[ Upstream commit 5f22a1d87c5315a98981ecf93cd8de226cffe6ca ]
Maximal message should be used as a limit to the max message payload allowed,
without the headers. The ConnectX-3 check is done against this value includes
the headers. When the payload is 4K this will cause the NIC to drop packets.
Increase maximal message to 8K as workaround, this shouldn't change current
behaviour because we continue to set the MTU to 4k.
To reproduce;
set MTU to 4296 on the corresponding interface, for example:
ifconfig eth0 mtu 4296 (both server and client)
On server:
ib_send_bw -c UD -d mlx4_0 -s 4096 -n 1000000 -i1 -m 4096
On client:
ib_send_bw -d mlx4_0 -c UD <server_ip> -s 4096 -n 1000000 -i 1 -m 4096
Fixes: 6e0d733d9215 ("IB/mlx4: Allow 4K messages for UD QPs")
Signed-off-by: Mark Bloch <markb@mellanox.com>
Reviewed-by: Majd Dibbiny <majd@mellanox.com>
Signed-off-by: Leon Romanovsky <leon@kernel.org>
Signed-off-by: Doug Ledford <dledford@redhat.com>
commit c482af646d0809a8d5e1b7f4398cce3592589b98 upstream.
For non-special QPs, the port value becomes non-zero only at the
RESET-to-INIT transition. If the QP has not undergone that transition,
its port number value is still zero.
If such a QP is destroyed before being moved out of the RESET state,
subtracting one from the qp port number results in a negative value.
Using that negative value as an index into the qp1_proxy array
results in an out-of-bounds array reference.
Fix this by testing that the QP type is one that uses qp1_proxy before
using the port number. For special QPs of all types, the port number is
specified at QP creation time.
Fixes: 9433c188915c ("IB/mlx4: Invoke UPDATE_QP for proxy QP1 on MAC changes")
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
commit 8ec07bf8a8b57d6c58927a16a0a22c0115cf2855 upstream.
When sending QP1 MAD packets which use a GRH, the source GID
(which consists of the 64-bit subnet prefix, and the 64 bit port GUID)
must be included in the packet GRH.
For SR-IOV, a GID cache is used, since the source GID needs to be the
slave's source GID, and not the Hypervisor's GID. This cache also
included a subnet_prefix. Unfortunately, the subnet_prefix field in
the cache was never initialized (to the default subnet prefix 0xfe80::0).
As a result, this field remained all zeroes. Therefore, when SR-IOV
was active, all QP1 packets which included a GRH had a source GID
subnet prefix of all-zeroes.
However, the subnet-prefix should initially be 0xfe80::0 (the default
subnet prefix). In addition, if OpenSM modifies a port's subnet prefix,
the new subnet prefix must be used in the GRH when sending QP1 packets.
To fix this we now initialize the subnet prefix in the SR-IOV GID cache
to the default subnet prefix. We update the cached value if/when OpenSM
modifies the port's subnet prefix. We take this cached value when sending
QP1 packets when SR-IOV is active.
Note that the value is stored as an atomic64. This eliminates any need
for locking when the subnet prefix is being updated.
Note also that we depend on the FW generating the "port management change"
event for tracking subnet-prefix changes performed by OpenSM. If running
early FW (before 2.9.4630), subnet prefix changes will not be tracked (but
the default subnet prefix still will be stored in the cache; therefore
users who do not modify the subnet prefix will not have a problem).
IF there is a need for such tracking also for early FW, we will add that
capability in a subsequent patch.
Fixes: 1ffeb2eb8be9 ("IB/mlx4: SR-IOV IB context objects and proxy/tunnel SQP support")
commit baa0be7026e2f7d1d40bfd45909044169e9e3c68 upstream.
The indentation in the QP1 GRH flow in procedure build_mlx_header is
really confusing. Fix it, in preparation for a commit which touches
this code.
commit 5b420d9cf7382c6e1512e96e02d18842d272049c upstream.
When RC, UC, or RAW QPs are created, a qp object is allocated (kzalloc).
If at a later point (in procedure create_qp_common) the qp creation fails,
this qp object must be freed.
