The driver starts the mcast_join task whenever the netdev interface is
UP without relation to the underlying IB port state.
Until the port state is ACTIVE all the join requests are irrelevant,
and the IB core returns -EINVAL. So the user will see errors such as:
"multicast join failed for ff12:401b:... , status -22".
Instead, have ipoib_mcast_join_task() return when the port is not active.
It will be called again when the port state is changed and the
low-level driver triggers the IB_EVENT_PORT_ACTIVE event or the
IB_EVENT_CLIENT_REREGISTER event.
Signed-off-by: Erez Shitrit <erezsh@mellanox.com>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
The driver should avoid calling ib_sa_free_multicast on the mcast->mc
object until it finishes its initialization state. Otherwise we can
crash when ipoib_mcast_dev_flush() attempts to use the uninitialized
multicast object.
Instead, only call wait_for_completion() for multicast entries that
started the join process, meaning that ib_sa_join_multicast() finished.
Fix a crash in ipoib_mcast_join_task(). (with help from Or Gerlitz)
Commit c8c2afe360b7 ("IPoIB: Use rtnl lock/unlock when changing device
flags") added a call to rtnl_lock() in ipoib_mcast_join_task(), which
is run from the ipoib_workqueue, and hence the workqueue can't be
flushed from the context of ipoib_stop().
In the current code, ipoib_stop() (which doesn't flush the workqueue)
calls ipoib_mcast_dev_flush(), which goes and deletes all the
multicast entries. This takes place without any synchronization with
a possible running instance of ipoib_mcast_join_task() for the same
ipoib device, leading to a crash due to NULL pointer dereference.
Fix this by making sure that the workqueue is flushed before
ipoib_mcast_dev_flush() is called. To make that possible, we move the
RTNL-lock wrapped code to ipoib_mcast_join_finish().
Cc: <stable@vger.kernel.org>
Lockdep points out a circular locking dependency betwwen the ipoib
device priv spinlock (priv->lock) and the neighbour table rwlock
(ntbl->rwlock).
In the normal path, ie neigbour garbage collection task, the neigh
table rwlock is taken first and then if the neighbour needs to be
deleted, priv->lock is taken.
However in some error paths, such as in ipoib_cm_handle_tx_wc(),
priv->lock is taken first and then ipoib_neigh_free routine is called
which in turn takes the neighbour table ntbl->rwlock.
The solution is to get rid the neigh table rwlock completely and use
only priv->lock.
Signed-off-by: Shlomo Pongratz <shlomop@mellanox.com>
Dave Miller <davem@davemloft.net> provided a detailed description of
why the way IPoIB is using neighbours for its own ipoib_neigh struct
is buggy:
Any time an ipoib_neigh is changed, a sequence like the following is made:
spin_lock_irqsave(&priv->lock, flags);
* It's safe to call ipoib_put_ah() inside
* priv->lock here, because we know that
* path->ah will always hold one more reference,
* so ipoib_put_ah() will never do more than
* decrement the ref count.
if (neigh->ah)
ipoib_put_ah(neigh->ah);
list_del(&neigh->list);
ipoib_neigh_free(dev, neigh);
spin_unlock_irqrestore(&priv->lock, flags);
ipoib_path_lookup(skb, n, dev);
This doesn't work, because you're leaving a stale pointer to the freed up
ipoib_neigh in the special neigh->ha pointer cookie. Yes, it even fails
with all the locking done to protect _changes_ to *ipoib_neigh(n), and
with the code in ipoib_neigh_free() that NULLs out the pointer.
The core issue is that read side calls to *to_ipoib_neigh(n) are not
being synchronized at all, they are performed without any locking. So
whether we hold the lock or not when making changes to *ipoib_neigh(n)
you still can have threads see references to freed up ipoib_neigh
objects.
cpu 1 cpu 2
n = *ipoib_neigh()
*ipoib_neigh() = NULL
kfree(n)
n->foo == OOPS
Perhaps the ipoib code can have a private path database it manages
entirely itself, which holds all the necessary information and is
looked up by some generic key which is available easily at transmit
time and does not involve generic neighbour entries.
See <http://marc.info/?l=linux-rdma&m=132812793105624&w=2> and
<http://marc.info/?l=linux-rdma&w=2&r=1&s=allows+references+to+freed+memory&q=b>
for the full discussion.
This patch aims to solve the race conditions found in the IPoIB driver.
