Update copyright information in the source files.
Signed-off-by: Tatyana Nikolova <Tatyana.E.Nikolova@intel.com>
Signed-off-by: Faisal Latif <Faisal.Latif@intel.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
Fix for reset which happens right after sending a terminate message.
Terminate timer is not deleted when the connection is closed.
Change the PHY clock divisor to make the MDIO clock 2.5MHz, instead of
3.5MHz (which is out of spec).
Support for Packed and Unaligned (PAU) FPDUs is needed for
interoperability between NES and non-NES nodes. When the NES hardware
detects a PAU frame, it will pass it to the driver to process the
frame. NES driver creates a new frame for each FPDU and forwards it
to the hardware to be sent to its associated qp.
Print the IP address of the remote host when a critical asynchronous event is
received.
Fixes a crash that occurs during close when error async event is received.
Terminate message is not sent to the remote node if already processing close.
- unify vlan and nonvlan rx path
- kill nesvnic->vlan_grp and nes_netdev_vlan_rx_register
- allow to turn on/off rx/tx vlan accel via ethtool (set_features)
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
nes_port_ibevent() should not be called when the nes RDMA device is not
registered with the RDMA core. Add missing checks of of_device_registered flag.
Signed-off-by: Maciej Sosnowski <maciej.sosnowski@intel.com>
In case of SFP+ PHY, link status check at interrupt processing can
give false results. For proper link status change detection a delayed
recheck is needed to give nes registers time to settle. Add a
periodic link status recheck scheduled at interrupt to detect
potential delayed registers state changes.
Addresses: http://bugs.openfabrics.org/bugzilla/show_bug.cgi?id=2117
Signed-off-by: Roland Dreier <rolandd@cisco.com>
Depending on link state change, IB_EVENT_PORT_ERR or
IB_EVENT_PORT_ACTIVE should be generated when handling MAC interrupts.
Plugging in a cable happens to result in series of interrupts changing
driver's link state a number of times before finally staying at link
up (e.g. link up, link down, link up, link down, ..., link up). To
prevent sending series of redundant IB_EVENT_PORT_ACTIVE and
IB_EVENT_PORT_ERR events, we use a timer to debounce them in
nes_port_ibevent().
Changing state to CLOSING when FIN is received causes A0 cards to
hang. Fix this by checking for A0 cards in FIN handling.
Signed-off-by: Faisal Latif <faisal.latif@intel.com>
When the driver receives an AE for FIN received, it closes the
connection without changing the state of the connection in the
hardware to closing. By changing the state to closing, hardware will
do a normal close sequence.
Fix confusing indentation that makes a statement look as if it's part of
an if statement when in fact it isn't.
Reported-by: Julia Lawall <julia@diku.dk>
Delete dead code in various places that is shown by gcc 4.6's new
-Wunused-but-set-variable warnings.
When ib_unregister_device() is called from netdev stop during ifdown,
it sometimes hangs. Changes made to indicate port_err to ib_dispatch_event()
during netdev stop and port_active during netdev open. The
ib_unregister_device() is only called during remove of the module.
Change code like
x = expr(++x)
that assigns to x twice without a sequence point in between to the
intended (and well-defined)
x = expr(x + 1)
Commit ce6e74f2 ("RDMA/nes: Make nesadapter->phy_lock usage
consistent") introduced a problem where phy_lock was only unlocked
within an if statement and so nes_process_mac_intr() could return with
phy_lock still held. Fix this.
This was discovered because of the sparse warning:
drivers/infiniband/hw/nes/nes_hw.c:2643:9: warning: context imbalance in 'nes_process_mac_intr' - different lock contexts for basic block
Reported-by: Roland Dreier <rdreier@cisco.com>
Signed-off-by: Chien Tung <chien.tin.tung@intel.com>
Under abnormal termination, modify_qp() closes the QP, and async event
(AE) handling also attempts to close the same QP, causing a crash.
Fix this by checking the state of the QP before processing the AE.
