path: root/drivers/infiniband
2014-05-13iser-target: Add missing se_cmd put for WRITE_PENDING in tx_comp_errNicholas Bellinger
commit 03e7848a64ed535a30f5d7fc6dede2d5a6a2534b upstream. This patch fixes a bug where outstanding RDMA_READs with WRITE_PENDING status require an extra target_put_sess_cmd() in isert_put_cmd() code when called from isert_cq_tx_comp_err() + isert_cq_drain_comp_llist() context during session shutdown. The extra kref PUT is required so that transport_generic_free_cmd() invokes the last target_put_sess_cmd() -> target_release_cmd_kref(), which will complete(&se_cmd->cmd_wait_comp) the outstanding se_cmd descriptor with WRITE_PENDING status, and awake the completion in target_wait_for_sess_cmds() to invoke TFO->release_cmd(). The bug was manifesting itself in target_wait_for_sess_cmds() where a se_cmd descriptor with WRITE_PENDING status would end up sleeping indefinately. Acked-by: Sagi Grimberg <sagig@mellanox.com> Cc: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-06ib_srpt: Use correct ib_sg_dma primitivesMike Marciniszyn
commit b076808051f2c80d38e03fb2f1294f525c7a446d upstream. The code was incorrectly using sg_dma_address() and sg_dma_len() instead of ib_sg_dma_address() and ib_sg_dma_len(). This prevents srpt from functioning with the Intel HCA and indeed will corrupt memory badly. Cc: Bart Van Assche <bvanassche@acm.org> Reviewed-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Tested-by: Vinod Kumar <vinod.kumar@intel.com> Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-06IB/ehca: Returns an error on ib_copy_to_udata() failureYann Droneaud
commit 5bdb0f02add5994b0bc17494f4726925ca5d6ba1 upstream. In case of error when writing to userspace, function ehca_create_cq() does not set an error code before following its error path. This patch sets the error code to -EFAULT when ib_copy_to_udata() fails. This was caught when using spatch (aka. coccinelle) to rewrite call to ib_copy_{from,to}_udata(). Link: https://www.gitorious.org/opteya/coccib/source/75ebf2c1033c64c1d81df13e4ae44ee99c989eba:ib_copy_udata.cocci Link: http://marc.info/?i=cover.1394485254.git.ydroneaud@opteya.com Signed-off-by: Yann Droneaud <ydroneaud@opteya.com> Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-06IB/mthca: Return an error on ib_copy_to_udata() failureYann Droneaud
commit 08e74c4b00c30c232d535ff368554959403d0432 upstream. In case of error when writing to userspace, the function mthca_create_cq() does not set an error code before following its error path. This patch sets the error code to -EFAULT when ib_copy_to_udata() fails. This was caught when using spatch (aka. coccinelle) to rewrite call to ib_copy_{from,to}_udata(). Link: https://www.gitorious.org/opteya/coccib/source/75ebf2c1033c64c1d81df13e4ae44ee99c989eba:ib_copy_udata.cocci Link: http://marc.info/?i=cover.1394485254.git.ydroneaud@opteya.com Signed-off-by: Yann Droneaud <ydroneaud@opteya.com> Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-06IB/nes: Return an error on ib_copy_from_udata() failure instead of NULLYann Droneaud
commit 9d194d1025f463392feafa26ff8c2d8247f71be1 upstream. In case of error while accessing to userspace memory, function nes_create_qp() returns NULL instead of an error code wrapped through ERR_PTR(). But NULL is not expected by ib_uverbs_create_qp(), as it check for error with IS_ERR(). As page 0 is likely not mapped, it is going to trigger an Oops when the kernel will try to dereference NULL pointer to access to struct ib_qp's fields. In some rare cases, page 0 could be mapped by userspace, which could turn this bug to a vulnerability that could be exploited: the function pointers in struct ib_device will be under userspace total control. This was caught when using spatch (aka. coccinelle) to rewrite calls to ib_copy_{from,to}_udata(). Link: https://www.gitorious.org/opteya/ib-hw-nes-create-qp-null Link: https://www.gitorious.org/opteya/coccib/source/75ebf2c1033c64c1d81df13e4ae44ee99c989eba:ib_copy_udata.cocci Link: http://marc.info/?i=cover.1394485254.git.ydroneaud@opteya.com Signed-off-by: Yann Droneaud <ydroneaud@opteya.com> Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-06IB/ipath: Fix potential buffer overrun in sending diag packet routineDennis Dalessandro
commit a2cb0eb8a64adb29a99fd864013de957028f36ae upstream. Guard against a potential buffer overrun. The size to read from the user is passed in, and due to the padding that needs to be taken into account, as well as the place holder for the ICRC it is possible to overflow the 32bit value which would cause more data to be copied from user space than is allocated in the buffer. Reported-by: Nico Golde <nico@ngolde.de> Reported-by: Fabian Yamaguchi <fabs@goesec.de> Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-23iser-target: Fix post_send_buf_count for RDMA READ/WRITENicholas Bellinger
commit b6b87a1df604678ed1be40158080db012a99ccca upstream. This patch fixes the incorrect setting of ->post_send_buf_count related to RDMA WRITEs + READs where isert_rdma_rw->send_wr_num was not being taken into account. This includes incrementing ->post_send_buf_count within isert_put_datain() + isert_get_dataout(), decrementing within __isert_send_completion() + isert_response_completion(), and clearing wr->send_wr_num within isert_completion_rdma_read() This is necessary because even though IB_SEND_SIGNALED is not set for RDMA WRITEs + READs, during a QP failure event the work requests will be returned with exception status from the TX completion queue. Acked-by: Sagi Grimberg <sagig@mellanox.com> Cc: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-23iscsi/iser-target: Fix isert_conn->state hung shutdown issuesNicholas Bellinger
