On 12/03/2015 01:18 AM, Christoph Hellwig wrote:
> The patch looks good to me, but while we touch this area, how about
> throwing in a few cosmetic fixes as well?
How about the patch below ? In that version of the ib_sg_to_pages() fix
these concerns have been addressed and additionally to more bugs have been fixed.
[PATCH] IB core: Fix ib_sg_to_pages()
Fix the code for detecting gaps. A gap occurs not only if the
second or later scatterlist element is not aligned but also if
any scatterlist element other than the last does not end at a
page boundary.
In the code for coalescing contiguous elements, ensure that
mr->length is correct and that last_page_addr is up-to-date.
Ensure that this function returns a negative
error code instead of zero if the first set_page() call fails.
Fixes: commit 4c67e2bfc8b7 ("IB/core: Introduce new fast registration API")
Reported-by: Christoph Hellwig <hch@lst.de>
Reviewed-by: Sagi Grimberg <sagig@mellanox.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
Move the __attribute_const__ declarations such that sparse understands
that these apply to the function itself and not to the return type.
This avoids that sparse reports error messages like the following:
drivers/infiniband/core/verbs.c:73:12: error: symbol 'ib_event_msg' redeclared with different type (originally declared at include/rdma/ib_verbs.h:470) - different modifiers
Fixes: 2b1b5b601230 ("IB/core, cma: Nice log-friendly string helpers")
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Cc: Sagi Grimberg <sagig@mellanox.com>
No callers and no providers left, go ahead and remove it.
Signed-off-by: Sagi Grimberg <sagig@mellanox.com>
Acked-by: Christoph Hellwig <hch@lst.de>
The new fast registration verb ib_map_mr_sg receives a scatterlist
and converts it to a page list under the verbs API thus hiding
the specific HW mapping details away from the consumer.
The provider drivers are provided with a generic helper ib_sg_to_pages
that converts a scatterlist into a vector of page addresses. The
drivers can still perform any HW specific page address setting
by passing a set_page function pointer which will be invoked for
each page address. This allows drivers to avoid keeping a shadow
page vectors and convert them to HW specific translations by doing
extra copies.
This API will allow ULPs to remove the duplicated code of constructing
a page vector from a given sg list.
The send work request ib_reg_wr also shrinks as it will contain only
mr, key and access flags in addition.
Tested-by: Christoph Hellwig <hch@lst.de>
Previously, vlan id and source MAC were used from QP attributes. Since
the net device is now stored in the GID attributes, they could be used
instead of getting this information from the QP attributes.
IB_QP_SMAC, IB_QP_ALT_SMAC, IB_QP_VID and IB_QP_ALT_VID were removed
because there is no known libibverbs that uses them.
This commit also modifies the vendors (mlx4, ocrdma) drivers in order
to use the new approach.
ocrdma driver changes were done by Somnath Kotur <Somnath.Kotur@Avagotech.Com>
Signed-off-by: Matan Barak <matanb@mellanox.com>
Adding an ability to query the IB cache by a netdev and get the
attributes of a GID. These parameters are necessary in order to
successfully resolve the required GID (when the netdevice is known)
and get the Ethernet L2 attributes from a GID.
Reviewed-By: Devesh Sharma <devesh.sharma@avagotech.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma
Pull inifiniband/rdma updates from Doug Ledford:
"This is a fairly sizeable set of changes. I've put them through a
decent amount of testing prior to sending the pull request due to
that.
There are still a few fixups that I know are coming, but I wanted to
go ahead and get the big, sizable chunk into your hands sooner rather
than waiting for those last few fixups.
Of note is the fact that this creates what is intended to be a
temporary area in the drivers/staging tree specifically for some
cleanups and additions that are coming for the RDMA stack. We
deprecated two drivers (ipath and amso1100) and are waiting to hear
back if we can deprecate another one (ehca). We also put Intel's new
hfi1 driver into this area because it needs to be refactored and a
transfer library created out of the factored out code, and then it and
the qib driver and the soft-roce driver should all be modified to use
that library.
I expect drivers/staging/rdma to be around for three or four kernel
releases and then to go away as all of the work is completed and final
deletions of deprecated drivers are done.
