Add a new IB_WR_SEND_WITH_INV send opcode that can be used to mark a
"send with invalidate" work request as defined in the iWARP verbs and
the InfiniBand base memory management extensions. Also put "imm_data"
and a new "invalidate_rkey" member in a new "ex" union in struct
ib_send_wr. The invalidate_rkey member can be used to pass in an
R_Key/STag to be invalidated. Add this new union to struct
ib_uverbs_send_wr. Add code to copy the invalidate_rkey field in
ib_uverbs_post_send().
Fix up low-level drivers to deal with the change to struct ib_send_wr,
and just remove the imm_data initialization from net/sunrpc/xprtrdma/,
since that code never does any send with immediate operations.
Also, move the existing IB_DEVICE_SEND_W_INV flag to a new bit, since
the iWARP drivers currently in the tree set the bit. The amso1100
driver at least will silently fail to honor the IB_SEND_INVALIDATE bit
if passed in as part of userspace send requests (since it does not
implement kernel bypass work request queueing). Remove the flag from
all existing drivers that set it until we know which ones are OK.
The values chosen for the new flag is not consecutive to avoid clashing
with flags defined in the XRC patches, which are not merged yet but
which are already in use and are likely to be merged soon.
This resurrects a patch sent long ago by Mikkel Hagen <mhagen@iol.unh.edu>.
Signed-off-by: Roland Dreier <rolandd@cisco.com>
This patch fixes a bug in the receive processing for UC RDMA WRITE with
immediate which caused the last packet to be dropped.
Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com>
The code to post UD sends tried to process work requests at the time
ib_post_send() is called without using a WQE queue. This was fine as
long as HW resources were available for sending a packet. This patch
changes UD to be handled more like RC and UC and shares more code.
Now that it's June, it's about time to update
the copyright notices of files that have changed.
Signed-off-by: John Gregor <john.gregor@qlogic.com>
According to chapter 17.2.8.1.1, QPs start in the migrated state and
should send packets with the M bit set in the BTH.
This patch fixes a bug introduced when moving some code around for
readability.
Setting the wqe pointer at the end of the function is a NOP since it
isn't used. Move it back to where it is used.
This patch adds support for multiple RDMA reads and atomics to be sent
before an ACK is required to be seen by the requester.
Signed-off-by: Bryan O'Sullivan <bryan.osullivan@qlogic.com>
struct ib_wc currently only includes the local QP number: this matches
the IB spec, but seems mostly useless. The following patch replaces
this with the pointer to qp itself, and updates all low level drivers
and all users.
This has the following advantages:
- Ability to get a per-qp context through wc->qp->qp_context
- Existing drivers already have the qp pointer ready in poll cq, so
this change actually saves a tiny bit (extra memory read) on data path
(for ehca it would actually be expensive to find the QP pointer when
polling a CQ, but ehca does not support SRQ so we can leave wc->qp as
NULL for ehca)
- Users that need the QP number can still get it through wc->qp->qp_num
Use case:
In IPoIB connected mode code, I have a common CQ shared by multiple
QPs. To track connection usage, I need a way to get at some per-QP
context upon the completion, and I would like to avoid allocating
context object per work request just to stick a QP pointer into it.
With this code, I can just use wc->qp->qp_context.
Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il>
This is required for IB conformance (spec ch. 9.6.1.5).
A lot of ipath layer code was only called in one place. Now that the
ipath_core and ib_ipath drivers are merged, it's more sensible to simply
inline the simple stuff that the layer code was doing.
Remove ips namespace from infinipath drivers. This renames ips_common.h to
ipath_common.h. Definitions, data structures, etc. that were not used by
kernel modules have moved to user-only headers. All names including ips have
been renamed to ipath. Some names have had an ipath prefix added.
Signed-off-by: Christian Bell <christian.bell@qlogic.com>
Cc: "Michael S. Tsirkin" <mst@mellanox.co.il>
Cc: Roland Dreier <rolandd@cisco.com>
This patch separates QP state used for sending and receiving RC packets so the
processing in the receive interrupt handler can be done mostly without locks
being held. ACK packets are now sent without requiring synchronization with
the send tasklet.
name
These files implement the Infiniband UC ("unreliable connection") and UD
("unreliable datagram") protocols.
Signed-off-by: Bryan O'Sullivan <bos@pathscale.com>
