The driver supports a few features (RNR NAK, port active event, SRQ
resize) that were not reported in the device capability flags. This
patch fixes that.
Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
The send DMA hardware queue voided a number of prior assumptions about
when a send is complete which led to completions being generated out of
order. There were also a number of locking issues when switching the QP
to the error or reset states, and we implement the IB_QPS_SQD state.
When errors are detected in RC, the QP should transition to the
IB_QPS_ERR state, not the IB_QPS_SQE state. Also, when the error is on
the responder side, the receive work completion error was incorrect
(remote vs. local).
If a send work request has immediate errors and is not put on the
send queue, we shouldn't update any of the QP state.
The increment of the SSN wasn't obeying this.
Commit 124b4dcb ("IB/ipath: add calls to new 7220 code and enable in
build") inadvertently added core to set dev->class_dev.dev back into
ib_ipath. This is completely redundant since commit 1912ffbb ("IB: Set
class_dev->dev in core for nice device symlink"), which removed
class_dev setting from low-level drivers, and also will break the build
when class_dev is removed completely from struct ib_device.
Describe disable_sma parameter with its name rather than the internal
ib_ipath_disable_sma variable name, so that the description shows up
properly in modinfo.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Acked-by: Ralph Campbell <ralph.campbell@qlogic.com>
This converts the main ib_device to use struct device instead of struct
class_device as class_device is going away.
Signed-off-by: Tony Jones <tonyj@suse.de>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Cc: Roland Dreier <rolandd@cisco.com>
Cc: Sean Hefty <sean.hefty@intel.com>
Cc: Hal Rosenstock <hal.rosenstock@gmail.com>
This patch adds the initialization calls into the new 7220 HCA files,
changes the Makefile to compile and link the new files, and code to
handle send DMA.
Signed-off-by: Dave Olson <dave.olson@qlogic.com>
A fixed partitioning of send buffers is determined at driver load time
for user processes and kernel use. Since send buffers are a scarce
resource, it makes sense to allow the kernel to use the buffers if they
are not in use by a user process.
Also, eliminate code duplication for ipath_force_pio_avail_update().
This patch adds code to get/set portinfo to support multiple link speeds
and widths.
Enable use of 4KB MTU. Since the driver uses more pinned memory for
receive buffers when the 4KB MTU is enabled, whether or not the fabric
supports that MTU, add a "mtu4096" module parameter that can be used to
limit the MTU to 2KB when it is known that 4KB MTUs can't be used
anyway.
Add new mappings from port physical state (a HW register value) to the
IB SubnGet(PortInfo) port physical state.
Add support for QLogic HCAs which have hardware performance sampling
registers for PortSamplesControl and PortSamplesResult MADs.
The error codes for ib_post_send(), ib_post_recv(), and ib_post_srq_recv()
were inconsistent. Use EINVAL for too many SGEs and ENOMEM for too many
WRs.
The link state event calls were being generated when the SM told the SMA
to change link states. This works for IB_EVENT_PORT_ACTIVE but not if
the link goes down and stays down. The fix is to generate event calls
from the interrupt handler when the HW link state changes.
The LMC value was being saved by the SMA in two places. This patch
cleans it up so only one copy is kept.
Follow the IB spec. (C10-96) for post send which states that a flushed
completion event should be generated for work requests posted when a QP
is in the error state.
The code to post UD sends tried to process work requests at the time
ib_post_send() is called without using a WQE queue. This was fine as
long as HW resources were available for sending a packet. This patch
changes UD to be handled more like RC and UC and shares more code.
Different processors have different ordering restrictions for write
combining. By taking advantage of this, we can eliminate some write
barriers when writing to the send buffers.
Make some functions that are only used in a single .c file static. In
addition to being a cleanup, this shrinks the generated code. On x86_64:
add/remove: 1/3 grow/shrink: 2/1 up/down: 4777/-4956 (-179)
function old new delta
handle_errors - 3994 +3994
__verbs_timer 42 710 +668
ipath_do_ruc_send 2131 2246 +115
ipath_no_bufs_available 136 - -136
ipath_disarm_senderrbufs 639 - -639
ipath_ib_timer 658 - -658
ipath_intr 5878 2355 -3523
Clean up some code by removing support for some older pre-production
HTX InfiniPath cards.
Add a barrier to make sure the CPU doesn't reorder writes to memory,
since user programs can be polling on the head index update and the
entry should be written before that.
Now that it's June, it's about time to update
the copyright notices of files that have changed.
Signed-off-by: John Gregor <john.gregor@qlogic.com>
The code to copy data from the receive queue buffers to the IB SGEs
doesn't check the SGE length, only the memory region/page length when
copying data. This could overwrite parts of the user's memory that
were not intended to be written. It can only happen if multiple SGEs
are used to describe a receive buffer which almost never happens in
practice.
The send function is called when posting new send work requests.
There is no point in trying to send a packet if the QP is already
waiting for a HW send buffer so don't clear the busy bit until the
buffer available interrupt happens.
