commit 9d194d1025f463392feafa26ff8c2d8247f71be1 upstream.
In case of error while accessing to userspace memory, function
nes_create_qp() returns NULL instead of an error code wrapped through
ERR_PTR(). But NULL is not expected by ib_uverbs_create_qp(), as it
check for error with IS_ERR().
As page 0 is likely not mapped, it is going to trigger an Oops when
the kernel will try to dereference NULL pointer to access to struct
ib_qp's fields.
In some rare cases, page 0 could be mapped by userspace, which could
turn this bug to a vulnerability that could be exploited: the function
pointers in struct ib_device will be under userspace total control.
This was caught when using spatch (aka. coccinelle)
to rewrite calls to ib_copy_{from,to}_udata().
Link: https://www.gitorious.org/opteya/ib-hw-nes-create-qp-null
Link: https://www.gitorious.org/opteya/coccib/source/75ebf2c1033c64c1d81df13e4ae44ee99c989eba:ib_copy_udata.cocci
Link: http://marc.info/?i=cover.1394485254.git.ydroneaud@opteya.com
Signed-off-by: Yann Droneaud <ydroneaud@opteya.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
Set the return variable to an error code as done elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
if@p1 (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret@p1 = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Use the possibly more efficient ether_addr_equal() instead of memcmp().
Signed-off-by: Wang Weidong <wangweidong1@huawei.com>
Signed-off-by: Ding Tianhong <dingtianhong@huawei.com>
Assigning a value to itself is pointless.
Spotted with coverity, no hardware to test.
Signed-off-by: Dave Jones <davej@fedoraproject.org>
Modify the type of local_addr and remote_addr fields in struct
iw_cm_id from struct sockaddr_in to struct sockaddr_storage to hold
IPv6 and IPv4 addresses uniformly.
Change the references of local_addr and remote_addr in cxgb4, cxgb3,
nes and amso drivers to match this. However to be able to actully run
traffic over IPv6, low-level drivers have to add code to support this.
Signed-off-by: Steve Wise <swise@opengridcomputing.com>
Reviewed-by: Sean Hefty <sean.hefty@intel.com>
[ Fix unused variable warnings when INFINIBAND_NES_DEBUG not set.
- Roland ]
This reverts commit bca1935ccdec, which removes variables
nes_tcp_state_str and nes_iwarp_state_str, assuming that they aren't
defined. However, they are defined within a #ifdef NES_DEBUG statement,
which if enabled causes "defined but not used" compiler warning, when
the variables are removed.
Signed-off-by: Tatyana Nikolova <Tatyana.E.Nikolova@intel.com>
We pass a few bytes of uninitialized stack memory to the user here.
Add a protocol argument to the VLAN packet tagging functions. In case of HW
tagging, we need that protocol available in the ndo_start_xmit functions,
so it is stored in a new field in the skb. The new field fits into a hole
(on 64 bit) and doesn't increase the sks's size.
Rename the hardware VLAN acceleration features to include "CTAG" to indicate
that they only support CTAGs. Follow up patches will introduce 802.1ad
server provider tagging (STAGs) and require the distinction for hardware not
supporting acclerating both.