Fixes: 1ffeb2eb8be99 ("IB/mlx4: SR-IOV IB context objects and proxy/tunnel SQP support")
Signed-off-by: Dotan Barak <dotanb@dev.mellanox.co.il>
commit f2940e2c76bb554a7fbdd28ca5b90904117a9e96 upstream.
When calculating the required size of an RC QP send queue, leave
enough space for masked atomic operations, which require more space than
"regular" atomic operation.
Fixes: 6fa8f719844b ("IB/mlx4: Add support for masked atomic operations")
Signed-off-by: Yishai Hadas <yishaih@mellanox.com>
Reviewed-by: Jack Morgenstein <jackm@mellanox.co.il>
Reviewed-by: Eran Ben Elisha <eranbe@mellanox.com>
There are several hits that WR buffer allocation(kmalloc) failed.
It failed at order 3 and/or 4 contigous pages allocation. At the same time
there are actually 100MB+ free memory but well fragmented.
So try vmalloc when kmalloc failed.
Signed-off-by: Wengang Wang <wen.gang.wang@oracle.com>
Acked-by: Or Gerlitz <ogerlitz@mellanox.com>
No ULP uses it anymore, go ahead and remove it.
Signed-off-by: Sagi Grimberg <sagig@mellanox.com>
Acked-by: Christoph Hellwig <hch@lst.de>
Support the new memory registration API by allocating a
private page list array in mlx4_ib_mr and populate it when
mlx4_ib_map_mr_sg is invoked. Also, support IB_WR_REG_MR
by setting the exact WQE as IB_WR_FAST_REG_MR, just take the
needed information from different places:
- page_size, iova, length, access flags (ib_mr)
- page array (mlx4_ib_mr)
- key (ib_reg_wr)
The IB_WR_FAST_REG_MR handlers will be removed later when
all the ULPs will be converted.
Tested-by: Christoph Hellwig <hch@lst.de>
Previously, vlan id and source MAC were used from QP attributes. Since
the net device is now stored in the GID attributes, they could be used
instead of getting this information from the QP attributes.
IB_QP_SMAC, IB_QP_ALT_SMAC, IB_QP_VID and IB_QP_ALT_VID were removed
because there is no known libibverbs that uses them.
This commit also modifies the vendors (mlx4, ocrdma) drivers in order
to use the new approach.
ocrdma driver changes were done by Somnath Kotur <Somnath.Kotur@Avagotech.Com>
Signed-off-by: Matan Barak <matanb@mellanox.com>
Adding an ability to query the IB cache by a netdev and get the
attributes of a GID. These parameters are necessary in order to
successfully resolve the required GID (when the netdevice is known)
and get the Ethernet L2 attributes from a GID.
Reviewed-By: Devesh Sharma <devesh.sharma@avagotech.com>
MLX4_IB_QP_BLOCK_MULTICAST_LOOPBACK is now supported downstream.
In addition, this flag was supported only for IB_QPT_UD, now, with the
new implementation it is supported for all QP types.
Support IB_USER_VERBS_EX_CMD_CREATE_QP in order to get the flag from
user space using the extension create qp command.
Signed-off-by: Eran Ben Elisha <eranbe@mellanox.com>
Current implementation for MLX4_IB_QP_BLOCK_MULTICAST_LOOPBACK is not
supported when link layer is Ethernet.
This patch will add counter based implementation for multicast loopback
prevention. HW can drop multicast loopback packets if sender QP counter
index is equal to receiver QP counter index. If qp flag
MLX4_IB_QP_BLOCK_MULTICAST_LOOPBACK is set and link layer is Ethernet,
create a new counter and attach it to the QP so it will continue
receiving multicast loopback traffic but it's own.
The decision if to create a new counter is being made at the qp
modification to RTR after the QP's port is set. When QP is destroyed or
moved back to reset state, delete the counter.
This is an infrastructure step for allocating and attaching more than
one counter to QPs on the same port. Allocate a counters table and
manage the insertion and removals of the counters in load and unload of
mlx4 IB.