commit defd884845297fd5690594bfe89656b01f16d87e upstream. This patch addresses a couple of different hug shutdown issues related to wait_event() + isert_conn->state. First, it changes isert_conn->conn_wait + isert_conn->conn_wait_comp_err from waitqueues to completions, and sets ISER_CONN_TERMINATING from within isert_disconnect_work(). Second, it splits isert_free_conn() into isert_wait_conn() that is called earlier in iscsit_close_connection() to ensure that all outstanding commands have completed before continuing. Finally, it breaks isert_cq_comp_err() into seperate TX / RX related code, and adds logic in isert_cq_rx_comp_err() to wait for outstanding commands to complete before setting ISER_CONN_DOWN and calling complete(&isert_conn->conn_wait_comp_err). Acked-by: Sagi Grimberg <sagig@mellanox.com> Cc: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-23iscsi/iser-target: Use list_del_init for ->i_conn_nodeNicholas Bellinger
commit 5159d763f60af693a3fcec45dce2021f66e528a4 upstream. There are a handful of uses of list_empty() for cmd->i_conn_node within iser-target code that expect to return false once a cmd has been removed from the per connect list. This patch changes all uses of list_del -> list_del_init in order to ensure that list_empty() returns false as expected. Acked-by: Sagi Grimberg <sagig@mellanox.com> Cc: Or Gerlitz <ogerlitz@mellanox.com> Cc: <stable@vger.kernel.org> #3.10+ Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22IB/qib: Add missing serdes init sequenceMike Marciniszyn
commit 2f75e12c4457a9b3d042c0a0d748fa198dc2ffaf upstream. Research has shown that commit a77fcf895046 ("IB/qib: Use a single txselect module parameter for serdes tuning") missed a key serdes init sequence. This patch add that sequence. Reviewed-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-20IB/qib: Convert qib_user_sdma_pin_pages() to use get_user_pages_fast()Jan Kara
commit 603e7729920e42b3c2f4dbfab9eef4878cb6e8fa upstream. qib_user_sdma_queue_pkts() gets called with mmap_sem held for writing. Except for get_user_pages() deep down in qib_user_sdma_pin_pages() we don't seem to need mmap_sem at all. Even more interestingly the function qib_user_sdma_queue_pkts() (and also qib_user_sdma_coalesce() called somewhat later) call copy_from_user() which can hit a page fault and we deadlock on trying to get mmap_sem when handling that fault. So just make qib_user_sdma_pin_pages() use get_user_pages_fast() and leave mmap_sem locking for mm. This deadlock has actually been observed in the wild when the node is under memory pressure. Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Roland Dreier <roland@purestorage.com> [Backported to 3.10: (Thanks to Ben Huthings) - Adjust context - Adjust indentation and nr_pages argument in qib_user_sdma_pin_pages()] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-13IB/qib: Fix QP check when looping back to/from QP1Ira Weiny
commit 6e0ea9e6cbcead7fa8c76e3e3b9de4a50c5131c5 upstream. The GSI QP type is compatible with and should be allowed to send data to/from any UD QP. This was found when testing ibacm on the same node as an SA. Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09iser-target: fix error return code in isert_create_device_ib_res()Wei Yongjun
commit 94a7111043d99819cd0a72d9b3174c7054adb2a0 upstream. Fix to return a negative error code from the error handling case instead of 0, as done elsewhere in this function. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04IB/srp: Report receive errors correctlyBart Van Assche
commit cd4e38542a5c2cab94e5410fb17c1cc004a60792 upstream. The IB spec does not guarantee that the opcode is available in error completions. Hence do not rely on it. See also commit 948d1e889e5b ("IB/srp: Introduce srp_handle_qp_err()"). Signed-off-by: Bart Van Assche <bvanassche@acm.org> Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04IB/qib: Fix txselect regressionMike Marciniszyn
commit 2fadd83184d58701f1116ca578465b5a75f9417c upstream. Commit 7fac33014f54("IB/qib: checkpatch fixes") was overzealous in removing a simple_strtoul for a parse routine, setup_txselect(). That routine is required to handle a multi-value string. Unwind that aspect of the fix. Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04IB/ipath: Convert ipath_user_sdma_pin_pages() to use get_user_pages_fast()Jan Kara
commit 4adcf7fb6783e354aab38824d803fa8c4f8e8a27 upstream. ipath_user_sdma_queue_pkts() gets called with mmap_sem held for writing. Except for get_user_pages() deep down in ipath_user_sdma_pin_pages() we don't seem to need mmap_sem at all. Even more interestingly the function ipath_user_sdma_queue_pkts() (and also ipath_user_sdma_coalesce() called somewhat later) call copy_from_user() which can hit a page fault and we deadlock on trying to get mmap_sem when handling that fault. So just make ipath_user_sdma_pin_pages() use get_user_pages_fast() and leave mmap_sem locking for mm. This deadlock has actually been observed in the wild when the node is under memory pressure. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com> [ Merged in fix for call to get_user_pages_fast from Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>. - Roland ] Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13ib_srpt: always set response for task managementJack Wang
