path: root/drivers/infiniband/ulp/iser/iser_verbs.c
2011-05-25RDMA/cma: Pass QP type into rdma_create_id()Sean Hefty
The RDMA CM currently infers the QP type from the port space selected by the user. In the future (eg with RDMA_PS_IB or XRC), there may not be a 1-1 correspondence between port space and QP type. For netlink export of RDMA CM state, we want to export the QP type to userspace, so it is cleaner to explicitly associate a QP type to an ID. Modify rdma_create_id() to allow the user to specify the QP type, and use it to make our selections of datagram versus connected mode. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2010-05-12IB/iser: Fix error flow in iser_create_ib_conn_res()Dan Carpenter
We shouldn't free things here because we free them later. The call tree looks like this: iser_connect() ==> initiating the connection establishment and later iser_cma_handler() => iser_route_handler() => iser_create_ib_conn_res() if we fail here, eventually iser_conn_release() is called, resulting in a double free. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Or Gerlitz <ogerlitz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-05-12IB/iser: Enhance disconnection logic for multi-pathingOr Gerlitz
The iser connection teardown flow isn't over until the underlying Connection Manager (e.g the IB CM) delivers a disconnected or timeout event through the RDMA-CM. When the remote (target) side isn't reachable, e.g when some HW e.g port/hca/switch isn't functioning or taken down administratively, the CM timeout flow is used and the event may be generated only after relatively long time -- on the order of tens of seconds. The current iser code exposes this possibly long delay to higher layers, specifically to the iscsid daemon and iscsi kernel stack. As a result, the iscsi stack doesn't respond well: this low-level CM delay is added to the fail-over time under HA schemes such as the one provided by DM multipath through the multipathd(8) service. This patch enhances the reference counting scheme on iser's IB connections so that the disconnect flow initiated by iscsid from user space (ep_disconnect) doesn't wait for the CM to deliver the disconnect/timeout event. (The connection teardown isn't done from iser's view point until the event is delivered) The iser ib (rdma) connection object is destroyed when its reference count reaches zero. When this happens on the RDMA-CM callback context, extra care is taken so that the RDMA-CM does the actual destroying of the associated ID, since doing it in the callback is prohibited. The reference count of iser ib connection normally reaches three, where the <ref, deref> relations are 1. conn <init, terminate> 2. conn <bind, stop/destroy> 3. cma id <create, disconnect/error/timeout callbacks> With this patch, multipath fail-over time is about 30 seconds, while without this patch, multipath fail-over time is about 130 seconds. Signed-off-by: Or Gerlitz <ogerlitz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-05-12IB/iser: Remove buggy back-pointer settingOr Gerlitz
The iscsi connection object life cycle includes binding and unbinding (conn_stop) to/from the iscsi transport connection object. Since iscsi connection objects are recycled, at the time the transport connection (e.g iser's IB connection) is released, it is not valid to touch the iscsi connection tied to the transport back-pointer since it may already point to a different transport connection. Signed-off-by: Or Gerlitz <ogerlitz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-05-12IB/iser: Add asynchronous event handlerOr Gerlitz
Add handler to handle events such as port up and down. This is useful when testing high-availability schemes such as multi-pathing. Signed-off-by: Or Gerlitz <ogerlitz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-24IB/iser: Remove unnecessary connection checksOr Gerlitz
Remove unnecessary checks for the IB connection state and for QP overflow, as conn state changes are reported by iSER to libiscsi and handled there. QP overflow is theoretically possible only when unsolicited data-outs are used; anyway it's being checked and handled by HW drivers. Signed-off-by: Or Gerlitz <ogerlitz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-02-24IB/iser: Simplify send flow/descriptorsOr Gerlitz
Simplify and shrink the logic/code used for the send descriptors. Changes include removing struct iser_dto (an unnecessary abstraction), using struct iser_regd_buf only for handling SCSI commands, using dma_sync instead of dma_map/unmap, etc. Signed-off-by: Or Gerlitz <ogerlitz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-02-24IB/iser: Use different CQ for send completionsOr Gerlitz
Use a different CQ for send completions, where send completions are polled by the interrupt-driven receive completion handler. Therefore, interrupts aren't used for the send CQ. Signed-off-by: Or Gerlitz <ogerlitz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-02-24IB/iser: Remove atomic counter for posted receive buffersOr Gerlitz
