path: root/drivers/infiniband
2009-05-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IB/mlx4: Don't overwrite fast registration page list when posting work request RDMA/cxgb3: Don't complete flushed send work requests twice
2009-05-13Merge branches 'cxgb3' and 'mlx4' into for-linusRoland Dreier
2009-05-09Fix deadlock in ipathfs ->get_sb()Al Viro
forgot to unlock superblock before calling deactivate_super()... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-07IB/mlx4: Don't overwrite fast registration page list when posting work requestJack Morgenstein
The low-level mlx4 driver modified the page-list addresses for fast register work requests post send to big-endian, and set a "present" bit. This caused problems later when the consumer attempted to unmap the pages using the page-list (using the list addresses which were assumed to be still in CPU-endian order). Fix the mlx4 driver to allocate two buffers and use a private buffer for the hardware-format bus addresses. This patch fixes <https://bugs.openfabrics.org/show_bug.cgi?id=1571>, an NFS/RDMA server crash. The cause of the crash was found by Vu Pham of Mellanox. The fix is along the lines suggested by Steve Wise in comment #21 in bug 1571. Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-05-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: (53 commits) [SCSI] libosd: OSD2r05: on-the-wire changes for latest OSD2 revision 5. [SCSI] libosd: OSD2r05: OSD_CRYPTO_KEYID_SIZE will grow 20 => 32 bytes [SCSI] libosd: OSD2r05: Prepare for rev5 attribute list changes [SCSI] libosd: fix potential ERR_PTR dereference in osd_initiator.c [SCSI] mpt2sas : bump driver version to 01.100.02.00 [SCSI] mpt2sas: fix hotplug event processing [SCSI] mpt2sas : release diagnotic buffers prior host reset [SCSI] mpt2sas : Broadcast Primative AEN bug fix [SCSI] mpt2sas : Identify Dell series-7 adapters at driver load time [SCSI] mpt2sas : driver name needs to be in the MPT2IOCINFO ioctl [SCSI] mpt2sas : running out of message frames [SCSI] mpt2sas : fix oops when firmware sends large sense buffer size [SCSI] mpt2sas : the sanity check in base_interrupt needs to be on dword boundary [SCSI] mpt2sas : unique ioctl magic number [SCSI] fix sign extension with 1.5TB usb-storage LBD=y [SCSI] ipr: Fix sleeping function called with interrupts disabled [SCSI] fcoe: fip: add multicast filter to receive FIP advertisements. [SCSI] libfc: Fix compilation warnings with allmodconfig [SCSI] fcoe: fix spelling typos and bad comments [SCSI] fcoe: don't export functions that are internal to fcoe ...
2009-04-29RDMA/cxgb3: Don't complete flushed send work requests twiceSteve Wise
When the SQ is flushed, mark the flushed entries as not signaled so the poll logic doesn't re-insert the CQ entry thinking its an out of order completion. The bug can cause the NFS/RDMA server to crash due to processing the same completed work request twice. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-28Merge branches 'cxgb3', 'ipoib', 'mthca', 'mlx4' and 'nes' into for-linusRoland Dreier
2009-04-27RDMA/nes: Update iw_nes versionChien Tung
Update version number to 1.5.0.0 Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-27RDMA/nes: Fix error path in nes_accept()Faisal Latif
If reg_phys_mem() fails, we need to free memory allocated for MPA frame with private data before returning the error. Also move nes_add_ref() after the reg_phys_mem() is successful. Signed-off-by: Faisal Latif <faisal.latif@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-27RDMA/nes: Fix hang issues for large cluster dynamic connectionsFaisal Latif
Running large cluster setup, we are hanging after many hours of testing. Fixing this required going over the code and making sure the rexmit entry was properly removed based on the cm_node's state and packet received. Also when receiving a FIN packet, check seq# and make sure there were no errors before calling handle_fin(). Following are the changes done in nes_cm.c: * handle_ack_pkt() needs to return error value, so in case of error, handle_fin() is not called. Some cleanup done while going over the code. * handle_rst_pkt(), handling of cm_node's NES_CM_STATE_LAST_ACK is missing. * process_packet(), in case of FIN only packet is received, call check_seq() before processing. * in handle_fin_pkt(), we are calling cleanup_retrans_entry() for all conditions, even if the packets need to be dropped. Signed-off-by: Faisal Latif <faisal.latif@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-27RDMA/nes: Increase rexmit timeout intervalFaisal Latif
Under heavy load with large cluster testing, it may take longer to receive a response to MPA requests. Change the driver to wait longer after each rexmit to max time value. Signed-off-by: Faisal Latif <faisal.latif@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-27RDMA/nes: Check for sequence number wrap-aroundFaisal Latif