commit c807f64340932e19f0d2ac9b30c8381e1f60663a upstream. The SRP specification requires: "Response data shall be provided in any SRP_RSP response that is sent in response to an SRP_TSK_MGMT request (see 6.7). The information in the RSP_CODE field (see table 24) shall indicate the completion status of the task management function." So fix this to avoid the SRP initiator interprets task management functions that succeeded as failed. Signed-off-by: Jack Wang <jinpu.wang@profitbricks.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13ib_srpt: Destroy cm_id before destroying QP.Nicholas Bellinger
commit 0b41d6ca616ddeb3b6c0a80e8770b6f53cd42806 upstream. This patch fixes a bug where ib_destroy_cm_id() was incorrectly being called after srpt_destroy_ch_ib() had destroyed the active QP. This would result in the following failed SRP_LOGIN_REQ messages: Received SRP_LOGIN_REQ with i_port_id 0x0:0x2590ffff1762bd, t_port_id 0x2c903009f8f40:0x2c903009f8f40 and it_iu_len 260 on port 1 (guid=0xfe80000000000000:0x2c903009f8f41) Received SRP_LOGIN_REQ with i_port_id 0x0:0x2590ffff1758f9, t_port_id 0x2c903009f8f40:0x2c903009f8f40 and it_iu_len 260 on port 2 (guid=0xfe80000000000000:0x2c903009f8f42) Received SRP_LOGIN_REQ with i_port_id 0x0:0x2590ffff175941, t_port_id 0x2c903009f8f40:0x2c903009f8f40 and it_iu_len 260 on port 2 (guid=0xfe80000000000000:0x2c90300a3cfb2) Received SRP_LOGIN_REQ with i_port_id 0x0:0x2590ffff176299, t_port_id 0x2c903009f8f40:0x2c903009f8f40 and it_iu_len 260 on port 1 (guid=0xfe80000000000000:0x2c90300a3cfb1) mlx4_core 0000:84:00.0: command 0x19 failed: fw status = 0x9 rejected SRP_LOGIN_REQ because creating a new RDMA channel failed. Received SRP_LOGIN_REQ with i_port_id 0x0:0x2590ffff176299, t_port_id 0x2c903009f8f40:0x2c903009f8f40 and it_iu_len 260 on port 1 (guid=0xfe80000000000000:0x2c90300a3cfb1) mlx4_core 0000:84:00.0: command 0x19 failed: fw status = 0x9 rejected SRP_LOGIN_REQ because creating a new RDMA channel failed. Received SRP_LOGIN_REQ with i_port_id 0x0:0x2590ffff176299, t_port_id 0x2c903009f8f40:0x2c903009f8f40 and it_iu_len 260 on port 1 (guid=0xfe80000000000000:0x2c90300a3cfb1) Reported-by: Navin Ahuja <navin.ahuja@saratoga-speed.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04iscsi-target: Fix iscsit_sequence_cmd reject handling for iserNicholas Bellinger
commit 561bf15892375597ee59d473a704a3e634c4f311 upstream This patch moves ISCSI_OP_REJECT failures into iscsit_sequence_cmd() in order to avoid external iscsit_reject_cmd() reject usage for all PDU types. It also updates PDU specific handlers for traditional iscsi-target code to not reset the session after posting a ISCSI_OP_REJECT during setup. (v2: Fix CMDSN_LOWER_THAN_EXP for ISCSI_OP_SCSI to call target_put_sess_cmd() after iscsit_sequence_cmd() failure) Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Cc: Or Gerlitz <ogerlitz@mellanox.com> Cc: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04iscsi-target: Fix iscsit_add_reject* usage for iserNicholas Bellinger
commit ba159914086f06532079fc15141f46ffe7e04a41 upstream This patch changes iscsit_add_reject() + iscsit_add_reject_from_cmd() usage to not sleep on iscsi_cmd->reject_comp to address a free-after-use usage bug in v3.10 with iser-target code. It saves ->reject_reason for use within iscsit_build_reject() so the correct value for both transport cases. It also drops the legacy fail_conn parameter usage throughput iscsi-target code and adds two iscsit_add_reject_cmd() and iscsit_reject_cmd helper functions, along with various small cleanups. (v2: Re-enable target_put_sess_cmd() to be called from iscsit_add_reject_from_cmd() for rejects invoked after target_get_sess_cmd() has been called) Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Cc: Or Gerlitz <ogerlitz@mellanox.com> Cc: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04iscsi-target: Fix ISCSI_OP_SCSI_TMFUNC handling for iserNicholas Bellinger
commit 186a9647019587b3784694894c4d136fd00cfd7b upstream. This patch adds target_get_sess_cmd reference counting for iscsit_handle_task_mgt_cmd(), and adds a target_put_sess_cmd() for the failure case. It also fixes a bug where ISCSI_OP_SCSI_TMFUNC type commands where leaking iscsi_cmd->i_conn_node and eventually triggering an OOPs during struct isert_conn shutdown. Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04iser-target: Fix session reset bug with RDMA_CM_EVENT_DISCONNECTEDNicholas Bellinger
commit b2cb96494d83b894a43ba8b9023eead8ff50684b upstream. This patch addresses a bug where RDMA_CM_EVENT_DISCONNECTED may occur before the connection shutdown has been completed by rx/tx threads, that causes isert_free_conn() to wait indefinately on ->conn_wait. This patch allows isert_disconnect_work code to invoke rdma_disconnect when isert_disconnect_work() process context is started by client session reset before isert_free_conn() code has been reached. It also adds isert_conn->conn_mutex protection for ->state within isert_disconnect_work(), isert_cq_comp_err() and isert_free_conn() code, along with isert_check_state() for wait_event usage. (v2: Add explicit iscsit_cause_connection_reinstatement call during isert_disconnect_work() to force conn reset) Cc: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04iser-target: Fix isert_put_reject payload buffer postNicholas Bellinger