Summary of changes for 4.3:
- Create drivers/staging/rdma
- Move amso1100 driver to staging/rdma and schedule for deletion
- Move ipath driver to staging/rdma and schedule for deletion
- Add hfi1 driver to staging/rdma and set TODO for move to regular
tree
- Initial support for namespaces to be used on RDMA devices
- Add RoCE GID table handling to the RDMA core caching code
- Infrastructure to support handling of devices with differing read
and write scatter gather capabilities
- Various iSER updates
- Kill off unsafe usage of global mr registrations
- Update SRP driver
- Misc mlx4 driver updates
- Support for the mr_alloc verb
- Support for a netlink interface between kernel and user space cache
daemon to speed path record queries and route resolution
- Ininitial support for safe hot removal of verbs devices"
* tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (136 commits)
IB/ipoib: Suppress warning for send only join failures
IB/ipoib: Clean up send-only multicast joins
IB/srp: Fix possible protection fault
IB/core: Move SM class defines from ib_mad.h to ib_smi.h
IB/core: Remove unnecessary defines from ib_mad.h
IB/hfi1: Add PSM2 user space header to header_install
IB/hfi1: Add CSRs for CONFIG_SDMA_VERBOSITY
mlx5: Fix incorrect wc pkey_index assignment for GSI messages
IB/mlx5: avoid destroying a NULL mr in reg_user_mr error flow
IB/uverbs: reject invalid or unknown opcodes
IB/cxgb4: Fix if statement in pick_local_ip6adddrs
IB/sa: Fix rdma netlink message flags
IB/ucma: HW Device hot-removal support
IB/mlx4_ib: Disassociate support
IB/uverbs: Enable device removal when there are active user space applications
IB/uverbs: Explicitly pass ib_dev to uverbs commands
IB/uverbs: Fix race between ib_uverbs_open and remove_one
IB/uverbs: Fix reference counting usage of event files
IB/core: Make ib_dealloc_pd return void
IB/srp: Create an insecure all physical rkey only if needed
The majority of callers never check the return value, and even if they
did, they can't do anything about a failure.
All possible failure cases represent a bug in the caller, so just
WARN_ON inside the function instead.
This fixes a few random errors:
net/rd/iw.c infinite loops while it fails. (racing with EBUSY?)
This also lays the ground work to get rid of error return from the
drivers. Most drivers do not error, the few that do are broken since
it cannot be handled.
Since uverbs can legitimately make use of EBUSY, open code the
check.
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Reviewed-by: Chuck Lever <chuck.lever@oracle.com>
Every single ULP requires a local_dma_lkey to do anything with
a QP, so let us ensure one exists for every PD created.
If the driver can supply a global local_dma_lkey then use that, otherwise
ask the driver to create a local use all physical memory MR associated
with the new PD.
Reviewed-by: Sagi Grimberg <sagig@dev.mellanox.co.il>
Acked-by: Christoph Hellwig <hch@infradead.org>
Reviewed-by: Steve Wise <swise@opengridcomputing.com>
Reviewed-by: Ira Weiny <ira.weiny@intel.com>
Tested-by: Ira Weiny <ira.weiny@intel.com>
Fully replaced by a more generic and suitable
ib_alloc_mr.
Use ib_alloc_mr with specific parameters.
Change the existing callers.
This was added in a thought of uniting all mr allocation
and deallocation routines but the fact is we have a single
deallocation routine already, ib_dereg_mr.
And, move mlx5_ib_destroy_mr specific logic into mlx5_ib_dereg_mr
(includes only signature stuff for now).
And, fixup the only callers (iser/isert) accordingly.
The verbs are obsolete. The ib_rereg_phys_mr() verb is not used by
kernel ULPs, and the last ib_reg_phys_mr() call site in the kernel
tree has now been removed.
Two staging tree call sites remain in the Lustre client. The Lustre
team has been notified of the deprecation of reg_phys_mr.
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Acked-by: Doug Ledford <dledford@redhat.com>
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
Currently, ib_create_cq uses cqe and comp_vecotr instead
of the extendible ib_cq_init_attr struct.
Earlier patches already changed the vendors to work with
ib_cq_init_attr. This patch changes the consumers too.
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
Add a new ib_cq_init_attr structure which contains the
previous cqe (minimum number of CQ entries) and comp_vector
(completion vector) in addition to a new flags field.
All vendors' create_cq callbacks are changed in order
to work with the new API.
This commit does not change any functionality.
Reviewed-By: Devesh Sharma <devesh.sharma@avagotech.com> to patch #2
In order to support constant callers of agent_send_response we add const
specifiers to the its pointer arguments.
Adjust the call tree accordingly.