check_seq() was not checking if the seq#s have wrapped. Fix it. Signed-off-by: Faisal Latif <faisal.latif@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-27RDMA/nes: Do not set apbvt entry for loopbackFaisal Latif
When a connect request comes, apbvt should only be set for non-loopback connections. Signed-off-by: Faisal Latif <faisal.latif@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-27RDMA/nes: Fix unused variable compile warning when INFINIBAND_NES_DEBUG=nChien Tung
Remove the NES_DEBUG that is causing the compile warning about an unused variable when INFINIBAND_NES_DEBUG is not enabled. Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-27RDMA/nes: Fix fw_ver in /sysChien Tung
/sys/class/infiniband/nes?/fw_ver is not displaying firmware version properly (it shows 0.0.0 with the current code). Fill in the correct firmware version number. Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-27RDMA/nes: Set trace length to 1 inch for SFP_DChien Tung
With updated PHY firmware for SFP_D, setting the trace length to 1 inch for SFP_D provides a more stable link. Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-27RDMA/nes: Enable repause timer for port 1Chien Tung
Enable repause timer for port 1. Without this setting, under stress, the chip may misbehave. Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-27RDMA/nes: Correct CDR loop filter setting for port 1Chien Tung
In commit 1b949324 ("RDMA/nes: Fix SFP+ PHY initialization") there is a mistake in the clean up code that removed port 1 CDR loop filter settings for 10G cards other than CX4. Put the correct setting back for appropriate PHY types. Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-27RDMA/nes: Modify thermo mitigation to flip SerDes1 ref clk to internalChien Tung
Change thermo mitigation code to flip the SerDes1 reference clock to internal, to match the change in commit a4849fc1 ("RDMA/nes: Add wide_ppm_offset parm for switch compatibility"). Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-27[SCSI] cxgb3i, iser, iscsi_tcp: set target can queueMike Christie
Set target can queue limit to the number of preallocated session tasks we have. This along with the cxgb3i can_queue patch will fix a throughput problem where it could only queue one LU worth of data at a time. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-21RDMA/nes: Fix resource issues in nes_create_cq() and nes_destroy_cq()Miroslaw Walukiewicz
In error paths where a CQ is not created, pbl is not freeed properly. In nes_destroy_cq(), add the corresponding check for nescq->mcrqf to not call nes_free_resource() when it is already done in nes_create_cq(). Signed-off-by: Miroslaw Walukiewicz <miroslaw.walukiewicz@intel.com> Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-21RDMA/nes: Remove root_256()'s unused pbl_count_256 parameterMatt Kraai
Signed-off-by: Matt Kraai <kraai@ftbfs.org> Acked-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-20IB/mthca: Fix timeout for INIT_HCA and a few other commandsJack Morgenstein
Commands INIT_HCA, CLOSE_HCA, SYS_EN, SYS_DIS, and CLOSE_IB all have 1 second timeouts. For INIT_HCA this causes problems when had more than 2^18 are QPs configured, since the command takes more than 1 second to complete. All other commands have 60-second timeouts. This patch makes the above commands consistent with the rest of the commands (and with the chip documentation). This patch is an expansion of a patch from Arthur Kepner <akepner@sgi.com> fixing just the INIT_HCA timeout. Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-20RDMA/cxgb3: Don't zero QP attrs when moving to IDLESteve Wise
QP attributes must stay initialized when moving back to IDLE. Zeroing them will crash the system in _flush_qp() if the QP is subsequently moved to ERROR and back to IDLE. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-20RDMA/nes: Fix bugs in nes_reg_phys_mr()Don Wood
The code incorrectly failed memory registration if the buffer was not page aligned. Also, the length field is mangled causing the hardware to think the registration is much larger than it really is. The fix is to remove the page alignment restriction as well the incorrect length adjustment. Also make sure that all buffers after the first start at a page boundary, and all buffers except the last end on a page boundary. Signed-off-by: Don Wood <donald.e.wood@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-20RDMA/nes: Fix compiler warning at nes_verbs.c:1955Chien Tung