commit 3df8f68aaf7ebe3d136a22262b41b350b0a1858b upstream. This patch adds the missing isert_put_reject() logic to post a outgoing payload buffer to hold the 48 bytes of original PDU header request payload for the rejected cmd. It also fixes ISTATE_SEND_REJECT handling in isert_response_completion() -> isert_do_control_comp() code, and drops incorrect iscsi_cmd_t->reject_comp usage. Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Cc: Or Gerlitz <ogerlitz@mellanox.com> Cc: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-04Merge branches 'iser' and 'qib' into for-nextRoland Dreier
2013-06-04IB/qib: Fix lockdep splat in qib_alloc_lkey()Mike Marciniszyn
The following backtrace is reported with CONFIG_PROVE_RCU: drivers/infiniband/hw/qib/qib_keys.c:64 suspicious rcu_dereference_check() usage! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 1 4 locks held by kworker/0:1/56: #0: (events){.+.+.+}, at: [<ffffffff8107a4f5>] process_one_work+0x165/0x4a0 #1: ((&wfc.work)){+.+.+.}, at: [<ffffffff8107a4f5>] process_one_work+0x165/0x4a0 #2: (device_mutex){+.+.+.}, at: [<ffffffffa0148dd8>] ib_register_device+0x38/0x220 [ib_core] #3: (&(&dev->lk_table.lock)->rlock){......}, at: [<ffffffffa017e81c>] qib_alloc_lkey+0x3c/0x1b0 [ib_qib] stack backtrace: Pid: 56, comm: kworker/0:1 Not tainted 3.10.0-rc1+ #6 Call Trace: [<ffffffff810c0b85>] lockdep_rcu_suspicious+0xe5/0x130 [<ffffffffa017e8e1>] qib_alloc_lkey+0x101/0x1b0 [ib_qib] [<ffffffffa0184886>] qib_get_dma_mr+0xa6/0xd0 [ib_qib] [<ffffffffa01461aa>] ib_get_dma_mr+0x1a/0x50 [ib_core] [<ffffffffa01678dc>] ib_mad_port_open+0x12c/0x390 [ib_mad] [<ffffffff810c2c55>] ? trace_hardirqs_on_caller+0x105/0x190 [<ffffffffa0167b92>] ib_mad_init_device+0x52/0x110 [ib_mad] [<ffffffffa01917c0>] ? sl2vl_attr_show+0x30/0x30 [ib_qib] [<ffffffffa0148f49>] ib_register_device+0x1a9/0x220 [ib_core] [<ffffffffa01b1685>] qib_register_ib_device+0x735/0xa40 [ib_qib] [<ffffffff8106ba98>] ? mod_timer+0x118/0x220 [<ffffffffa017d425>] qib_init_one+0x1e5/0x400 [ib_qib] [<ffffffff812ce86e>] local_pci_probe+0x4e/0x90 [<ffffffff81078118>] work_for_cpu_fn+0x18/0x30 [<ffffffff8107a566>] process_one_work+0x1d6/0x4a0 [<ffffffff8107a4f5>] ? process_one_work+0x165/0x4a0 [<ffffffff8107c9c9>] worker_thread+0x119/0x370 [<ffffffff8107c8b0>] ? manage_workers+0x180/0x180 [<ffffffff8108294e>] kthread+0xee/0x100 [<ffffffff81082860>] ? __init_kthread_worker+0x70/0x70 [<ffffffff815c04ac>] ret_from_fork+0x7c/0xb0 [<ffffffff81082860>] ? __init_kthread_worker+0x70/0x70 Per Documentation/RCU/lockdep-splat.txt, the code now uses rcu_access_pointer() vs. rcu_dereference(). Reported-by: Jay Fenlason <fenlason@redhat.com> Reviewed-by: Dean Luick <dean.luick@intel.com> Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2013-06-04IB/iser: Add Mellanox copyrightOr Gerlitz
Add Mellanox copyright to the iser initiator source code which I maintain. Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2013-06-04IB/iser: Fix device removal flowRoi Dayan
Change the code to destroy the "last opened" rdma_cm id after making sure we released all other objects (QP, CQs, PD, etc) associated with the IB device. Since iser accesses the IB device using the rdma_cm id, we need to free any objects that are related to the device that is associated with the rdma_cm id prior to destroying that id. When this isn't done, the low level driver that created this device can be unloaded before iser has a chance to free all the objects and a such a call may invoke code segment which isn't valid any more and crash. Cc: Sean Hefty <sean.hefty@intel.com Signed-off-by: Roi Dayan <roid@mellanox.com> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2013-05-29ib_srpt: Call target_sess_cmd_list_set_waiting during shutdown_sessionNicholas Bellinger
Given that srpt_release_channel_work() calls target_wait_for_sess_cmds() to allow outstanding se_cmd_t->cmd_kref a change to complete, the call to perform target_sess_cmd_list_set_waiting() needs to happen in srpt_shutdown_session() Also, this patch adds an explicit call to srpt_shutdown_session() within srpt_drain_channel() so that target_sess_cmd_list_set_waiting() will be called in the cases where TFO->shutdown_session() is not triggered directly by TCM. Cc: Joern Engel <joern@logfs.org> Cc: Roland Dreier <roland@kernel.org> Cc: stable@vger.kernel.org Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2013-05-20target: Remove unused wait_for_tasks bit in target_wait_for_sess_cmdsJoern Engel