Now that both the posting and reaping of receive buffers is done in the completion path, the counter of outstanding buffers not be atomic. Signed-off-by: Or Gerlitz <ogerlitz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-02-24IB/iser: New receive buffer posting logicOr Gerlitz
Currently, the recv buffer posting logic is based on the transactional nature of iSER which allows for posting a buffer before sending a PDU. Change this to post only when the number of outstanding recv buffers is below a water mark and in a batched manner, thus simplifying and optimizing the data path. Use a pre-allocated ring of recv buffers instead of allocating from kmem cache. A special treatment is given to the login response buffer whose size must be 8K unlike the size of buffers used for any other purpose which is 128 bytes. Signed-off-by: Or Gerlitz <ogerlitz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-02-24IB/iser: Revert commit bba7ebb "avoid recv buffer exhaustion"Or Gerlitz
We will make a major change in the recv buffer posting logic, after which the problem commit bba7ebb "avoid recv buffer exhaustion caused by unexpected PDUs" comes to solve doesn't exist any more, so revert it. Signed-off-by: Or Gerlitz <ogerlitz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-12-04tree-wide: fix some typos and punctuation in commentsThadeu Lima de Souza Cascardo
fix some typos and punctuation in comments Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-02-27IB/iser: Remove hard setting of path MTUOr Gerlitz
Remove hard setting of the IB MTU used by iSER's RC queue-pair to 1K, as this was done due to inter-op issues with an old iser target which is not used any more. Signed-off-by: Or Gerlitz <ogerlitz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-12-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1429 commits) net: Allow dependancies of FDDI & Tokenring to be modular. igb: Fix build warning when DCA is disabled. net: Fix warning fallout from recent NAPI interface changes. gro: Fix potential use after free sfc: If AN is enabled, always read speed/duplex from the AN advertising bits sfc: When disabling the NIC, close the device rather than unregistering it sfc: SFT9001: Add cable diagnostics sfc: Add support for multiple PHY self-tests sfc: Merge top-level functions for self-tests sfc: Clean up PHY mode management in loopback self-test sfc: Fix unreliable link detection in some loopback modes sfc: Generate unique names for per-NIC workqueues 802.3ad: use standard ethhdr instead of ad_header 802.3ad: generalize out mac address initializer 802.3ad: initialize ports LACPDU from const initializer 802.3ad: remove typedef around ad_system 802.3ad: turn ports is_individual into a bool 802.3ad: turn ports is_enabled into a bool 802.3ad: make ntt bool ixgbe: Fix set_ringparam in ixgbe to use the same memory pools. ... Fixed trivial IPv4/6 address printing conflicts in fs/cifs/connect.c due to the conversion to %pI (in this networking merge) and the addition of doing IPv6 addresses (from the earlier merge of CIFS).
2008-12-21IB/iser: Avoid recv buffer exhaustion caused by unexpected PDUsDavid Disseldorp
iSCSI/iSER targets may send PDUs without a prior request from the initiator. RFC 5046 refers to these PDUs as "unexpected". NOP-In PDUs with itt=RESERVED and Asynchronous Message PDUs occupy this category. The amount of active "unexpected" PDU's an iSER target may have at any time is governed by the MaxOutstandingUnexpectedPDUs key, which is not yet supported. Currently when an iSER target sends an "unexpected" PDU, the initiators recv buffer consumed by the PDU is not replaced. If over initial_post_recv_bufs_num "unexpected" PDUs are received then the receive queue will run out of receive work requests entirely. This patch ensures recv buffers consumed by "unexpected" PDUs are replaced in the next iser_post_receive_control() call. Signed-off-by: David Disseldorp <ddiss@sgi.com> Signed-off-by: Ken Sandars <ksandars@sgi.com> Acked-by: Or Gerlitz <ogerlitz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-10-31drivers: replace NIPQUAD()Harvey Harrison
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u can be replaced with %pI4 Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-23removed unused #include <linux/version.h>'sAdrian Bunk
This patch lets the files using linux/version.h match the files that #include it. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-22IB/iser: Add support for RDMA_CM_EVENT_ADDR_CHANGE eventOr Gerlitz
