[ Upstream commit fbb7dc5db6dee553b5a07c27e86364a5223e244c ]
gcc points out a suspicious mixing of enum types in a function that
converts from MTHCA_OPCODE_* values to IB_WC_* values:
drivers/infiniband/hw/mthca/mthca_cq.c: In function 'mthca_poll_one':
drivers/infiniband/hw/mthca/mthca_cq.c:607:21: warning: implicit conversion from 'enum <anonymous>' to 'enum ib_wc_opcode' [-Wenum-conversion]
607 | entry->opcode = MTHCA_OPCODE_INVALID;
Nothing seems to ever check for MTHCA_OPCODE_INVALID again, no idea if
this is meaningful, but it seems harmless as it deals with an invalid
input.
Remove MTHCA_OPCODE_INVALID and set the ib_wc_opcode to 0xFF, which is
still bogus, but at least doesn't make compiler warnings.
Fixes: 2a4443a69934 ("[PATCH] IB/mthca: fill in opcode field for send completions")
Link: https://lore.kernel.org/r/20201026211311.3887003-1-arnd@kernel.org
Signed-off-by: Jason Gunthorpe <jgg@nvidia.com>
[ Upstream commit 6830ff853a5764c75e56750d59d0bbb6b26f1835 ]
We return 'err' in the error branch, but this variable may be set as zero
by the above code. Fix it by setting 'err' as a negative value before we
goto the error label.
Fixes: 74c2174e7be5 ("IB uverbs: add mthca user CQ support")
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Link: https://lore.kernel.org/r/1605837422-42724-1-git-send-email-wangxiongfeng2@huawei.com
Signed-off-by: Xiongfeng Wang <wangxiongfeng2@huawei.com>
Use a bit in wc_flags rather then a whole integer to hold the
"checksum OK" flag. By itself, this change doesn't reduce the size of
struct ib_wc on 64bit machines -- it stays on 56 bytes because of
padding. However, it will allow to add more fields in the future
without enlarging the struct. Also, it will let us have a unified
approach with future libibverbs checksum offload reporting, because a
bit flag doesn't break the library ABI.
This patch was suggested during conversation with Liran Liss
<liranl@mellanox.com>.
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
Reviewed-by: Sean Hefty <sean.hefty@intel.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
Instead of having firmware command functions return an error and also
a status, leading to code like:
err = mthca_FW_COMMAND(..., &status);
if (err)
goto out;
if (status) {
err = -E...;
goto out;
all over the place, just handle the FW status inside the FW command
handling code (the way mlx4 does it), so we can simply write:
err = mthca_FW_COMMAND(...);
if (err)
goto out;
In addition to simplifying the source code, this also saves a healthy
chunk of text:
add/remove: 0/0 grow/shrink: 10/88 up/down: 510/-3357 (-2847)
function old new delta
static.trans_table 324 584 +260
mthca_cmd_poll 352 477 +125
mthca_cmd_wait 511 567 +56
mthca_table_put 213 240 +27
mthca_cleanup_db_tab 372 387 +15
__mthca_remove_one 314 323 +9
mthca_cleanup_user_db_tab 275 283 +8
__mthca_init_one 1738 1746 +8
mthca_cleanup 20 21 +1
mthca_MAD_IFC 1081 1082 +1
mthca_MGID_HASH 43 40 -3
mthca_MAP_ICM_AUX 23 20 -3
mthca_MAP_ICM 19 16 -3
mthca_MAP_FA 23 20 -3
mthca_READ_MGM 43 38 -5
mthca_QUERY_SRQ 43 38 -5
mthca_QUERY_QP 59 54 -5
mthca_HW2SW_SRQ 43 38 -5
mthca_HW2SW_MPT 60 55 -5
mthca_HW2SW_EQ 43 38 -5
mthca_HW2SW_CQ 43 38 -5
mthca_free_icm_table 120 114 -6
mthca_query_srq 214 206 -8
mthca_free_qp 662 654 -8
mthca_cmd 38 28 -10
mthca_alloc_db 1321 1311 -10
mthca_setup_hca 1067 1055 -12
mthca_WRITE_MTT 35 22 -13
mthca_WRITE_MGM 40 27 -13
mthca_UNMAP_ICM_AUX 36 23 -13
mthca_UNMAP_FA 36 23 -13
mthca_SYS_DIS 36 23 -13
mthca_SYNC_TPT 36 23 -13
mthca_SW2HW_SRQ 35 22 -13
