Faster kernel compiles by way of fewer unnecessary includes.
[akpm@linux-foundation.org: fix fallout]
[akpm@linux-foundation.org: fix build]
Signed-off-by: Kent Overstreet <koverstreet@google.com>
Cc: Zach Brown <zab@redhat.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Asai Thambi S P <asamymuthupa@micron.com>
Cc: Selvan Mani <smani@micron.com>
Cc: Sam Bradshaw <sbradshaw@micron.com>
Cc: Jeff Moyer <jmoyer@redhat.com>
Cc: Benjamin LaHaise <bcrl@kvack.org>
Reviewed-by: "Theodore Ts'o" <tytso@mit.edu>
A long time ago, in v2.4, VM_RESERVED kept swapout process off VMA,
currently it lost original meaning but still has some effects:
| effect | alternative flags
1| account as reserved_vm | VM_IO
2| skip in core dump | VM_IO, VM_DONTDUMP
3| do not merge or expand | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP
4| do not mlock | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP
This patch removes reserved_vm counter from mm_struct. Seems like nobody
cares about it, it does not exported into userspace directly, it only
reduces total_vm showed in proc.
Thus VM_RESERVED can be replaced with VM_IO or pair VM_DONTEXPAND | VM_DONTDUMP.
remap_pfn_range() and io_remap_pfn_range() set VM_IO|VM_DONTEXPAND|VM_DONTDUMP.
remap_vmalloc_range() set VM_DONTEXPAND | VM_DONTDUMP.
[akpm@linux-foundation.org: drivers/vfio/pci/vfio_pci.c fixup]
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Cc: Carsten Otte <cotte@de.ibm.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Eric Paris <eparis@redhat.com>
Cc: James Morris <james.l.morris@oracle.com>
Cc: Jason Baron <jbaron@redhat.com>
Cc: Kentaro Takeda <takedakn@nttdata.co.jp>
Cc: Matt Helsley <matthltc@us.ibm.com>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Robert Richter <robert.richter@amd.com>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: Venkatesh Pallipadi <venki@google.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
These were getting it implicitly via device.h --> module.h but
we are going to stop that when we clean up the headers.
Fix these in advance so the tree remains biscect-clean.
Adapt to new api. We plan to remove old one later. Almost all
changes are trivial, but there is one real fix: the following code is
unsafe:
int ncpus = num_online_cpus()
for (i = 0; i < ncpus; i++) {
because 1) we don't guarantee last bit of online cpus is equal to
num_online_cpus(). some arch assign sparse cpu number. 2) cpu
hotplugging may change cpu_online_mask at same time. we need to pin
it by get_online_cpus().
Acked-by: Mike Marciniszyn <mike.marciniszyn@qlogic.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
The big kernel lock has been removed from all these files at some point,
leaving only the #include.
Remove this too as a cleanup.
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
Acked-by: Ralph Campbell <ralph.campbell@qlogic.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
cycle_kernel_lock() got pushed down to ipath_open(). I tried hard to
understand what it might protect, but finally gave up.
Roland noted that qlogic seems to have abandoned the ipath driver and
came to the following wise conclusion: "So I guess if the BKL stuff is
blocking you in any way, we can just drop it from ipath and leave it
as yet another race condition in a rotting old driver."
LKML-Reference: <adad44tj090.fsf@cisco.com>
Cc: Roland Dreier <rdreier@cisco.com>
* mark struct vm_area_struct::vm_ops as const
* mark vm_ops in AGP code
But leave TTM code alone, something is fishy there with global vm_ops
being used.
strlcpy() will always null terminate the string. node_desc is not
guaranteed to be NUL-terminated so just use memcpy().
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Impact: cleanup
We're moving from handing around cpumask_t's to handing around struct
cpumask *'s. cpus_*, cpumask_t and cpu_*_map are deprecated: convert
to cpumask_*, cpu_*_mask.
