As result of the deprecation of the MSI-X/MSI enablement functions
pci_enable_msix() and pci_enable_msi_block(), all drivers using these
two interfaces need to be updated to use the new
pci_enable_msi_range() or pci_enable_msi_exact() and
pci_enable_msix_range() or pci_enable_msix_exact() interfaces.
Signed-off-by: Alexander Gordeev <agordeev@redhat.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: Tom Tucker <tom@opengridcomputing.com>
Cc: Steve Wise <swise@opengridcomputing.com>
Cc: Roland Dreier <roland@kernel.org>
Cc: Sean Hefty <sean.hefty@intel.com>
Cc: Hal Rosenstock <hal.rosenstock@gmail.com>
Cc: Hoang-Nam Nguyen <hnguyen@de.ibm.com>
Cc: Christoph Raisch <raisch@de.ibm.com>
Cc: Mike Marciniszyn <infinipath@intel.com>
Cc: Faisal Latif <faisal.latif@intel.com>
The PCIE capability offset is saved during PCI bus walking. It will
remove an unnecessary search in the PCI configuration space if this
value is referenced instead of reacquiring it. Also, pci_is_pcie is a
better way of determining if the device is PCIE or not (as it uses the
same saved PCIE capability offset).
Signed-off-by: Jon Mason <jdmason@kudzu.us>
Instead of having firmware command functions return an error and also
a status, leading to code like:
err = mthca_FW_COMMAND(..., &status);
if (err)
goto out;
if (status) {
err = -E...;
goto out;
all over the place, just handle the FW status inside the FW command
handling code (the way mlx4 does it), so we can simply write:
err = mthca_FW_COMMAND(...);
if (err)
goto out;
In addition to simplifying the source code, this also saves a healthy
chunk of text:
add/remove: 0/0 grow/shrink: 10/88 up/down: 510/-3357 (-2847)
function old new delta
static.trans_table 324 584 +260
mthca_cmd_poll 352 477 +125
mthca_cmd_wait 511 567 +56
mthca_table_put 213 240 +27
mthca_cleanup_db_tab 372 387 +15
__mthca_remove_one 314 323 +9
mthca_cleanup_user_db_tab 275 283 +8
__mthca_init_one 1738 1746 +8
mthca_cleanup 20 21 +1
mthca_MAD_IFC 1081 1082 +1
mthca_MGID_HASH 43 40 -3
mthca_MAP_ICM_AUX 23 20 -3
mthca_MAP_ICM 19 16 -3
mthca_MAP_FA 23 20 -3
mthca_READ_MGM 43 38 -5
mthca_QUERY_SRQ 43 38 -5
mthca_QUERY_QP 59 54 -5
mthca_HW2SW_SRQ 43 38 -5
mthca_HW2SW_MPT 60 55 -5
mthca_HW2SW_EQ 43 38 -5
mthca_HW2SW_CQ 43 38 -5
mthca_free_icm_table 120 114 -6
mthca_query_srq 214 206 -8
mthca_free_qp 662 654 -8
mthca_cmd 38 28 -10
mthca_alloc_db 1321 1311 -10
mthca_setup_hca 1067 1055 -12
mthca_WRITE_MTT 35 22 -13
mthca_WRITE_MGM 40 27 -13
mthca_UNMAP_ICM_AUX 36 23 -13
mthca_UNMAP_FA 36 23 -13
mthca_SYS_DIS 36 23 -13
mthca_SYNC_TPT 36 23 -13
mthca_SW2HW_SRQ 35 22 -13
mthca_SW2HW_MPT 35 22 -13
mthca_SW2HW_EQ 35 22 -13
mthca_SW2HW_CQ 35 22 -13
mthca_RUN_FW 36 23 -13
mthca_DISABLE_LAM 36 23 -13
mthca_CLOSE_IB 36 23 -13
mthca_CLOSE_HCA 38 25 -13
mthca_ARM_SRQ 39 26 -13
mthca_free_icms 178 164 -14
mthca_QUERY_DDR 389 375 -14
mthca_resize_cq 1063 1048 -15
mthca_unmap_eq_icm 123 107 -16
mthca_map_eq_icm 396 380 -16
mthca_cmd_box 90 74 -16
mthca_SET_IB 433 417 -16
mthca_RESIZE_CQ 369 353 -16
mthca_MAP_ICM_page 240 224 -16
mthca_MAP_EQ 183 167 -16
mthca_INIT_IB 473 457 -16
mthca_INIT_HCA 745 729 -16
mthca_map_user_db 816 798 -18
mthca_SYS_EN 157 139 -18
mthca_cleanup_qp_table 78 59 -19
mthca_cleanup_eq_table 168 149 -19
mthca_UNMAP_ICM 143 121 -22
mthca_modify_srq 172 149 -23
mthca_unmap_fmr 198 174 -24
mthca_query_qp 814 790 -24
mthca_query_pkey 343 319 -24
mthca_SET_ICM_SIZE 34 10 -24
mthca_QUERY_DEV_LIM 1870 1846 -24
mthca_map_cmd 1130 1105 -25
mthca_ENABLE_LAM 401 375 -26
mthca_modify_port 247 220 -27
mthca_query_device 884 850 -34
mthca_NOP 75 41 -34
mthca_table_get 287 249 -38
mthca_init_qp_table 333 293 -40
mthca_MODIFY_QP 348 308 -40
mthca_close_hca 131 89 -42
mthca_free_eq 435 390 -45
mthca_query_port 755 705 -50
mthca_free_cq 581 528 -53
mthca_alloc_icm_table 578 524 -54
mthca_multicast_attach 1041 986 -55
mthca_init_hca 326 271 -55