The patch removes the connection between the core networking neighbour
structure and the ipoib_neigh structure. In addition to avoiding the
race described above, it allows us to handle SKBs carrying IP packets
that don't have any associated neighbour.
We add an ipoib_neigh hash table with N buckets where the key is the
destination hardware address. The ipoib_neigh is fetched from the
hash table and instead of the stashed location in the neighbour
structure. The hash table uses both RCU and reference counting to
guarantee that no ipoib_neigh instance is ever deleted while in use.
Fetching the ipoib_neigh structure instance from the hash also makes
the special code in ipoib_start_xmit that handles remote and local
bonding failover redundant.
Aged ipoib_neigh instances are deleted by a garbage collection task
that runs every M seconds and deletes every ipoib_neigh instance that
was idle for at least 2*M seconds. The deletion is safe since the
ipoib_neigh instances are protected using RCU and reference count
mechanisms.
The number of buckets (N) and frequency of running the GC thread (M),
are taken from the exported arb_tbl.
Otherwise local_bh_enable() complains.
Reported-by: Or Gerlitz <ogerlitz@mellanox.com>
Commit a0417fa3a18a ("net: Make qdisc_skb_cb upper size bound
explicit.") made it possible for a netdev driver to use skb->cb
between its header_ops.create method and its .ndo_start_xmit
method. Use this in ipoib_hard_header() to stash away the LL address
(GID + QPN), instead of the "ipoib_pseudoheader" hack. This allows
IPoIB to stop lying about its hard_header_len, which will let us fix
the L2 check for GRO.
To reflect the fact that a refrence is not obtained to the
resulting neighbour entry.
Acked-by: Roland Dreier <roland@purestorage.com>
Commit f2c31e32b37 ("net: fix NULL dereferences in check_peer_redir()")
forgot to take care of infiniband uses of dst neighbours.
Many thanks to Marc Aurele who provided a nice bug report and feedback.
Reported-by: Marc Aurele La France <tsi@ualberta.ca>
Cc: <stable@kernel.org>
This following can occur with ipoib when processing a multicast reponse:
BUG: soft lockup - CPU#0 stuck for 67s! [ib_mad1:982]
Modules linked in: ...
CPU 0:
Pid: 982, comm: ib_mad1 Not tainted 2.6.32-131.0.15.el6.x86_64 #1 ProLiant DL160 G5
RIP: 0010:[<ffffffff814ddb27>] [<ffffffff814ddb27>] _spin_unlock_irqrestore+0x17/0x20
RSP: 0018:ffff8802119ed860 EFLAGS: 00000246
0000000000000004 RBX: ffff8802119ed860 RCX: 000000000000a299
RDX: ffff88021086c700 RSI: 0000000000000246 RDI: 0000000000000246
RBP: ffffffff8100bc8e R08: ffff880210ac229c R09: 0000000000000000
R10: ffff88021278aab8 R11: 0000000000000000 R12: ffff8802119ed860
R13: ffffffff8100be6e R14: 0000000000000001 R15: 0000000000000003
FS: 0000000000000000(0000) GS:ffff880028200000(0000) knlGS:0000000000000000
CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b
CR2: 00000000006d4840 CR3: 0000000209aa5000 CR4: 00000000000406f0
Call Trace:
[<ffffffffa032c247>] ? ipoib_mcast_send+0x157/0x480 [ib_ipoib]
[<ffffffff8100bc8e>] ? apic_timer_interrupt+0xe/0x20
[<ffffffffa03283d4>] ? ipoib_path_lookup+0x124/0x2d0 [ib_ipoib]
[<ffffffffa03286fc>] ? ipoib_start_xmit+0x17c/0x430 [ib_ipoib]
[<ffffffff8141e758>] ? dev_hard_start_xmit+0x2c8/0x3f0
[<ffffffff81439d0a>] ? sch_direct_xmit+0x15a/0x1c0
[<ffffffff81423098>] ? dev_queue_xmit+0x388/0x4d0
[<ffffffffa032d6b7>] ? ipoib_mcast_join_finish+0x2c7/0x510 [ib_ipoib]
[<ffffffffa032dab8>] ? ipoib_mcast_sendonly_join_complete+0x1b8/0x1f0 [ib_ipoib]
[<ffffffffa02a0946>] ? mcast_work_handler+0x1a6/0x710 [ib_sa]
[<ffffffffa015f01e>] ? ib_send_mad+0xfe/0x3c0 [ib_mad]
[<ffffffffa00f6c93>] ? ib_get_cached_lmc+0xa3/0xb0 [ib_core]
[<ffffffffa02a0f9b>] ? join_handler+0xeb/0x200 [ib_sa]
[<ffffffffa029e4fc>] ? ib_sa_mcmember_rec_callback+0x5c/0xa0 [ib_sa]
[<ffffffffa029e79c>] ? recv_handler+0x3c/0x70 [ib_sa]