Signed-off-by: Ira Weiny <ira.weiny@intel.com>
Reviewed-by: Hal Rosenstock <hal@mellanox.com>
Reviewed-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
into k.o/for-4.2
Some of us keep revisiting the code to decode enumerations that
appear in out logs. Let's borrow the nice logging helpers that
exists in xprtrdma and rds for CMA events, IB events and WC statuses.
Reviewd-by: Sean Hefty <sean.hefty@intel.com>
Introduce helper rdma_cap_eth_ah() to help us check if the port of an
IB device support Ethernet Address Handler.
Signed-off-by: Michael Wang <yun.wang@profitbricks.com>
Reviewed-by: Sean Hefty <sean.hefty@intel.com>
Tested-by: Doug Ledford <dledford@redhat.com>
Use raw management helpers to reform IB-core verbs
For RoCE, resolution of layer 2 address attributes forces no VLAN if
link-local GIDs are used. This patch allows applications to choose
the VLAN ID for link-local based RoCE GIDs by setting IB_QP_VID in
their QP attribute mask, and prevents the core from overriding this
choice.
Cc: Ursula Braun <ursula.braun@de.ibm.com>
Signed-off-by: Moni Shoua <monis@mellanox.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
Fix a few functions that are declared with __attribute_const__ in the
ib_verbs.h header file but defined without it in verbs.c. This gets rid
of the following sparse warnings:
drivers/infiniband/core/verbs.c:51:5: error: symbol 'ib_rate_to_mult' redeclared with different type (originally declared at include/rdma/ib_verbs.h:469) - different modifiers
drivers/infiniband/core/verbs.c:68:14: error: symbol 'mult_to_ib_rate' redeclared with different type (originally declared at include/rdma/ib_verbs.h:607) - different modifiers
drivers/infiniband/core/verbs.c:85:5: error: symbol 'ib_rate_to_mbps' redeclared with different type (originally declared at include/rdma/ib_verbs.h:476) - different modifiers
drivers/infiniband/core/verbs.c:111:1: error: symbol 'rdma_node_get_transport' redeclared with different type (originally declared at include/rdma/ib_verbs.h:84) - different modifiers
Introduce a verbs interface for signature-related operations. A
signature handover operation configures the layouts of data and
protection attributes both in memory and wire domains.
Signature operations are:
- INSERT:
Generate and insert protection information when handing over
data from input space to output space.
- validate and STRIP:
Validate protection information and remove it when handing over
- validate and PASS:
Validate protection information and pass it when handing over
Once the signature handover opration is done, the HCA will offload
data integrity generation/validation while performing the actual data
transfer.
Additions:
1. HCA signature capabilities in device attributes
Verbs provider supporting signature handover operations fills
relevant fields in device attributes structure returned by
ib_query_device.
2. QP creation flag IB_QP_CREATE_SIGNATURE_EN
Creating a QP that will carry signature handover operations may
require some special preparations from the verbs provider. So we
add QP creation flag IB_QP_CREATE_SIGNATURE_EN to declare that the
created QP may carry out signature handover operations. Expose
signature support to verbs layer (no support for now).
3. New send work request IB_WR_REG_SIG_MR
Signature handover work request. This WR will define the signature
handover properties of the memory/wire domains as well as the
domains layout. The purpose of this work request is to bind all
the needed information for the signature operation:
- data to be transferred: wr->sg_list (ib_sge).
* The raw data, pre-registered to a single MR (normally, before
signature, this MR would have been used directly for the data
transfer)
- data protection guards: sig_handover.prot (ib_sge).
* The data protection buffer, pre-registered to a single MR, which
contains the data integrity guards of the raw data blocks.
Note that it may not always exist, only in cases where the user is
interested in storing protection guards in memory.
- signature operation attributes: sig_handover.sig_attrs.
* Tells the HCA how to validate/generate the protection information.
Once the work request is executed, the memory region that will
describe the signature transaction will be the sig_mr. The
application can now go ahead and send the sig_mr.rkey or use the
sig_mr.lkey for data transfer.
4. New Verb ib_check_mr_status
check_mr_status verb checks the status of the memory region post
transaction. The first check that may be used is
IB_MR_CHECK_SIG_STATUS, which will indicate if any signature
errors are pending for a specific signature-enabled ib_mr. This
verb is a lightwight check and is allowed to be taken from
interrupt context. An application must call this verb after it is
known that the actual data transfer has finished.
This commit introduces verbs for creating/destoying memory
regions which will allow new types of memory key operations such
as protected memory registration.