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
Pull infiniband update from Roland Dreier:
"Main batch of InfiniBand/RDMA changes for 3.9:
- SRP error handling fixes from Bart Van Assche
- Implementation of memory windows for mlx4 from Shani Michaeli
- Lots of cxgb4 HW driver fixes from Vipul Pandya
- Make iSER work for virtual functions, other fixes from Or Gerlitz
- Fix for bug in qib HW driver from Mike Marciniszyn
- IPoIB fixes from me, Itai Garbi, Shlomo Pongratz, Yan Burman
- Various cleanups and warning fixes from Julia Lawall, Paul Bolle,
Wei Yongjun"
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (41 commits)
IB/mlx4: Advertise MW support
IB/mlx4: Support memory window binding
mlx4: Implement memory windows allocation and deallocation
mlx4_core: Enable memory windows in {INIT, QUERY}_HCA
mlx4_core: Disable memory windows for virtual functions
IPoIB: Free ipoib neigh on path record failure so path rec queries are retried
IB/srp: Fail I/O requests if the transport is offline
IB/srp: Avoid endless SCSI error handling loop
IB/srp: Avoid sending a task management function needlessly
IB/srp: Track connection state properly
IB/mlx4: Remove redundant NULL check before kfree
IB/mlx4: Fix compiler warning about uninitialized 'vlan' variable
IB/mlx4: Convert is_xxx variables in build_mlx_header() to bool
IB/iser: Enable iser when FMRs are not supported
IB/iser: Avoid error prints on EAGAIN registration failures
IB/iser: Use proper define for the commands per LUN value advertised to SCSI ML
IB/uverbs: Implement memory windows support in uverbs
IB/core: Add "type 2" memory windows support
mlx4_core: Propagate MR deregistration failures to caller
mlx4_core: Rename MPT-related functions to have mpt_ prefix
This patch enhances the IB core support for Memory Windows (MWs).
MWs allow an application to have better/flexible control over remote
access to memory.
Two types of MWs are supported, with the second type having two flavors:
Type 1 - associated with PD only
Type 2A - associated with QPN only
Type 2B - associated with PD and QPN
Applications can allocate a MW once, and then repeatedly bind the MW
to different ranges in MRs that are associated to the same PD. Type 1
windows are bound through a verb, while type 2 windows are bound by
posting a work request.
The 32-bit memory key is composed of a 24-bit index and an 8-bit
key. The key is changed with each bind, thus allowing more control
over the peer's use of the memory key.
The changes introduced are the following:
* add memory window type enum and a corresponding parameter to ib_alloc_mw.
* type 2 memory window bind work request support.
* create a struct that contains the common part of the bind verb struct
ibv_mw_bind and the bind work request into a single struct.
* add the ib_inc_rkey helper function to advance the tag part of an rkey.
Consumer interface details:
* new device capability flags IB_DEVICE_MEM_WINDOW_TYPE_2A and
IB_DEVICE_MEM_WINDOW_TYPE_2B are added to indicate device support
for these features.
Devices can set either IB_DEVICE_MEM_WINDOW_TYPE_2A or
IB_DEVICE_MEM_WINDOW_TYPE_2B if it supports type 2A or type 2B
memory windows. It can set neither to indicate it doesn't support
type 2 windows at all.
* modify existing provides and consumers code to the new param of
ib_alloc_mw and the ib_mw_bind_info structure
Signed-off-by: Haggai Eran <haggaie@mellanox.com>
Signed-off-by: Shani Michaeli <shanim@mellanox.com>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
Documentation/networking/ip-sysctl.txt
drivers/net/ethernet/broadcom/bnx2x/bnx2x_cmn.c
Both conflicts were simply overlapping context.
A build fix for qlcnic is in here too, simply removing the added
devinit annotations which no longer exist.
perm_addr is initialized correctly in register_netdevice() so to init it in
drivers is no longer needed.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Use strlcpy where possible to ensure the string is \0 terminated.
Use always sizeof(string) instead of 32, ETHTOOL_BUSINFO_LEN
and custom defines.
Use snprintf instead of sprint.
Remove unnecessary inits of ->fw_version
Remove unnecessary inits of drvinfo struct.
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: Tom Tucker <tom@opengridcomputing.com>
Cc: Steve Wise <swise@opengridcomputing.com>
Cc: Roland Dreier <roland@kernel.org>
Cc: Sean Hefty <sean.hefty@intel.com>
Cc: Hal Rosenstock <hal.rosenstock@gmail.com>
Cc: Hoang-Nam Nguyen <hnguyen@de.ibm.com>
Cc: Christoph Raisch <raisch@de.ibm.com>
Cc: Mike Marciniszyn <infinipath@intel.com>
Cc: Faisal Latif <faisal.latif@intel.com>
The terminate timer needs to be initialized just once.
To avoid nes tcp_timer crash for SMP architectures, add_timer is
replaced with mod_timer.