Initialize pbl_count_256 to 0 to get rid of the warning: drivers/infiniband/hw/nes/nes_verbs.c: In function 'nes_reg_mr': drivers/infiniband/hw/nes/nes_verbs.c:1955: warning: 'pbl_count_256' may be used uninitialized in this function Reported-by: Roland Dreier <rdreier@cisco.com> Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-20IPoIB: Disable NAPI while CQ is being drainedYossi Etigin
If NAPI is enabled while IPoIB's CQ is being drained, it creates a race on priv->ibwc between ipoib_poll() and ipoib_drain_cq(), leading to memory corruption. The solution is to enable/disable NAPI in ipoib_ib_dev_{open/stop}() instead of in ipoib_{open/stop}(), and sync NAPI on the INITIALIZED flag instead on the ADMIN_UP flag. This way NAPI will be disabled when ipoib_drain_cq() is called. This fixes <https://bugs.openfabrics.org/show_bug.cgi?id=1587>. Signed-off-by: Yossi Etigin <yosefe@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-20RDMA/cxgb3: Adjust ORD/IRD (if needed) for peer2peer connectionsSteve Wise
NFS/RDMA currently fails to set up connections if peer2peer is on. This is due to the fact that the NFS/RDMA client sets its ORD to 0. If peer2peer is set, make sure the active side ORD is >= 1 and the passive side IRD is >=1. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: RDMA/nes: Add support for new SFP+ PHY RDMA/nes: Add wide_ppm_offset parm for switch compatibility RDMA/nes: Fix SFP+ PHY initialization RDMA/nes: Fix nes_nic_cm_xmit() error handling RDMA/nes: Fix error handling issues RDMA/nes: Fix incorrect casts on 32-bit architectures IPoIB: Document newish features RDMA/cma: Create cm id even when IB port is down RDMA/cma: Use rate from IPoIB broadcast when joining IPoIB multicast groups IPoIB: Avoid free_netdev() BUG when destroying a child interface mlx4_core: Don't leak mailbox for SET_PORT on Ethernet ports RDMA/cxgb3: Release dependent resources only when endpoint memory is freed. RDMA/cxgb3: Handle EEH events IB/mlx4: Use pgprot_writecombine() for BlueFlame pages
2009-04-08Merge branches 'cma', 'cxgb3', 'ipoib', 'mlx4' and 'nes' into for-nextRoland Dreier
2009-04-08RDMA/nes: Add support for new SFP+ PHYChien Tung
Add new register settings for new SFP+ PHY/firmware. Add new PHY to to nes_netdev_get/set_settings. Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-08RDMA/nes: Add wide_ppm_offset parm for switch compatibilityChien Tung
We have observed unstable link with a new BNT switch. Add wide_ppm_offset parameter to allow the user to control the clock ppm offset on the CX4 interface for better compatibility. Default is 100ppm, setting it to 1 will increase it to 300ppm. Change default SerDes1 reference clock to external source. Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-08RDMA/nes: Fix SFP+ PHY initializationChien Tung
SFP+ PHY initialization has very long delays, incorrect settings for direct attach copper cables, and inconsistent link detection. Adjust delays to the minimum required by the PHY. Worst case is now less than 4 seconds. Add new register settings for direct attach cables. Change link detection logic to use two new registers for more consistent link state detection. Reorganize code to shorten line length. Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-08RDMA/nes: Fix nes_nic_cm_xmit() error handlingFaisal Latif
We are getting crash or hung situation when we are running network cable pull tests during RDMA traffic. In schedule_nes_timer(), we return an error if nes_nic_cm_xmit() returns failure. This is changed to success as skb is being put on the timer routines to be processed later. In send_syn() case, we are indicating connect failure once from nes_connect() and the other when the rexmit retries expires. The other issue is skb->users which we are incrementing before calling nes_nic_cm_xmit() which calls dev_queue_xmit() but in case of failure we are decrementing the skb->users at the same time putting the skb on the rexmit path. Even if dev_queue_xmit() fails, the skb->users is decremented already. We are removing the decrement of skb->users in case of failure from both schedule_nes_timer() as well as from nes_cm_timer_tick(). There is also extra check in nes_cm_timer_tick() for rexmit failure which does a break from the loop is removed. This causes problem as the other nodes have their cm_node->ref_count incremented and are not processed. Signed-off-by: Faisal Latif <faisal.latif@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-08RDMA/nes: Fix error handling issuesFaisal Latif
Fix issues found by static code analysis: (1) Check if cm_node was successfully created for loopback connection. (2) schedule_nes_timer() does not free up allocated memory after encountering an error. There is a WARN_ON() for this condition. (3) there is a cm_node->freed flag which is set but not used. Reported-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Faisal Latif <faisal.latif@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-08RDMA/nes: Fix incorrect casts on 32-bit architecturesDon Wood