Indirect memory registration is registering several (one
of more) pre-registered memory regions in a specific layout.
The Indirect region may potentialy describe several regions
and some repitition format between them.
Protected Memory registration is registering a memory region
with various data integrity attributes which will describe protection
schemes that will be handled by the HCA in an offloaded manner.
These memory regions will be applicable for a new REG_SIG_MR
work request introduced later in this patchset.
In the future these routines may replace or implement current memory
regions creation routines existing today:
- ib_reg_user_mr
- ib_alloc_fast_reg_mr
- ib_get_dma_mr
- ib_dereg_mr
drivers/infiniband/hw/mlx4/main.c
Existing user space applications provide only IBoE L3 address
attributes to the kernel when they issue a modify QP modify. To work
with them and let such apps (plus kernel consumers which don't use the
RDMA-CM) keep working transparently under the IBoE GID IP addressing
changes, add an Eth L2 address resolution helper.
Signed-off-by: Moni Shoua <monis@mellanox.co.il>
Add the complementary RDMA_NODE_USNIC_UDP for RDMA_TRANSPORT_USNIC_UDP.
Signed-off-by: Upinder Malhi <umalhi@cisco.com>
This patch add the support for Ethernet L2 attributes in the
verbs/cm/cma structures.
When dealing with L2 Ethernet, we should use smac, dmac, vlan ID and priority
in a similar manner that the IB L2 (and the L4 PKEY) attributes are used.
Thus, those attributes were added to the following structures:
* ib_ah_attr - added dmac
* ib_qp_attr - added smac and vlan_id, (sl remains vlan priority)
* ib_wc - added smac, vlan_id
* ib_sa_path_rec - added smac, dmac, vlan_id
* cm_av - added smac and vlan_id
For the path record structure, extra care was taken to avoid the new
fields when packing it into wire format, so we don't break the IB CM
and SA wire protocol.
On the active side, the CM fills. its internal structures from the
path provided by the ULP. We add there taking the ETH L2 attributes
and placing them into the CM Address Handle (struct cm_av).
On the passive side, the CM fills its internal structures from the WC
associated with the REQ message. We add there taking the ETH L2
attributes from the WC.
When the HW driver provides the required ETH L2 attributes in the WC,
they set the IB_WC_WITH_SMAC and IB_WC_WITH_VLAN flags. The IB core
code checks for the presence of these flags, and in their absence does
address resolution from the ib_init_ah_from_wc() helper function.
ib_modify_qp_is_ok is also updated to consider the link layer. Some
parameters are mandatory for Ethernet link layer, while they are
irrelevant for IB. Vendor drivers are modified to support the new
function signature.
Add RDMA_TRANSPORT_USNIC_UDP which will be used by usNIC.
Enforce the rule that when requesting remote write or atomic permissions, local
write must be indicated as well. See IB spec 11.2.8.2.
Spotted by: Hagay Abramovsky <hagaya@mellanox.com>
Signed-off-by: Eli Cohen <eli@mellanox.com>
This patch adds new rdma node and new rdma transport, and supporting
code used by Cisco's low latency driver called usNIC. usNIC uses its
own transport, distinct from IB and iWARP.
Signed-off-by: Jeff Squyres <jsquyres@cisco.com>
'qib' into for-next
The RDMA stack allows for applications to create IB_QPT_RAW_PACKET
QPs, which receive plain Ethernet packets, specifically packets that
don't carry any QPN to be matched by the receiving side. Applications
using these QPs must be provided with a method to program some
steering rule with the HW so packets arriving at the local port can be
routed to them.
This patch adds ib_create_flow(), which allow providing a flow
specification for a QP. When there's a match between the
specification and a received packet, the packet is forwarded to that
QP, in a the same way one uses ib_attach_multicast() for IB UD
multicast handling.
Flow specifications are provided as instances of struct ib_flow_spec_yyy,
which describe L2, L3 and L4 headers. Currently specs for Ethernet, IPv4,
TCP and UDP are defined. Flow specs are made of values and masks.
The input to ib_create_flow() is a struct ib_flow_attr, which contains
a few mandatory control elements and optional flow specs.
struct ib_flow_attr {
enum ib_flow_attr_type type;
u16 size;
u16 priority;
u32 flags;
u8 num_of_specs;
u8 port;
/* Following are the optional layers according to user request
* struct ib_flow_spec_yyy
* struct ib_flow_spec_zzz
As these specs are eventually coming from user space, they are defined and
used in a way which allows adding new spec types without kernel/user ABI
change, just with a little API enhancement which defines the newly added spec.