This allows the compiler to do a bit better; on my x86-64 build:
add/remove: 0/2 grow/shrink: 1/0 up/down: 2288/-2365 (-77)
function old new delta
nes_init_phy 273 2561 +2288
nes_init_1g_phy 469 - -469
nes_init_2025_phy 1896 - -1896
nes_{read,write}_1G_phy_reg() are using phy_lock while
nes_{read,write}_10G_phy_reg() leave that to the caller.
Remove phy_lock from 1G routines and leave the locking to the caller.
Add additional phy_lock calls around 1G read/write.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Clear the stall bit to drop any incoming packets while destroying NIC
QP. This will prevent a chip resource leak.
Add support for KR device id 0x0110. While at it, cleanup
nes_init_phy() by splitting it into nes_init_1g_phy() and
nes_init_2025_phy().
Remove support for NES_PHY_TYPE_IRIS, which was used on an XFP board
that was only manufactured in small quantities and given out for evals
in even smaller quantities.
There is a double disconnect during AE processing, causing crashes.
While fixing the crash, also simplify the AE handling code.
STags are generated randomly but the driver does not correctly prevent
a zero STag. Using STag zero is privileged and causes a user space
application to fail. This change prevents the driver from trying to
allocate a zero STag.
Update copyright from Intel-NE, Inc. to Intel Corporation. Use proper
branding string in Kconfig and simplify description.
Add a check to nes_create_cq() to return -EINVAL if creating a CQ with
depth > max_cqe (32766).
Add additional PHY uC status check in case PHY firmware is not running
properly with heartbeat. Add a hard PHY reset if uC status is 0x0
after initial reset.
Replace alloc_fmr, unmap_fmr, dealloc_fmr and map_phys_fmr with
alloc_fast_reg_mr, alloc_fast_reg_page_list, free_fast_reg_page_list.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1623 commits)
netxen: update copyright
netxen: fix tx timeout recovery
netxen: fix file firmware leak
netxen: improve pci memory access
netxen: change firmware write size
tg3: Fix return ring size breakage
netxen: build fix for INET=n
cdc-phonet: autoconfigure Phonet address
Phonet: back-end for autoconfigured addresses
Phonet: fix netlink address dump error handling
ipv6: Add IFA_F_DADFAILED flag
net: Add DEVTYPE support for Ethernet based devices
mv643xx_eth.c: remove unused txq_set_wrr()
ucc_geth: Fix hangs after switching from full to half duplex
ucc_geth: Rearrange some code to avoid forward declarations
phy/marvell: Make non-aneg speed/duplex forcing work for 88E1111 PHYs
drivers/net/phy: introduce missing kfree
drivers/net/wan: introduce missing kfree
net: force bridge module(s) to be GPL
Subject: [PATCH] appletalk: Fix skb leak when ipddp interface is not loaded
Fixed up trivial conflicts:
- arch/x86/include/asm/socket.h
converted to <asm-generic/socket.h> in the x86 tree. The generic
header has the same new #define's, so that works out fine.
- drivers/net/tun.c
fix conflict between 89f56d1e9 ("tun: reuse struct sock fields") that
switched over to using 'tun->socket.sk' instead of the redundantly
available (and thus removed) 'tun->sk', and 2b980dbd ("lsm: Add hooks
to the TUN driver") which added a new 'tun->sk' use.
Noted in 'next' by Stephen Rothwell.
When an asynchronous event occurs that requires a terminate, it is
sometimes possible to identify the wqe in error. This change uses
flush to get this information to the poll routine. The flush
operation puts the status into the cqe. If this information is not
available, it continues to use the more generic flush code as before.
Signed-off-by: Don Wood <donald.e.wood@intel.com>
Implement the sending and receiving of Terminate packets.
CQ errors are not being handled correctly. Put in the the upcall for
CQ errors.
The generic packet receive code takes care of setting
netdev->last_rx when necessary, for the sake of the
bonding ARP monitor.