[<ffffffffa01603a4>] ? ib_mad_completion_handler+0x844/0x9d0 [ib_mad]
[<ffffffffa015fb60>] ? ib_mad_completion_handler+0x0/0x9d0 [ib_mad]
[<ffffffff81088830>] ? worker_thread+0x170/0x2a0
[<ffffffff8108e160>] ? autoremove_wake_function+0x0/0x40
[<ffffffff810886c0>] ? worker_thread+0x0/0x2a0
[<ffffffff8108ddf6>] ? kthread+0x96/0xa0
[<ffffffff8100c1ca>] ? child_rip+0xa/0x20
Coinciding with stack trace is the following message:
ib0: ib_address_create failed
The code below in ipoib_mcast_join_finish() will note the above
failure in the address handle but otherwise continue:
ah = ipoib_create_ah(dev, priv->pd, &av);
if (!ah) {
ipoib_warn(priv, "ib_address_create failed\n");
} else {
The while loop at the bottom of ipoib_mcast_join_finish() will attempt
to send queued multicast packets in mcast->pkt_queue and eventually
end up in ipoib_mcast_send():
if (!mcast->ah) {
if (skb_queue_len(&mcast->pkt_queue) < IPOIB_MAX_MCAST_QUEUE)
skb_queue_tail(&mcast->pkt_queue, skb);
else {
++dev->stats.tx_dropped;
dev_kfree_skb_any(skb);
My read is that the code will requeue the packet and return to the
ipoib_mcast_join_finish() while loop and the stage is set for the
"hung" task diagnostic as the while loop never sees a non-NULL ah, and
will do nothing to resolve.
There are GFP_ATOMIC allocates in the provider routines, so this is
possible and should be dealt with.
The test that induced the failure is associated with a host SM on the
same server during a shutdown.
This patch causes ipoib_mcast_join_finish() to exit with an error
which will flush the queued mcast packets. Nothing is done to unwind
the QP attached state so that subsequent sends from above will retry
the join.
Reviewed-by: Ram Vepa <ram.vepa@qlogic.com>
Reviewed-by: Gary Leshner <gary.leshner@qlogic.com>
Signed-off-by: Mike Marciniszyn <mike.marciniszyn@qlogic.com>
These files were getting the moduleparam infrastructure from the
implicit presence of module.h being everywhere, but that is going
away soon.
dst_{get,set}_neighbour()
drivers/net/stmmac/stmmac_main.c
drivers/net/wireless/wl12xx/wl1271_cmd.c
drivers/net/wireless/wl12xx/wl1271_main.c
drivers/net/wireless/wl12xx/wl1271_spi.c
net/core/ethtool.c
net/mac80211/scan.c
Converts the list and the core manipulating with it to be the same as uc_list.
+uses two functions for adding/removing mc address (normal and "global"
variant) instead of a function parameter.
+removes dev_mcast.c completely.
+exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for
manipulation with lists on a sandbox (used in bonding and 80211 drivers)
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Finally this bit can be removed. Currently, after the bonding driver is
changed/fixed (32a806c194ea112cfab00f558482dd97bee5e44e net-next-2.6),
that's not possible for an addr with different length than dev->addr_len
to be present in list. Removing this check as in new mc_list there will be
no addrlen in the record.
Apparently bogus mc address can break IPOIB multicast processing. Therefore
returning the check for addrlen back until this is resolved in bonding (I don't
see any other point from where mc address with non-dev->addr_len length can came
from).
Due to the loop complexicity in nes_nic.c, I'm using char* to copy mc addresses
to it.
Multicast joins can succeed even if the IB port is down. This happens
when the SM runs on the same port with the requesting port. However,
IPoIB calls netif_carrier_on() when the join of the broadcast group
succeeds, without caring about the state of the IB port. The result
is an IPoIB interface in RUNNING state but without an active IB port
to support it.
If a bonding interface uses this IPoIB interface as a slave it might
not detect that this slave is almost useless and failover
functionality will be damaged. The fix checks the state of the IB
port in the carrier_task before calling netif_carrier_on().