mthca_SW2HW_MPT 35 22 -13
mthca_SW2HW_EQ 35 22 -13
mthca_SW2HW_CQ 35 22 -13
mthca_RUN_FW 36 23 -13
mthca_DISABLE_LAM 36 23 -13
mthca_CLOSE_IB 36 23 -13
mthca_CLOSE_HCA 38 25 -13
mthca_ARM_SRQ 39 26 -13
mthca_free_icms 178 164 -14
mthca_QUERY_DDR 389 375 -14
mthca_resize_cq 1063 1048 -15
mthca_unmap_eq_icm 123 107 -16
mthca_map_eq_icm 396 380 -16
mthca_cmd_box 90 74 -16
mthca_SET_IB 433 417 -16
mthca_RESIZE_CQ 369 353 -16
mthca_MAP_ICM_page 240 224 -16
mthca_MAP_EQ 183 167 -16
mthca_INIT_IB 473 457 -16
mthca_INIT_HCA 745 729 -16
mthca_map_user_db 816 798 -18
mthca_SYS_EN 157 139 -18
mthca_cleanup_qp_table 78 59 -19
mthca_cleanup_eq_table 168 149 -19
mthca_UNMAP_ICM 143 121 -22
mthca_modify_srq 172 149 -23
mthca_unmap_fmr 198 174 -24
mthca_query_qp 814 790 -24
mthca_query_pkey 343 319 -24
mthca_SET_ICM_SIZE 34 10 -24
mthca_QUERY_DEV_LIM 1870 1846 -24
mthca_map_cmd 1130 1105 -25
mthca_ENABLE_LAM 401 375 -26
mthca_modify_port 247 220 -27
mthca_query_device 884 850 -34
mthca_NOP 75 41 -34
mthca_table_get 287 249 -38
mthca_init_qp_table 333 293 -40
mthca_MODIFY_QP 348 308 -40
mthca_close_hca 131 89 -42
mthca_free_eq 435 390 -45
mthca_query_port 755 705 -50
mthca_free_cq 581 528 -53
mthca_alloc_icm_table 578 524 -54
mthca_multicast_attach 1041 986 -55
mthca_init_hca 326 271 -55
mthca_query_gid 487 431 -56
mthca_free_srq 524 468 -56
mthca_free_mr 168 111 -57
mthca_create_eq 1560 1501 -59
mthca_multicast_detach 790 728 -62
mthca_write_mtt 918 854 -64
mthca_register_device 1406 1342 -64
mthca_fmr_alloc 947 883 -64
mthca_mr_alloc 652 582 -70
mthca_process_mad 1242 1164 -78
mthca_dev_lim 910 830 -80
find_mgm 482 400 -82
mthca_modify_qp 3852 3753 -99
mthca_init_cq 1281 1181 -100
mthca_alloc_srq 1719 1610 -109
mthca_init_eq_table 1807 1679 -128
mthca_init_tavor 761 491 -270
mthca_init_arbel 2617 2098 -519
Signed-off-by: Goldwyn Rodrigues <rgoldwyn@suse.de>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
This patch adds support for the IB "base memory management extension"
(BMME) and the equivalent iWARP operations (which the iWARP verbs
mandates all devices must implement). The new operations are:
- Allocate an ib_mr for use in fast register work requests.
- Allocate/free a physical buffer lists for use in fast register work
requests. This allows device drivers to allocate this memory as
needed for use in posting send requests (eg via dma_alloc_coherent).
- New send queue work requests:
* send with remote invalidate
* fast register memory region
* local invalidate memory region
* RDMA read with invalidate local memory region (iWARP only)
Consumer interface details:
- A new device capability flag IB_DEVICE_MEM_MGT_EXTENSIONS is added
to indicate device support for these features.
- New send work request opcodes IB_WR_FAST_REG_MR, IB_WR_LOCAL_INV,
IB_WR_RDMA_READ_WITH_INV are added.
- A new consumer API function, ib_alloc_mr() is added to allocate
fast register memory regions.
- New consumer API functions, ib_alloc_fast_reg_page_list() and
ib_free_fast_reg_page_list() are added to allocate and free
device-specific memory for fast registration page lists.
- A new consumer API function, ib_update_fast_reg_key(), is added to
allow the key portion of the R_Key and L_Key of a fast registration
MR to be updated. Consumers call this if desired before posting
a IB_WR_FAST_REG_MR work request.
Consumers can use this as follows:
- MR is allocated with ib_alloc_mr().
- Page list memory is allocated with ib_alloc_fast_reg_page_list().
- MR R_Key/L_Key "key" field is updated with ib_update_fast_reg_key().