Drop unused transport_wait_for_tasks() check in target_wait_for_sess_cmds shutdown code, and convert tcm_qla2xxx + ib_srpt fabric drivers. Cc: Joern Engel <joern@logfs.org> Cc: Roland Dreier <roland@kernel.org> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2013-05-08Merge tag 'rdma-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband Pull InfiniBand/RDMA changes from Roland Dreier: - XRC transport fixes - Fix DHCP on IPoIB - mlx4 preparations for flow steering - iSER fixes - miscellaneous other fixes * tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (23 commits) IB/iser: Add support for iser CM REQ additional info IB/iser: Return error to upper layers on EAGAIN registration failures IB/iser: Move informational messages from error to info level IB/iser: Add module version mlx4_core: Expose a few helpers to fill DMFS HW strucutures mlx4_core: Directly expose fields of DMFS HW rule control segment mlx4_core: Change a few DMFS fields names to match firmare spec mlx4: Match DMFS promiscuous field names to firmware spec mlx4_core: Move DMFS HW structs to common header file IB/mlx4: Set link type for RAW PACKET QPs in the QP context IB/mlx4: Disable VLAN stripping for RAW PACKET QPs mlx4_core: Reduce warning message for SRQ_LIMIT event to debug level RDMA/iwcm: Don't touch cmid after dropping reference IB/qib: Correct qib_verbs_register_sysfs() error handling IB/ipath: Correct ipath_verbs_register_sysfs() error handling RDMA/cxgb4: Fix SQ allocation when on-chip SQ is disabled SRPT: Fix odd use of WARN_ON() IPoIB: Fix ipoib_hard_header() return value RDMA: Rename random32() to prandom_u32() RDMA/cxgb3: Fix uninitialized variable ...
2013-05-08Merge branches 'cxgb4', 'ipoib', 'iser', 'misc', 'mlx4', 'qib' and 'srp' ↵Roland Dreier
into for-next
2013-05-07aio: don't include aio.h in sched.hKent Overstreet
Faster kernel compiles by way of fewer unnecessary includes. [akpm@linux-foundation.org: fix fallout] [akpm@linux-foundation.org: fix build] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07drivers/infiniband/hw: rename random32() to prandom_u32()Andrew Morton
Use preferable function name which implies using a pseudo-random number generator. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-01IB/iser: Add support for iser CM REQ additional infoOr Gerlitz
Annex A12 of the IBTA spec defines additional information that needs to be provided through the CM exchange relating to usage of ZBVA (Zero Based VAs) and Send With Invalidate over an iSER connection. Currently, the initiator sets both to not supported, but does provide the header so that existing iSER targets can be patched to start looking on the private data carried by the CM. This is a preparation step to enable iSER with HW drivers for which FMRs are not supported, such as mlx4 VF instances or new HW devices which might support only FRWR (Fast Registration Work-Requests) along the details of the IB_DEVICE_MEM_MGT_EXTENSIONS device capability. Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2013-05-01IB/iser: Return error to upper layers on EAGAIN registration failuresOr Gerlitz
Commit 819a087316a6 ("IB/iser: Avoid error prints on EAGAIN registration failures") not only eliminated the error print on that case, but rather also modified the code such that it doesn't return any error to upper layers. As a result a wrong mapping was used. Fix this to correctly return the error in that case. Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2013-05-01IB/iser: Move informational messages from error to info levelRoi Dayan
Introduce iser_info() and move informational messages that were printed as errors to use that macro. Also, cleanup printk leftovers to use the existing macros. Signed-off-by: Roi Dayan <roid@mellanox.com> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> [ Use pr_warn(... instead of printk(KERN_WARNING .... - Roland ] Signed-off-by: Roland Dreier <roland@purestorage.com>
2013-05-01IB/iser: Add module versionRoi Dayan
Add displaying module version, update the version to 1.1, and remove the DRV_DATE define. Signed-off-by: Roi Dayan <roid@mellanox.com> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2013-05-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights (1721 non-merge commits, this has to be a record of some sort): 1) Add 'random' mode to team driver, from Jiri Pirko and Eric Dumazet. 2) Make it so that any driver that supports configuration of multiple MAC addresses can provide the forwarding database add and del calls by providing a default implementation and hooking that up if the driver doesn't have an explicit set of handlers. From Vlad Yasevich. 3) Support GSO segmentation over tunnels and other encapsulating devices such as VXLAN, from Pravin B Shelar. 4) Support L2 GRE tunnels in the flow dissector, from Michael Dalton. 5) Implement Tail Loss Probe (TLP) detection in TCP, from Nandita Dukkipati. 6) In the PHY layer, allow supporting wake-on-lan in situations where the PHY registers have to be written for it to be configured. Use it to support wake-on-lan in mv643xx_eth. From Michael Stapelberg. 7) Significantly improve firewire IPV6 support, from YOSHIFUJI Hideaki. 8) Allow multiple packets to be sent in a single transmission using network coding in batman-adv, from Martin Hundebøll. 9) Add support for T5 cxgb4 chips, from Santosh Rastapur. 10) Generalize the VXLAN forwarding tables so that there is more flexibility in configurating various aspects of the endpoints. From David Stevens. 11) Support RSS and TSO in hardware over GRE tunnels in bxn2x driver, from Dmitry Kravkov. 12) Zero copy support in nfnelink_queue, from Eric Dumazet and Pablo Neira Ayuso. 13) Start adding networking selftests. 14) In situations of overload on the same AF_PACKET fanout socket, or per-cpu packet receive queue, minimize drop by distributing the load to other cpus/fanouts. From Willem de Bruijn and Eric Dumazet. 15) Add support for new payload offset BPF instruction, from Daniel Borkmann. 16) Convert several drivers over to mdoule_platform_driver(), from Sachin Kamat. 17) Provide a minimal BPF JIT image disassembler userspace tool, from Daniel Borkmann. 