This patch split up struct ib_send_wr so that all non-trivial verbs
use their own structure which embedds struct ib_send_wr. This dramaticly
shrinks the size of a WR for most common operations:
sizeof(struct ib_send_wr) (old): 96
sizeof(struct ib_send_wr): 48
sizeof(struct ib_rdma_wr): 64
sizeof(struct ib_atomic_wr): 96
sizeof(struct ib_ud_wr): 88
sizeof(struct ib_fast_reg_wr): 88
sizeof(struct ib_bind_mw_wr): 96
sizeof(struct ib_sig_handover_wr): 80
And with Sagi's pending MR rework the fast registration WR will also be
down to a reasonable size:
sizeof(struct ib_fastreg_wr): 64
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> [srp, srpt]
Reviewed-by: Chuck Lever <chuck.lever@oracle.com> [sunrpc]
Tested-by: Haggai Eran <haggaie@mellanox.com>
Tested-by: Sagi Grimberg <sagig@mellanox.com>
Tested-by: Steve Wise <swise@opengridcomputing.com>
Manage RoCE gid table with logic in IB/core, which is common to all
vendors, and remove the mechanism from the mlx4 IB driver.
Since management of the GID cache may lead to index mismatch with the
hardware GID table, a translation between indexes is required when
modifying a QP or creating an address handle.
Signed-off-by: Moni Shoua <monis@mellanox.com>
This is an infrastructure step to attach all the QPs opened from the
IB driver to a counter in order to collect VF stats from the PF using
those counters.
If the port's type is Ethernet, the counter policy demands two counters
per port (one for RoCE and one for Ethernet). The port default counter
(allocated in mlx4_core) is used for the Ethernet netdev QPs and we
allocate another counter for RoCE.
If the port's traffic is Infiniband, the counter policy demands
one counter per port, so it can use the port's default counter.
Also, Add 'allocated' flag for each counter in order to clean it at
unload.
Signed-off-by: Hadar Hen Zion <hadarh@mellanox.com>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
Reserve the last valid counter index for "sink" counter, when a
new counter cannot be allocated, the driver will use this counter.
In order to avoid allocating this counter on any other flow, fix the
indices bitmap allocation range, and reserve the sink counter index.
Add macro for the sink counter index and replace all appearences of the
index with the macro.
into for-4.1
Since ib_dma_map_single can fail use ib_dma_mapping_error to check
for errors.
Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
Acked-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
The current code decreases from the mss size (which is the gso_size
from the kernel skb) the size of the packet headers.
It shouldn't do that because the mss that comes from the stack
(e.g IPoIB) includes only the tcp payload without the headers.
The result is indication to the HW that each packet that the HW sends
is smaller than what it could be, and too many packets will be sent
for big messages.
An easy way to demonstrate one more aspect of the problem is by
configuring the ipoib mtu to be less than 2*hlen (2*56) and then
run app sending big TCP messages. This will tell the HW to send packets
with giant (negative value which under unsigned arithmetics becomes
a huge positive one) length and the QP moves to SQE state.
Fixes: b832be1e4007 ('IB/mlx4: Add IPoIB LSO support')
Reported-by: Matthew Finlay <matt@mellanox.com>
Signed-off-by: Erez Shitrit <erezsh@mellanox.com>
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
Pull InfiniBand/RDMA updates from Roland Dreier:
- Re-enable on-demand paging changes with stable ABI
- Fairly large set of ocrdma HW driver fixes
- Some qib HW driver fixes
- Other miscellaneous changes
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (43 commits)
IB/qib: Add blank line after declaration
IB/qib: Fix checkpatch warnings
IB/mlx5: Enable the ODP capability query verb
IB/core: Add on demand paging caps to ib_uverbs_ex_query_device
IB/core: Add support for extended query device caps
RDMA/cxgb4: Don't hang threads forever waiting on WR replies
RDMA/ocrdma: Fix off by one in ocrdma_query_gid()
RDMA/ocrdma: Use unsigned for bit index
RDMA/ocrdma: Help gcc generate better code for ocrdma_srq_toggle_bit
RDMA/ocrdma: Update the ocrdma module version string
RDMA/ocrdma: set vlan present bit for user AH
RDMA/ocrdma: remove reference of ocrdma_dev out of ocrdma_qp structure
RDMA/ocrdma: Add support for interrupt moderation
RDMA/ocrdma: Honor return value of ocrdma_resolve_dmac
RDMA/ocrdma: Allow expansion of the SQ CQEs via buddy CQ expansion of the QP
RDMA/ocrdma: Discontinue support of RDMA-READ-WITH-INVALIDATE
RDMA/ocrdma: Host crash on destroying device resources
RDMA/ocrdma: Report correct state in ibv_query_qp
RDMA/ocrdma: Debugfs enhancments for ocrdma driver
RDMA/ocrdma: Report correct count of interrupt vectors while registering ocrdma device
In case handle_eth_ud_smac_index fails, we need to free the allocated resources.