Enhance iser to act upon notification on network stack changes that make its RDMA connection unaligned with the link used by the stack for the <src,dst> IPs used to establish the connection. When RDMA_CM_EVENT_ADDR_CHANGE arrives, just disconnect the connection, assuming that the user space iscsid daemon will reconnect, and the new connection will be aligned with the IP stack. Signed-off-by: Or Gerlitz <ogerlitz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (102 commits) [SCSI] scsi_dh: fix kconfig related build errors [SCSI] sym53c8xx: Fix bogus sym_que_entry re-implementation of container_of [SCSI] scsi_cmnd.h: remove double inclusion of linux/blkdev.h [SCSI] make struct scsi_{host,target}_type static [SCSI] fix locking in host use of blk_plug_device() [SCSI] zfcp: Cleanup external header file [SCSI] zfcp: Cleanup code in zfcp_erp.c [SCSI] zfcp: zfcp_fsf cleanup. [SCSI] zfcp: consolidate sysfs things into one file. [SCSI] zfcp: Cleanup of code in zfcp_aux.c [SCSI] zfcp: Cleanup of code in zfcp_scsi.c [SCSI] zfcp: Move status accessors from zfcp to SCSI include file. [SCSI] zfcp: Small QDIO cleanups [SCSI] zfcp: Adapter reopen for large number of unsolicited status [SCSI] zfcp: Fix error checking for ELS ADISC requests [SCSI] zfcp: wait until adapter is finished with ERP during auto-port [SCSI] ibmvfc: IBM Power Virtual Fibre Channel Adapter Client Driver [SCSI] sg: Add target reset support [SCSI] lib: Add support for the T10 (SCSI) Data Integrity Field CRC [SCSI] sd: Move scsi_disk() accessor function to sd.h ...
2008-07-14RDMA: Remove subversion $Id tagsRoland Dreier
They don't get updated by git and so they're worse than useless. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-12[SCSI] iser: Modify iser to take a iscsi_endpoint struct in ep callouts and ↵Mike Christie
session setup This hooks iser into the iscsi endpoint code. Previously it handled the lookup and allocation. This has been made generic so bnx2i and iser can share it. It also allows us to pass iser the leading conn's ep, so we know the ib_deivce being used and can set it as the scsi_host's parent. And that allows scsi-ml to set the dma_mask based on those values. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] iser: fix handling of scsi cmnds during recovery.Mike Christie
After the stop_conn callback has returned the LLD should not touch the scsi cmds. iscsi_tcp and libiscsi use the conn->recv_lock and suspend_rx field to halt recv path processing, but iser does not have any protection. This patch modifies iser so that userspace can just call the ep_disconnect callback, which will halt all recv IO, before calling the stop_conn callback so we do not have to worry about the conn->recv_lock and suspend rx field. iser just needs to stop the send side from accessing the ib conn. Fixup to handle when the ep poll fails and ep disconnect is called from Erez. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-16IB/iser: Release connection resources on RDMA_CM_EVENT_DEVICE_REMOVAL eventErez Zilber
When a RDMA_CM_EVENT_DEVICE_REMOVAL event is raised, iSER should release the connection resources. This is necessary when the IB HCA module is unloaded while open-iscsi is still running. Currently, iSER just BUG()s. Signed-off-by: Erez Zilber <erezz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-03-10IB/iser: Handle iser_device allocation error gracefullyArne Redlich
"iser_device" allocation failure is "handled" with a BUG_ON() right before dereferencing the NULL-pointer - fix this! Signed-off-by: Arne Redlich <arne.redlich@xiranet.com> Signed-off-by: Erez Zilber <erezz@voltaire.com>
2008-03-10IB/iser: Fix list iteration bugArne Redlich
The iteration through the list of "iser_device"s during device lookup/creation is broken -- it might result in an infinite loop if more than one HCA is used with iSER. Fix this by using list_for_each_entry() instead of the open-coded flawed list iteration code. Signed-off-by: Arne Redlich <arne.redlich@xiranet.com> Signed-off-by: Erez Zilber <erezz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/iser: Print information about unhandled RDMA CM eventsErez Zilber
Some RDMA CM events are not supported or not handled in iSER. This patch adds some info (printk) for the user about them. Signed-off-by: Erez Zilber <erezz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/iser: Typo fix (s/destory/destroy/)Oliver Pinter
Signed-off-by: Oliver Pinter <oliver.pntr@gmail.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-10-09IB/iser: Remove unnecessary includesRoland Dreier
<asm/scatterlist.h> is not needed because everyplace it appears, <linux/scatterlist.h> also appears. <asm/io.h> is not needed because nothing seems to be using device IO anyway. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-07-17IB/iser: Make a couple of functions staticRoland Dreier
Make iser_conn_release() and iser_start_rdma_unaligned_sg() static, since they are only used in the .c file where they are defined. In addition to being a cleanup, this even shrinks the generated code by allowing the single call of iser_start_rdma_unaligned_sg() to be inlined into its callsite. On x86_64: add/remove: 0/1 grow/shrink: 1/0 up/down: 466/-533 (-67) function old new delta iser_reg_rdma_mem 1518 1984 +466 iser_start_rdma_unaligned_sg 533 - -533 Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-06-02[SCSI] libiscsi: make can_queue configurableMike Christie
