanox.com>
both callers of device_get_devnode() are only interested in lower 16bits
and nobody tries to return anything wider than 16bit anyway.
'misc', 'mlx4', 'misc', 'nes', 'qib' and 'xrc' into for-next
Allow processes that share the same XRC domain to open an existing
shareable QP. This permits those processes to receive events on the
shared QP and transfer ownership, so that any process may modify the
QP. The latter allows the creating process to exit, while a remaining
process can still transition it for path migration purposes.
Signed-off-by: Sean Hefty <sean.hefty@intel.com>
XRC TGT QPs are shared resources among multiple processes. Since the
creating process may exit, allow other processes which share the same
XRC domain to open an existing QP. This allows us to transfer
ownership of an XRC TGT QP to another process.
Allow user space to operate on XRC TGT QPs the same way as other types
of QPs, with one notable exception: since XRC TGT QPs may be shared
among multiple processes, the XRC TGT QP is allowed to exist beyond the
lifetime of the creating process.
The process that creates the QP is allowed to destroy it, but if the
process exits without destroying the QP, then the QP will be left bound
to the lifetime of the XRCD.
TGT QPs are not associated with CQs or a PD.
We require additional information to create XRC SRQs than we can
exchange using the existing create SRQ ABI. Provide an enhanced create
ABI for extended SRQ types.
Based on patches by Jack Morgenstein <jackm@dev.mellanox.co.il>
and Roland Dreier <roland@purestorage.com>
Allow user space to create XRC domains. Because XRCDs are expected to
be shared among multiple processes, we use inodes to identify an XRCD.
cmd is unsigned, no need to check for < 0. Found by code inspection.
Commits 71c29bd5c235 ("IB/uverbs: Add devnode method to set path/mode")
and c3af0980ce01 ("IB: Add devnode methods to cm_class and umad_class")
added devnode methods that set the mode.
However, these methods don't check for a NULL mode, and so we get a
crash when unloading modules because devtmpfs_delete_node() calls
device_get_devnode() with mode == NULL.
Add the missing checks.
Signed-off-by: Goldwyn Rodrigues <rgoldwyn@suse.de>
[ Also fix cm.c. - Roland ]
We want udev to create a device node under /dev/infiniband with
permission 0666 for uverbsX devices, so add a devnode method to set the
appropriate info.
Several RDMA user-access drivers have file_operations structures with
no .llseek method set. None of the drivers actually do anything with
f_pos, so this means llseek is essentially a NOP, instead of returning
an error as leaving other file_operations methods unimplemented would
do. This is mostly harmless, except that a NULL .llseek means that
default_llseek() is used, and this function grabs the BKL, which we
would like to avoid.
Since llseek does nothing useful on these files, we would like it to
return an error to userspace instead of silently grabbing the BKL and
succeeding. For nearly all of the file types, we take the
belt-and-suspenders approach of setting the .llseek method to
no_llseek and also calling nonseekable_open(); the exception is the
uverbs_event files, which are created with anon_inode_getfile(), which
already sets f_mode the same way as nonseekable_open() would.
This work is motivated by Arnd Bergmann's bkl-removal tree.
Signed-off-by: Roland Dreier <rolandd@cisco.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Convert some drivers who export a single string as class attribute
to the new class_attr_string functions. This removes redundant
code all over.
Passing the attribute to the low level IO functions allows all kinds
of cleanups, by sharing low level IO code without requiring
an own function for every piece of data.
Also drivers can extend the attributes with own data fields
and use that in the low level function.
This makes the class attributes the same as sysdev_class attributes
and plain attributes.
This will allow further cleanups in drivers.
Full tree sweep converting all users.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (52 commits)
init: Open /dev/console from rootfs
mqueue: fix typo "failues" -> "failures"
mqueue: only set error codes if they are really necessary
mqueue: simplify do_open() error handling
mqueue: apply mathematics distributivity on mq_bytes calculation
mqueue: remove unneeded info->messages initialization
mqueue: fix mq_open() file descriptor leak on user-space processes
fix race in d_splice_alias()
set S_DEAD on unlink() and non-directory rename() victims
vfs: add NOFOLLOW flag to umount(2)
get rid of ->mnt_parent in tomoyo/realpath
hppfs can use existing proc_mnt, no need for do_kern_mount() in there
Mirror MS_KERNMOUNT in ->mnt_flags
get rid of useless vfsmount_lock use in put_mnt_ns()
Take vfsmount_lock to fs/internal.h
get rid of insanity with namespace roots in tomoyo
take check for new events in namespace (guts of mounts_poll()) to namespace.c
Don't mess with generic_permission() under ->d_lock in hpfs
sanitize const/signedness for udf
nilfs: sanitize const/signedness in dealing with ->d_name.name
Fix up fairly trivial (famous last words...) conflicts in
drivers/infiniband/core/uverbs_main.c and security/tomoyo/realpath.c
The anon_inodes interface has been split to allow creating a bare
(non-installed) file pointer and also extended to allow specifying
O_RDONLY in the flags. This makes it a suitable replacement for the
private "infinibandeventfs" pseudo-filesystem used by uverbs, and this
replacement saves a small chunk of boilerplate code.
Clean up the errors as shown when 'let c_space_errors=1' is set in vim.
Signed-off-by: Alex Chiang <achiang@hp.com>
Some large systems may support more than IB_UVERBS_MAX_DEVICES
(currently 32).
This change allows us to support more devices in a backwards-compatible
manner. The first IB_UVERBS_MAX_DEVICES keep the same major/minor
device numbers that they've always had.
If there are more than IB_UVERBS_MAX_DEVICES, we then dynamically
request a new major device number (new minors start at 0).
This change increases the maximum number of HCAs to 64 (from 32).