The were some incorrect casts to unsigned long that caused 64-bit values to be truncated on 32-bit architectures and made the driver pass invalid adresses and lengths to the hardware. The problems were primarily seen with kernels with highmem configured but some could show up in non-highmem kernels, too. Signed-off-by: Don Wood <donald.e.wood@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-08RDMA/cma: Create cm id even when IB port is downYossi Etigin
When doing rdma_resolve_addr(), if the relevant IB port is down, the function fails and the cm_id is not bound to the correct device. Therefore, application does not have a device handle and cannot wait for the port to become active. The function fails because the underlying IPoIB interface is not joined to the broadcast group and therefore the SA does not have a multicast record to take a Q_Key from. The fix is to use lazy Q_Key resolution - cma_set_qkey() will set id_priv->qkey if it was not set, and will be called just before the Q_Key is really required. Signed-off-by: Yossi Etigin <yosefe@voltaire.com> Acked-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07dma-mapping: replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64)Yang Hongyang
Replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01RDMA/cma: Use rate from IPoIB broadcast when joining IPoIB multicast groupsYossi Etigin
When joining an IPoIB multicast group, use the same rate as in the broadcast group. Otherwise, if the RDMA CM creates this group before IPoIB does, it might get a different rate. This will cause IPoIB to fail joining to the same group later on, because IPoIB uses strict rate selection. Signed-off-by: Yossi Etigin <yosefe@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-03-31IPoIB: Avoid free_netdev() BUG when destroying a child interfaceRoland Dreier
We have to release the RTNL before calling free_netdev() so that the device state has a chance to become NETREG_UNREGISTERED. Otherwise when removing a child interface, we hit the BUG() that tests the device state in free_netdev(). Reported-by: Yossi Etigin <yosefe@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-03-30RDMA/cxgb3: Release dependent resources only when endpoint memory is freed.Steve Wise
The cxgb3 l2t entry, hwtid, and dst entry were being released before all the iwch_ep references were released. This can cause a crash in t3_l2t_send_slow() and other places where the l2t entry is used. The fix is to defer releasing these resources until all endpoint references are gone. Details: - move flags field to the iwch_ep_common struct. - add a flag indicating resources are to be released. - release resources at endpoint free time instead of close/abort time. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-03-30RDMA/cxgb3: Handle EEH eventsSteve Wise
- wrap calls into cxgb3 and fail them if we're in the middle of a PCI EEH event. - correctly unwind and release endpoint and other resources when we are in an EEH event. - dispatch IB_EVENT_DEVICE_FATAL event when cxgb3 notifies iw_cxgb3 of a fatal error. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-03-30IB/mlx4: Use pgprot_writecombine() for BlueFlame pagesRoland Dreier
The PAT work on x86 has finally made pgprot_writecombine() a usable API for modular drivers. As the comment indicates, this is exactly what we want to use in mlx4_ib to map BlueFlame pages up to userspace, since using WC for these pages improves small message latency significantly. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-03-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (119 commits) [SCSI] scsi_dh_rdac: Retry for NOT_READY check condition [SCSI] mpt2sas: make global symbols unique [SCSI] sd: Make revalidate less chatty [SCSI] sd: Try READ CAPACITY 16 first for SBC-2 devices [SCSI] sd: Refactor sd_read_capacity() [SCSI] mpt2sas v00.100.11.15 [SCSI] mpt2sas: add MPT2SAS_MINOR(221) to miscdevice.h [SCSI] ch: Add scsi type modalias [SCSI] 3w-9xxx: add power management support [SCSI] bsg: add linux/types.h include to bsg.h [SCSI] cxgb3i: fix function descriptions [SCSI] libiscsi: fix possbile null ptr session command cleanup [SCSI] iscsi class: remove host no argument from session creation callout [SCSI] libiscsi: pass session failure a session struct [SCSI] iscsi lib: remove qdepth param from iscsi host allocation [SCSI] iscsi lib: have lib create work queue for transmitting IO [SCSI] iscsi class: fix lock dep warning on logout [SCSI] libiscsi: don't cap queue depth in iscsi modules [SCSI] iscsi_tcp: replace scsi_debug/tcp_debug logging with iscsi conn logging [SCSI] libiscsi_tcp: replace tcp_debug/scsi_debug logging with session/conn logging ...