This patch allows us to set can_queue and cmds_per_lun from userspace when we create the session/host. From there we can set it on a per target basis. The patch fully converts iscsi_tcp, but only hooks up ib_iser for cmd_per_lun since it currently has a lots of preallocations based on can_queue. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: Roland Dreier <rdreier@cisco.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-06IB: Add CQ comp_vector supportMichael S. Tsirkin
Add a num_comp_vectors member to struct ib_device and extend ib_create_cq() to pass in a comp_vector parameter -- this parallels the userspace libibverbs API. Update all hardware drivers to set num_comp_vectors to 1 and have all ULPs pass 0 for the comp_vector value. Pass the value of num_comp_vectors to userspace rather than hard-coding a value of 1. We want multiple CQ event vector support (via MSI-X or similar for adapters that can generate multiple interrupts), but it's not clear how many vectors we want, or how we want to deal with policy issues such as how to decide which vector to use or how to set up interrupt affinity. This patch is useful for experimenting, since no core changes will be necessary when updating a driver to support multiple vectors, and we know that we want to make at least these changes anyway. Signed-off-by: Michael S. Tsirkin <mst@dev.mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-04-05IB/iser: Don't defer connection failure notification to workqueueErez Zilber
When a connection is terminated asynchronously from the iSCSI layer's perspective, iSER needs to notify the iSCSI layer that the connection has failed. This is done using a workqueue (switched to from the iSER tasklet context). Meanwhile, the connection object (that holds the work struct) is released. If the workqueue function wasn't called yet, it will be called later with a NULL pointer, which will crash the kernel. The context switch (tasklet to workqueue) is not required, and everything can be done from the iSER tasklet. This eliminates the NULL work struct bug (and simplifies the code). Signed-off-by: Erez Zilber <erezz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-09-28IB/iser: Have iSER data transaction object point to iSER connErez Zilber
iSER uses a data transaction object (struct iser_dto) as part of its IB data descriptors (struct iser_desc) management. It also uses a hierarchy of connection structures pointing to each other. A DTO may exist even after the iscsi_iser connection pointed by it is destroyed (eg one that is bound to a post receive buffer which was flushed by the IB HW). Hence DTOs need point to the lowest connection, which is struct iser_conn. Signed-off-by: Erez Zilber <erezz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB/iser: Do not use FMR for a single dma entry sgErez Zilber
Fast Memory Registration (fmr) is used to register for rdma an sg whose elements are not linearly sequential after dma mapping. The IB verbs layer provides an "all dma memory MR (memory region)" which can be used for RDMA-ing a dma linearly sequential buffer. Change the code to use the dma mr instead of doing fmr when dma mapping produces a single dma entry sg. Signed-off-by: Erez Zilber <erezz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB/iser: make FMR "page size" be 4K and not PAGE_SIZEErez Zilber
As iser is able to use at most one rdma operation for the execution of a scsi command, and registration of the sg associated with scsi command has its restrictions, the code checks if an sg is "aligned for rdma". Alignment for rdma is measured in "fmr page" units whose possible resolutions are different between HCAs and can be smaller, equal or bigger to the system page size. When the system page size is bigger than 4KB (eg the default with ia64 kernels) there a bigger chance that an sg would be aligned for rdma if the fmr page size is 4KB. Change the code to create FMR whose pages are of size 4KB and to take that into account when processing the sg. Signed-off-by: Erez Zilber <erezz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-07-14[PATCH] fmr pool: remove unnecessary pointer dereferenceMichael S. Tsirkin
ib_fmr_pool_map_phys gets the virtual address by pointer but never writes there, and users (e.g. srp) seem to assume this and ignore the value returned. This patch cleans up the API to get the VA by value, and updates all users. Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Acked-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-22IB/iser: iSER RDMA CM (CMA) and IB verbs interactionOr Gerlitz
This file contains the low level interaction with the RDMA CM and the IB verbs, where iSER is consumer of both. Signed-off-by: Or Gerlitz <ogerlitz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