Adresses: https://bugs.openfabrics.org/show_bug.cgi?id=1726
Signed-off-by: Moni Shoua <monis@voltaire.com>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
Check that the format of multicast link addresses is correct before
taking them from dev->mc_list to priv->multicast_list. This way we
never try to send a bogus address to the SA, which prevents badness
from erronous 'ip maddr addr add', broken bonding drivers, etc.
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
IPoIB currently must use irqsave locking for priv->lock, since it is
taken from interrupt context in one path. However, ipoib_send() does
skb_orphan(), and the network stack locking is not IRQ-safe.
Therefore we need to make sure we don't hold priv->lock when calling
ipoib_send() to avoid lockdep warnings (the code was almost certainly
safe in practice, since the only code path that takes priv->lock from
interrupt context would never call into the network stack).
Addresses: http://bugzilla.kernel.org/show_bug.cgi?id=13757
Reported-by: Bart Van Assche <bart.vanassche@gmail.com>
Define three accessors to get/set dst attached to a skb
struct dst_entry *skb_dst(const struct sk_buff *skb)
void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst)
void skb_dst_drop(struct sk_buff *skb)
This one should replace occurrences of :
dst_release(skb->dst)
skb->dst = NULL;
Delete skb->dst field
When IPoIB tries to join a multicast group, and the SA module's SM
address handle is NULL (because of an SM change, etc), the join
returns with -EAGAIN status. In that case, don't print an error
message unless multicast debugging is enabled.
Signed-off-by: Yossi Etigin <yosefe@voltaire.com>
Because the ipoib_workqueue is not flushed when ipoib interface is
brought down, ipoib_mcast_join() may trigger a join to the broadcast
group after priv->broadcast was set to NULL (during cleanup). This
will cause the system to be a member of the broadcast group when
interface is down. As a side effect, this breaks the optimization of
setting the Q_key only when joining the broadcast group.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Replace all uses of IPOIB_GID_FMT, IPOIB_GID_RAW_ARG() and IPOIB_GID_ARG()
Currently, IPoIB is an LLTX driver that uses its own IRQ-disabling
tx_lock. Not only do we want to get rid of LLTX, this actually causes
problems because of the skb_orphan() done with this tx_lock held: some
skb destructors expect to be run with interrupts enabled.
The simplest fix for this is to get rid of the driver-private tx_lock
and stop using LLTX. We kill off priv->tx_lock and use
netif_tx_lock[_bh]() instead; the patch to do this is a tiny bit
tricky because we need to update places that take priv->lock inside
the tx_lock to disable IRQs, rather than relying on tx_lock having
already disabled IRQs.
Also, there are a couple of places where we need to disable BHs to
make sure we have a consistent context to call netif_tx_lock() (since
we no longer can use _irqsave() variants), and we also have to change
ipoib_send_comp_handler() to call drain_tx_cq() through a timer rather
than directly, because ipoib_send_comp_handler() runs in interrupt
context and drain_tx_cq() must run in BH context so it can call
netif_tx_lock().
Taking rtnl_lock in ipoib_mcast_join_complete() causes a deadlock with
ipoib_stop(). We avoid it by scheduling the piece of code that takes
the lock on ipoib_workqueue instead of executing it directly. This
works because we only flush the ipoib_workqueue with the RTNL not held.
The deadlock happens because ipoib_stop() calls ipoib_ib_dev_down()
which calls ipoib_mcast_dev_flush(), which calls ipoib_mcast_free(),
which calls ipoib_mcast_leave(). The latter calls
ib_sa_free_multicast(), and this waits until the multicast completion
handler finishes. This handler is ipoib_mcast_join_complete(), which
waits for the rtnl_lock(), which was already taken by ipoib_stop().
This bug was introduced in commit a77a57a1 ("IPoIB: Fix deadlock on
RTNL in ipoib_stop()").
Commit c8c2afe3 ("IPoIB: Use rtnl lock/unlock when changing device
is run from the ipoib_workqueue. However, ipoib_stop() (which is run
inside rtnl_lock()) flushes this workqueue, which leads to a deadlock
if the join task is pending.
Fix this by simply not flushing the workqueue from ipoib_stop(). It
turns out that we really don't care about workqueue tasks running
during or after ipoib_stop(), as long as we make sure to flush the
workqueue before unregistering a netdev.
This fixes <https://bugs.openfabrics.org/show_bug.cgi?id=1114>.
