path: root/drivers/infiniband
2008-03-12IPoIB: Allocate priv->tx_ring with vmalloc()Roland Dreier
Commit 7143740d ("IPoIB: Add send gather support") made struct ipoib_tx_buf significantly larger, since the mapping member changed from a single u64 to an array with MAX_SKB_FRAGS + 1 entries. This means that allocating tx_rings with kzalloc() may fail because there is not enough contiguous memory for the new, much bigger size. Fix this regression by allocating the rings with vmalloc() instead. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-03-11IPoIB/cm: Set tx_wr.num_sge in connected mode post_send()Roland Dreier
Commit 7143740d ("IPoIB: Add send gather support") made it possible for tx_wr.num_sge to be != 1 -- this happens if send gather support is enabled. However, the code in the connected mode post_send() function assumes the old invariant, namely that tx_wr.num_sge is always 1. Fix this by explicitly setting tx_wr.num_sge to 1 in the CM post_send(). Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-03-11IPoIB: Don't drop multicast sends when they can be queuedOr Gerlitz
When set_multicast_list() is called the multicast task is restarted and the IPOIB_MCAST_STARTED bit is cleared. As a result for some window of time, multicast packets are not transmitted nor queued but rather dropped by ipoib_mcast_send(). These dropped packets are painful in two cases: - bonding fail-over which both calls set_multicast_list() on the new active slave and sends Gratuitous ARP through that slave. - IP_DROP_MEMBERSHIP code which both calls set_multicast_list() on the device and issues IGMP leave. In both these cases, depending on the scheduling of the IPoIB multicast task, the packets would be dropped. As a result, in the bonding case, the failover would not be detected by the peers until their neighbour is renewed the neighbour (which takes a few tens of seconds). In the IGMP case, the IP router doesn't get an IGMP leave and would only learn on that from further probes on the group (also a delay of at least a few tens of seconds). Fix this by allowing transmission (or queuing) depending on the IPOIB_FLAG_OPER_UP flag instead of the IPOIB_MCAST_STARTED flag. Signed-off-by: Olga Shern <olgas@voltaire.com> Signed-off-by: Or Gerlitz <ogerlitz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-03-11IB/ipath: Reset the retry counter for RDMA_READ_RESPONSE_MIDDLE packetsPatrick Marchand Latifi
Reset the retry counter when we get a good RDMA_READ_RESPONSE_MIDDLE packet. This fix will prevent the requester from reporting a retry exceeded error too early. Signed-off-by: Patrick Marchand Latifi <patrick.latifi@qlogic.com>
2008-03-11IB/ipath: Fix error completion put on send CQ instead of recv CQPatrick Marchand Latifi
A work completion entry could be placed on the wrong completion queue when an RC QP is placed in the error state. Signed-off-by: Patrick Marchand Latifi <patrick.latifi@qlogic.com> Acked-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-03-11IB/ipath: Fix RC QP initializationPatrick Marchand Latifi
This patch fixes the initialization of RC QPs, since we would rely on the queue pair type (ibqp->qp_type) being set, but this field is only initialized when we return from ipath_create_qp (it is initialized by the user-level verbs library). The fix is to not depend on this field to initialize the send and the receive state of the RC QP. Signed-off-by: Patrick Marchand Latifi <patrick.latifi@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-03-11IB/ipath: Fix potentially wrong RNR retry counter returned in ipath_query_qp()Patrick Marchand Latifi
There can be a case where the requester's rnr retry counter (s_rnr_retry) is less than the number of rnr retries allowed per QP (s_rnr_retry_cnt). This can happen if the s_rnr_retry counter is being decremented and an ipath_query_qp call is issued during that time frame. The fix is to always return the number of rnr retries allowed per QP instead of the requester's rnr counter. Found by code review. Signed-off-by: Patrick Marchand Latifi <patrick.latifi@qlogic.com> Acked-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-03-11IB/ipath: Fix IB compliance problems with link state vs physical stateRalph Campbell
Subnet manager SetPortinfo messages distingush between changing the link state (DOWN, ARM, ACTIVE) and the link physical state (POLL, SLEEP, DISABLED). These are somewhat independent commands and affect when link width and speed changes take effect. Without this patch, a link DOWN physical state NOP command was causing the link width and speed settings to take effect which should only happen when the link physical state is goes down (either by a SMP or some link physical error like link errors exceeding the threshold). Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-03-10RDMA/iwcm: Don't access a cm_id after dropping referenceSteve Wise