- MR made VALID and bound to a specific page list via
ib_post_send(IB_WR_FAST_REG_MR)
- MR made INVALID via ib_post_send(IB_WR_LOCAL_INV),
ib_post_send(IB_WR_RDMA_READ_WITH_INV) or an incoming send with
invalidate operation.
- MR is deallocated with ib_dereg_mr()
- page lists dealloced via ib_free_fast_reg_page_list().
Applications can allocate a fast register MR once, and then can
repeatedly bind the MR to different physical block lists (PBLs) via
posting work requests to a send queue (SQ). For each outstanding
MR-to-PBL binding in the SQ pipe, a fast_reg_page_list needs to be
allocated (the fast_reg_page_list is owned by the low-level driver
from the consumer posting a work request until the request completes).
Thus pipelining can be achieved while still allowing device-specific
page_list processing.
The 32-bit fast register memory key/STag is composed of a 24-bit index
and an 8-bit key. The application can change the key each time it
fast registers thus allowing more control over the peer's use of the
key/STag (ie it can effectively be changed each time the rkey is
rebound to a page list).
Signed-off-by: Steve Wise <swise@opengridcomputing.com>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
They don't get updated by git and so they're worse than useless.
Arbel and Sinai devices support checksum generation and verification
of TCP and UDP packets for UD IPoIB messages. This patch checks if
the HCA supports this and sets the IB_DEVICE_UD_IP_CSUM capability
flag if it does. It implements support for handling the IB_SEND_IP_CSUM
send flag and setting the csum_ok field in receive work completions.
Signed-off-by: Eli Cohen <eli@mellnaox.co.il>
replace:
big_endian_variable = cpu_to_beX(beX_to_cpu(big_endian_variable) +
expression_in_cpu_byteorder);
with:
beX_add_cpu(&big_endian_variable, expression_in_cpu_byteorder);
Generated with a semantic patch.
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Cc: Sean Hefty <sean.hefty@intel.com>
Cc: Hal Rosenstock <hal.rosenstock@gmail.com>
Architectures such as ia64 see alignment traps when doing a 64-bit
read from __be32 doorbell[2] arrays to do doorbell writes in
mthca_write64(). Fix this by just passing the two halves of the
doorbell value into mthca_write64(). This actually improves the
generated code by allowing the compiler to see what's going on better.
First thing mm.h does is including sched.h solely for can_do_mlock() inline
function which has "current" dereference inside. By dealing with can_do_mlock()
mm.h can be detached from sched.h which is good. See below, why.
This patch
a) removes unconditional inclusion of sched.h from mm.h
b) makes can_do_mlock() normal function in mm/mlock.c
c) exports can_do_mlock() to not break compilation
d) adds sched.h inclusions back to files that were getting it indirectly.
e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were
getting them indirectly
Net result is:
a) mm.h users would get less code to open, read, preprocess, parse, ... if
they don't need sched.h
b) sched.h stops being dependency for significant number of files:
on x86_64 allmodconfig touching sched.h results in recompile of 4083 files,
after patch it's only 3744 (-8.3%).
Cross-compile tested on
all arm defconfigs, all mips defconfigs, all powerpc defconfigs,
alpha alpha-up
arm
i386 i386-up i386-defconfig i386-allnoconfig
ia64 ia64-up
m68k
mips
parisc parisc-up
powerpc powerpc-up
s390 s390-up
sparc sparc-up
sparc64 sparc64-up
um-x86_64
x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig
as well as my two usual configs.
mthca_cq_clean() updates the CQ consumer index without moving CQEs
back to HW ownership. As a result, the same WRID might get reported
twice, resulting in a use-after-free. This was observed in IPoIB CM.
Fix by moving all freed CQEs to HW ownership.
This fixes <https://bugs.openfabrics.org/show_bug.cgi?id=617>
Signed-off-by: Michael S. Tsirkin <mst@dev.mellanox.co.il>
The semantics defined by the InfiniBand specification say that
completion events are only generated when a completions is added to a
completion queue (CQ) after completion notification is requested. In
other words, this means that the following race is possible:
while (CQ is not empty)
ib_poll_cq(CQ);
// new completion is added after while loop is exited
ib_req_notify_cq(CQ);
// no event is generated for the existing completion
To close this race, the IB spec recommends doing another poll of the
CQ after requesting notification.
However, it is not always possible to arrange code this way (for
example, we have found that NAPI for IPoIB cannot poll after
requesting notification). Also, some hardware (eg Mellanox HCAs)
actually will generate an event for completions added before the call
to ib_req_notify_cq() -- which is allowed by the spec, since there's
no way for any upper-layer consumer to know exactly when a completion
was really added -- so the extra poll of the CQ is just a waste.