Cc: Ralph Campbell <infinipath@qlogic.com>
Fixes timing race resulting in panic. Not a performance sensitive path.
Signed-off-by: Dave Olson <dave.olson@qlogic.com>
ipath_piobufbase was a single value offset, but is multiple values on
newer chips, so use only the 32 bits for the 2K buffers (4K buffers
are currently used only by the driver).
Now that device_create() has been audited, rename things back to the
original call to be sane.
Cc: Roland Dreier <rolandd@cisco.com>
Cc: Sean Hefty <sean.hefty@intel.com>
Cc: Hal Rosenstock <hal.rosenstock@gmail.com>
device_create() is race-prone, so use the race-free
device_create_drvdata() instead as device_create() is going away.
All of the open() functions which don't need the BKL on their face may
still depend on its acquisition to serialize opens against driver
initialization. So make those functions acquire then release the BKL to be
on the safe side.
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
This documents the fact that somebody looked at the relevant open()
functions and concluded that, due to their trivial nature, no locking was
needed.
The official reason is "with the presence of pid namespaces in the
kernel using pid_t-s inside one is no longer safe."
But the reason I fix this right now is the following:
About a month ago (when 2.6.25 was not yet released) there still was a
one last caller of a to-be-deprecated-soon function find_pid() - the
kill_proc() function, which in turn was only used by nfs callback
code.
During the last merge window, this last caller was finally eliminated
by some NFS patch(es) and I was about to finally kill this kill_proc()
and find_pid(), but found, that I was late and the kill_proc is now
called from the ipath driver since commit 58411d1c ("IB/ipath: Head of
Line blocking vs forward progress of user apps").
So here's a patch that fixes this code to use struct pid * and (!)
the kill_pid routine.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Now that we always use PIO for vl15 on 7220, we could get stuck forever
if we happened to run out of PIO buffers from the verbs code, because
the setup code wouldn't run; the interrupt was also ignored if SDMA was
supported. We also have to reduce the pio update threshold if we have
fewer kernel buffers than the existing threshold.
Clean up the initialization a bit to get ordering safer and more
sensible, and use the existing ipath_chg_kernavail call to do init,
rather than doing it separately.
Drop unnecessary clearing of pio buffer on pio parity error.
Drop incorrect updating of pioavailshadow when exitting freeze mode
(software state may not match chip state if buffer has been allocated
and not yet written).
If we couldn't get a kernel buffer for a while, make sure we are
in sync with hardware, mainly to handle the exitting freeze case.
This converts the main ib_device to use struct device instead of struct
class_device as class_device is going away.
Signed-off-by: Tony Jones <tonyj@suse.de>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com>
This patch adds the initialization calls into the new 7220 HCA files,
changes the Makefile to compile and link the new files, and code to
handle send DMA.
The patch adds a number of minor changes to support newer HCAs:
- New send buffer control bits
- New error condition bits
- Locking and initialization changes
- More send buffers
Newer HCAs have a threshold counter to reduce the number of DMAs the
chip makes to update the PIO buffer availability status bits. This
patch enables the feature.
Newer HCAs have a HW option to write a sequence number to each receive
queue entry and avoid a separate DMA of the tail register to memory.
This patch adds support for these changes.
A fixed partitioning of send buffers is determined at driver load time
for user processes and kernel use. Since send buffers are a scarce
resource, it makes sense to allow the kernel to use the buffers if they
are not in use by a user process.
Also, eliminate code duplication for ipath_force_pio_avail_update().
Enable use of 4KB MTU. Since the driver uses more pinned memory for
receive buffers when the 4KB MTU is enabled, whether or not the fabric
supports that MTU, add a "mtu4096" module parameter that can be used to
limit the MTU to 2KB when it is known that 4KB MTUs can't be used
anyway.
The code was checking if units are present, but not that present units
were usable (link up, etc.)
The IBA7220 uses a count-based triggering mechanism, and therefore
can't use the same bandwidth verification mechanism as older chips.