cm_work_handler() can access cm_id_priv after it drops its reference by calling iwch_deref_id(), which might cause it to be freed. The fix is to look at whether IWCM_F_CALLBACK_DESTROY is set _before_ dropping the reference. Then if it was set, free the cm_id on this thread. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-03-10IB/iser: Handle iser_device allocation error gracefullyArne Redlich
"iser_device" allocation failure is "handled" with a BUG_ON() right before dereferencing the NULL-pointer - fix this! Signed-off-by: Arne Redlich <arne.redlich@xiranet.com> Signed-off-by: Erez Zilber <erezz@voltaire.com>
2008-03-10IB/iser: Fix list iteration bugArne Redlich
The iteration through the list of "iser_device"s during device lookup/creation is broken -- it might result in an infinite loop if more than one HCA is used with iSER. Fix this by using list_for_each_entry() instead of the open-coded flawed list iteration code. Signed-off-by: Arne Redlich <arne.redlich@xiranet.com> Signed-off-by: Erez Zilber <erezz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-03-09RDMA/cxgb3: Fix iwch_create_cq() off-by-one errorJon Mason
The cxbg3 driver is unnecessarily decreasing the number of CQ entries by one when creating a CQ. This will cause the CQ not to have as many entries as requested by the user if the user requests a power of 2 size. Signed-off-by: Jon Mason <jon@opengridcomputing.com> Acked-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-29RDMA/cxgb3: Return correct max_inline_data when creating a QPJon Mason
Set cap.max_inline_data to the actual max inline data that the adapter support, so that userspace apps see the right value returned. Signed-off-by: Jon Mason <jon@opengridcomputing.com> Acked-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-29IB/fmr_pool: Flush all dirty FMRs from ib_fmr_pool_flush()Pete Wyckoff
Commit a3cd7d90 ("IB/fmr_pool: ib_fmr_pool_flush() should flush all dirty FMRs") caused a regression for iSER and was reverted in e5507736. This change attempts to redo the original patch so that all used FMR entries are flushed when ib_flush_fmr_pool() is called without affecting the normal FMR pool cleaning thread. Simply move used entries from the clean list onto the dirty list in ib_flush_fmr_pool() before letting the cleanup thread do its job. Signed-off-by: Pete Wyckoff <pw@osc.edu> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-29Revert "IB/fmr_pool: ib_fmr_pool_flush() should flush all dirty FMRs"Pete Wyckoff
This reverts commit a3cd7d9070be417a21905c997ee32d756d999b38. The original commit breaks iSER reliably, making it complain: iser: iser_reg_page_vec:ib_fmr_pool_map_phys failed: -11 The FMR cleanup thread runs ib_fmr_batch_release() as dirty entries build up. This commit causes clean but used FMR entries also to be purged. During that process, another thread can see that there are no free FMRs and fail, even though there should always have been enough available. Signed-off-by: Pete Wyckoff <pw@osc.edu> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-29IB/cm: Flush workqueue when removing deviceSean Hefty
When a CM MAD is received, it is queued to a CM workqueue for processing. The queued work item references the port and device on which the MAD was received. If that device is removed from the system before the work item can execute, the work item will reference freed memory. To fix this, flush the workqueue after unregistering to receive MAD, and before the device is be freed. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-26RDMA/nes: Fix interrupt moderation low thresholdJohn Lacombe
Interrupt moderation low threshold value was incorrectly triggering, indicating that the threshold should be lowered. The impact was the timer was likely to become 40usecs and get stuck there. The biggest side effect was too many interrupts and nonoptimal performance. Signed-off-by: John Lacombe <jlacombe@neteffect.com> Signed-off-by: Glenn Streiff <gstreiff@neteffect.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-26RDMA/nes: Fix CRC endianness for RDMA connection establishment on big-endianFaisal Latif
With commit ef19454b ("[LIB] crc32c: Keep intermediate crc state in cpu order"), the behavior of crc32c changes on big-endian platforms. Our algorithm expects the previous behavior; otherwise we have RDMA connection establishment failure on big-endian platforms like powerpc. Apply cpu_to_le32() to value returned by crc32c() to get the previous behavior. Signed-off-by: Faisal Latif <flatif@neteffect.com> Signed-off-by: Glenn Streiff <gstreiff@neteffect.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-26RDMA/nes: Fix use-after-free in mini_cm_dec_refcnt_listen()Faisal Latif
