path: root/drivers/infiniband/hw/ipath/ipath_ruc.c
2008-05-13IB/ipath: Fix many locking issues when switching to error stateRalph Campbell
The send DMA hardware queue voided a number of prior assumptions about when a send is complete which led to completions being generated out of order. There were also a number of locking issues when switching the QP to the error or reset states, and we implement the IB_QPS_SQD state. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-05-13IB/ipath: Fix RC and UC error handlingRalph Campbell
When errors are detected in RC, the QP should transition to the IB_QPS_ERR state, not the IB_QPS_SQE state. Also, when the error is on the responder side, the receive work completion error was incorrect (remote vs. local). Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-05-07IB/ipath: Need to always request and handle PIO avail interruptsDave Olson
Now that we always use PIO for vl15 on 7220, we could get stuck forever if we happened to run out of PIO buffers from the verbs code, because the setup code wouldn't run; the interrupt was also ignored if SDMA was supported. We also have to reduce the pio update threshold if we have fewer kernel buffers than the existing threshold. Clean up the initialization a bit to get ordering safer and more sensible, and use the existing ipath_chg_kernavail call to do init, rather than doing it separately. Drop unnecessary clearing of pio buffer on pio parity error. Drop incorrect updating of pioavailshadow when exitting freeze mode (software state may not match chip state if buffer has been allocated and not yet written). If we couldn't get a kernel buffer for a while, make sure we are in sync with hardware, mainly to handle the exitting freeze case. Signed-off-by: Dave Olson <dave.olson@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-04-16IB/core: Add support for "send with invalidate" work requestsRoland Dreier
Add a new IB_WR_SEND_WITH_INV send opcode that can be used to mark a "send with invalidate" work request as defined in the iWARP verbs and the InfiniBand base memory management extensions. Also put "imm_data" and a new "invalidate_rkey" member in a new "ex" union in struct ib_send_wr. The invalidate_rkey member can be used to pass in an R_Key/STag to be invalidated. Add this new union to struct ib_uverbs_send_wr. Add code to copy the invalidate_rkey field in ib_uverbs_post_send(). Fix up low-level drivers to deal with the change to struct ib_send_wr, and just remove the imm_data initialization from net/sunrpc/xprtrdma/, since that code never does any send with immediate operations. Also, move the existing IB_DEVICE_SEND_W_INV flag to a new bit, since the iWARP drivers currently in the tree set the bit. The amso1100 driver at least will silently fail to honor the IB_SEND_INVALIDATE bit if passed in as part of userspace send requests (since it does not implement kernel bypass work request queueing). Remove the flag from all existing drivers that set it until we know which ones are OK. The values chosen for the new flag is not consecutive to avoid clashing with flags defined in the XRC patches, which are not merged yet but which are already in use and are likely to be merged soon. This resurrects a patch sent long ago by Mikkel Hagen <mhagen@iol.unh.edu>. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-04-16IB/ipath: add calls to new 7220 code and enable in buildDave Olson
This patch adds the initialization calls into the new 7220 HCA files, changes the Makefile to compile and link the new files, and code to handle send DMA. Signed-off-by: Dave Olson <dave.olson@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/ipath: Fix RNR NAK handlingRalph Campbell
This patch fixes a couple of minor problems with RNR NAK handling: - The insertion sort was causing extra delay when inserting ahead vs. behind an existing entry on the list. - A resend of a first packet of a message which is still not ready, needs another RNR NAK (i.e., it was suppressed when it shouldn't). - Also, the resend tasklet doesn't need to be woken up unless the ACK/NAK actually indicates progress has been made. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/ipath: Fix sendctrl lockingJohn Gregor
Code review pointed out that the locking around uses of ipath_sendctrl and kr_sendctrl were, in several places, incorrect and/or inconsistent. Signed-off-by: John Gregor <john.gregor@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-10-30IB/ipath: Fix a race where s_last is updated without lock heldRalph Campbell
There is a small window where a send work queue entry could be overwritten by ib_post_send() because s_last is updated before the entry is read. This patch closes the window by acquiring the lock and updating the last send work queue entry index after reading the wr_id. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-10-09IB/ipath: Change UD to queue work requests like RC & UCRalph Campbell
The code to post UD sends tried to process work requests at the time ib_post_send() is called without using a WQE queue. This was fine as long as HW resources were available for sending a packet. This patch changes UD to be handled more like RC and UC and shares more code. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-07-17IB/ipath: Make a few functions staticRoland Dreier
Make some functions that are only used in a single .c file static. In addition to being a cleanup, this shrinks the generated code. On x86_64: add/remove: 1/3 grow/shrink: 2/1 up/down: 4777/-4956 (-179) function old new delta handle_errors - 3994 +3994 __verbs_timer 42 710 +668 ipath_do_ruc_send 2131 2246 +115 ipath_no_bufs_available 136 - -136 ipath_disarm_senderrbufs 639 - -639 ipath_ib_timer 658 - -658 ipath_intr 5878 2355 -3523 Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-07-09IB/ipath: Add barrier before updating WC head in shared memoryRalph Campbell
Add a barrier to make sure the CPU doesn't reorder writes to memory, since user programs can be polling on the head index update and the entry should be written before that. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-07-09IB/ipath: Update copyright datesJohn Gregor
Now that it's June, it's about time to update the copyright notices of files that have changed. Signed-off-by: John Gregor <john.gregor@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-07-09IB/ipath: Send ACK invalid where appropriateRobert Walsh
The IB specification ch. 9.9.3 table 58 says that a QP which isn't set up for the operation should return a NAK invalid request. Signed-off-by: Robert Walsh <robert.walsh@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-07-09IB/ipath: Fix possible data corruption if multiple SGEs used for receiveRalph Campbell