In ipath_query_device(), some of the struct ib_device_attr fields were
not being initialized.
Signed-off-by: Robert Walsh <robert.walsh@qlogic.com>
Although our chip supports 4K MTUs, our driver doesn't yet support
this feature, so limit the maximum MTU to 2K until we get support for
4K MTUs implemented.
Once upon a time, GPIO interrupts were rare. But then a chip bug in
the waldo series forced the use of a GPIO interrupt to signal packet
reception. This greatly increased the frequency of GPIO interrupts
which have the gpio_mask bits set on the waldo chips. Other bits in
the gpio_status register are used for I2C clock and data lines, these
bits are usually on. An "unlikely" annotation leftover from the old
days was improperly applied to these bits, and an unnecessary chip
mmio read was being accessed in the interrupt fast path on waldo.
Remove the stagnant unlikely annotation in the interrupt handler and
keep a shadow copy of the gpio_mask register to avoid the slow mmio
read when testing for interruptable GPIO bits.
Signed-off-by: Arthur Jones <arthur.jones@qlogic.com>
Add a num_comp_vectors member to struct ib_device and extend
ib_create_cq() to pass in a comp_vector parameter -- this parallels
the userspace libibverbs API. Update all hardware drivers to set
num_comp_vectors to 1 and have all ULPs pass 0 for the comp_vector
value. Pass the value of num_comp_vectors to userspace rather than
hard-coding a value of 1.
We want multiple CQ event vector support (via MSI-X or similar for
adapters that can generate multiple interrupts), but it's not clear
how many vectors we want, or how we want to deal with policy issues
such as how to decide which vector to use or how to set up interrupt
affinity. This patch is useful for experimenting, since no core
changes will be necessary when updating a driver to support multiple
vectors, and we know that we want to make at least these changes
anyway.
Signed-off-by: Michael S. Tsirkin <mst@dev.mellanox.co.il>
Fix the pending mmap code so it doesn't corrupt the list of pending
mmaps and crash the machine when pending mmaps are destroyed without
first being mapped. Also, remove an unused variable, and use standard
kernel lists instead of our own homebrewed linked list implementation
to keep the pending mmap list.
All RDMA drivers except ehca set class_dev->dev to their dma_device
value (ehca leaves this unset). dma_device is the only value that
makes any sense, so move this assignment to core/sysfs.c. This reduce
the duplicated code in the rest of the drivers and gives ehca a nice
/sys/class/infiniband/ehcaX/device symlink.
Signed-off-by: Joachim Fenkes <fenkes@de.ibm.com>
This patch fixes a bug where multicast packets without a GRH were not
being dropped as per the IB spec.
Signed-off-by: Bryan O'Sullivan <bryan.osullivan@qlogic.com>
This patch adds support for multiple RDMA reads and atomics to be sent
before an ACK is required to be seen by the requester.
This patch implements the interposing DMA mapping functions to allow
support for IOMMUs and remove the dependence on phys_to_virt() and
bus_to_virt().
The array has only 5 entries, so [5] should have been [4].
In some places, particularly drivers and __init code, the init utsns is the
appropriate one to use. This patch replaces those with a the init_utsname
helper.
Changes: Removed several uses of init_utsname(). Hope I picked all the
right ones in net/ipv4/ipconfig.c. These are now changed to
utsname() (the per-process namespace utsname) in the previous
patch (2/7)
[akpm@osdl.org: CIFS fix]
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
Cc: Kirill Korotaev <dev@openvz.org>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Herbert Poetzl <herbert@13thfloor.at>
Cc: Andrey Savochkin <saw@sw.ru>
Cc: Serge Hallyn <serue@us.ibm.com>
This also entailed a little GPIO-interrupt general cleanup.
The sender requests an ACK every 1/2 MB to avoid retransmit timeouts that
were causing MVAPICH mod_bw to fail after a predictable number of sends.
Modifications to the existing rdma header files, core files, drivers,
and ulp files to support iWARP, including:
- Hook iWARP CM into the build system and use it in rdma_cm.
- Convert enum ib_node_type to enum rdma_node_type, which includes
the possibility of RDMA_NODE_RNIC, and update everything for this.
Signed-off-by: Tom Tucker <tom@opengridcomputing.com>
Signed-off-by: Steve Wise <swise@opengridcomputing.com>
This is useful for testing purposes.
When we first submitted a userspace subnet management agent, it was
rejected, so we left it out of the final driver submission. This patch
removes a number of vestigial references to it.
A lot of ipath layer code was only called in one place. Now that the
ipath_core and ib_ipath drivers are merged, it's more sensible to simply
inline the simple stuff that the layer code was doing.
There is little point in keeping the two drivers separate, so we are
merging them.
Improve performance of userspace post receive, post SRQ receive, and
poll CQ operations for ipath by allowing userspace to directly mmap()
receive queues and completion queues. This eliminates the copying
between userspace and the kernel in the data path.