Fix use-after-free spotted by Coverity checker flagged by Adrian Bunk. Signed-off-by: Faisal Latif <flatif@neteffect.com> Signed-off-by: Glenn Streiff <gstreiff@neteffect.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-26RDMA/nes: Fix use-after-free in nes_create_cq()Glenn Streiff
Just delete the debugging statement so we don't use cqp_request after freeing it. Adrian Bunk flagged this use-after-free issue spotted by the Coverity checker. Signed-off-by: Glenn Streiff <gstreiff@neteffect.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-26RDMA/nes: Fix a check-after-use in nes_probe()Adrian Bunk
Fix a check-after-use spotted by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Glenn Streiff <gstreiff@neteffect.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-26RDMA/nes: Fix a memory leak in schedule_nes_timer()Adrian Bunk
Fix a memory leak spotted by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Glenn Streiff <gstreiff@neteffect.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-25RDMA/nes: Fix off-by-oneAdrian Bunk
Fix an off-by-one spotted by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Glenn Streiff <gstreiff@neteffect.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-25RDMA/nes: Resurrect error path dead codeChien Tung
Adrian Bunk pointed out that a Coverity scan found some apparently dead code in nes_verbs.c that really shouldn't have been dead. The function nes_create_cq() was missing the assignment err = 1; just prior to an iteration that conditionally set err = 0 if a PBL was found for a given virtual CQ. I also noticed we should have been returning -EFAULT on a couple related error paths. Signed-off-by: Chien Tung <ctung@neteffect.com> Signed-off-by: Glenn Streiff <gstreiff@neteffect.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-25RDMA/cxgb3: Fix shift calc in build_phys_page_list() for 1-entry page listsBryan Rosenburg
A single entry (addr 0x10001000, size 0x2000) will get converted to page address 0x10000000 with a page size of 0x4000. The code as it stands doesn't address the single buffer case, but in fact it allows the subsequent single-buffer special case to be eliminated entirely. Because the mask now includes the (page adjusted) starting and ending addresses, the general case works for the single buffer case as well. Signed-off-by: Bryan Rosenburg <rosnbrg@us.ibm.com> Acked-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-19IB/mthca: Free correct MPT on error exit from mthca_fmr_alloc()Roland Dreier
When mthca_fmr_alloc() returns an error, it should free the MPT at the index key, not mr->ibmr.lkey, since the lkey has been mangled by hw_index_to_key() and no longer is the real index. This bug causes corruption of the MPT table free bitmap when mthca_fmr_alloc() fails. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-19IPoIB/cm: Fix ipoib_cm_dev_stop() cleanup when drain times outPradeep Satyanarayana
Commit efcd9971 ("IPoIB/cm: Factor out ipoib_cm_free_rx_reap_list()") introduced a bug in ipoib_cm_dev_stop() when the receive drain times out. In that case, the function moves all the pending rx stuff into a private list but then calls ipoib_cm_free_rx_reap_list(), which handles a different list. Fix this by moving everything to the rx_reap_list that will actually get freed up. This fixes <https://bugs.openfabrics.org/show_bug.cgi?id=906>. Signed-off-by: Pradeep Satyanarayana <pradeeps@linux.vnet.ibm.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-18RDMA/nes: Fix possible array overrunRoland Dreier
In nes_create_qp(), the test if (nesqp->mmap_sq_db_index > NES_MAX_USER_WQ_REGIONS) { is used to error out if the db_index is too large; however, if the test doesn't trigger, then the index is used as nes_ucontext->mmap_nesqp[nesqp->mmap_sq_db_index] = nesqp; and mmap_nesqp is declared as struct nes_qp *mmap_nesqp[NES_MAX_USER_WQ_REGIONS]; which leads to an array overrun if the index is exactly equal to NES_MAX_USER_WQ_REGIONS. Fix this by bailing out if the index is greater than or equal to NES_MAX_USER_WQ_REGIONS. This was spotted by the Coverity checker (CID 2162). Acked-by: Glenn Streiff <gstreiff@neteffect.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-16RDMA/nes: Fix VLAN supportChien Tung
