Signed-off-by: Roland Dreier <rolandd@cisco.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
If the second vmalloc() fails, the wrong pointer is pased to vfree(), so
the first vmalloc() ends up getting leaked.
This was spotted by the Coverity checker (CID 2709).
Fixes timing race resulting in panic. Not a performance sensitive path.
Signed-off-by: Dave Olson <dave.olson@qlogic.com>
Now that we always use PIO for vl15 on 7220, we could get stuck forever
if we happened to run out of PIO buffers from the verbs code, because
the setup code wouldn't run; the interrupt was also ignored if SDMA was
supported. We also have to reduce the pio update threshold if we have
fewer kernel buffers than the existing threshold.
Clean up the initialization a bit to get ordering safer and more
sensible, and use the existing ipath_chg_kernavail call to do init,
rather than doing it separately.
Drop unnecessary clearing of pio buffer on pio parity error.
Drop incorrect updating of pioavailshadow when exitting freeze mode
(software state may not match chip state if buffer has been allocated
and not yet written).
If we couldn't get a kernel buffer for a while, make sure we are
in sync with hardware, mainly to handle the exitting freeze case.
Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com>
This patch adds the initialization calls into the new 7220 HCA files,
changes the Makefile to compile and link the new files, and code to
handle send DMA.
The patch adds a number of minor changes to support newer HCAs:
- New send buffer control bits
- New error condition bits
- Locking and initialization changes
- More send buffers
This patch makes chip reset more robust and reduces lock contention
between user and kernel TID register updates.
Newer HCAs support MSI interrupts and also INTx interrupts. Fix the
code so that INTx can be reliably enabled if MSI interrupts are not
working.
Newer HCAs have a threshold counter to reduce the number of DMAs the
chip makes to update the PIO buffer availability status bits. This
patch enables the feature.
Newer HCAs have a HW option to write a sequence number to each receive
queue entry and avoid a separate DMA of the tail register to memory.
This patch adds support for these changes.
This patch makes some white space changes and minor non-functional
changes to more closely match the code in OFED-1.3.
A fixed partitioning of send buffers is determined at driver load time
for user processes and kernel use. Since send buffers are a scarce
resource, it makes sense to allow the kernel to use the buffers if they
are not in use by a user process.
Also, eliminate code duplication for ipath_force_pio_avail_update().
The link can be put in LINKDOWN_DISABLE state either locally or via a
MAD. However, the link-recovery code will take it out of that state as
a side-effect of attempts to clear SerDes/XGXS issues.
We add a flag to indicate "link is down on purpose, leave it alone."
Signed-off-by: Michael Albaugh <michael.albaugh@qlogic.com>
There's a conflict between our need to quiesce PSM-based applications
to avoid HoL blocking when the IB link goes down and the apps' desire
to remain running so that their quiescence timout mechanism can keep
running.
The compromise is to STOP the processes for a fixed period of time and
then alternate between CONT and STOP until the link is again active.
If there are poor interactions with subnet manager configuration at a
given site, the interval can be adjusted via a module paramter.
Signed-off-by: John Gregor <john.gregor@qlogic.com>
Enable use of 4KB MTU. Since the driver uses more pinned memory for
receive buffers when the 4KB MTU is enabled, whether or not the fabric
supports that MTU, add a "mtu4096" module parameter that can be used to
limit the MTU to 2KB when it is known that 4KB MTUs can't be used
anyway.
Fix
drivers/infiniband/hw/ipath/ipath_init_chip.c:526:10: warning: symbol 'val' shadows an earlier one
drivers/infiniband/hw/ipath/ipath_init_chip.c:473:6: originally declared here
by giving the second val a different name.
Acked-by: Arthur Jones <arthur.jones@qlogic.com>
The 6110 had a bug that caused some registers to be swapped; it was
fixed for the 7220 (and didn't affect the 6120 because it had fewer
registers). This adds a flag and related code to handle that, and
includes some minor cleanups in the same area.
The number of configured ports for the 7220 changes the number of eager
TIDs available per port, for all but port 0 (kernel port) which remains
constant, so add a field to give port0 count separate from the portdata
structure.
This patch moves some arrays that were defined per-device to be
variables defined in the per context data structure, thus avoiding extra
kzalloc() calls.
In preparation for upcoming chips that have different values for
INFINIPATH_R_PORTENABLE_SHIFT, INFINIPATH_R_INTRAVAIL_SHIFT,
INFINIPATH_R_TAILUPD_SHIFT, and portcfg_shift, remove the shared
#defines and use device-specific variables instead.
kreceive is now portdata * instead of devdata * and other kreceive
related cleanups....
Code review pointed out that the locking around uses of ipath_sendctrl
and kr_sendctrl were, in several places, incorrect and/or inconsistent.
Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com>
Acked-by: Michael Albaugh <Michael.Albaugh@qlogic.com>
Tested-by: Arthur Jones <arthur.jones@qlogic.com>
On some system hardware, we are seeing moderately common cases of the
chip errormask register being overwritten due to a chip bug in iba6120
that is triggered by a vendor-specific PCIe broadcast message. This
patch merely checks periodically, and corrects it if needed (the
overwrite can cause us to not get error and hardware error
interrupts). Also, make dd->ipath_errormask the one, true canonical
source for kr_errormask, and remove references to ipath_ignorederrs as
it is currently unused.
There was confused use of INFINIPATH_S_PIOBUFAVAILUPD (value) and
IPATH_S_PIOBUFAVAILUPD (bit position). Also, some callers of
ipath_cancel_sends() need kr_sendctrl restored, and some want to do it
later.
The default calculation for the number of send buffers to allocate to
the kernel was too high for the PCIe version of the chip thus leaving
fewer than desired send buffers for user MPI applications.
Now that it's June, it's about time to update
the copyright notices of files that have changed.
This centralizes the use of the abort functionality, removes the
unneeded buffer cancel (abort does the same thing), sets up to ignore
launch errors after abort, same as cancel. We need abort on exit from
freeze mode to avoid having buffers stuck in the busy state, if a user
process happened to complete the send while we were in freeze mode
doing the recovery.
Define pkt rcvd 'type' in a way consistent with HW spec and chips.
The hardware considers received packets of type 0 to be expected, and
type 1 to be eager. The driver was calling the ipath_f_put_tid
functions using a variable called 'type' set to 0 for eager and to 1
for expected packets. Worse, the iba6110 and iba6120 drivers used
those values inconsistently. This was quite confusing. Now
everything is consistent with the hardware.
Although our chip supports 4K MTUs, our driver doesn't yet support
this feature, so limit the maximum MTU to 2K until we get support for
4K MTUs implemented.
Signed-off-by: Robert Walsh <robert.walsh@qlogic.com>
We currently track various errors, now we enhance that capability by
logging some of them to EEPROM. We also now log a cumulative "active"
time defined by traffic though the InfiniPath HCA beyond the normal SM
traffic.
The new LED blinking interface adds more contention for the
unprotected GPIO pins that were already shared, though not commonly at
the same time. We add locks to the accesses to these pins so that
Read-Modify-Write is now safe. Some of these locks are added at
interrupt context, so we shadow the registers which drive and inspect
these pins to avoid the mmio read/writes. This mitigates the effects
of the locks and hastens us through the interrupt.
Add locking and always use shadows for registers controlling GPIO pins
(ExtCtrl and GPIOout). The use of shadows implies doing less I/O,
which can make I2C operation too fast on some platforms. An explicit
udelay(1) in SCL manipulation fixes that.
Re-init of the kernel structures after a chip reset was leaving the
portdata structure for port zero in an inconsistent state, and a
pointer to it either stale (in re-init code) or NULL (in devdata)
Fixing the order of operations on this struct, and the condition for
interrupt access, prevents the crashes.
Signed-off-by: Bryan O'Sullivan <bryan.osullivan@qlogic.com>
Mostly cleanup.
If the module parameter "kpiobufs" is set too high, the calculation to
reset it to a sane value was incorrect.
Remove variables that are set but then never looked at in the ipath
driver. These cleanups came from David Binderman's list of "set but
never used" warnings from icc.
When we first submitted a userspace subnet management agent, it was
rejected, so we left it out of the final driver submission. This patch
removes a number of vestigial references to it.
Change comment: no longer imply that user can set ipath_kpiobufs to zero.
Actually set ipath_kpiobufs from parameter. Previously only altered
per-device ipath_lastport_piobuf, which was over-written in chip init.
Allocate enough pointers for all possible ports, to avoid problems in
cleanup/unload.
Remove ips namespace from infinipath drivers. This renames ips_common.h to
ipath_common.h. Definitions, data structures, etc. that were not used by
kernel modules have moved to user-only headers. All names including ips have
been renamed to ipath. Some names have had an ipath prefix added.
Signed-off-by: Christian Bell <christian.bell@qlogic.com>
Cc: "Michael S. Tsirkin" <mst@mellanox.co.il>
Cc: Roland Dreier <rolandd@cisco.com>
via DMA
We can't tell for sure if any packets are in the infinipath receive buffer
when we shut down a chip port. Normally this is taken care of by orderly
shutdown, but when processes are terminated, or sending process has a bug, we
can continue to receive packets. So rather than writing zero to the address
registers for the closing port, we point it at a dummy memory.
The two arrays only had space for 4 units.
Also changed from ipath_set_sps_lid() to ipath_set_lid(); the sps was
leftover.
Made in-memory rcvhdrq tail update be in dma_alloc'ed memory, not random user
or special kernel (needed for ppc, also "just the right thing to do").
Some cleanups to make unexpected link transitions less likely to produce
complaints about packet errors, and also to not leave SMA packets stuck and
unable to go out.
A few other random debug and comment cleanups.
Always init rcvhdrq head/tail registers to 0, to avoid race conditions (should
have been that way some time ago).