Fixes: 2f5bb473681b ("mlx4: Add ref counting to port MAC table for RoCE")
Signed-off-by: Majd Dibbiny <majd@mellanox.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
The driver exposes interfaces that directly relate to HW state. Upon fatal
error, consumers of these interfaces (ULPs) that rely on completion of
all their posted work-request could hang, thereby introducing dependencies
in shutdown order. To prevent this from happening, we manage the
relevant resources (CQs, QPs) that are used by the device. Upon a fatal error,
we now generate simulated completions for outstanding WQEs that were not
completed at the time the HW was reset.
It includes invoking the completion event handler for all involved CQs so that
the ULPs will poll those CQs. When polled we return simulated CQEs with
IB_WC_WR_FLUSH_ERR return code enabling ULPs to clean up their resources and
not wait forever for completions upon receiving remove_one.
The above change requires an extra check in the data path to make sure that when
device is in error state, the simulated CQEs will be returned and no further
WQEs will be posted.
When the mlx4 IB (RoCE) device works in link aggregation mode, it
exposes a single port to upper layers. Therefore, applications always
set '1' in port_num attribute when modifying a QP or creating an address handle.
To make sure that a node uses all available ports the mlx4 driver will
override the port_num attribute with a round robin policy.
This function is implemented twice... get rid of one copy.
A0 hybrid steering is a form of high performance flow steering.
By using this mode, mlx4 cards use a fast limited table based steering,
in order to enable fast steering of unicast packets to a QP.
In order to implement A0 hybrid steering we allocate resources
from different zones:
(1) General range
(2) Special MAC-assigned QPs [RSS, Raw-Ethernet] each has its own region.
When we create a rss QP or a raw ethernet (A0 steerable and BF ready) QP,
we try hard to allocate the QP from range (2). Otherwise, we try hard not
to allocate from this range. However, when the system is pushed to its
limits and one needs every resource, the allocator uses every region it can.
Meaning, when we run out of raw-eth qps, the allocator allocates from the
general range (and the special-A0 area is no longer active). If we run out
of RSS qps, the mechanism tries to allocate from the raw-eth QP zone. If that
is also exhausted, the allocator will allocate from the general range
(and the A0 region is no longer active).
Note that if a raw-eth qp is allocated from the general range, it attempts
to allocate the range such that bits 6 and 7 (blueflame bits) in the
QP number are not set.
When the feature is used in SRIOV, the VF has to notify the PF what
kind of QP attributes it needs. In order to do that, along with the
"Eth QP blueflame" bit, we reserve a new "A0 steerable QP". According
to the combination of these bits, the PF tries to allocate a suitable QP.
In order to maintain backward compatibility (with older PFs), the PF
notifies which QP attributes it supports via QUERY_FUNC_CAP command.
When using BF (Blue-Flame), the QPN overrides the VLAN, CV, and SV fields
in the WQE. Thus, BF may only be used for QPNs with bits 6,7 unset.
The current Ethernet driver code reserves a Tx QP range with 256b alignment.
This is wrong because if there are more than 64 Tx QPs in use,
QPNs >= base + 65 will have bits 6/7 set.
This problem is not specific for the Ethernet driver, any entity that
tries to reserve more than 64 BF-enabled QPs should fail. Also, using
ranges is not necessary here and is wasteful.