18) Rewrite F-RTO implementation in TCP to match the final specification of it in RFC4138 and RFC5682. From Yuchung Cheng. 19) Provide netlink socket diag of netlink sockets ("Yo dawg, I hear you like netlink, so I implemented netlink dumping of netlink sockets.") From Andrey Vagin. 20) Remove ugly passing of rtnetlink attributes into rtnl_doit functions, from Thomas Graf. 21) Allow userspace to be able to see if a configuration change occurs in the middle of an address or device list dump, from Nicolas Dichtel. 22) Support RFC3168 ECN protection for ipv6 fragments, from Hannes Frederic Sowa. 23) Increase accuracy of packet length used by packet scheduler, from Jason Wang. 24) Beginning set of changes to make ipv4/ipv6 fragment handling more scalable and less susceptible to overload and locking contention, from Jesper Dangaard Brouer. 25) Get rid of using non-type-safe NLMSG_* macros and use nlmsg_*() instead. From Hong Zhiguo. 26) Optimize route usage in IPVS by avoiding reference counting where possible, from Julian Anastasov. 27) Convert IPVS schedulers to RCU, also from Julian Anastasov. 28) Support cpu fanouts in xt_NFQUEUE netfilter target, from Holger Eitzenberger. 29) Network namespace support for nf_log, ebt_log, xt_LOG, ipt_ULOG, nfnetlink_log, and nfnetlink_queue. From Gao feng. 30) Implement RFC3168 ECN protection, from Hannes Frederic Sowa. 31) Support several new r8169 chips, from Hayes Wang. 32) Support tokenized interface identifiers in ipv6, from Daniel Borkmann. 33) Use usbnet_link_change() helper in USB net driver, from Ming Lei. 34) Add 802.1ad vlan offload support, from Patrick McHardy. 35) Support mmap() based netlink communication, also from Patrick McHardy. 36) Support HW timestamping in mlx4 driver, from Amir Vadai. 37) Rationalize AF_PACKET packet timestamping when transmitting, from Willem de Bruijn and Daniel Borkmann. 38) Bring parity to what's provided by /proc/net/packet socket dumping and the info provided by netlink socket dumping of AF_PACKET sockets. From Nicolas Dichtel. 39) Fix peeking beyond zero sized SKBs in AF_UNIX, from Benjamin Poirier" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits) filter: fix va_list build error af_unix: fix a fatal race with bit fields bnx2x: Prevent memory leak when cnic is absent bnx2x: correct reading of speed capabilities net: sctp: attribute printl with __printf for gcc fmt checks netlink: kconfig: move mmap i/o into netlink kconfig netpoll: convert mutex into a semaphore netlink: Fix skb ref counting. net_sched: act_ipt forward compat with xtables mlx4_en: fix a build error on 32bit arches Revert "bnx2x: allow nvram test to run when device is down" bridge: avoid OOPS if root port not found drivers: net: cpsw: fix kernel warn on cpsw irq enable sh_eth: use random MAC address if no valid one supplied 3c509.c: call SET_NETDEV_DEV for all device types (ISA/ISAPnP/EISA) tg3: fix to append hardware time stamping flags unix/stream: fix peeking with an offset larger than data in queue unix/dgram: fix peeking with an offset larger than data in queue unix/dgram: peek beyond 0-sized skbs openvswitch: Remove unneeded ovs_netdev_get_ifindex() ...
2013-04-30Merge branch 'for-next-merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull SCSI target update from Nicholas Bellinger: "The highlights this round include: - Add fileio support for WRITE_SAME w/ UNMAP=1 discard (asias) - Add fileio support for UNMAP discard (asias) - Add tcm_vhost hotplug support to work with upstream QEMU vhost-scsi-pci code (asias + mst) - Check for aborted sequence in tcm_fc response path (mdr) - Add initial iscsit_transport support into iscsi-target code (nab) - Refactor iscsi-target RX PDU logic + export request PDU handling (nab) - Refactor iscsi-target TX queue logic + export response PDU creation (nab) - Add new iSCSI Extentions for RDMA (ISER) target driver (Or + nab) The biggest changes revolve around iscsi-target refactoring in order to support the iser-target driver. This includes the conversion of the iscsi-target data-path to use modern se_cmd->cmd_kref counting, and allowing transport independent aspects of RX/TX PDU request/response handling be shared across existing traditional iscsi-target code, and the new iser-target code. Thanks to Or Gerlitz + Mellanox for supporting the iser-target development effort!" * 'for-next-merge' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (25 commits) iser-target: Add iSCSI Extensions for RDMA (iSER) target driver tcm_vhost: Enable VIRTIO_SCSI_F_HOTPLUG tcm_vhost: Add ioctl to get and set events missed flag tcm_vhost: Add hotplug/hotunplug support tcm_vhost: Refactor the lock nesting rule tcm_fc: Check for aborted sequence iscsi-target: Add iser network portal attribute iscsi-target: Refactor TX queue logic + export response PDU creation iscsi-target: Refactor RX PDU logic + export request PDU handling iscsi-target: Add per transport iscsi_cmd alloc/free iscsi-target: Add iser-target parameter keys + setup during login iscsi-target: Initial traditional TCP conversion to iscsit_transport iscsi-target: Add iscsit_transport API template target: Add export of target_get_sess_cmd symbol target: Change default sense key of NOT_READY target/file: Set is_nonrot attribute target: Add sbc_execute_unmap() helper target/iblock: Add iblock_do_unmap() helper target/file: Add fd_do_unmap() helper target/file: Add UNMAP emulation support ...