mthca_query_gid 487 431 -56
mthca_free_srq 524 468 -56
mthca_free_mr 168 111 -57
mthca_create_eq 1560 1501 -59
mthca_multicast_detach 790 728 -62
mthca_write_mtt 918 854 -64
mthca_register_device 1406 1342 -64
mthca_fmr_alloc 947 883 -64
mthca_mr_alloc 652 582 -70
mthca_process_mad 1242 1164 -78
mthca_dev_lim 910 830 -80
find_mgm 482 400 -82
mthca_modify_qp 3852 3753 -99
mthca_init_cq 1281 1181 -100
mthca_alloc_srq 1719 1610 -109
mthca_init_eq_table 1807 1679 -128
mthca_init_tavor 761 491 -270
mthca_init_arbel 2617 2098 -519
Signed-off-by: Goldwyn Rodrigues <rgoldwyn@suse.de>
By default, each device is assumed to be able only handle 64 KB chunks
during DMA. By giving the segment size a larger value, the block layer
will coalesce more S/G entries together for SRP, allowing larger
requests with the same sg_tablesize setting. The block layer is the
only direct user of it, though a few IOMMU drivers reference it as
well for their *_map_sg coalescing code. pci-gart_64 on x86, and a
smattering on on sparc, powerpc, and ia64.
Since other IB protocols could potentially see larger segments with
this, let's check those:
- iSER is fine, because you limit your maximum request size to 512
KB, so we'll never overrun the page vector in struct iser_page_vec
(128 entries currently). It is independent of the DMA segment size,
and handles multi-page segments already.
- IPoIB is fine, as it maps each page individually, and doesn't use
ib_dma_map_sg().
- RDS appears to do the right thing and has no dependencies on DMA
segment size, but I don't claim to have done a complete audit.
- NFSoRDMA and 9p are OK -- they do not use ib_dma_map_sg(), so they
doesn't care about the coalescing.
- Lustre's ko2iblnd does not care about coalescing -- it properly
walks the returned sg list.
This patch ups the value on Mellanox hardware to 1 GB, which matches
reported firmware limits on mlx4.
Signed-off-by: David Dillow <dillowda@ornl.gov>
Some systems have PCI addresses that don't fit in unsigned long (eg some
32-bit PowerPC 440 systems have 36-bit bus addresses). Fix up the driver
by using phys_addr_t where appropriate, so we don't truncate any PCI
resource addresses before ioremapping them.
Signed-off-by: John L. Burr <jlburr@cadence.com>
[ Update to apply to current driver source. - Roland ]
Signed-off-by: Roland Dreier <rolandd@cisco.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
and 'nes' into for-linus
Userspace apps are supposed to release all ib device resources if they
receive a fatal async event (IBV_EVENT_DEVICE_FATAL). However, the
app has no way of knowing when the device has come back up, except to
repeatedly attempt ibv_open_device() until it succeeds.
However, currently there is no protection against the open succeeding
while the device is in being removed following the fatal event. In
this case, the open will succeed, but as a result the device waits in
the middle of its removal until the new app releases its resources --
and the new app will not do so, since the open succeeded at a point
following the fatal event generation.
This patch adds an "active" flag to the device. The active flag is set
to false (in the fatal event flow) before the "fatal" event is
generated, so any subsequent ibv_dev_open() call to the device will
fail until the device comes back up, thus preventing the above
deadlock.
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Replace open-coded reimplementations with printk_once().
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
The current MTT allocator uses kmalloc() to allocate a buffer for its
buddy allocator, and thus is limited in the amount of MTT segments
that it can control. As a result, the size of memory that can be
registered is limited too. This patch uses a module parameter to
control the number of MTT entries that each segment represents,
allowing more memory to be registered with the same number of
segments.