2009-03-26RDMA/nes: Fix mis-mergeRoland Dreier
When net-next and infiniband were merged upstream, each branch deleted one of a pair of adjacent lines from nes_nic.c, but when Linus fixed the conflict up, he brought back both of the lines. Fix up to the intended final tree state. Signed-off-by: Roland Dreier <rolandd@cisco.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-26Merge branch 'timers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (26 commits) posix timers: fix RLIMIT_CPU && fork() time: ntp: fix bug in ntp_update_offset() & do_adjtimex(), fix time: ntp: clean up second_overflow() time: ntp: simplify ntp_tick_adj calculations time: ntp: make 64-bit constants more robust time: ntp: refactor do_adjtimex() some more time: ntp: refactor do_adjtimex() time: ntp: fix bug in ntp_update_offset() & do_adjtimex() time: ntp: micro-optimize ntp_update_offset() time: ntp: simplify ntp_update_offset_fll() time: ntp: refactor and clean up ntp_update_offset() time: ntp: refactor up ntp_update_frequency() time: ntp: clean up ntp_update_frequency() time: ntp: simplify the MAX_TICKADJ_SCALED definition time: ntp: simplify the second_overflow() code flow time: ntp: clean up kernel/time/ntp.c x86: hpet: stop HPET_COUNTER when programming periodic mode x86: hpet: provide separate functions to stop and start the counter x86: hpet: print HPET registers during setup (if hpet=verbose is used) time: apply NTP frequency/tick changes immediately ...
2009-03-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1750 commits) ixgbe: Allow Priority Flow Control settings to survive a device reset net: core: remove unneeded include in net/core/utils.c. e1000e: update version number e1000e: fix close interrupt race e1000e: fix loss of multicast packets e1000e: commonize tx cleanup routine to match e1000 & igb netfilter: fix nf_logger name in ebt_ulog. netfilter: fix warning in ebt_ulog init function. netfilter: fix warning about invalid const usage e1000: fix close race with interrupt e1000: cleanup clean_tx_irq routine so that it completely cleans ring e1000: fix tx hang detect logic and address dma mapping issues bridge: bad error handling when adding invalid ether address bonding: select current active slave when enslaving device for mode tlb and alb gianfar: reallocate skb when headroom is not enough for fcb Bump release date to 25Mar2009 and version to 0.22 r6040: Fix second PHY address qeth: fix wait_event_timeout handling qeth: check for completion of a running recovery qeth: unregister MAC addresses during recovery. ... Manually fixed up conflicts in: drivers/infiniband/hw/cxgb3/cxio_hal.h drivers/infiniband/hw/nes/nes_nic.c
2009-03-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (30 commits) RDMA/cxgb3: Enforce required firmware IB/mlx4: Unregister IB device prior to CLOSE PORT command mlx4_core: Add link type autosensing mlx4_core: Don't perform SET_PORT command for Ethernet ports RDMA/nes: Handle MPA Reject message properly RDMA/nes: Improve use of PBLs RDMA/nes: Remove LLTX RDMA/nes: Inform hardware that asynchronous event has been handled RDMA/nes: Fix tmp_addr compilation warning RDMA/nes: Report correct vendor_id and vendor_part_id RDMA/nes: Update copyright to new legal entity and year RDMA/nes: Account for freed PBL after HW operation IB: Remove useless ibdev_is_alive() tests from sysfs code IB/sa_query: Fix AH leak due to update_sm_ah() race IB/mad: Fix ib_post_send_mad() returning 0 with no generate send comp IB/mad: initialize mad_agent_priv before putting on lists IB/mad: Fix null pointer dereference in local_completions() IB/mad: Fix RMPP header RRespTime manipulation IB/iser: Remove hard setting of path MTU mlx4_core: Add device IDs for MT25458 10GigE devices ...
2009-03-26Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: drivers/net/wimax/i2400m/usb-notif.c