The new mechanism introduced here will support reservation for
"Eth QPs eligible for BF" for all drivers: bare-metal, multi-PF, and VFs
(when hypervisors support WC in VMs). The flow we use is:
1. In mlx4_en, allocate Tx QPs one by one instead of a range allocation,
and request "BF enabled QPs" if BF is supported for the function
2. In the ALLOC_RES FW command, change param1 to:
a. param1[23:0] - number of QPs
b. param1[31-24] - flags controlling QPs reservation
Bit 31 refers to Eth blueflame supported QPs. Those QPs must have
bits 6 and 7 unset in order to be used in Ethernet.
Bits 24-30 of the flags are currently reserved.
When a function tries to allocate a QP, it states the required attributes
for this QP. Those attributes are considered "best-effort". If an attribute,
such as Ethernet BF enabled QP, is a must-have attribute, the function has
to check that attribute is supported before trying to do the allocation.
In a lower layer of the code, mlx4_qp_reserve_range masks out the bits
which are unsupported. If SRIOV is used, the PF validates those attributes
and masks out unsupported attributes as well. In order to notify VFs which
attributes are supported, the VF uses QUERY_FUNC_CAP command. This command's
mailbox is filled by the PF, which notifies which QP allocation attributes
it supports.
Signed-off-by: Eugenia Emantayev <eugenia@mellanox.co.il>
Pull infiniband/rdma fixes from Roland Dreier:
"Last late set of InfiniBand/RDMA fixes for 3.17:
- fixes for the new memory region re-registration support
- iSER initiator error path fixes
- grab bag of small fixes for the qib and ocrdma hardware drivers
- larger set of fixes for mlx4, especially in RoCE mode"
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (26 commits)
IB/mlx4: Fix VF mac handling in RoCE
IB/mlx4: Do not allow APM under RoCE
IB/mlx4: Don't update QP1 in native mode
IB/mlx4: Avoid accessing netdevice when building RoCE qp1 header
mlx4: Fix mlx4 reg/unreg mac to work properly with 0-mac addresses
IB/core: When marshaling uverbs path, clear unused fields
IB/mlx4: Avoid executing gid task when device is being removed
IB/mlx4: Fix lockdep splat for the iboe lock
IB/mlx4: Get upper dev addresses as RoCE GIDs when port comes up
IB/mlx4: Reorder steps in RoCE GID table initialization
IB/mlx4: Don't duplicate the default RoCE GID
IB/mlx4: Avoid null pointer dereference in mlx4_ib_scan_netdevs()
IB/iser: Bump version to 1.4.1
IB/iser: Allow bind only when connection state is UP
IB/iser: Fix RX/TX CQ resource leak on error flow
RDMA/ocrdma: Use right macro in query AH
RDMA/ocrdma: Resolve L2 address when creating user AH
mlx4: Correct error flows in rereg_mr
IB/qib: Correct reference counting in debugfs qp_stats
IPoIB: Remove unnecessary port query
We had several problems here. First, a race condition on QP1 mac
handling between mlx4_ib_update_qps and mlx4_ib_modify_qp, which is
fixed by taking the qp mutex in mlx4_ib_update_qps.
Also, qp->pri.smac_port was not updated in mlx4_ib_update_qps.
Last, in __mlx4_ib_modify_qp we did not properly handle the case where
the mac is zero, but port is non-zero.
Automatic Path Migration is not supported under RoCE. Therefore,
return a "not-supported" error if the caller attempts to set an
alternate path in a QP context.
In addition, if there are no IB ports configured, do not report
APM capability in the device flags returned by mlx4_ib_query_device.
The source MAC is needed in RoCE when building the QP1 header.
Currently, this is obtained from the source net device. However, the net
device may not yet exist, or can be destroyed in parallel to this QP1 send
operation (e.g through the VPI port change flow) so accessing it may cause
a kernel crash.
To fix this, we maintain a source MAC cache per port for the net device in
struct mlx4_ib_roce. This cached MAC is initialized to be the default MAC
address obtained during HCA initialization via QUERY_PORT. This cached MAC
is updated via the netdev event notifier handler.
Since the cached MAC is held in an atomic64 object, we do not need locking
when accessing it.