Acked-by: Neil Horman <nhorman@txudriver.com>
With a postfix increment, i is incremented one past 10K/5K before the
loop ends, so the error messages will be displayed too soon if the
test succeeds on the last iteration. Fix the comparisons to be >
instead of >=.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
With updated PHY firmware for SFP_D, setting the trace length to 1
inch for SFP_D provides a more stable link.
Enable repause timer for port 1. Without this setting, under stress,
the chip may misbehave.
In commit 1b949324 ("RDMA/nes: Fix SFP+ PHY initialization") there is
a mistake in the clean up code that removed port 1 CDR loop filter
settings for 10G cards other than CX4. Put the correct setting back
for appropriate PHY types.
Change thermo mitigation code to flip the SerDes1 reference clock to
internal, to match the change in commit a4849fc1 ("RDMA/nes: Add
wide_ppm_offset parm for switch compatibility").
Add new register settings for new SFP+ PHY/firmware.
Add new PHY to to nes_netdev_get/set_settings.
We have observed unstable link with a new BNT switch.
Add wide_ppm_offset parameter to allow the user to control the clock
ppm offset on the CX4 interface for better compatibility. Default is
100ppm, setting it to 1 will increase it to 300ppm. Change default
SerDes1 reference clock to external source.
SFP+ PHY initialization has very long delays, incorrect settings for
direct attach copper cables, and inconsistent link detection.
Adjust delays to the minimum required by the PHY. Worst case is now
less than 4 seconds. Add new register settings for direct attach
cables. Change link detection logic to use two new registers for more
consistent link state detection. Reorganize code to shorten line
length.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1750 commits)
ixgbe: Allow Priority Flow Control settings to survive a device reset
net: core: remove unneeded include in net/core/utils.c.
e1000e: update version number
e1000e: fix close interrupt race
e1000e: fix loss of multicast packets
e1000e: commonize tx cleanup routine to match e1000 & igb
netfilter: fix nf_logger name in ebt_ulog.
netfilter: fix warning in ebt_ulog init function.
netfilter: fix warning about invalid const usage
e1000: fix close race with interrupt
e1000: cleanup clean_tx_irq routine so that it completely cleans ring
e1000: fix tx hang detect logic and address dma mapping issues
bridge: bad error handling when adding invalid ether address
bonding: select current active slave when enslaving device for mode tlb and alb
gianfar: reallocate skb when headroom is not enough for fcb
Bump release date to 25Mar2009 and version to 0.22
r6040: Fix second PHY address
qeth: fix wait_event_timeout handling
qeth: check for completion of a running recovery
qeth: unregister MAC addresses during recovery.
Manually fixed up conflicts in:
drivers/infiniband/hw/cxgb3/cxio_hal.h
drivers/infiniband/hw/nes/nes_nic.c
NETIF_F_LLTX is deprecated. Remove private TX locking from the driver
and remove the NETIF_F_LLTX feature flag. This also fixes a warning
in some configs that comes from doing skb_linearize() call in the
hard_start_xmit method with IRQs disabled (if HIGHMEM is enabled,
skb_linearize() may end up enabling BHs, which is a no-no if hard IRQs
are disabled in that context). By getting rid of LLTX, we do not
disable IRQs when skb_linearize() is called.
Remove the sq_lock as it is not needed for non-LLTX. Fix ethtool not
to show the counter for sq_lock.
Reported-by: aluno3@poczta.onet.pl
When asynchronous events are processed by software, it is necessary
to let the hardware know that software has handled the event. This
frees up the entry in the asynchronous event queue.
ibv_devinfo displays 0 for vendor_id and vendor_part_id. Fill in OUI
and device_id for those two fields.
Update copyright to the new legal entity, Intel-NE, Inc., an Intel
company. Update copyright for the new year.
Following the removal of the unused struct net_device * parameter from
the NAPI functions named *netif_rx_* in commit 908a7a1, they are
exactly equivalent to the corresponding *napi_* functions and are
therefore redundant.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