Signed-off-by: Eli Cohen <eli@mellanox.co.il>
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)
Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com>
Replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64)
Back in prehistoric (pre-git!) days, the kernel's MSI-X support did
request_mem_region() on a device's MSI-X tables, which meant that a
driver that enabled MSI-X couldn't use pci_request_regions() (since
that would clash with the PCI layer's MSI-X request).
However, that was removed (by me!) years ago, so mthca can just use
pci_request_regions() and pci_release_regions() instead of its own
much more complicated code that avoids requesting the MSI-X tables.
They don't get updated by git and so they're worse than useless.
The mthca driver returns the maximum number of scatter/gather entries
returned by the firmware as the max_sge value when device properties
are queried. However, the firmware also reports a limit on the
maximum descriptor size allowed, and because mthca takes into account
the worst case send request overhead when checking whether to allow a
QP to be created, the largest number of scatter/gather entries that
can be used with mthca may be limited by the maximum descriptor size
rather than just by the actual s/g entry limit.
This means that applications cannot actually create QPs with
max_send_sge equal to the limit returned by ib_query_device(). Fix
this by checking if the maximum descriptor size imposes a lower limit
and if so returning that lower limit.
mthca_make_profile() returns the size in bytes of the HCA context
layout it creates, or a negative value if an error occurs. However,
the return value is declared as u64 and the memfree initialization
path casts this value to int to test if it is negative. This makes it
think incorrectly than an error has occurred if the context size
happens to be bigger than 2GB, since this turns into a negative int.
Fix this by having mthca_make_profile() return an s64 and testing
for an error by checking whether this 64-bit value itself is negative.
Arbel and Sinai devices support checksum generation and verification
of TCP and UDP packets for UD IPoIB messages. This patch checks if
the HCA supports this and sets the IB_DEVICE_UD_IP_CSUM capability
flag if it does. It implements support for handling the IB_SEND_IP_CSUM
send flag and setting the csum_ok field in receive work completions.
Signed-off-by: Eli Cohen <eli@mellnaox.co.il>
For memfree devices, the firmware QUERY_ADAPTER command does not
return vendor_id, device_id, and revision_id; do not return these
fields in the QUERY_ADAPTER function for memfree devices.
Instead, for memfree devices, initialize the rev_id field of the mthca
device via init_node_data (MAD IFC query), as is done in the
query_device verb implementation.
Remove MSI support from the mthca driver, as scheduled. There is no
reason to use MSI instead of MSI-X, since MSI-X performs better. No
one has spoken up since MSI support was deprecated in commit f6be6fbe
("IB/mthca: Schedule MSI support for removal"), so apparently the MSI
support is unused.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
These driver changes incorporate the proposed PCI-X / PCI-Express read
byte count interface. Reading and setting those values doesn't take
place "manually", instead wrapping functions are called to allow
quirks for some PCI bridges.
Signed-off by: Peter Oruba <peter.oruba@amd.com>
Based on work by Stephen Hemminger <shemminger@linux-foundation.org>
Cc: Roland Dreier <rolandd@cisco.com>
Cc: Michael S. Tsirkin <mst@mellanox.co.il>
Recover from MSI-X errors by automatically falling back on regular
interrupt, instead of asking the user to do this manually. This makes
it possible to enable MSI-X by default, and will make it possible to
get rid of the msi_x module option in the future.
Signed-off-by: Michael S. Tsirkin <mst@dev.mellanox.co.il>
When warning about out-of-date firmware, current mthca code messes up
the formatting of the version if the subminor doesn't have three
digits. It doesn't fill the field with 0s so we end up with:
ib_mthca 0000:0b:00.0: HCA FW version 1.1. 0 is old (1.2. 0 is current).
Change the format from "%3d" to "%03d" to get the right thing printed.
The mthca driver supports both MSI and MSI-X. However, MSI-X works with
all hardware that the driver handles, and provides a superset of what
MSI does, so there's no point in having code for both. Schedule MSI
support for removal in 2008 to give anyone who actually needs MSI and
who can't use MSI time to speak up.
Update the driver's list of current firmware versions with Mellanox's
latest releases.
We allocate the MTT table with alloc_pages() and then do pci_map_sg(),
so we must call pci_dma_sync_sg() after the CPU writes to the MTT
table. This works since the device will never write MTTs on mem-free
HCAs, once we get rid of the use of the WRITE_MTT firmware command.
This change is needed to make that work, and is an improvement for
now, since it gives FMRs a chance at working.
For MPTs, both the device and CPU might write there, so we must
allocate DMA coherent memory for these.
Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il>
MTTs are allocated in non-cache-coherent memory, so we must give
reserved MTTs their own cache line, to prevent both device and
CPU from writing into the same cache line at the same time.
mthca_device_mutex() can be initialized automatically with
DEFINE_MUTEX() rather than explicitly calling mutex_init(). This
saves a bit of text and shrinks the source by a line, so we may as
well do it....