We wrongly tested QP context bits without BE conversion
as was spotted by sparse...
drivers/infiniband/hw/mlx4/qp.c:1685:38: sparse: restricted __be32 degrades to integer
Fix that!
Fixes: d2fce8a ('mlx4: Set user-space raw Ethernet QPs to properly handle VXLAN traffic')
Raw Ethernet QPs opened from user-space lack the proper setup to
recieve/handle VXLAN traffic when VXLAN offloads are enabled.
Fix that by adding a tunnel steering rule on top of the normal unicast
steering rule and set the tunnel_type field in the QP context.
Pull main InfiniBand/RDMA updates from Roland Dreier:
- add iWARP port mapper to avoid conflicts between RDMA and normal
stack TCP connections.
- fixes for i386 / x86-64 structure padding differences (ABI
compatibility for 32-on-64) from Yann Droneaud.
- a pile of SRP initiator fixes from Bart Van Assche.
- fixes for a writeback / memory allocation deadlock with NFS over
IPoIB connected mode from Jiri Kosina.
- the usual fixes and cleanups to mlx4, mlx5, cxgb4 and other low-level
drivers.
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (61 commits)
RDMA/cxgb4: Add support for iWARP Port Mapper user space service
RDMA/nes: Add support for iWARP Port Mapper user space service
RDMA/core: Add support for iWARP Port Mapper user space service
IB/mlx4: Fix gfp passing in create_qp_common()
IB/umad: Fix use-after-free on close
IB/core: Fix kobject leak on device register error flow
RDMA/cxgb4: add missing padding at end of struct c4iw_alloc_ucontext_resp
mlx4_core: Fix GFP flags parameters to be gfp_t
IB/core: Fix port kobject deletion during error flow
IB/core: Remove unneeded kobject_get/put calls
IB/core: Fix sparse warnings about redeclared functions
IB/mad: Fix sparse warning about gfp_t use
IB/mlx4: Implement IB_QP_CREATE_USE_GFP_NOIO
IB: Add a QP creation flag to use GFP_NOIO allocations
IB: Return error for unsupported QP creation flags
IB: Allow build of hw/ and ulp/ subdirectories independently
mlx4_core: Move handling of MLX4_QP_ST_MLX to proper switch statement
RDMA/cxgb4: Add missing padding at end of struct c4iw_create_cq_resp
IB/srp: Avoid problems if a header uses pr_fmt
IB/umad: Fix error handling
'mlx5', 'noio', 'ocrdma', 'qib', 'srp' and 'usnic' into for-next
There are two kzalloc() calls which were not converted to use value of
gfp passed to create_qp_common() instead of using hardcoded GFP_KERNEL
in 40f2287bd583 ("IB/mlx4: Implement IB_QP_CREATE_USE_GFP_NOIO"). Fix
this by passing gfp value down properly.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Modify the various routines used to allocate memory resources which
serve QPs in mlx4 to get an input GFP directive. Have the Ethernet
driver to use GFP_KERNEL in it's QP allocations as done prior to this
commit, and the IB driver to use GFP_NOIO when the IB verbs
IB_QP_CREATE_USE_GFP_NOIO QP creation flag is provided.
This commit adds the infrastructure for enabling selected VFs to
operate SMI (QP0) MADs without restriction.
Additionally, for these enabled VFs, their QP0 proxy and tunnel QPs
are MLX QPs. As such, they operate over VL15. Therefore, they are
not affected by "credit" problems or changes in the VLArb table (which
may shut down VL0).
Non-enabled VFs may only create UD proxy QP0 qps (which are forced by
the hypervisor to send packets using the q-key it assigns and places
in the qp-context). Thus, non-enabled VFs will not pose a security
risk. The hypervisor discards any privileged MADs it receives from
these non-enabled VFs.
By default, all VFs are NOT enabled, and must explicitly be enabled
by the administrator.
The sysfs interface which operates the VF enablement infrastructure
is provided in the next commit.
Currently, VFs in SRIOV VFs are denied QP0 access. The main reason
for this decision is security, since Subnet Management Datagrams
(SMPs) are not restricted by network partitioning and may affect the
physical network topology. Moreover, even the SM may be denied access
from portions of the network by setting management keys unknown to the
SM.