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
Documentation/powerpc/booting-without-of.txt
drivers/atm/Makefile
drivers/net/fs_enet/fs_enet-main.c
drivers/pci/pci-acpi.c
net/8021q/vlan.c
net/iucv/iucv.c
Now that we have a specific lock to protect the network
device unicast and multicast lists, remove extraneous
grabs of the TX lock in cases where the code only needs
address list protection.
Add netif_addr_{lock,unlock}{,_bh}() helpers.
Use them to protect operations that operate on or read
the network device unicast and multicast address lists.
Also use them in cases where the code simply wants to
block calls into the driver's ->set_rx_mode() and
->set_multicast_list() methods.
When the driver sets the MTU of the net device outside of its
change_mtu method, it should make use of dev_set_mtu() instead of
directly setting the mtu field of struct netdevice. Otherwise
functions registered to be called upon MTU change will not get called
(this is done through call_netdevice_notifiers() in dev_set_mtu()).
Signed-off-by: Eli Cohen <eli@mellanox.co.il>
Use of this lock is required to synchronize changes to the netdvice's
data structs. Also move the call to ipoib_flush_paths() after the
modification of the netdevice flags in set_mode().
ipoib_mcast_detach() does nothing except call ib_detach_mcast(), so just
use the core API in the one place that does a multicast group detach.
add/remove: 0/1 grow/shrink: 0/1 up/down: 0/-105 (-105)
function old new delta
ipoib_mcast_leave 357 319 -38
ipoib_mcast_detach 67 - -67
The current code will set the Q_Key for any join of a non-sendonly
multicast group. The operation involves a modify QP operation, which
is fairly heavyweight, and is only really required after the join of
the broadcast group. Fix this by adding a parameter to ipoib_mcast_attach()
to control when the Q_Key is set.
The IPOIB_MCAST_STARTED flag is not used at all since commit b3e2749b
("IPoIB: Don't drop multicast sends when they can be queued"), so
remove it.
They don't get updated by git and so they're worse than useless.
We saw a kernel oops in our regression testing when a multicast "join
finish" occurred just after the interface was -- this is
<https://bugs.openfabrics.org/show_bug.cgi?id=1040>. The test
randomly causes the HCA physical port to go down then up.
The cause of this is that ipoib_mcast_join_finish() processing happen
just after ipoib_mcast_dev_flush() was invoked (in which case the
broadcast pointer is NULL). This patch tests for and handles the case
where priv->broadcast is NULL.
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
This patch enables IPoIB to use 4K UD messages (when the underlying
device and fabrics support a 4K MTU) by using two scatter buffers when
PAGE_SIZE is less than or equal to thhe HCA IB MTU size. The first
buffer is for IPoIB header + GRH header, and the second buffer is the
IPoIB payload, which is 4K-4.
Signed-off-by: Shirley Ma <xma@us.ibm.com>
When set_multicast_list() is called the multicast task is restarted
and the IPOIB_MCAST_STARTED bit is cleared. As a result for some
window of time, multicast packets are not transmitted nor queued but
rather dropped by ipoib_mcast_send(). These dropped packets are
painful in two cases:
- bonding fail-over which both calls set_multicast_list() on the new
active slave and sends Gratuitous ARP through that slave.
- IP_DROP_MEMBERSHIP code which both calls set_multicast_list() on the
device and issues IGMP leave.
In both these cases, depending on the scheduling of the IPoIB
multicast task, the packets would be dropped. As a result, in the
bonding case, the failover would not be detected by the peers until
their neighbour is renewed the neighbour (which takes a few tens of
seconds). In the IGMP case, the IP router doesn't get an IGMP leave
and would only learn on that from further probes on the group (also a
delay of at least a few tens of seconds).
Fix this by allowing transmission (or queuing) depending on the
IPOIB_FLAG_OPER_UP flag instead of the IPOIB_MCAST_STARTED flag.
Signed-off-by: Olga Shern <olgas@voltaire.com>
Signed-off-by: Or Gerlitz <ogerlitz@voltaire.com>
An IPoIB subnet on an IB fabric that spans multiple IB subnets can't
use link-local scope in multicast GIDs. The existing routines that
map IP/IPv6 multicast addresses into IB link-level addresses hard-code
the scope to link-local, and they also leave the partition key field
uninitialised. This patch adds a parameter (the link-level broadcast
address) to the mapping routines, allowing them to initialise both the
scope and the P_Key appropriately, and fixes up the call sites.
The next step will be to add a way to configure the scope for an IPoIB
interface.