Use WARN() rather than printk() followed by WARN_ON(1), for conciseness.
A simplified version of the semantic patch that makes this transformation
is as follows: (http://coccinelle.lip6.fr/)
// <smpl>
expression list es;
-printk(
+WARN(1,
es);
-WARN_ON(1);
// </smpl>
[ Remove extra KERN_ERR from WARN() format. - Roland ]
Locking fix to prevent race conditions. Fpdus (per qp) need to be
forwarded to hardware in the order of their sequence numbers.
Signed-off-by: Donald Wood <Donald.E.Wood@intel.com>
Fix for incorrect ip header address when forwarding fpdus to hardware.
Bumpthe version of the nes driver to reflect recent fixes.
Remove unnecessary if-else statement -- we do the same thing either way.
Static code analyzer cppcheck points out a missing break.
Reported-by: David Binderman <dcb314@hotmail.com>
Addresses: <https://bugzilla.kernel.org/show_bug.cgi?id=47671>
Pull infiniband updates from Roland Dreier:
"First batch of InfiniBand/RDMA changes for the 3.7 merge window:
- mlx4 IB support for SR-IOV
- A couple of SRP initiator fixes
- Batch of nes hardware driver fixes
- Fix for long-standing use-after-free crash in IPoIB
- Other miscellaneous fixes"
This merge also removes a new use of __cancel_delayed_work(), and
replaces it with the regular cancel_delayed_work() that is now irq-safe
thanks to the workqueue updates.
That said, I suspect the sequence in question should probably use
"mod_delayed_work()". I just did the minimal "don't use deprecated
functions" fixup, though.
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (45 commits)
IB/qib: Fix local access validation for user MRs
mlx4_core: Disable SENSE_PORT for multifunction devices
mlx4_core: Clean up enabling of SENSE_PORT for older (ConnectX-1/-2) HCAs
mlx4_core: Stash PCI ID driver_data in mlx4_priv structure
IB/srp: Avoid having aborted requests hang
IB/srp: Fix use-after-free in srp_reset_req()
IB/qib: Add a qib driver version
RDMA/nes: Fix compilation error when nes_debug is enabled
RDMA/nes: Print hardware resource type
RDMA/nes: Fix for crash when TX checksum offload is off
RDMA/nes: Cosmetic changes
RDMA/nes: Fix for incorrect MSS when TSO is on
RDMA/nes: Fix incorrect resolving of the loopback MAC address
mlx4_core: Fix crash on uninitialized priv->cmd.slave_sem
mlx4_core: Trivial cleanups to driver log messages
mlx4_core: Trivial readability fix: "0X30" -> "0x30"
IB/mlx4: Create paravirt contexts for VFs when master IB driver initializes
mlx4: Modify proxy/tunnel QP mechanism so that guests do no calculations
mlx4: Paravirtualize Node Guids for slaves
mlx4: Activate SR-IOV mode for IB
Removing old variables caused a compile error from nes_debug().
Hardware resource types are added and when a resource isn't available,
its type is printed.
When TX checksum offload is disabled for an iWarp connection,
skb->ip_summed needs to be set to CHECKSUM_NONE.
- Remove unnecessary statement "if (1)"
- Refactor a statement (wqe_misc |= NES_NIC_SQ_WQE_COMPLETION) out of
if/else statement, because it is independant of the flow.
- Define netdev->features in one line for clarity.
In TSO handling code, skb_shared_info() is used to get the MSS
instead of the bool function skb_is_gso() (which always returns 1).
Convert delayed_work users doing cancel_delayed_work() followed by
queue_delayed_work() to mod_delayed_work().
Most conversions are straight-forward. Ones worth mentioning are,
* drivers/edac/edac_mc.c: edac_mc_workq_setup() converted to always
use mod_delayed_work() and cancel loop in
edac_mc_reset_delay_period() is dropped.
* drivers/platform/x86/thinkpad_acpi.c: No need to remember whether
watchdog is active or not. @fan_watchdog_active and related code
dropped.
* drivers/power/charger-manager.c: Seemingly a lot of
delayed_work_pending() abuse going on here.