However, it is desirable to grant SMI access to certain privileged
VFs, so that certain network management activities may be conducted
within virtual machines instead of the hypervisor.
This commit does the following:
1. Create QP0 tunnel QPs for all VFs.
2. Discard SMI mads sent-from/received-for non-privileged VFs in the
hypervisor MAD multiplex/demultiplex logic. SMI mads from/for
privileged VFs are allowed to pass.
3. MAD_IFC wrapper changes/fixes. For non-privileged VFs, only
host-view MAD_IFC commands are allowed, and only for SMI LID-Routed
GET mads. For privileged VFs, there are no restrictions.
This commit does not allow privileged VFs as yet. To determine if a VF
is privileged, it calls function mlx4_vf_smi_enabled(). This function
returns 0 unconditionally for now.
The next two commits allow defining and activating privileged VFs.
When we receive a netdev event indicating a netdev change and/or
a netdev address change, we must change the MAC index used by the
proxy QP1 (in the QP context), otherwise RoCE CM packets sent by the
VF will not carry the same source MAC address as the non-CM packets.
We use the UPDATE_QP command to perform this change.
In order to avoid modifying a QP context based on netdev event,
while the driver attempts to destroy this QP (e.g either the mlx4_ib
or ib_mad modules are unloaded), we use mutex locking in both flows.
Since the relevant mlx4 proxy GSI QP is created indirectly by the
mad module when they create their GSI QP, the mlx4 didn't need to
keep track on that QP prior to this change.
Now, when QP modifications are needed to this QP from within the
driver, we added refernece to it.
Pull infiniband updates from Roland Dreier:
"Main batch of InfiniBand/RDMA changes for 3.15:
- The biggest change is core API extensions and mlx5 low-level driver
support for handling DIF/DIX-style protection information, and the
addition of PI support to the iSER initiator. Target support will
be arriving shortly through the SCSI target tree.
- A nice simplification to the "umem" memory pinning library now that
we have chained sg lists. Kudos to Yishai Hadas for realizing our
code didn't have to be so crazy.
- Another nice simplification to the sg wrappers used by qib, ipath
and ehca to handle their mapping of memory to adapter.
- The usual batch of fixes to bugs found by static checkers etc.
from intrepid people like Dan Carpenter and Yann Droneaud.
- A large batch of cxgb4, ocrdma, qib driver updates"
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (102 commits)
RDMA/ocrdma: Unregister inet notifier when unloading ocrdma
RDMA/ocrdma: Fix warnings about pointer <-> integer casts
RDMA/ocrdma: Code clean-up
RDMA/ocrdma: Display FW version
RDMA/ocrdma: Query controller information
RDMA/ocrdma: Support non-embedded mailbox commands
RDMA/ocrdma: Handle CQ overrun error
RDMA/ocrdma: Display proper value for max_mw
RDMA/ocrdma: Use non-zero tag in SRQ posting
RDMA/ocrdma: Memory leak fix in ocrdma_dereg_mr()
RDMA/ocrdma: Increment abi version count
RDMA/ocrdma: Update version string
be2net: Add abi version between be2net and ocrdma
RDMA/ocrdma: ABI versioning between ocrdma and be2net
RDMA/ocrdma: Allow DPP QP creation
RDMA/ocrdma: Read ASIC_ID register to select asic_gen
RDMA/ocrdma: SQ and RQ doorbell offset clean up
RDMA/ocrdma: EQ full catastrophe avoidance
RDMA/cxgb4: Disable DSGL use by default
RDMA/cxgb4: rx_data() needs to hold the ep mutex
Fix the following warning for the mlx4 driver:
$ make M=drivers/infiniband C=2 CF=-D__CHECK_ENDIAN__
drivers/infiniband/hw/mlx4/qp.c:1885:31: warning: restricted __be16 degrades to integer
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
Since there is no connection between the MAC/VLAN and the GID
when using IP-based addressing, the proxy QP1 (running on the
slave) must pass the source-mac, destination-mac, and vlan_id
information separately from the GID. Additionally, the Host
must pass the remote source-mac and vlan_id back to the slave,
This is achieved as follows:
Outgoing MADs:
1. Source MAC: obtained from the CQ completion structure
(struct ib_wc, smac field).