We need to account for the VLAN header size in nes_netdev_change_mtu() and nes_netdev_init(). Also, add spin lock/unlock during VLAN RX registration so only one process can assign VLAN group for a given interface at a time. Signed-off-by: Chien Tung <ctung@neteffect.com> Signed-off-by: Glenn Streiff <gstreiff@neteffect.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-15RDMA/nes: Fix MAC interrupt erroneously masked on ifdownGlenn Streiff
Only mask out MAC interrupt if necessary and re-enable on ifup. There could be multiple netdevs going through the same MAC. MAC interrupts should not be masked off until the last netdev is downed. Signed-off-by: Chien Tung <ctung@neteffect.com> Signed-off-by: Glenn Streiff <gstreiff@neteffect.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-15IB: Fix return value in ib_device_register_sysfs()Li Zefan
If kobject_create_and_add() fails and returns NULL, the current code in ib_device_register_sysfs() does not set ret and hence returns 0. Set ret to -ENOMEM for this failure, so that the caller knows that ib_device_register_sysfs() actually failed. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-14RDMA/cma: Do not issue MRA if user rejects connection requestSean Hefty
There's an undesirable interaction with issuing MRA requests to increase connection timeouts and the listen backlog. When the rdma_cm receives a connection request, it queues an MRA with the ib_cm. (The ib_cm will send an MRA if it receives a duplicate REQ.) The rdma_cm will then create a new rdma_cm_id and give that to the user, which in this case is the rdma_user_cm. If the listen backlog maintained in the rdma_user_cm is full, it destroys the rdma_cm_id, which in turns destroys the ib_cm_id. The ib_cm_id generates a REJ because the state of the ib_cm_id has changed to MRA sent, versus REQ received. When the backlog is full, we just want to drop the REQ so that it is retried later. Fix this by deferring queuing the MRA until after the user of the rdma_cm has examined the connection request. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-14IB/mlx4: mlx4_ib_fmr_alloc() should call mlx4_fmr_enable()Jack Morgenstein
Currently mlx4_ib_fmr_alloc() calls mlx4_mr_enable() instead of mlx4_fmr_enable(). The two functions are equivalent at the moment, but this is not really correct (and the change is needed to fix a bug). Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-14IPoIB: Remove unused struct ipoib_cm_tx.ibwc memberEli Cohen
struct ipoib_cm_tx.ibwc is unused since commit 1b524963 ("IPoIB/cm: Use common CQ for CM send completions"), so remove it. Signed-off-by: Eli Cohen <eli@mellanox.co.il>
2008-02-14IPoIB: On P_Key change event, reset state properlyJack Morgenstein
In P_Key event handling, if the old P_Key is no longer available, the driver must call ipoib_ib_dev_stop() -- just as it does when the P_Key is still available (see procedure __ipoib_ib_dev_flush()). When a P_Key becomes available, the driver will perform ipoib_open(), which assumes that the QP is in RESET, the cm_id has been destroyed/deleted, etc. If ipoib_ib_dev_stop() is not called as described above, then these assumptions will be false, and the attempt to bring the interface up will fail. Found by Mellanox QA. Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-13IB/mthca: Convert to use be16_add_cpu()Marcin Slusarz
replace: big_endian_variable = cpu_to_beX(beX_to_cpu(big_endian_variable) + expression_in_cpu_byteorder); with: beX_add_cpu(&big_endian_variable, expression_in_cpu_byteorder); Generated with a semantic patch. Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Hal Rosenstock <hal.rosenstock@gmail.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-13RDMA/cxgb3: Fail loopback connectionsSteve Wise
The cxgb3 HW and driver don't support loopback RDMA connections. So fail any connection attempt where the destination address is local. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-12IB/cm: Fix infiniband_cm class kobject ref countingRoland Dreier
Commit 9af57b7a ("IB/cm: Add basic performance counters") introduced a bug in how the reference count for cm_class.subsys.kobj was handled: the path that released a device did a kobject_put() on that kobject, but there was no kobject_get() in the path the handles adding a device. So the reference count ended up too low, which leads to bad things. Fix up and simplify the reference counting to avoid this. (Actually, I introduced the bug when fixing the patch up to match some of Greg's kobject changes, but who's counting) Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-12IB/cm: Remove debug printk()s that snuck upstreamRoland Dreier
Pesky little devils, sneaking around... Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-12IB/mthca: Add missing sg_init_table() in mthca_map_user_db()Roland Dreier