The code to copy data from the receive queue buffers to the IB SGEs doesn't check the SGE length, only the memory region/page length when copying data. This could overwrite parts of the user's memory that were not intended to be written. It can only happen if multiple SGEs are used to describe a receive buffer which almost never happens in practice. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-07-09IB/ipath: Wait for PIO available interruptRalph Campbell
The send function is called when posting new send work requests. There is no point in trying to send a packet if the QP is already waiting for a HW send buffer so don't clear the busy bit until the buffer available interrupt happens. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-07-09IB/ipath: Fix local loopback bug when waiting for resourcesRalph Campbell
This patch fixes a minor bug where the wrong QP was checked for a send work request that should wait for an RNR timeout. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-04-18IB/ipath: Support larger IB_QP_MAX_DEST_RD_ATOMIC and IB_QP_MAX_QP_RD_ATOMICRalph Campbell
This patch adds support for multiple RDMA reads and atomics to be sent before an ACK is required to be seen by the requester. Signed-off-by: Bryan O'Sullivan <bryan.osullivan@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-04-18IB/ipath: NMI cpu lockup if local loopback usedRalph Campbell
If a post send is done in loopback and there is no receive queue entry, the sending QP is put on a timeout list for a while so the receiver has a chance to post a receive buffer. If the another post send is done, the code incorrectly tried to put the QP on the timeout list again an corrupted the timeout list. This eventually leads to a spin lock deadlock NMI due to the timer function looping forever with the lock held. Signed-off-by: Bryan O'Sullivan <bryan.osullivan@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-04-18IB/ipath: Fix SRQ limit event causing dropped CQ entryRalph Campbell
A silly programming error causes a CQ entry to not be generated if a SRQ limit event is generated. Signed-off-by: Bryan O'Sullivan <bryan.osullivan@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-02-04IB: Return qp pointer as part of ib_wcMichael S. Tsirkin
struct ib_wc currently only includes the local QP number: this matches the IB spec, but seems mostly useless. The following patch replaces this with the pointer to qp itself, and updates all low level drivers and all users. This has the following advantages: - Ability to get a per-qp context through wc->qp->qp_context - Existing drivers already have the qp pointer ready in poll cq, so this change actually saves a tiny bit (extra memory read) on data path (for ehca it would actually be expensive to find the QP pointer when polling a CQ, but ehca does not support SRQ so we can leave wc->qp as NULL for ehca) - Users that need the QP number can still get it through wc->qp->qp_num Use case: In IPoIB connected mode code, I have a common CQ shared by multiple QPs. To track connection usage, I need a way to get at some per-QP context upon the completion, and I would like to avoid allocating context object per work request just to stick a QP pointer into it. With this code, I can just use wc->qp->qp_context. Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-28IB/ipath: Flush RWQEs if access error or invalid error seenBryan O'Sullivan
If the receiver goes into the error state, we need to flush the posted receive WQEs. Signed-off-by: Bryan O'Sullivan <bryan.osullivan@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-28IB/ipath: Ensure that PD of MR matches PD of QP checking the RkeyBryan O'Sullivan
2006-09-22IB/ipath: simplify layering codeBryan O'Sullivan
A lot of ipath layer code was only called in one place. Now that the ipath_core and ib_ipath drivers are merged, it's more sensible to simply inline the simple stuff that the layer code was doing. Signed-off-by: Bryan O'Sullivan <bryan.osullivan@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB/ipath: Performance improvements via mmap of queuesRalph Campbell
Improve performance of userspace post receive, post SRQ receive, and poll CQ operations for ipath by allowing userspace to directly mmap() receive queues and completion queues. This eliminates the copying between userspace and the kernel in the data path. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-07-01[PATCH] IB/ipath: namespace cleanup: replace ips with ipathBryan O'Sullivan
Remove ips namespace from infinipath drivers. This renames ips_common.h to ipath_common.h. Definitions, data structures, etc. that were not used by kernel modules have moved to user-only headers. All names including ips have been renamed to ipath. Some names have had an ipath prefix added. Signed-off-by: Christian Bell <christian.bell@qlogic.com> Signed-off-by: Bryan O'Sullivan <bryan.osullivan@qlogic.com> Cc: "Michael S. Tsirkin" <mst@mellanox.co.il> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-01[PATCH] IB/ipath: rC receive interrupt performance changesBryan O'Sullivan
This patch separates QP state used for sending and receiving RC packets so the processing in the receive interrupt handler can be done mostly without locks being held. ACK packets are now sent without requiring synchronization with the send tasklet. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Bryan O'Sullivan <bryan.osullivan@qlogic.com> Cc: "Michael S. Tsirkin" <mst@mellanox.co.il> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-01[PATCH] IB/ipath: share more common code between RC and UC protocolsBryan O'Sullivan
2006-07-01[PATCH] IB/ipath: update copyrights and other strings to reflect new company ↵Bryan O'Sullivan
name Signed-off-by: Bryan O'Sullivan <bryan.osullivan@qlogic.com> Cc: "Michael S. Tsirkin" <mst@mellanox.co.il> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-23IB/ipath: replace uses of LIST_POISONBryan O'Sullivan
Per Andrew's request. Signed-off-by: Bryan O'Sullivan <bos@pathscale.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-05-01IB/ipath: simplify RC send postingBryan O'Sullivan
Remove some unnecessarily complicated tests. Signed-off-by: Bryan O'Sullivan <bos@pathscale.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-03-31IB/ipath: misc infiniband code, part 2Bryan O'Sullivan
Management datagram support, queue pairs, and reliable and unreliable connections. Signed-off-by: Bryan O'Sullivan <bos@pathscale.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