Signed-off-by: Rolf Manderscheid <rvm@obsidianresearch.com>
Fix whitespace blunders, convert "foo* bar" to "foo *bar", etc.
IPoIB uses a two layer neighboring scheme, such that for each struct neighbour
whose device is an ipoib one, there is a struct ipoib_neigh buddy which is
created on demand at the tx flow by an ipoib_neigh_alloc(skb->dst->neighbour)
call.
When using the bonding driver, neighbours are created by the net stack on behalf
of the bonding (master) device. On the tx flow the bonding code gets an skb such
that skb->dev points to the master device, it changes this skb to point on the
slave device and calls the slave hard_start_xmit function.
Under this scheme, ipoib_neigh_destructor assumption that for each struct
neighbour it gets, n->dev is an ipoib device and hence netdev_priv(n->dev)
can be casted to struct ipoib_dev_priv is buggy.
To fix it, this patch adds a dev field to struct ipoib_neigh which is used
instead of the struct neighbour dev one, when n->dev->flags has the
IFF_MASTER bit set.
Signed-off-by: Moni Shoua <monis at voltaire.com>
Signed-off-by: Or Gerlitz <ogerlitz at voltaire.com>
Acked-by: Roland Dreier <rdreier@cisco.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (87 commits)
mlx4_core: Fix section mismatches
IPoIB: Allow setting policy to ignore multicast groups
IB/mthca: Mark error paths as unlikely() in post_srq_recv functions
IB/ipath: Minor fix to ordering of freeing and zeroing of tid pages.
IB/ipath: Remove redundant link state checks
IB/ipath: Fix IB_EVENT_PORT_ERR event
IB/ipath: Better handling of unexpected GPIO interrupts
IB/ipath: Maintain active time on all chips
IB/ipath: Fix QHT7040 serial number check
IB/ipath: Indicate a couple of chip bugs to userspace
IB/ipath: iba6110 rev4 no longer needs recv header overrun workaround
IB/ipath: Use counters in ipath_poll and cleanup interrupts in ipath_close
IB/ipath: Remove duplicate copy of LMC
IB/ipath: Add ability to set the LMC via the sysfs debugging interface
IB/ipath: Optimize completion queue entry insertion and polling
IB/ipath: Implement IB_EVENT_QP_LAST_WQE_REACHED
IB/ipath: Generate flush CQE when QP is in error state
IB/ipath: Remove redundant code
IB/ipath: Future proof eeprom checksum code (contents reading)
IB/ipath: UC RDMA WRITE with IMMEDIATE doesn't send the immediate
Use the stats member of struct netdevice in IPoIB, so we can save
memory by deleting the stats member of struct ipoib_dev_priv, and save
code by deleting ipoib_get_stats().
The kernel IB stack allows (through the RDMA CM) userspace
applications to join and use multicast groups from the IPoIB MGID
range. This allows multicast traffic to be handled directly from
userspace QPs, without going through the kernel stack, which gives
better performance for some applications.
However, to fully interoperate with IP multicast, such userspace
applications need to participate in IGMP reports and queries, or else
routers may not forward the multicast traffic to the system where the
application is running. The simplest way to do this is to share the
kernel IGMP implementation by using the IP_ADD_MEMBERSHIP option to
join multicast groups that are being handled directly in userspace.
However, in such cases, the actual multicast traffic should not also
be handled by the IPoIB interface, because that would burn resources
handling multicast packets that will just be discarded in the kernel.
To handle this, this patch adds lookup on the database used for IB
multicast group reference counting when IPoIB is joining multicast
groups, and if a multicast group is already handled by user space,
then the IPoIB kernel driver ignores the group. This is controlled by
a per-interface policy flag. When the flag is set, IPoIB will not
join and attach its QP to a multicast group which already has an entry
in the database; when the flag is cleared, IPoIB will behave as before
this change.
For each IPoIB interface, the /sys/class/net/$intf/umcast attribute
controls the policy flag. The default value is off/0.
To support QoS within and between subnets, modify IPoIB to request
specific Traffic Class values with path record queries, using
the value associated with the IPoIB broadcast group.
Signed-off-by: Sean Hefty <sean.hefty@intel.com>
[ See some comments I made on this at v1 and v2 of the posts
<http://lists.openfabrics.org/pipermail/general/2007-August/039275.html>
<http://lists.openfabrics.org/pipermail/general/2007-September/040312.html> ]
Reviewed-by: Or Gerlitz <ogerlitz@voltaire.com>