Usually harmless, since the scatterlist is always hard-coded to a length of 1, but it triggers a BUG() if CONFIG_DEBUG_SG=y, so we better fix it. This fixes <http://bugzilla.kernel.org/show_bug.cgi?id=9934>. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-08IPoIB: Add send gather supportEli Cohen
This patch acts as a preparation for using checksum offload for IB devices capable of inserting/verifying checksum in IP packets. The patch does not actaully turn on NETIF_F_SG - we defer that to the patches adding checksum offload capabilities. We only add support for send gathers for datagram mode, since existing HW does not support checksum offload on connected QPs. Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Signed-off-by: Eli Cohen <eli@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-08IPoIB: Add high DMA feature flagEli Cohen
All current InfiniBand devices can handle all DMA addresses, and it's hard to imagine anyone would be silly enough to build a new device that couldn't. Therefore, enable the NETIF_F_HIGHDMA feature for IPoIB. This has no effect for no, but is needed when we enable gather/scatter support and checksum stateless offloads. Signed-off-by: Eli Cohen <eli@mellnaox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-08IB/mlx4: Use multiple WQ blocks to post smaller send WQEsJack Morgenstein
ConnectX HCA supports shrinking WQEs, so that a single work request can be made of multiple units of wqe_shift. This way, WRs can differ in size, and do not have to be a power of 2 in size, saving memory and speeding up send WR posting. Unfortunately, if we do this then the wqe_index field in CQEs can't be used to look up the WR ID anymore, so our implementation does this only if selective signaling is off. Further, on 32-bit platforms, we can't use vmap() to make the QP buffer virtually contigious. Thus we have to use constant-sized WRs to make sure a WR is always fully within a single page-sized chunk. Finally, we use WRs with the NOP opcode to avoid wrapping around the queue buffer in the middle of posting a WR, and we set the NoErrorCompletion bit to avoid getting completions with error for NOP WRs. However, NEC is only supported starting with firmware 2.2.232, so we use constant-sized WRs for older firmware. And, since MLX QPs only support SEND, we use constant-sized WRs in this case. When stamping during NOP posting, do stamping following setting of the NOP WQE valid bit. Signed-off-by: Michael S. Tsirkin <mst@dev.mellanox.co.il> Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-06IB/mlx4: Consolidate code to get an entry from a struct mlx4_bufRoland Dreier
We use struct mlx4_buf for kernel QP, CQ and SRQ buffers, and the code to look up an entry is duplicated in get_cqe_from_buf() and the QP and SRQ versions of get_wqe(). Factor this out into mlx4_buf_offset(). This will also make it easier to switch over to using vmap() for buffers. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-04RDMA/nes: Add a driver for NetEffect RNICsGlenn Streiff
Add a standard NIC and RDMA/iWARP driver for NetEffect 1/10Gb ethernet adapters. Signed-off-by: Glenn Streiff <gstreiff@neteffect.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-04IB/mthca: Return proper error codes from mthca_fmr_alloc()Olaf Kirch
If the allocation of the MTT or the mailbox failed, mthca_fmr_alloc() would return 0 (success) no matter what. This leads to crashes a little down the road, when we try to dereference eg mr->mtt, which was really ERR_PTR(-Ewhatever). Signed-off-by: Olaf Kirch <olaf.kirch@oracle.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-04IB: Avoid marking __devinitdata as constRoland Dreier
2008-02-04IB/mlx4: Actually print out the driver versionRoland Dreier
The string mlx4_ib_version was defined, but never used. Print out the version once when the first device is initialized. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-04IB/ib_mthca: Pre-link receive WQEs in Tavor modeEli Cohen
We have recently discovered that Tavor mode requires each WQE in a posted list of receive WQEs to have a valid NDA field at all times. This requirement holds true for regular QPs as well as for SRQs. This patch prelinks the receive queue in a regular QP and keeps the free list in SRQ always properly linked. Signed-off-by: Eli Cohen <eli@mellanox.co.il> Reviewed-by: Jack Morgenstein <jackm@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-04IB/mthca: Remove checks for srq->first_free < 0Eli Cohen
The SRQ receive posting functions make sure that srq->first_free never becomes negative, so we can remove tests of whether it is negative. Signed-off-by: Eli Cohen <eli@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