Add module parameters that enable settting some of the HCA
profile values, such as the number of QPs, CQs, etc.
Signed-off-by: Leonid Arsh <leonida@voltaire.com>
Signed-off-by: Moni Shoua <monis@voltaire.com>
Commit b3b30f5e ("IB/mthca: Recover from catastrophic errors")
introduced some section mismatch breakage, because the error recovery
code tears down and reinitializes the device, which calls into lots of
code originally marked __devinit and __devexit from regular .text.
Fix this by getting rid of these now-incorrect section markers.
Reported by Randy Dunlap <randy.dunlap@oracle.com>.
Trigger device remove and then add when a catastrophic error is
detected in hardware. This, in turn, will cause a device reset, which
we hope will recover from the catastrophic condition.
Since this might interefere with debugging the root cause, add a
module option to suppress this behaviour.
Signed-off-by: Jack Morgenstein <jackm@mellanox.co.il>
Update the driver's list of HCA firmware revisions to make sure people
running Sinai firmware older than 1.1.0 get a message suggesting a
firmware upgrade. Update the Arbel versions as well while we are at it.
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
This is needed if we wish to change the size of the resource structures.
Based on an original patch from Vivek Goyal <vgoyal@in.ibm.com>
Cc: Vivek Goyal <vgoyal@in.ibm.com>
The driver allocates SRQ WQEs size with a power of 2 size both for
Tavor and for memfree. For Tavor, however, the hardware only requires
the WQE size to be a multiple of 16, not a power of 2, and the max
number of scatter-gather allowed is reported accordingly by the
firmware (and this is the value currently returned by
ib_query_device() and ibv_query_device()).
If the max number of scatter/gather entries reported by the FW is used
when creating an SRQ, the creation will fail for Tavor, since the
required WQE size will be increased to the next power of 2, which
turns out to be larger than the device permitted max WQE size (which
is not a power of 2).
This patch reduces the reported SRQ max wqe size so that it can be used
successfully in creating an SRQ on Tavor HCAs.
The PCI spec recommends against drivers playing with a device's PCI
read burst size, and says that systems software should configure it.
And we actually have users that report that changing it from the
default set by BIOS hurts performance and/or stability for them. On
the other hand, the Mellanox Programmer's Reference Manual recommends
turning it up all the way to the maximum value. Some tests conducted
here in the lab do not show performance improvement from this tuning,
but this might be just me.
As a work-around, make this tuning an option, off by default (safe
value), with an eye towards removing it completely one day if no one
complains.
Push translation of static rate to HCA format into low-level drivers,
where it belongs. For static rate encoding, use encoding of rate
field from IB standard PathRecord, with addition of value 0, for
backwards compatibility with current usage. The changes are:
- Add enum ib_rate to midlayer includes.
- Get rid of static rate translation in IPoIB; just use static rate
directly from Path and MulticastGroup records.
- Update mthca driver to translate absolute static rate into the
format used by hardware. This also fixes mthca's static rate
handling for HCAs that are capable of 4X DDR.
Change the mthca debugging trace output code so that it can enabled
and disabled at runtime with the debug_level module parameter in
sysfs. Also, don't allow CONFIG_INFINIBAND_MTHCA_DEBUG to be disabled
unless CONFIG_EMBEDDED is selected. We want users (and especially
distros) to have this turned on unless they really need to save space,
because by the time we want debugging output, it's usually too late to
rebuild a kernel.
Update known firmware versions in driver's table to the latest releases.
Sinai (one-port PCI Express) HCAs get improved throughput for messages
bigger than 80 KB in DDR mode if memory keys are formatted in a
specific way. The enhancement only works if the memory key table is
smaller than 2^24 entries. For larger tables, the enhancement is off
and a warning is printed (to avoid silent performance loss).
Signed-off-by: Michael Tsirkin <mst@mellanox.co.il>
There are some cards around that have UAR (user access region) size
different from 8 MB. Relax our sanity check to make sure that the PCI
BAR is big enough to access the UAR size reported by the device
firmware instead.
Check error return on call to mthca_dev_lim for Tavor
(as is done for memfree).
Move the computation of QP capabilities (max scatter/gather entries,
max inline data, etc) into the kernel, and have the uverbs module
return the values as part of the create QP response. This keeps
precise knowledge of device limits in the low-level kernel driver.
This requires an ABI bump, so while we're making changes, get rid of
the max_sge parameter for the modify SRQ command -- it's not used and
shouldn't be there.
Report the device's real page size capability in mthca_query_device().
Mellanox has decided that the components of the firmware version are
really meant to be displayed in decimal, e.g. 0x000400070190 is
version 4.7.400. Change the format we use from "%x.%x.%x" to
"%d.%d.%d" to match this convention.
Set mthca_driver.owner to THIS_MODULE.