To support the 7220, allow enabling and disabling armlaunch errors on
application request. Minor robustness improvements as well.
The number of configured ports for the 7220 changes the number of eager
TIDs available per port, for all but port 0 (kernel port) which remains
constant, so add a field to give port0 count separate from the portdata
structure.
User registers have different alignments on different chips (4KB on
older, 64KB on 7220). Allow mapping the user registers on kernels with
page sizes up to 64K.
This patch moves some arrays that were defined per-device to be
variables defined in the per context data structure, thus avoiding extra
kzalloc() calls.
In preparation for upcoming chips that have different values for
INFINIPATH_R_PORTENABLE_SHIFT, INFINIPATH_R_INTRAVAIL_SHIFT,
INFINIPATH_R_TAILUPD_SHIFT, and portcfg_shift, remove the shared
#defines and use device-specific variables instead.
kreceive is now portdata * instead of devdata * and other kreceive
related cleanups....
Signed-off-by: Nick Piggin <npiggin@suse.de>
Code review pointed out that the locking around uses of ipath_sendctrl
and kr_sendctrl were, in several places, incorrect and/or inconsistent.
Signed-off-by: John Gregor <john.gregor@qlogic.com>
Fixed to be the same as everywhere else. copy and then zero the page *
in the array first, and then pass the copy to the VM routines.
ipath_poll() suffered from a couple subtle bugs. Under the right
conditions we could leave recv interrupts enabled on an ipath user
context on close, thereby taking potentially unwanted interrupts on the
next open -- this is fixed by unconditionally turning off recv
interrupts on close. Also, we now use counters rather than set/clear
bits which allows us to make sure we catch all interrupts at the cost of
changing the semantics slightly (it's now give me all events since the
last time I called poll() rather than give me all events since I called
_this_ poll routine). We also added some memory barriers which may help
ensure we get all notifications in a timely manner.
Signed-off-by: Arthur Jones <arthur.jones@qlogic.com>
Fix ipath_poll and enhance it so we can poll for urgent packets or
regular packets and receive notifications of when a header queue
overflows.
Signed-off-by: Robert Walsh <robert.walsh@qlogic.com>
Previously the driver and userspace code handled the case of 1 subport
somewhat inconsistently. The new interpretation of this situation is
that if one subport is requested, the driver turns on the subport
mechanism and arranges for the port to be "shared" by one process. In
normal use the userspace library does not use this configuration and
instead arranges for the port not to be shared at all. This
particular idiom can be useful for testing purposes.
Signed-off-by: Mark Debbage <mark.debbage@qlogic.com>
When subports are required to run a program, this patch checks that
the driver and the userspace library have compatible subport
implementations. This is achieved through checks on the swminor
version field built into the driver and userspace library. Bad
combinations are reported through syslog and result in an error when
opening the port.
Define pkt rcvd 'type' in a way consistent with HW spec and chips.
The hardware considers received packets of type 0 to be expected, and
type 1 to be eager. The driver was calling the ipath_f_put_tid
functions using a variable called 'type' set to 0 for eager and to 1
for expected packets. Worse, the iba6110 and iba6120 drivers used
those values inconsistently. This was quite confusing. Now
everything is consistent with the hardware.
At some point things changed so that all the affinity bits can be set,
but cpus_full() macro is not true. This caused problems with the unit
selection logic on multi-unit (board) configurations.
Signed-off-by: Bryan O'Sullivan <bryan.osullivan@qlogic.com>
Due to a chip bug, the PIOAvail register is not always updated to
memory. This patch allows userspace to force an update.
Improve port-sharing performance by allowing any process to receive
packets from the shared hardware port under a spin lock for mutual
exclusion. Previously, one process was nominated as the master and
that process was responsible for receiving all packets from the shared
hardware port and either consuming them or forwarding them to their
destination. This led to starvation problems for other processes when
the master process was busy in computation phases.
