path: root/drivers/infiniband/hw/mthca/mthca_memfree.h
2007-05-02PCI: Cleanup the includes of <linux/pci.h>Jean Delvare
I noticed that many source files include <linux/pci.h> while they do not appear to need it. Here is an attempt to clean it all up. In order to find all possibly affected files, I searched for all files including <linux/pci.h> but without any other occurence of "pci" or "PCI". I removed the include statement from all of these, then I compiled an allmodconfig kernel on both i386 and x86_64 and fixed the false positives manually. My tests covered 66% of the affected files, so there could be false positives remaining. Untested files are: arch/alpha/kernel/err_common.c arch/alpha/kernel/err_ev6.c arch/alpha/kernel/err_ev7.c arch/ia64/sn/kernel/huberror.c arch/ia64/sn/kernel/xpnet.c arch/m68knommu/kernel/dma.c arch/mips/lib/iomap.c arch/powerpc/platforms/pseries/ras.c arch/ppc/8260_io/enet.c arch/ppc/8260_io/fcc_enet.c arch/ppc/8xx_io/enet.c arch/ppc/syslib/ppc4xx_sgdma.c arch/sh64/mach-cayman/iomap.c arch/xtensa/kernel/xtensa_ksyms.c arch/xtensa/platform-iss/setup.c drivers/i2c/busses/i2c-at91.c drivers/i2c/busses/i2c-mpc.c drivers/media/video/saa711x.c drivers/misc/hdpuftrs/hdpu_cpustate.c drivers/misc/hdpuftrs/hdpu_nexus.c drivers/net/au1000_eth.c drivers/net/fec_8xx/fec_main.c drivers/net/fec_8xx/fec_mii.c drivers/net/fs_enet/fs_enet-main.c drivers/net/fs_enet/mac-fcc.c drivers/net/fs_enet/mac-fec.c drivers/net/fs_enet/mac-scc.c drivers/net/fs_enet/mii-bitbang.c drivers/net/fs_enet/mii-fec.c drivers/net/ibm_emac/ibm_emac_core.c drivers/net/lasi_82596.c drivers/parisc/hppb.c drivers/sbus/sbus.c drivers/video/g364fb.c drivers/video/platinumfb.c drivers/video/stifb.c drivers/video/valkyriefb.c include/asm-arm/arch-ixp4xx/dma.h sound/oss/au1550_ac97.c I would welcome test reports for these files. I am fine with removing the untested files from the patch if the general opinion is that these changes aren't safe. The tested part would still be nice to have. Note that this patch depends on another header fixup patch I submitted to LKML yesterday: [PATCH] scatterlist.h needs types.h http://lkml.org/lkml/2007/3/01/141 Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-12IB/mthca: Fix access to MTT and MPT tables on non-cache-coherent CPUsMichael S. Tsirkin
We allocate the MTT table with alloc_pages() and then do pci_map_sg(), so we must call pci_dma_sync_sg() after the CPU writes to the MTT table. This works since the device will never write MTTs on mem-free HCAs, once we get rid of the use of the WRITE_MTT firmware command. This change is needed to make that work, and is an improvement for now, since it gives FMRs a chance at working. For MPTs, both the device and CPU might write there, so we must allocate DMA coherent memory for these. Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-03-20IB/mthca: Use an enum for HCA page sizeIshai Rabinovitz
Use a named enum for the HCA's internal page size, rather than having magic values of 4096 and shifts by 12 all over the code. Also, fix one minor bug in EQ handling: only one HCA page is mapped to the HCA during initialization, but a full kernel page is unmapped during cleanup. This might cause problems when PAGE_SIZE != 4096. Signed-off-by: Ishai Rabinovitz <ishai@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-01-30IB/mthca: Semaphore to mutex conversionsRoland Dreier
Convert semaphores to mutexes in mthca. Leave firmware command interface poll_sem and event_sem as semaphores. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2005-10-28Merge master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6Roland Dreier
2005-10-28[PATCH] gfp_t: drivers/infinibandAl Viro
2005-10-18[IB] mthca: Use enum in mthca_alloc_db() prototypeRoland Dreier
Make the type parameter of mthca_alloc_db() be an enum mthca_db_type instead of an int. This doesn't have any practical effect but documents the functions a little better. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2005-08-26[PATCH] IB: sparse endianness cleanupSean Hefty
Fix sparse warnings. Use __be* where appropriate. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2005-08-26[PATCH] IB: Add copyright noticesRoland Dreier
Make some lawyers happy and add copyright notices for people who forgot to include them when they actually touched the code. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2005-07-07[PATCH] IB uverbs: add mthca user doorbell record supportRoland Dreier
Add support for userspace doorbell records to mthca. Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] IB/mthca: add mthca_table_find() functionMichael S. Tsirkin
Add mthca_table_find() function, which returns the lowmem address of an entry in a mem-free HCA's context tables. This will be used by the FMR implementation. Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Signed-off-by: Roland Dreier <roland@topspin.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] IB/mthca: map MPT/MTT context in mem-free modeRoland Dreier
In mem-free mode, when allocating memory regions, make sure that the HCA has context memory mapped to cover the virtual space used for the MPT and MTTs being used. Signed-off-by: Roland Dreier <roland@topspin.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