The flow spec structures are defined with TLV (Type-Length-Value)
entries, which allows calling ib_create_flow() with a list of variable
length of optional specs.
For the actual processing of ib_flow_attr the driver uses the number
of specs and the size mandatory fields along with the TLV nature of
the specs.
Steering rules processing order is according to the domain over which
the rule is set and the rule priority. All rules set by user space
applicatations fall into the IB_FLOW_DOMAIN_USER domain, other domains
could be used by future IPoIB RFS and Ethetool flow-steering interface
implementation. Lower numerical value for the priority field means
higher priority.
The returned value from ib_create_flow() is a struct ib_flow, which
contains a database pointer (handle) provided by the HW driver to be
used when calling ib_destroy_flow().
Applications that offload TCP/IP traffic can also be written over IB
UD QPs. The ib_create_flow() / ib_destroy_flow() API is designed to
support UD QPs too. A HW driver can set IB_DEVICE_MANAGED_FLOW_STEERING
to denote support for flow steering.
The ib_flow_attr enum type supports usage of flow steering for promiscuous
and sniffer purposes:
IB_FLOW_ATTR_NORMAL - "regular" rule, steering according to rule specification
IB_FLOW_ATTR_ALL_DEFAULT - default unicast and multicast rule, receive
all Ethernet traffic which isn't steered to any QP
IB_FLOW_ATTR_MC_DEFAULT - same as IB_FLOW_ATTR_ALL_DEFAULT but only for multicast
IB_FLOW_ATTR_SNIFFER - sniffer rule, receive all port traffic
ALL_DEFAULT and MC_DEFAULT rules options are valid only for Ethernet link type.
Signed-off-by: Hadar Hen Zion <hadarh@mellanox.com>
Fix a potential race when event occurrs on a target XRC QP and in the
middle of reporting that on its shared qps, one of them is destroyed
by user space application. Also add note for kernel consumers in
ib_verbs.h that they must not destroy the QP from within the handler.
Signed-off-by: Yishai Hadas <yishaih@mellanox.com>
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
For QPs of type IB_QPT_XRC_TGT the IB core assigns a common event
handler __ib_shared_qp_event_handler(), and the optionally supplied
event handler is stored. When the common handler is called it iterates
on all opened QPs and calles the original handlers without checking if
they are NULL. Fix that.
Signed-off-by: Shlomo Pongratz <shlomop@mellanox.com>
This patch enhances the IB core support for Memory Windows (MWs).
MWs allow an application to have better/flexible control over remote
access to memory.
Two types of MWs are supported, with the second type having two flavors:
Type 1 - associated with PD only
Type 2A - associated with QPN only
Type 2B - associated with PD and QPN
Applications can allocate a MW once, and then repeatedly bind the MW
to different ranges in MRs that are associated to the same PD. Type 1
windows are bound through a verb, while type 2 windows are bound by
posting a work request.
The 32-bit memory key is composed of a 24-bit index and an 8-bit
key. The key is changed with each bind, thus allowing more control
over the peer's use of the memory key.
The changes introduced are the following:
* add memory window type enum and a corresponding parameter to ib_alloc_mw.
* type 2 memory window bind work request support.
* create a struct that contains the common part of the bind verb struct
ibv_mw_bind and the bind work request into a single struct.
* add the ib_inc_rkey helper function to advance the tag part of an rkey.
Consumer interface details:
* new device capability flags IB_DEVICE_MEM_WINDOW_TYPE_2A and
IB_DEVICE_MEM_WINDOW_TYPE_2B are added to indicate device support
for these features.
Devices can set either IB_DEVICE_MEM_WINDOW_TYPE_2A or
IB_DEVICE_MEM_WINDOW_TYPE_2B if it supports type 2A or type 2B
memory windows. It can set neither to indicate it doesn't support
type 2 windows at all.
* modify existing provides and consumers code to the new param of
ib_alloc_mw and the ib_mw_bind_info structure
Signed-off-by: Haggai Eran <haggaie@mellanox.com>
Signed-off-by: Shani Michaeli <shanim@mellanox.com>
'ocrdma', 'qib' and 'raw-qp' into for-linus
IB_QPT_RAW_PACKET allows applications to build a complete packet,
including L2 headers, when sending; on the receive side, the HW will
not strip any headers.