Motivated by this, we add a new flag "IB_CQ_REPORT_MISSED_EVENTS" for
ib_req_notify_cq() so that it can return a hint about whether the a
completion may have been added before the request for notification.
The return value of ib_req_notify_cq() is extended so:
< 0 means an error occurred while requesting notification
== 0 means notification was requested successfully, and if
IB_CQ_REPORT_MISSED_EVENTS was passed in, then no
events were missed and it is safe to wait for another
event.
> 0 is only returned if IB_CQ_REPORT_MISSED_EVENTS was
passed in. It means that the consumer must poll the
CQ again to make sure it is empty to avoid the race
described above.
We add a flag to enable this behavior rather than turning it on
unconditionally, because checking for missed events may incur
significant overhead for some low-level drivers, and consumers that
don't care about the results of this test shouldn't be forced to pay
for the test.
struct ib_wc currently only includes the local QP number: this matches
the IB spec, but seems mostly useless. The following patch replaces
this with the pointer to qp itself, and updates all low level drivers
and all users.
This has the following advantages:
- Ability to get a per-qp context through wc->qp->qp_context
- Existing drivers already have the qp pointer ready in poll cq, so
this change actually saves a tiny bit (extra memory read) on data path
(for ehca it would actually be expensive to find the QP pointer when
polling a CQ, but ehca does not support SRQ so we can leave wc->qp as
NULL for ehca)
- Users that need the QP number can still get it through wc->qp->qp_num
Use case:
In IPoIB connected mode code, I have a common CQ shared by multiple
QPs. To track connection usage, I need a way to get at some per-QP
context upon the completion, and I would like to avoid allocating
context object per work request just to stick a QP pointer into it.
With this code, I can just use wc->qp->qp_context.
Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il>
According to the Tavor and Arbel programmer's reference manuals, the
number of bytes transferred is not provided in the byte_cnt field of
the CQ entry for atomic operation completions. For atomic operations,
the number of bytes transferred is always 8 (when the status is
"success"), and this constant value should always be used by the
driver in the ib_wc entry returned, rather than using the CQE.
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Commit b3b30f5e ("IB/mthca: Recover from catastrophic errors")
introduced some section mismatch breakage, because the error recovery
code tears down and reinitializes the device, which calls into lots of
code originally marked __devinit and __devexit from regular .text.
Fix this by getting rid of these now-incorrect section markers.
Reported by Randy Dunlap <randy.dunlap@oracle.com>.
We discovered a problem when running IPoIB applications on multiple
CPUs on an Altix system. Many messages such as:
ib_mthca 0002:01:00.0: SQ 000014 full (19941644 head, 19941707 tail, 64 max, 0 nreq)
appear in syslog, and the driver wedges up.
Apparently this is because writes to the doorbells from different CPUs
reach the device out of order. The following patch adds mmiowb() calls
after doorbell rings to ensure the doorbell writes are ordered.
Signed-off-by: Arthur Kepner <akepner@sgi.com>
Remove some trailing whitespace that has snuck in despite the best
efforts of whitespace=error-all. Also fix a few other whitespace
bogosities.
Documentation/infiniband/core_locking.txt says:
All of the methods in struct ib_device exported by a low-level
driver must be fully reentrant. The low-level driver is required to
perform all synchronization necessary to maintain consistency, even
if multiple function calls using the same object are run
simultaneously.
However, mthca's modify_qp, modify_srq and resize_cq methods are
currently not reentrant. Add a mutex to the QP, SRQ and CQ structures
so that these calls can be properly serialized.
Memfree firmware is in rare cases reporting WQE index == base - 1 in
receive completion with error, instead of (rq size - 1); base is 0 in
mthca. Here is a patch to avoid kernel crash and report a correct WR
id in this case.
Fix races in in destroying various objects. If a destroy routine
waits for an object to become free by doing
wait_event(&obj->wait, !atomic_read(&obj->refcount));
/* now clean up and destroy the object */
and another place drops a reference to the object by doing
if (atomic_dec_and_test(&obj->refcount))
wake_up(&obj->wait);
then this is susceptible to a race where the wait_event() and final
freeing of the object occur between the atomic_dec_and_test() and the
wake_up(). And this is a use-after-free, since wake_up() will be
called on part of the already-freed object.
Fix this in mthca by replacing the atomic_t refcounts with plain old
integers protected by a spinlock. This makes it possible to do the
decrement of the reference count and the wake_up() so that it appears
as a single atomic operation to the code waiting on the wait queue.