2. Destination MAC: obtained from the tunnel header
3. vlan_id: obtained from the tunnel header.
Incoming MADs
1. The source (i.e., remote) MAC and vlan_id are passed in
the tunnel header to the proxy QP1.
VST mode support:
For outgoing MADs, the vlan_id obtained from the header is
discarded, and the vlan_id specified by the Hypervisor is used
instead.
For incoming MADs, the incoming vlan_id (in the wc) is discarded, and the
"invalid" vlan (0xffff) is substituted when forwarding to the slave.
Signed-off-by: Moni Shoua <monis@mellanox.co.il>
The IB side of RoCE requires the MAC table index of the
MAC address used by its QPs.
To obtain the real MAC index, the IB side registers the
MAC (increasing its ref count, and also returning the
real MAC index) during the modify-qp sequence.
This protects against the ETH side deleting or modifying
that MAC table entry while the QP is active.
Note that until the modify-qp command returns success,
the MAC and VLAN information only has "candidate" status.
If the modify-qp succeeds, the "candidate" info is promoted
to the operational MAC/VLAN info for the qp. If the modify fails,
the candidate MAC/VLAN is unregistered, and the old qp info
is preserved.
The patch is a bit complex, because there are multiple qp
transitions where the primary-path information may be
modified: INIT-to-RTR, and SQD-to-SQD.
Similarly for the alternate path information.
Therefore the code must handle cases where path information
has already been entered into the QP context by previous
qp transitions.
For the MAC address, the success logic is as follows:
1. If there was no previous MAC, simply move the candidate
MAC information to the operational information, and reset
the candidate MAC info.
2. If there was a previous MAC, unregister it. Then move
the MAC information from candidate to operational, and
reset the candidate info (as in 1. above).
The MAC address failure logic is the same for all cases:
- Unregister the candidate MAC, and reset the candidate MAC info.
For Vlan registration, the logic is similar.
This requires the following modifications:
1. Fix build_mlx4_header to properly fill in the ETH fields
2. Adjust mux and demux QP1 flow to support RoCE.
This commit still assumes only one GID per slave for RoCE.
The commit enabling multiple GIDs is a subsequent commit, and
is done separately because of its complexity.
drivers/infiniband/hw/mlx4/main.c
IP based RoCE gids don't store Ethernet L2 parameters, MAC and VLAN.
Therefore, we need to extract them from the CQE and place them in
struct ib_wc (to be used for cases were they were taken from the gid).
Also, when modifying a QP or building address handle, instead of
parsing the dgid to get the MAC and VLAN, take them from the address
handle attributes.
This patch add the support for Ethernet L2 attributes in the
verbs/cm/cma structures.
When dealing with L2 Ethernet, we should use smac, dmac, vlan ID and priority
in a similar manner that the IB L2 (and the L4 PKEY) attributes are used.
Thus, those attributes were added to the following structures:
* ib_ah_attr - added dmac
* ib_qp_attr - added smac and vlan_id, (sl remains vlan priority)
* ib_wc - added smac, vlan_id
* ib_sa_path_rec - added smac, dmac, vlan_id
* cm_av - added smac and vlan_id
For the path record structure, extra care was taken to avoid the new
fields when packing it into wire format, so we don't break the IB CM
and SA wire protocol.
On the active side, the CM fills. its internal structures from the
path provided by the ULP. We add there taking the ETH L2 attributes
and placing them into the CM Address Handle (struct cm_av).
On the passive side, the CM fills its internal structures from the WC
associated with the REQ message. We add there taking the ETH L2
attributes from the WC.
When the HW driver provides the required ETH L2 attributes in the WC,
they set the IB_WC_WITH_SMAC and IB_WC_WITH_VLAN flags. The IB core
code checks for the presence of these flags, and in their absence does
address resolution from the ib_init_ah_from_wc() helper function.
ib_modify_qp_is_ok is also updated to consider the link layer. Some
parameters are mandatory for Ethernet link layer, while they are
irrelevant for IB. Vendor drivers are modified to support the new
function signature.
