path: root/drivers/infiniband/hw/mlx4/mr.c
2008-04-29IB: expand ib_umem_get() prototypeArthur Kepner
Add a new parameter, dmasync, to the ib_umem_get() prototype. Use dmasync = 1 when mapping user-allocated CQs with ib_umem_get(). Signed-off-by: Arthur Kepner <akepner@sgi.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Jes Sorensen <jes@sgi.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Roland Dreier <rdreier@cisco.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: David Miller <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14IB/mlx4: mlx4_ib_fmr_alloc() should call mlx4_fmr_enable()Jack Morgenstein
Currently mlx4_ib_fmr_alloc() calls mlx4_mr_enable() instead of mlx4_fmr_enable(). The two functions are equivalent at the moment, but this is not really correct (and the change is needed to fix a bug). Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-10-09IB/mlx4: Implement FMRsJack Morgenstein
Implement FMRs for mlx4. This is an adaptation of code from mthca. Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il> Signed-off-by: Michael S. Tsirkin <mst@dev.mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-10-09mlx4_core: Write MTTs from CPU instead with of WRITE_MTT FW commandJack Morgenstein
Write MTT entries directly to ICM from the driver (eliminating use of WRITE_MTT command). This reduces the number of FW commands needed to register an MR by at least a factor of 2 and speeds up memory registration significantly. This code will also be used to implement FMRs. Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il> Signed-off-by: Michael S. Tsirkin <mst@dev.mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-05-08IB/mlx4: Add a driver Mellanox ConnectX InfiniBand adaptersRoland Dreier
Add an InfiniBand driver for Mellanox ConnectX adapters. Because these adapters can also be used as ethernet NICs and Fibre Channel HBAs, the driver is split into two modules: mlx4_core: Handles low-level things like device initialization and processing firmware commands. Also controls resource allocation so that the InfiniBand, ethernet and FC functions can share a device without stepping on each other. mlx4_ib: Handles InfiniBand-specific things; plugs into the InfiniBand midlayer. Signed-off-by: Roland Dreier <rolandd@cisco.com>