While touching this code, also simplify mthca_cq_clean(): the CQ being
cleaned cannot go away, because it still has a QP attached to it. So
there's no reason to be paranoid and look up the CQ by number; it's
perfectly safe to use the pointer that the callers already have.
Quite a few cleanup functions in mthca were marked as __devexit.
However, they could also be called from error paths during
initialization, so they cannot be marked that way. Just delete all of
the incorrect annotations.
Add low-level driver support for resizing CQs (both kernel and
userspace) to mthca.
The might_sleep() annotations in mthca are silly -- they all occur
shortly before calls that will end up in core functions like kmalloc()
that will print the same warning in an unsafe context anyway. In
fact, beyond cluttering the source, we're actually bloating text with
CONFIG_DEBUG_SPINLOCK_SLEEP and/or CONFIG_PREEMPT_VOLUNTARY set.
With both options set, getting rid of the might_sleep()s saves a lot:
add/remove: 0/0 grow/shrink: 0/7 up/down: 0/-171 (-171)
mthca_pd_alloc 132 109 -23
mthca_init_cq 969 946 -23
mthca_mr_alloc 592 568 -24
mthca_pd_free 67 42 -25
mthca_free_mr 219 194 -25
mthca_free_cq 570 545 -25
mthca_fmr_alloc 742 716 -26
The function mthca_free_err_wqe() can never fail, so get rid of its
return value. That means handle_error_cqe() doesn't have to check
what mthca_free_err_wqe() returns, which means it can't fail either
and doesn't have to return anything either. All this results in
simpler source code and a slight object code improvement:
add/remove: 0/0 grow/shrink: 0/2 up/down: 0/-10 (-10)
mthca_free_err_wqe 83 81 -2
mthca_poll_cq 1758 1750 -8
Fill vendor_err field in completion with error.
When cleaning up a CQ for a QP attached to SRQ, need to free an SRQ
WQE only if the CQE is a receive completion.
Signed-off-by: Jack Morgenstein <jackm@mellanox.co.il>
Handle case where prod_index has wrapped around and become less than
cq->cons_index by checking that their difference as a signed int is
positive rather than comparing directly.
Implement reporting asynchronous CQ events in Mellanox HCA driver.
Move the InfiniBand headers from drivers/infiniband/include to include/rdma.
This allows InfiniBand-using code to live elsewhere, and lets us remove the
ugly EXTRA_CFLAGS include path from the InfiniBand Makefiles.
Add mthca support for shared receive queues (SRQs),
including userspace SRQs.
Mem-free HCAs never generate error CQEs that complete multiple WQEs,
so just skip the call to mthca_free_err_wqe() for them rather than
having logic to handle the mem-free case in mthca_free_err_wqe().
Clean up the allocation of memory for queues by factoring out the
common code into mthca_buf_alloc() and mthca_buf_free(). Now CQs and
QPs share the same queue allocation code, which we'll also use for SRQs.
Fix sparse warnings. Use __be* where appropriate.
Signed-off-by: Sean Hefty <sean.hefty@intel.com>
Make some lawyers happy and add copyright notices for people who
forgot to include them when they actually touched the code.
Fix handling of error CQ entries on mem-free HCAs: the doorbell count
is never valid so we shouldn't look at it. This fixes problems exposed
by new HCA firmware.
Add support for userspace completion queues (CQs) to mthca.
Future versions of Mellanox HCA firmware will require command mailboxes to be
aligned to 4K. Support this by using a pci_pool to allocate all mailboxes.
This has the added benefit of shrinking the source and text of mthca.
Signed-off-by: Roland Dreier <roland@topspin.com>
Make mthca_table_put() and mthca_table_put_range() NOPs if the device is not
mem-free, so that we don't have to have "if (mthca_is_memfree())" tests in the
callers of these functions. This makes our code more readable and
maintainable, and saves a couple dozen bytes of text in ib_mthca.ko as well.
Switch all allocations of coherent memory from pci_alloc_consistent() to
dma_alloc_coherent(), so that we can pass GFP_KERNEL. This should help when
the system is low on memory.
Clean up CQ debugging code: make dump_cqe print on one line, and only dump
error CQ entries for local operation errors.
Add Sun copyright to files modified by Tom Duffy.
Signed-off-by: Tom Duffy <tduffy@sun.com>
Clean up mem-free mode support by introducing mthca_is_memfree() function,
which encapsulates the logic of deciding if a device is mem-free.
Fill in missing fields in send completions.
Signed-off-by: Itamar Rabenstein <itamar@mellanox.co.il>
On error path, only free doorbell records if we're in mem-free mode.
infrastructure for it.
Let it rip!