[delayed_]work_pending() are unsynchronized and racy when used like
this. I converted one instance in fullbatt_handler(). Please
conver the rest so that it invokes workqueue APIs for the intended
target state rather than trying to game work item pending state
transitions. e.g. if timer should be modified - call
mod_delayed_work(), canceled - call cancel_delayed_work[_sync]().
* drivers/thermal/thermal_sys.c: thermal_zone_device_set_polling()
simplified. Note that round_jiffies() calls in this function are
meaningless. round_jiffies() work on absolute jiffies not delta
delay used by delayed_work.
v2: Tomi pointed out that __cancel_delayed_work() users can't be
safely converted to mod_delayed_work(). They could be calling it
from irq context and if that happens while delayed_work_timer_fn()
is running, it could deadlock. __cancel_delayed_work() users are
dropped.
Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Acked-by: Anton Vorontsov <cbouatmailru@gmail.com>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Doug Thompson <dougthompson@xmission.com>
Cc: David Airlie <airlied@linux.ie>
Cc: "John W. Linville" <linville@tuxdriver.com>
Cc: Zhang Rui <rui.zhang@intel.com>
Cc: Len Brown <len.brown@intel.com>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: Johannes Berg <johannes@sipsolutions.net>
Don't call the ibqp event_handler pointer in the case it wasn't initialized.
Set ORD value of the connecting peer to be at least one in order to
accommodate an RDMA READ Request message.
Pull InfiniBand/RDMA changes for the 3.4 merge window from Roland Dreier:
"Nothing big really stands out; by patch count lots of fixes to the
mlx4 driver plus some cleanups and fixes to the core and other
drivers."
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (28 commits)
mlx4_core: Scale size of MTT table with system RAM
mlx4_core: Allow dynamic MTU configuration for IB ports
IB/mlx4: Fix info returned when querying IBoE ports
IB/mlx4: Fix possible missed completion event
mlx4_core: Report thermal error events
mlx4_core: Fix one more static exported function
IB: Change CQE "csum_ok" field to a bit flag
RDMA/iwcm: Reject connect requests if cmid is not in LISTEN state
RDMA/cxgb3: Don't pass irq flags to flush_qp()
mlx4_core: Get rid of redundant ext_port_cap flags
RDMA/ucma: Fix AB-BA deadlock
IB/ehca: Fix ilog2() compile failure
IB: Use central enum for speed instead of hard-coded values
IB/iser: Post initial receive buffers before sending the final login request
IB/iser: Free IB connection resources in the proper place
IB/srp: Consolidate repetitive sysfs code
IB/srp: Use pr_fmt() and pr_err()/pr_warn()
IB/core: Fix SDR rates in sysfs
mlx4: Enforce device max FMR maps in FMR alloc
IB/mlx4: Set bad_wr for invalid send opcode
'srp' and 'srpt' into for-next
The kernel IB stack uses one enumeration for IB speed, which wasn't
explicitly specified in the verbs header file. Add that enum, and use
it all over the code.
The IB speed/width notation is also used by iWARP and IBoE HW drivers,
which use the convention of rate = speed * width to advertise their
port link rate.
Fix endianness problems detect by sparse, introduced with the enhanced
MPA patch.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Faisal Latif <Faisal.Latif@intel.com>
drivers/infiniband/hw/nes/nes_cm.c
Simple whitespace conflict.
Update copyright information in the source files.
Fix fast memory registration opcode in local invalidate completion.
Zero high order word of fast memory registration (FMR) length field.
FMR length field is 32 bits, so high word should always be zero.
Make sure all exit paths from this function unlock everything.
Reported-by: Bart Van Assche <bvanassche@acm.org>
Set a reject flag, when sending MPA reject message to inform the peer
that the application has rejected the connection.
Now we must provide the IP destination address, and a reference has
to be dropped when we're done with the entry.
module_param(bool) used to counter-intuitively take an int. In
fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy
trick.
It's time to remove the int/unsigned int option. For this version
it'll simply give a warning, but it'll break next kernel version.
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
