Now that it's June, it's about time to update
the copyright notices of files that have changed.
Signed-off-by: John Gregor <john.gregor@qlogic.com>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
The IB specification ch. 9.9.3 table 58 says that a QP which isn't set
up for the operation should return a NAK invalid request.
Signed-off-by: Robert Walsh <robert.walsh@qlogic.com>
A duplicate RDMA read request can fool the responder into NAKing a new
RDMA read request because the responder wasn't keeping track of
whether the queue of RDMA read requests had been sent at least once.
For example, requester sends 4 2K byte RDMA read requests, times out,
and resends the first, then sees the 4 responses, then sends a 5th
RDMA read or atomic operation. The responder sees the 4 requests,
sends 4 responses, sees the resent 1st request, rewinds the queue,
then sees the 5th request but thinks the queue is full and that the
requester is invalidly sending a 5th new request.
Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com>
A RDMA read response or atomic response can ACK earlier sends and RDMA
writes. In this case, the wrong work request pointer was being used
to store the read first response or atomic result. Also, if a RDMA
read request is retried, the code to compute which request to resend
was incorrect.
According to chapter 17.2.8.1.1, QPs start in the migrated state and
should send packets with the M bit set in the BTH.
Fix a problem where simple ACKs can be sent ahead of RDMA read
responses thus implicitly NAKing the RDMA read.
Signed-off-by: Ralph Campbell <ralph.cambpell@qlogic.com>
Fix a missing unlock in ipath_rc_rcv_resp() and remove an extra unlock
from ipath_rc_rcv_error().
This fixes a problem which causes too many RC timeouts and
retransmits.
This patch fixes the problem reported by Bernd Schubert <bs@q-leap.de>
with kernel debug options enabled:
BUG: at kernel/lockdep.c:1860 trace_hardirqs_on()
This was caused by using spin_lock_irq()/spin_unlock_irq() from
interrupt context. Fix all the places that might be called from
interrupts to use spin_lock_irqsave()/spin_unlock_irqrestore().
Fix RDMA read response length checking for RDMA_READ_RESPONSE_ONLY to
allow a zero length response. RDMA read responses which don't match
the expected length or occur in response to some other operation
should generate a completion queue error (see table 56, ch. 9.9.2.3 in
the IB spec).
Signed-off-by: Bryan O'Sullivan <bryan.osullivan@qlogic.com>
This patch fixes a number of bugs with updating the PSN for retries of
RC requests.
When switching to the QP error state, the completion queue entries
(error or flush) were not being generated correctly.
This patch adds support for multiple RDMA reads and atomics to be sent
before an ACK is required to be seen by the requester.
struct ib_wc currently only includes the local QP number: this matches
the IB spec, but seems mostly useless. The following patch replaces
this with the pointer to qp itself, and updates all low level drivers
and all users.
This has the following advantages:
- Ability to get a per-qp context through wc->qp->qp_context
- Existing drivers already have the qp pointer ready in poll cq, so
this change actually saves a tiny bit (extra memory read) on data path
(for ehca it would actually be expensive to find the QP pointer when
polling a CQ, but ehca does not support SRQ so we can leave wc->qp as
NULL for ehca)
- Users that need the QP number can still get it through wc->qp->qp_num
Use case:
In IPoIB connected mode code, I have a common CQ shared by multiple
QPs. To track connection usage, I need a way to get at some per-QP
context upon the completion, and I would like to avoid allocating
context object per work request just to stick a QP pointer into it.
With this code, I can just use wc->qp->qp_context.
Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il>
The PSN used to generate the request following a RDMA read was
incorrect and some state booking wasn't maintained correctly. This
patch fixes that.
If the receiver goes into the error state, we need to flush the
posted receive WQEs.
This is required for IB conformance (spec ch. 9.6.1.5).
The sender requests an ACK every 1/2 MB to avoid retransmit timeouts that
were causing MVAPICH mod_bw to fail after a predictable number of sends.
A lot of ipath layer code was only called in one place. Now that the
ipath_core and ib_ipath drivers are merged, it's more sensible to simply
inline the simple stuff that the layer code was doing.
Remove ips namespace from infinipath drivers. This renames ips_common.h to
ipath_common.h. Definitions, data structures, etc. that were not used by
kernel modules have moved to user-only headers. All names including ips have
been renamed to ipath. Some names have had an ipath prefix added.
Signed-off-by: Christian Bell <christian.bell@qlogic.com>
Cc: "Michael S. Tsirkin" <mst@mellanox.co.il>
Cc: Roland Dreier <rolandd@cisco.com>
This patch separates QP state used for sending and receiving RC packets so the
processing in the receive interrupt handler can be done mostly without locks
being held. ACK packets are now sent without requiring synchronization with
the send tasklet.
name
Per Andrew's request.
Signed-off-by: Bryan O'Sullivan <bos@pathscale.com>
This is an implementation of the Infiniband RC ("reliable connection")
protocol.