This QP type is designed for userspace direct access to Ethernet; for
example by applications that do TCP/IP themselves. Only processes
with the NET_RAW capability are allowed to create raw packet QPs (the
name "raw packet QP" is supposed to suggest an analogy to AF_PACKET /
SOL_RAW sockets).
Just as we don't allow PDs, CQs, etc. to be destroyed if there are QPs
that are attached to them, don't let a QP be destroyed if there are
multicast group(s) attached to it. Use the existing usecnt field of
struct ib_qp which was added by commit 0e0ec7e ("RDMA/core: Export
ib_open_qp() to share XRC TGT QPs") to track this.
We have just been investigating kernel panics related to
cq->ibcq.event_handler() completion calls. The problem is that
ib_destroy_qp() fails with -EBUSY.
Further investigation revealed qp->usecnt is not initialized. This
counter was introduced in linux-3.2 by commit 0e0ec7e0638e
("RDMA/core: Export ib_open_qp() to share XRC TGT QPs") but it only
gets initialized for IB_QPT_XRC_TGT, but it is checked in
ib_destroy_qp() for any QP type.
Fix this by initializing qp->usecnt for every QP we create.
Signed-off-by: Bernd Schubert <bernd.schubert@itwm.fraunhofer.de>
Signed-off-by: Sven Breuner <sven.breuner@itwm.fraunhofer.de>
[ Initialize qp->usecnt in uverbs too. - Sean ]
Signed-off-by: Sean Hefty <sean.hefty@intel.com>
Cc: <stable@vger.kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
'misc', 'mlx4', 'misc', 'nes', 'qib' and 'xrc' into for-next
These were getting it implicitly via device.h --> module.h but
we are going to stop that when we clean up the headers.
Fix these in advance so the tree remains biscect-clean.
XRC TGT QPs are shared resources among multiple processes. Since the
creating process may exit, allow other processes which share the same
XRC domain to open an existing QP. This allows us to transfer
ownership of an XRC TGT QP to another process.
Allow user space to create XRC domains. Because XRCDs are expected to
be shared among multiple processes, we use inodes to identify an XRCD.
Based on patches by Jack Morgenstein <jackm@dev.mellanox.co.il>
XRC TGT QPs are intended to be shared among multiple users and
processes. Allow the destruction of an XRC TGT QP to be done explicitly
through ib_destroy_qp() or when the XRCD is destroyed.
To support destroying an XRC TGT QP, we need to track TGT QPs with the
XRCD. When the XRCD is destroyed, all tracked XRC TGT QPs are also
cleaned up.
To avoid stale reference issues, if a user is holding a reference on a
TGT QP, we increment a reference count on the QP. The user releases the
reference by calling ib_release_qp. This releases any access to the QP
from a user above verbs, but allows the QP to continue to exist until
destroyed by the XRCD.
XRC ("eXtended reliable connected") is an IB transport that provides
better scalability by allowing senders to specify which shared receive
queue (SRQ) should be used to receive a message, which essentially
allows one transport context (QP connection) to serve multiple
destinations (as long as they share an adapter, of course).
XRC communication is between an initiator (INI) QP and a target (TGT)
QP. Target QPs are associated with SRQs through an XRCD. An XRC TGT QP
behaves like a receive-only RD QP. XRC INI QPs behave similarly to RC
QPs, except that work requests posted to an XRC INI QP must specify the
remote SRQ that is the target of the work request.
We define two new QP types for XRC, to distinguish between INI and TGT
QPs, and update the core layer to support XRC QPs.
This patch is derived from work by Jack Morgenstein
XRC defines SRQs that are specifically used by XRC connections. Expand
the SRQ code to support XRC SRQs. An XRC SRQ is currently restricted to
only XRC use according to the IB XRC Annex.
Portions of this patch were derived from work by
Jack Morgenstein <jackm@dev.mellanox.co.il>.
Currently, there is only a single ("basic") type of SRQ, but with XRC
support we will add a second. Prepare for this by defining an SRQ type
and setting all current users to IB_SRQT_BASIC.
A few new concepts are introduced to support this. This patch adds:
- A new device capability flag, IB_DEVICE_XRC, which low-level
drivers set to indicate that a device supports XRC.
- A new object type, XRC domains (struct ib_xrcd), and new verbs
ib_alloc_xrcd()/ib_dealloc_xrcd(). XRCDs are used to limit which
XRC SRQs an incoming message can target.
This patch is derived from work by Jack Morgenstein <jackm@dev.mellanox.co.il>.