2013-04-29drivers/infiniband/hw/mlx4: convert to using idr_alloc_cyclic()Jeff Layton
Signed-off-by: Jeff Layton <jlayton@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Jack Morgenstein <jackm@dev.mellanox.co.il> Cc: Or Gerlitz <ogerlitz@mellanox.com> Cc: Roland Dreier <roland@purestorage.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29drivers/infiniband/hw/amso1100: convert to using idr_alloc_cyclicJeff Layton
Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Tejun Heo <tj@kernel.org> Cc: Steve Wise <swise@opengridcomputing.com> Cc: Tom Tucker <tom@opengridcomputing.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-25iser-target: Add iSCSI Extensions for RDMA (iSER) target driverNicholas Bellinger
This patch adds support for iSCSI Extensions for RDMA target mode, and includes CQ pooling per isert_device context distributed across multiple active iser target sessions. It also uses cmwq process context for RX / TX ib_post_cq() polling via isert_cq_desc->cq_[rx,tx]_work invoked by isert_cq_[rx,tx]_callback() hardIRQ context callbacks. v5 changes: - Use ISER_RECV_DATA_SEG_LEN instead of hardcoded value in ISER_RX_PAD_SIZE (Or) - Fix make W=1 warnings (Or) - Add missing depends on NET && INFINIBAND_ADDR_TRANS in Kconfig (Randy + Or) - Make isert_device_find_by_ib_dev() return proper ERR_PTR (Wei Yongjun) - Properly setup iscsi_np->np_sockaddr in isert_setup_np() (Shlomi + nab) - Add special case for early ISCSI_OP_SCSI_CMD exception handling (nab) v4 changes: - Mark isert_cq_rx_work as static (Or) - Drop unnecessary ib_dma_sync_single_for_cpu + ib_dma_sync_single_for_device calls for isert_cmd->sense_buf_dma from isert_put_response (Or) - Use 12288 for ISER_RX_PAD_SIZE base to save extra page per struct iser_rx_desc (Or + nab) - Drop now unnecessary isert_rx_desc usage, and convert RX users to iser_rx_desc (Or + nab) - Move isert_[alloc,free]_rx_descriptors() ahead of isert_create_device_ib_res() usage (nab) - Mark isert_cq_[rx,tx]_callback() + prototypes as static - Fix 'warning: 'ret' may be used uninitialized' warning for isert_create_device_ib_res on powerpc allmodconfig (fengguang + nab) - Fix 'warning: 'ret' may be used uninitialized' warning for isert_connect_request on i386 allyesconfig (fengguang + nab) - Fix pr_debug conversion specification in isert_rx_completion() (fengguang + nab) - Drop unnecessary isert_conn->conn_cm_id != NULL check in isert_connect_release causing the build warning: "variable dereferenced before check 'isert_conn->conn_cm_id'" - Fix isert_lid + isert_np leak in isert_setup_np failure path - Add isert_conn->conn_wait_comp_err usage in isert_free_conn() for isert_cq_comp_err completion path - Add isert_conn->logout_posted bit to determine decrement of isert_conn->post_send_buf_count from logout response completion - Always set ISER_CONN_DOWN from isert_disconnect_work() callback v3 changes: - Convert to use per isert_cq_desc->cq_[rx,tx]_work + drop tasklets (Or + nab) - Move IB_EVENT_QP_LAST_WQE_REACHED warn into correct isert_qp_event_callback (Or) - Drop unnecessary IB_ACCESS_REMOTE_* access flag usage in isert_create_device_ib_res (Or) - Add common isert_init_send_wr(), and convert isert_put_* calls (Or) - Move to verbs+core logic to single ib_isert.[c,h] (Or + nab) - Add kmem_cache isert_cmd_cache usage for descriptor allocation (nab) - Move common ib_post_send() logic used by isert_put_*() to isert_post_response() (nab) - Add isert_put_reject call in isert_response_queue() for posting ISCSI_REJECT response. (nab) - Add ISTATE_SEND_REJECT checking in isert_do_control_comp. (nab) v2 changes: - Drop unused ISERT_ADDR_ROUTE_TIMEOUT define - Add rdma_notify() call for IB_EVENT_COMM_EST in isert_qp_event_callback() - Make isert_query_device() less verbose - Drop unused RDMA_CM_EVENT_ADDR_ERROR and RDMA_CM_EVENT_ROUTE_ERROR cases from isert_cma_handler() - Drop unused rdma/ib_fmr_pool.h include - Update isert_conn_setup_qp() to assign cq based upon least used - Add isert_create_device_ib_res() to setup PD, CQs and MRs for each underlying struct ib_device, instead of using per isert_conn resources. - Add isert_free_device_ib_res() to release PD, CQs and MRs for each underlying struct ib_device. - Add isert_device_find_by_ib_dev() - Change isert_connect_request() to drop PD, CQs and MRs allocation, and use isert_device_find_by_ib_dev() instead. - Add isert_device_try_release() - Change isert_connect_release() to decrement cq_active_qps, and drop PD, CQs and MRs resource release. - Update isert_connect_release() to call isert_device_try_release() - Make isert_create_device_ib_res() determine device->cqs_used based upon num_online_cpus() - Drop misleading isert_dump_ib_wc() usage - Drop unused rdma/ib_fmr_pool.h include - Use proper xfer_len for login PDUs in isert_rx_completion() - Add isert_release_cmd() usage - Change isert_alloc_cmd() to setup iscsi_cmd.release_cmd() pointer - Change isert_put_cmd() to perform per iscsi_opcode specific release logic - Add isert_unmap_cmd() call for ISCSI_OP_SCSI_CMD from isert_put_cmd() - Change isert_send_completion() to call atomic_dec(&isert_conn->post_send_buf_count) based upon per iscsi_opcode logic - Drop ISTATE_REMOVE processing from isert_immediate_queue() - Drop ISTATE_SEND_DATAIN processing from isert_response_queue() - Drop ISTATE_SEND_STATUS processing from isert_response_queue() - Drop iscsit_transport->iscsit_unmap_cmd() and ->iscsit_free_cmd() - Convert iser_cq_tx_tasklet() to use struct isert_cq_desc pooling logic - Convert isert_cq_tx_callback() to use struct isert_cq_desc pooling logic - Convert iser_cq_rx_tasklet() to use struct isert_cq_desc pooling logic - Convert isert_cq_rx_callback() to use struct isert_cq_desc pooling logic - Add explict iscsit_stop_dataout_timer() call to isert_do_rdma_read_comp() - Use isert_get_dataout() for iscsit_transport->iscsit_get_dataout() caller - Drop ISTATE_SEND_R2T processing from isert_immediate_queue() - Drop unused rdma/ib_fmr_pool.h include - Drop isert_cmd->cmd_kref in favor of se_cmd->cmd_kref usage - Add struct isert_device in order to support multiple EQs + CQ pooling - Add struct isert_cq_desc - Drop tasklets and cqs from isert_conn - Bump ISERT_MAX_CQ to 64 - Various minor checkpatch fixes Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2013-04-24IB/mlx4: Set link type for RAW PACKET QPs in the QP contextEli Cohen
When the link type is Ethernet, setting the link type in the QP context will enable TCP/IP stateless offloads (checksum, LSO, RSS) for RAW PACKET Ethernet QPs. For IB UD QPs this worked OK since the value assumed by the firmware for IB link layer is zero. Signed-off-by: Eli Cohen <eli@mellanox.com> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2013-04-24IB/mlx4: Disable VLAN stripping for RAW PACKET QPsDotan Barak
Fix the asymmetric behavior w.r.t VLAN insertion/stripping for RAW PACKET QPs -- we don't insert on send and need not strip on receive. Signed-off-by: Dotan Barak <dotanb@dev.mellanox.co.il> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2013-04-24RDMA/iwcm: Don't touch cmid after dropping referenceSteve Wise
The function cm_work_handler() cannot touch the cm_id after it derefs it, because it might be freed on another concurrent thread. If there are more work items queued for this cm_id, then we know there must be more references because they are added when the work items are queued. So in the while loop inside cm_work_handler(), after derefing, if the queue is empty, then exit the function. Otherwise we know it's safe to re-acquire the lock. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2013-04-24net/mlx4_en: Add HW timestamping (TS) supportAmir Vadai
The patch allows to enable/disable HW timestamping for incoming and/or outgoing packets. It adds and initializes all structs and callbacks needed by kernel TS API. To enable/disable HW timestamping appropriate ioctl should be used. Currently HWTSTAMP_FILTER_ALL/NONE and HWTSAMP_TX_ON/OFF only are supported. When enabling TS on receive flow - VLAN stripping will be disabled. Also were made all relevant changes in RX/TX flows to consider TS request and plant HW timestamps into relevant structures. mlx4_ib was fixed to compile with new mlx4_cq_alloc() signature. Signed-off-by: Eugenia Emantayev <eugenia@mellanox.com> Signed-off-by: Amir Vadai <amirv@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-19net: vlan: add protocol argument to packet tagging functionsPatrick McHardy
Add a protocol argument to the VLAN packet tagging functions. In case of HW tagging, we need that protocol available in the ndo_start_xmit functions, so it is stored in a new field in the skb. The new field fits into a hole (on 64 bit) and doesn't increase the sks's size. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-19net: vlan: rename NETIF_F_HW_VLAN_* feature flags to NETIF_F_HW_VLAN_CTAG_*Patrick McHardy
Rename the hardware VLAN acceleration features to include "CTAG" to indicate that they only support CTAGs. Follow up patches will introduce 802.1ad server provider tagging (STAGs) and require the distinction for hardware not supporting acclerating both. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-17IPoIB: add support for TIPC protocolPatrick McHardy
Support TIPC in the IPoIB driver. Since IPoIB now keeps track of its own neighbour entries and doesn't require the packet to have a dst_entry anymore, the only necessary changes are to: - not drop multicast TIPC packets because of the unknown ethernet type - handle unicast TIPC packets similar to IPv4/IPv6 unicast packets in ipoib_start_xmit(). An alternative would be to remove all ethertype limitations since they're not necessary anymore, all TIPC needs to know about is ARP and RARP since it wants to always perform "path find", even if a path is already known. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-16IB/qib: Correct qib_verbs_register_sysfs() error handlingMike Marciniszyn
qib_verbs_register_sysfs() never cleans up from a failure. Additionally, the caller of qib_verbs_register_sysfs() doesn't return the correct "ret" value. This patch resolves both of those issues. Reported-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Reviewed-by: Dean Luick <dean.luick@intel.com> Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
